POLO 1.0 TSI all modules malfunctions
wkeating
South Africa
C?ID=307967
Hi all
Any advice as to what the reason for all the no communication fault codes could be? car was in accident
Sunday,17,December,2017,09:34:07:42541
VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4401.4
VIN: WVWZZZ6RZGY109000   License Plate:
Mileage: 21618km-13432mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY109000   Mileage: 21618km-13432miles
03-ABS Brakes -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHZB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AQ    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 2309
   Revision: W1H25---
   Coding: 01110012232411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10TFS01104C906026AQ 001004
   ROD: EV_ECM10TFS01104C906026AQ_001.rod
   VCID: 70B8218D2A297157AA1-8024
   CAN Converter 01:
13 Faults Found:
17167 - Databus
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:03
                    Engine speed: 1034.50 /min
                    Normed load value: 15.7 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 14.512 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bit 0: 7
                    Cruise_control_shutoff_conditions_irreversible-Bit 0: 0
                    Cruise_control_shutoff_conditions_irreversible-Bit 8: 0
                    Cruise control system: temporary deactivation-Bit 0: 255
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 0
18065 - Coolant Pump 2
          P261C 00 [175] - Short to GND
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:45
                    Coolant temperature: 85 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.156 V
                    Outside air temperature: 28 °C
                    Absolute intake pressure: 99 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 19.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
17670 - Brake Switch (F)
          P0572 00 [167] - Short to GND
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 15:55:37
                    Coolant temperature: 21 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.803 V
                    Outside air temperature: 24 °C
                    Fuel level: 18.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.9980
4082 - Fuel Pressure Regulator Valve (N276)
          P2295 00 [175] - Short to Ground
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:43
                    Fuel level: 19.00 l
5462 - Starter Control; Returned Message
          P3053 00 [175] - 50 Short to Ground
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:22:56
                    Engine speed: 106.50 /min
                    Normed load value: 38.4 %
                    Coolant temperature: 77 °C
                    Voltage terminal 30: 9.164 V
                    Starter control: terminal 50 acknowledgment-Bit 0: 1
                    Starter control: relay 1-Bit 0: 3
                    Starter control: release conditions-Bit 0: 0
                    Starter control: release conditions-Bit 8: 98
                    Starter control: shut-off conditions 1-Bit 0: 0
                    Starter control: shut-off conditions 1-Bit 8: 0
                    Number of manual engine starts-Bit 0: 0
                    Number of manual engine starts-Bit 16: 0
                    Number of manual engine starts-Bit 24: 0
                    Number of manual engine starts-Bit 8: 11
                    Target torque for combustion engine crankshaft level: -11.5 Nm
4238 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
          P2185 00 [175] - Signal too High
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:42
                    Fuel level: 19.00 l
18942 - No Communication with ABS Brake Control Module
          U0121 00 [047] - -
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:42
                    Fuel level: 19.00 l
4713 - No Communication with ABS Brake Control Module
          U0121 00 [175] - -
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:42
                    Fuel level: 19.00 l
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:42
                    Fuel level: 19.00 l
4715 - No Communication with Instrument Cluster
          U0155 00 [032] - -
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
                    Engine speed: 1116.00 /min
                    Normed load value: 14.1 %
                    Voltage terminal 30: 13.970 V
                    Outside air temperature: 20 °C
                    Absolute intake pressure: 38 kPa abs
                    Engine torque: 17.7 Nm
                    Fuel level: 18.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
4719 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
                    Fuel level: 18.00 l
4720 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
                    Engine speed: 1056.00 /min
                    Normed load value: 14.9 %
                    Voltage terminal 30: 14.701 V
                    Absolute intake pressure: 39 kPa abs
                    Engine torque: 19.3 Nm
                    Fuel level: 18.00 l
4360 - Circuit for Brake Vacuum Pump
          P1429 00 [047] - Open Circuit
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:13:42
                    Fuel level: 19.00 l
Readiness: 0110 0001
Address 03: ABS Brakes
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H03 0108
   Serial number:  1509141B-1730
   Coding: 200100011000000000
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 1D6628398D3BAC3F517-8048
262914 - Refrigerant Pressure
          B10AB F0 [013] - Too Low
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:00:35
459012 - Databus
          U1121 00 [013] - Missing Message
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:00:27
459778 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [012] - Performance
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001588079752
   Coding: 0300084042530A7B0FA44080B127038800005B0257010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_VW26.rod
   VCID: 3038E18DEAA93157EA1-8064
   Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y15M09D21H19M54S43
   Coding: 9038DD
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU017091552607157
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU018091552612524
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY152013150
   Serial number: 00000000000033242899
   Subsystem 6 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU021091552641022
   Coding: 1400A0
   Subsystem 7 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU015091552582228
