Results 1 to 6 of 6
Thread: Controller refused the key! Error 78: Unknown (0x78)???
    Dec 2017
    Before I start tearing the kessy apart again I wanted to ask if this code was legitimately due to incorrect PIN or another error. I purchased a 2005 A8L W12 a couple of weeks ago that has been sitting for 3yrs due to minor frontend damage (hit a coyote) and I want to use the motor in another project but I'd like to get it up and running before tearing the car apart. The guy lost the keys so I purchased some 3rd party software, removed the 93c86 chip from the kessy, read the pin using the software (53754) and programmed a new PCF7936 transponder chip. I put everything back together, installed in the car and tried logging in through "security access" but I get the "Controller refused the key!" error. My lock out timers are all at zero in measuring block 24 even after failed login. I'm just wondering if I screwed something up possibly on the kessy module when I reflowed the chip. everything looks good though. I'm trying to avoid a dealer visit just to get the car running so I can tear it apart and I'm not sure if they'll do anything to the car with the shape it is in and I haven't transferred the title to my name (notarized and signed over to me) mainly because it was going to scrap after I stripped it down and sold off any good bits.
    Võru, Estonia
    Are you sure you can add keys to this kessy via adaption and not only via eeprom?
    Anyhow, where's autoscan.
    The world is my oyster...
  3. Likes Uwe liked this post
    Dec 2017
    Sunday,10,December,2017,10:28:32:38883
    VCDS Version: 17.8.0.1
    Dealer/Shop Name: DG
    VIN: WAUMR44E95N014152   License Plate:
    Chassis Type: 4E (4E0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 25 28 34 36
              37 38 42 46 47 4F 52 53 55 56 61 62 65 66 67 69 72 76 77
    VIN: WAUMR44E95N014152   Mileage: 155700km-96747miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    0F-Digital Radio -- Status: Cannot be reached 1100
    11-Engine II -- Status: Cannot be reached 1100
    31-Engine other -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    34-Level Control -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Malfunction 1010
    66-Seat, Rear -- Status: Malfunction 0010
    67-Voice Control -- Status: Cannot be reached 1100
    69-Trailer -- Status: Cannot be reached 1100
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 909 131 D
       Component:     FBS AUDID3  H04 0140
       Revision: 01404004    Serial number: AUX3Z0E0757779
       Coding: 0410624
       Shop #: WSC 02311 785 00200
       VCID: 58BFFFBFEB84888692-800C
       Subsystem 1 - Part No: 4E0 905 852 D
       Component: ELV                 1834
    12 Faults Found:
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Fault Frequency: 14
                        Reset counter: 163
                        Mileage: 154400 km
                        Date: 2004.07.21
                        Time: 12:56:52
                        Reset counter: 179
                        Mileage: 154416 km
                        Date: 2004.03.25
                        Time: 00:00:14
                        Fault Frequency: 0
                        Reset counter: 180
                        Mileage: 154432 km
                        Date: 2004.03.25
                        Time: 04:57:36
                        Fault Frequency: 14
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 05:17:48
    01176 - Key
                        Fault Frequency: 14
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:02:00
    00576 - Terminal 15
                        Fault Status: 00100110
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:06:48
    00166 - Access/Start Authorization Switch (E415)
                        Fault Status: 00101010
                        Fault Frequency: 14
                        Reset counter: 204
    00179 - Access/Start Authorization Antenna; Drivers Side (R134)
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
    00180 - Access/Start Authorization Antenna; Passenger Side (R135)
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
    00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
    00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
    00183 - Interior Access/Start Authorization Antenna 1 (R138)
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
       Part No SW: 4E0 910 760 C    HW: 4E0 959 760
       Component: Sitzmemory BFS H08  0060
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 3940576
       Shop #: WSC 00000 785 00200
       VCID: 23459853E2421B5EB7-8076
                        Fault Status: 00100001
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2013.05.05
                        Time: 00:00:02
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2013.05.05
                        Time: 00:00:02
    Address 07: Control Head
       Part No SW: 4E0 910 043 A    HW: 4E0 820 043 B
       Component: KLIMAAUTOMAT    016 0340
       Revision: 00000029    Serial number: 00000000060495
       Coding: 1126737
       VCID: 1B35A0B3DA32239E7F-804E
    6 Faults Found:
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 164
                        Mileage: 123115 km
                        Date: 2011.12.02
                        Time: 15:55:29
                        Voltage: 11.20 V
    00065 - Rear Left Footwell Heater (Z42)
                        Fault Frequency: 165
                        Reset counter: 164
                        Mileage: 150861 km
                        Date: 2012.08.22
                        Time: 12:59:28
                        Voltage: 9.20 V
    00532 - Supply Voltage B+
                        Reset counter: 175
                        Mileage: 154420 km
                        Date: 2004.10.04
                        Time: 13:02:30
                        Voltage: 8.30 V
    00003 - Control Module
                        Fault Status: 00100011
                        Fault Frequency: 21
                        Reset counter: 197
                        Mileage: 154420 km
                        Date: 2004.04.06
                        Time: 20:21:56
                        Temperature: 50.0°C
                        Fault Frequency: 16
                        Reset counter: 203
                        Mileage: 153667 km
                        Date: 2012.10.21
                        Time: 22:51:45
                014 - Defective
                        Fault Frequency: 16
                        Reset counter: 203
                        Mileage: 153667 km
                        Date: 2012.10.21
                        Time: 22:51:45
    Address 09: Cent. Elect.
