Internal Control Module Memori check Audi A4
caliche1275
Columbia
C?ID=160533
Hi, I have to change the module estering?
Wednesday,20,December,2017,17:00:09:49232
VCDS Version: 17.8.1.0 (x64)
VIN: WAUZZZ8K6DA094146   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K6DA094146   Mileage: 55590km-34542miles
Address 01: Engine (B8-PA-CDHA)       Labels:. 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
   Component: 1.8l R4/4V TF H04 0003
   Revision: PBH04---
   Coding: 0A191013040400002000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM18TFS0118K1907115N 001005
   ROD: EV_ECM18TFS011.rod
   VCID: 39790C7FB899C28E96-806C
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 011540
   Shop #: WSC 06325 000 00000
   VCID: 000FA19B93C3534691-8054
   Part No SW: 8K0 907 064 GQ    HW: 8K0 907 064 FQ
   Component: BCM2 2.0      H11 0621
   Coding: 03814000000000000000
   VCID: 0501B08F8CE1766EA2-8050
   Subsystem 1 - Part No SW: 8K0 959 754 E    HW: 8K0 959 754 E
   Serial number: 0512000036281002
   Serial number: 2312000135349015
   Part No SW: 8K1 820 043 Q    HW: 8K1 820 043 Q
   Component: KLIMA 1 ZONE  H02 0121
   Revision: A0000000    Serial number: 01180620121997
   Coding: 640022C000
   VCID: 3663074381872DF67B-8062
03220 - Stop Valve for Coolant for Climatronic (N422)
                    Fault Status: 00100110
                    Reset counter: 52
                    Mileage: 55596 km
                    Date: 2017.12.20
                    Time: 15:26:07
                    Voltage: 14.30 V
                    Voltage: 14.20 V
                    Voltage: 14.20 V
                    Voltage: 14.30 V
                    Bin. Bits: 00000000
                    Time: 240.00 s
                    Count: 65534
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000441582502
   Coding: 2600C0108034AFC00081400000001D0D0F1C030802010201000004000400020100000020000000
   VCID: 77FDCA47C60D14FEA0-8022
   Component: WWS 270612  H07 0080
   Serial number: SWF12060276671
   Coding: 00FD11
   Serial number: 20367004
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001906123449
   Serial number: 7A688536000000000001
   Serial number: 003KFD93X0FP
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 42883 001 1048576
   VCID: 489F79BBF373AB0619-801C
   Serial number: 6334MSME6E4412048
   Serial number: 6344MSME6E35541DP
   Serial number: 6352QSME2B1B087AR
   Serial number: 6362QSME5C1A1A68V
   Serial number: 63732SME241C1142Q
   Serial number: 63832SME241C1076X
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120702000038
   Coding: 000012
   VCID: 4FAD52A71E1D7C3E58-801A
   Part No SW: 8K0 920 901 C    HW: 8K0 920 901 C
   Component: KOMBIINSTR.   H09 0553
   Revision: 00200000    Serial number: RB623GG6D
   Coding: 1384080002010008050000
   VCID: 2B5526374AC5601E14-807E
   Part No SW: 8R0 907 468 F    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0051
   Revision: 1V060024    Serial number: 2441V126068027
   Coding: 80C303FF00
   VCID: 428B6B93DD4F8156C7-8016
   Serial number: 7765457701
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020202
   VCID: 39790C7FB099C28E96-806C
   Component: TSG FA        H09 0304
   Coding: 011C02204100410001
   VCID: 56A3A7C321C70DF69B-8002
   Revision: 00001000    Serial number: 0004627975
   Coding: 100000000001
   Shop #: WSC 00158 001 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34673D4B9FFB3FE645-8060
1052420 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
                    Mileage: 55483 km
                    Date: 2017.12.10
                    Time: 10:24:01
                    valid
   Revision: 00002001    Serial number: 0178820983
   Coding: 011A062200B900448130013280000000
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   Component: TSG BF        H09 0304
   VCID: 55A1A0CF3CC106EE92-8000
   Revision: --------    Serial number: 00000001135512
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 387F097B8393DB8669-806C
   Part No SW: 8R1 035 195 H    HW: 8R1 035 195 H
   Component: Symphony3 US  H04 0461
   Revision: 00000001    Serial number: AUZ5Z4L1524978
   Coding: 0402008201018500015B070800
   VCID: 3A7B1373B59FC9969F-806E
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 52
                    Mileage: 55138 km
                    Date: 2017.12.02
                    Time: 14:05:26
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C02204000210001
   VCID: 59B9ACFF50D9228EB6-800C
   Component: TSG HR        H07 0304
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005510958
   Coding: 0010390
   VCID: 3D71186F64B1FEAEBA-8068
End-------------------------(Elapsed Time: 03:11)--------------------------
DrPeter
16.4905° S, 151.7375° W
- According to my research, yes it would appear you will need to replace the 'J500-Power Steering Control Module'.
You could try disconnecting the battery for 30 minutes, reconnect and then turn the ignition on and try to clear all the codes.
These Ross-Tech wiki pages maybe helpful:
- Audi RCEPS Steering Assist
- B2000 - Control Module: Defective
Hope this helps,
drpeter
caliche1275
Columbia
C?ID=160533
Tanks for the information, and I tried all that but it´s still the same , something I do not understand is that the address is working perfect, apparently it´s just a question of the witness on the board.
DrPeter
- You are welcome, if the 'J500-Power Steering Control Module' communicates and functions correctly, I guess you could just drive the vehicle?
drpeter