   Coding: 0400A0
8202 - Bulb for Left DRL
          B121D 15 [009] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:59:02
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:59:02
227080 - Turn Signal Switch
          B1144 29 [008] - Signal Implausible
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
528917 - Databus
                    Fault Frequency: 23
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:53
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
   Component: VW20Airbag00R 001 0360
   Revision: --------    Serial number: 003RH005Y011
   Coding: 88C0C000000000005C0000CA008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3536D09915CB147FB97-8060
   Subsystem 1 - Part No SW: -----------    HW: 410 821 909 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C51D211E082DN
   Subsystem 2 - Part No SW: -----------    HW: 410 822 709 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H0032293D852F2FV
   Subsystem 3 - Part No SW: -----------    HW: 442 150 609 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A009B1C81BC361BQ
   Subsystem 4 - Part No SW: -----------    HW: 442 150 609 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00991C81BC4A3BW
8 Faults Found:
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
                    Reset counter: 183
9682162 - Multiple collision brake
          B13BC F2 [137] - No function
                    Mileage: 21618 km
                    Date: 2016.10.01
                    Time: 22:22:21
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:55
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:55
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:55
          B1007 1B [137] - Resistance Too High
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:55
1052672 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:53
1052928 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 03:58:53
   Part No SW: 6C0 920 740 C    HW: 6C0 920 740 C
   Component: KOMBI         201 1420
   Coding: 272409002180000801082A001000000000000000
   VCID: 221C1BC5B44593C76C5-8076
6 Faults Found:
16776962 - Databus
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
16776968 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:26:02
16776971 - Databus
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
16776973 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:26:02
16776978 - Databus
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
16776988 - Databus
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:02
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001588079752
   Coding: 030100046F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 659640D9E5EBA4FFC97-8030
65793 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:28:08
                    Supply voltage: Terminal 30: 12.8 V
                    Terminal 15: On
131603 - No Communication with ABS Brake Control Module
          U0121 00 [009] - -
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:26:33
                    Supply voltage: Terminal 30: 13.6 V
                    Terminal 15: On
197169 - Controls in Steering Wheel
                    Fault Frequency: 13
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:26:33
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:26:33
                    Supply voltage: Terminal 30: 13.5 V
                    Terminal 15: On
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CF9T1001
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E843FF5301D67A7B8D-803A
9 Faults Found:
1058048 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Engine speed: 0 /min
                    Vehicle speed: 50.00 km/h
                    System status: ERROR
                    Voltage terminal 30: 12.18 V
                    Power steering current consumption: 0.50 A
                    End stage temperature: 34 °C
                    Steering assistance: engine output: 0.00 %
                    Sensor for motor position: 0 °
                    Sensor for motor position: 0 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: -0.16 Nm
                    Steering torque: OK
1054720 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Voltage terminal 30: 12.21 V
                    Steering torque: -0.15 Nm
                    Steering torque: OK
1066752 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 183
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 15:56:06
                    Engine speed: 151 /min
                    Voltage terminal 30: 8.95 V
                    End stage temperature: 18 °C
                    Steering torque: OK
6351360 - Crash Shut-Down Activated
          P1609 00 [009] - -
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:31
                    Steering torque: OK
1095680 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Steering torque: OK
1096704 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Steering torque: OK
1106944 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Steering torque: OK
1088512 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:34
                    Steering torque: OK
1089536 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:34:32
                    Steering torque: OK
   Part No SW: 3Q0 035 819 A    HW: 3Q0 035 819 A
   Component: MU-S--ER      H24 0245
   Serial number: VWZAZ2R0518045
   Coding: 02620000BE00000051110001000918001F0104860120010001
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2F3AE2F1F7972EAFF3B-807A
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H52 1028
   Serial number: VWZ8Z9REU00TRL
          B1061 13 [009] - Open Circuit
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:32:55
                    Voltage terminal 30: 12.3 V
6702 - Databus
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:32:57
7175 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:32:55
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 143
                    Mileage: 21618 km
                    Date: 2016.11.03
                    Time: 00:32:56
End----------(Elapsed Time: 01:06, VBatt start/end: 11.8V/13.7V)-----------
NZDubNurd
New Zealand
C?ID=230482
The ABS is totally offline for a start - fuses, and/or wiring is most likely for a good chunk of them, in a damaged car.
iichel
Netherlands, eastern part
C?ID=284912
Looks like a massive wiring loom issue. Check fuses check grounds check CAN and remove faulty modules.
Errors in the engine indicate an issue with wiring loom multiple components. Both are possible. Did you clear all dtcs and re-scan?