    Address 0E: Media Player 1
    Address 0F: Digital Radio
    Address 11: Engine II
    Address 15: Airbags
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549
       Coding: 0012141
       VCID: 65C1C64BACF6256E19-8030
       Component: Lenkradmodul    H05 0080
    8 Faults Found:
    00447 - Function Limitation due to Over-Voltage
                        Fault Frequency: 30
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.03.25
                        Time: 00:13:19
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.03.25
                        Time: 00:18:37
                        Fault Frequency: 15
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.05.03
                        Time: 21:33:05
                        Fault Frequency: 11
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.05.03
                        Time: 21:35:00
                        Reset counter: 204
                        Fault Status: 00101110
                        Fault Frequency: 14
                        Reset counter: 204
                        Date: 2063.15.31
                        Time: 31:63:02
                        Reset counter: 204
                        Reset counter: 204
                        Mileage: 155698 km
                        Date: 2004.03.25
                        Time: 00:00:40
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 950 L    HW: 4E0 920 950 L
       Component: KOMBIINSTR. VDO H53 0210
       Revision: D05         Serial number: AUDID3E0000215
       Coding: 0016233
       Shop #: WSC 42512 444 12218
       VCID: 2D517E6BB486DD2E11-8078
    16346 - Control Module - ROM Error
                014 - Defective
                        Fault Status: 00000011
                        Mileage: 145902 km
                        Date: 2012.06.08
                        Time: 18:36:48
                        Fault Frequency: 7
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.10.04
                        Time: 13:00:21
                        Reset counter: 177
                        Mileage: 154420 km
    Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
       Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
       Component: Gateway         H07 0040
       Revision: 07          Serial number: 050050510327AB
       Coding: FDFEFFFD1B7904
       Shop #: WSC 02313 785 00200
       VCID: 264381479170EE76D0-8072
    6 Faults Found:
    00384 - Optical Databus
                        Reset counter: 164
                        Mileage: 154400 km
                        Date: 2004.07.03
                        Time: 00:02:07
    01517 - Control Module for Trailer/Towing Sensor (J345)
                        Reset counter: 164
                        Mileage: 154413 km
                        Date: 2004.08.15
                        Time: 08:46:17
                        Reset counter: 180
                        Mileage: 154442 km
                        Date: 2004.03.25
                        Time: 04:57:34
                        Reset counter: 204
                        Mileage: 155691 km
                        Date: 2004.05.20
                        Time: 21:10:07
                        Reset counter: 204
                        Mileage: 155700 km
                        Date: 2004.03.25
                        Time: 00:06:50
    01312 - Powertrain Data Bus
                        Reset counter: 204
                        Mileage: 155700 km
                        Date: 2004.03.25
                        Time: 00:07:40
    Address 25: Immobilizer        Labels: 4E0-910-131.lbl
       Coding: 0410624
       Component: ELV                 1834
       4E0905852D  ELV                 1834
    12 Faults Found:
    00956 - Key 2
                        Fault Frequency: 14
                        Reset counter: 163
                        Mileage: 154400 km
                        Date: 2004.07.21
                        Time: 12:56:52
                        Reset counter: 179
                        Mileage: 154416 km
                        Date: 2004.03.25
                        Time: 00:00:14
                        Fault Frequency: 0
                        Reset counter: 180
                        Mileage: 154432 km
                        Date: 2004.03.25
                        Time: 04:57:36
                        Fault Frequency: 14
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 05:17:48
    01176 - Key
                        Fault Frequency: 14
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:02:00
    00576 - Terminal 15
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:06:48
                        Fault Frequency: 14
                        Reset counter: 204
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
                        Fault Frequency: 0
                        Reset counter: 164
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:03:08
       Part No SW: 4E0 910 158     HW: 4E0 919 158 A
       Component: KLIMA-STG. FOND 015 0210
       Revision: 00000017    Serial number: 00000000024205
       Coding: 0000000
       VCID: 61C9D25BB8DE494EE5-8034
    01863 - Air Outlet Motor; Rear Left (V218)
    01864 - Air Outlet Motor; Rear Right (V219)
    Address 34: Level Control
       Component: Sitzmemory FS  H08  0060
       Coding: 4071658
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2013.05.05
                        Time: 00:00:02
    Address 37: Navigation
    Address 38: Roof Electronics
    Address 46: Central Conv.
