Electric key trunk closing on SQ5 8R 2016
POPOV
Sweden
C?ID=5982
I can open my trunk with my key but I cannot close it on my SQ5 8R 2016.
Coding option isn't enabled in the Trunk Elect. 6D module. No security access code tip given by VCDS and 12345 doesn't work.
Any advises, has someone managed to code the key closing too?
Below is a auto-scan of my car
Saturday,23,December,2017,12:25:26:02978
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4401.4
VIN: WAUZZZ8R5GA108264   License Plate:
Mileage: 14570km-9053mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 20 22 36 42 44 46 47 52 53
          56 5F 62 69 6D 72 A9 AC C0
VIN: WAUZZZ8R5GA108264   Mileage: 14570km-9053miles
Address 01: Engine (J623-DEHA)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  X23 0004
   Revision: 54X23---
   Coding: 2A2A403A253603030000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589C 001006
   ROD: EV_ECM30BTD0118K5907589C.rod
   VCID: 41CA9ED9D082684EDE-8014
   Part No SW: 8R0 927 158 BC    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRDW H19 1003
   Revision: --H19---
   Coding: 000001
   VCID: 7F4ED821E6F6DEBEE8-802A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Component: ESP8 quattro  H09 0020
   Coding: 38DDCE01
   Shop #: WSC 06192 000 00000
   VCID: 05424AC98C2A846EA2-8050
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05A54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 004C5BDD9308A14691-8054
   Serial number: 3216000012820011
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Component: KLIMA 3 ZONEN H04 0122
   Revision: C1000000    Serial number: 01110220161238
   Coding: 3629008080
   VCID: 77BE3001C6C6E6FEA0-8022
   Revision: 08016001    Serial number: 00001279072201
   Coding: 2600C0108074AFE0218140C300001D0D0F9CE70826090201000008004400030100000024000000
   VCID: 78BC333DCBD8E986A9-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160202  H13 0050
   Serial number: 90243014160127012000
   Coding: 01DD13
   Serial number: 61338954
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000402160556
   Serial number: 3E394D08000000000001
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD1KGBZ
   Coding: 30483531313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48DC83FDF3B8590619-801C
   Serial number: 6334MSME564B5663J
   Serial number: 6344MSME5669046FP
   Serial number: 6352QSME2F512E6E-
   Serial number: 6362QSME1B76406CP
   Serial number: 63732SME52744748/
   Serial number: 63832SME5E5024782
   Revision: --------    Serial number: 90372PB500032
   Coding: 000037
   VCID: 44C497CDC7907D66F5-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 F    HW: 8R0 920 931 F
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03E35232H
   Coding: 13AF2200830100080B0000
   Shop #: WSC 06335 123 12345
   VCID: 383CF33D8B58298669-806C
Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
   Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
   Component: Standheizung  H26 0270
   Revision: 77007007    Serial number: 20160121080110
   Coding: 5D4401
   VCID: 291A267940F2800EE6-807C
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z161290213
   Coding: 80CD07FF00
   VCID: 7EB02525E9FCD7B6E3-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 0020409103
   Serial number: 16039001157011200410
   Revision: AA001002
   Coding: 02012064747464545425363E00
   VCID: 7CB42F2DFFE0C5A6CD-8028
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000202160001010
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
   VCID: 2F2EC8617616EE3E38-807A
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000182937585
   Coding: 01581B00000000000000
   VCID: 42C891D5DD847356C7-8016
   Revision:             Serial number: 0000185157656
   Coding: 011D12215E00440004
   VCID: 4FEEA8E11ED68E3E58-801A
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000001    Serial number: 0000631401
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46C08DC5F9AC4F76EB-8012
   Revision: 00002001    Serial number: 0394156040
   Coding: 013A0E20A0A930958720053680040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813055448807
   VCID: 2D12D269741A9C2E0A-8078
   Revision:             Serial number: 0000185970267
   VCID: 4ED0B5E519DC873653-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 00000001773076
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3A38E935BD543B969F-806E
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227BX0G2507167
   Coding: 010003010000000001
   VCID: 26002D4551ECAF76CB-8072
   Part No SW: 8R1 035 670 L    HW: 8R1 035 670 J
   Component: H-BNT-EU      H50 0946
   Revision: --------    Serial number: 516BK0GS009596
   Coding: 1A0100060205A3ED4580AB5E00000403040000000000000000
   VCID: 3C34EF2DBF6005A68D-8068
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H42 0104
   Serial number: A130BW0G3528826
   Serial number: 00000002465488
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000186013259
   Coding: 010C12204000240004
   VCID: 46C08DC5F1AC4F76EB-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: Anhaenger     H12 0100
   Revision: 1G001001    Serial number: 00000394097136
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 3522FA099C4AD4EE72-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D32E229A47A0CAEBA-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000186011314
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 160116201301
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
   VCID: 79BA3639F8D2F08ED6-802C
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160250920
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 160123200709
   ROD: EV_ActuaForExterNoiseUDS_VW12.rod
   VCID: 3228C1156524C3D657-8066
End----------(Elapsed Time: 02:11, VBatt start/end: 12.1V/12.1V)-----------
Surrey Sam
C?ID=181917
I have a B8 RS4 (8k) and couldn't find a way to do this via coding. So instead I purchased a Bexpro CTM1 module and wired that into the car. It works well and I can now close the tailgate via the key fob and drivers door switch.
POPOV
Sweden
C?ID=5982
Thanks for the tip, I've seen another similar solution on youtube. It's possible to do the vcds coding on pre-fl A6's (same platform as the Q5) but then something changed and nobody seems to have succeeded.
AndySwede
Stockholm Sweden
C?ID=172802
Well this is odd. I know that Skoda Superb, Octavia and Passat B8 are another platform but I have successfully coded the remote closing on fob and interior switch.
They were all MY 2016 and I don´t see why the 6D module should be different in a Q5.
Have you looked at all possible channels?
POPOV
Sweden
C?ID=5982
I've done the same coding on my Octavia RS mk3 and worked without issues.
The channels are not identified so I'll be doing it blindfolded, if even possible to change without the security access code set.
Hej från Sverige!
AndySwede
Stockholm Sweden
C?ID=172802
Hej hej,
Where in Sweden are you located?
POPOV
Sweden
C?ID=5982
I'm in Skåne-land =)
Dukedesmo
C?ID=288946