    Address 47: Sound System
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
       Component: ILM Beifahrer   H09 0040
       Revision:             Serial number: 00000000054164
       Coding: 0010111
       VCID: 1E33A9A7C92036B698-804A
                        Fault Status: 00110010
                        Fault Frequency: 11
                        Reset counter: 204
                        Mileage: 155688 km
                        Date: 2004.05.20
                        Time: 21:10:00
                        Fault Status: 01110100
                        Fault Frequency: 27
                        Reset counter: 164
                        Mileage: 154420 km
                        Date: 2023.06.06
                        Time: 00:00:00
                        Fault Frequency: 42
                        Reset counter: 204
                        Mileage: 155688 km
                        Date: 2004.05.20
                        Time: 20:07:00
                        Reset counter: 204
                        Date: 2023.06.06
                        Time: 00:00:00
    02258 - Door Opener Transmitter
                        Reset counter: 164
                        Mileage: 153664 km
                        Date: 2012.10.21
                        Time: 22:51:00
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
       Component: Türsteuer.BF BRM002 0060
       Coding: 0032492
       VCID: 204F975FF3540046AA-8074
    01308 - Control Module for Roof Electronics (J528)
                        Fault Frequency: 0
                        Reset counter: 204
                        Fault Frequency: 0
                        Reset counter: 204
    02111 - Motor for Window Regulator
                        Fault Frequency: 0
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.26
                        Time: 11:03:22
                        Fault Frequency: 0
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.26
                        Time: 11:03:22
    Address 53: Parking Brake
    Address 55: Headlight Range
    Address 56: Radio
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0510
       Revision: 00000000    Serial number: 00000000000395
       Shop #: WSC 03109 444 85666
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  2505170228
       Coding: 344530393135313035412056413032353035313730323238
                000 -  -  - Intermittent
                        Fault Frequency: 39
                        Mileage: 151466 km
                        Date: 2012.10.14
                        Time: 17:02:07
                        Fault Status: 00110100
                        Reset counter: 167
                        Mileage: 154368 km
                        Date: 2004.03.31
                        Time: 17:18:25
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 33
                        Mileage: 154400 km
                        Date: 2004.04.12
                        Time: 10:10:41
    02255 - Voltage Measuring Lead from Vbat
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 164
                        Date: 2004.03.26
                        Time: 02:14:27
                        Fault Status: 00110001
                        Reset counter: 177
                        Mileage: 154420 km
                        Date: 2004.03.25
                        Time: 00:29:20
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
       Component: Türsteuer.HL BRM002 0060
       Coding: 0032492
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 21:05:58
                        Reset counter: 204
    Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
       Part No SW: 4E0 910 273     HW: 4E0 907 273
       Component: Reifendruck 2   H01
       Revision: 00010028    Serial number: 00000900030361
       Coding: 0212428
       VCID: 5FCDD4A38EAA7FBED3-800A
                        Fault Status: 10100010
                        Fault Frequency: 22
                        Reset counter: 204
                        Mileage: 154420 km
                        Date: 2004.05.03
                        Time: 21:47:24
                        Speed: 255.0 km/h
                        Voltage: 6.80 V
                        (no units): 42.0
                        Temperature: 0.0°C
                        Temperature: 0.0°C
                        Temperature: 0.0°C
                        Temperature: 0.0°C
                        Fault Frequency: 24
                        Reset counter: 170
                        Mileage: 147921 km
                        Date: 2012.06.16
                        Time: 04:31:01
                        Speed: 10.0 km/h
                        Temperature: 21.0°C
                        Error Code: 0
                        Pressure: 3.57 bar
                        Pressure: 2.70 bar
                        Pressure: 3.15 bar
                        Pressure: 2.40 bar
    02214 - Tire Pressure Warning
                        Fault Frequency: 253
                        Reset counter: 0
                        Temperature: 40.0°C
                        Error Code: 1792
                        Pressure: 0.00 bar
                        Pressure: 0.00 bar
                        Pressure: 0.00 bar
                        Pressure: 0.00 bar
    Address 66: Seat, Rear        Labels: None
       Part No SW: 4E0 910 860     HW: 4E0 959 860
       Component: Sitz Fond      H06  0050
       Revision: 00000000    Serial number: 5DS 008 795-01
       Coding: 0000510
                        Reset counter: 204
                        Mileage: 155696 km
                        Date: 2004.03.25
                        Time: 00:00:02
    Address 67: Voice Control
    Address 69: Trailer
    Address 72: Door, Rear Right
    Address 76: Park Assist
    Address 77: Telephone
    End-------------------------(Elapsed Time: 04:44)--------------------------
    Quote Originally Posted by dgauthreaux View Post
    They told me I could remove the chip, read the eeprom, create the transponder and then I had to use VCDS to adapt the keys to the kessy.
    Who are "they"?
    Dec 2017
    didn't know if we can speak of other software.....TMPRO2
    Dec 2017
    problem solved!!! I thought that I re-wrote to the eeprom after programming the transponder but I didn't.. dumbass mistake on my part. took the chip out this morning and read the dump, compared to the original dump and nothing was different. wrote the new file to the eeprom and adapted keys. need to work on this stuff after my morning coffee. car is running now and purrs like a kitten. best $1000.00 i ever spent. it's a shame I'm going to tear it apart.
  8. Likes Uwe liked this post
