Results 1 to 4 of 4
Thread: 2013 Seat Leon 5DR 1.2 TSI DSG Style (MQB)
    May 2017
    Initial scan without any modifications to the hardware.
    Wednesday,31,May,2017,19:56:23:18632
    VCDS Version: 17.1.3.0
    Dealer/Shop Name: Chop shop
    VIN: VSSZZZ5FZDR039344   License Plate: xxx-123
    Mileage: 106149km-65957mi   Repair Order:
    Chassis Type: 5F (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5
    VIN: VSSZZZ5FZDR039344   Mileage: 106149km-65957miles
    Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 A    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 5541
       Revision: WAH08---
       Coding: 01250032232401080000
       Shop #: WSC 00049 770 00125
       ASAM Dataset: EV_ECM12TFS01104E906016A 001006
       ROD: EV_ECM12TFS01104E906016A_AU37.rod
       VCID: 20766ECA3B8B2B41C9-8074
       Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 4512
       Revision: 00043014    Serial number: CU501303286885
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021.rod
       VCID: 49A0D36EE8F1CA097E-801C
       Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
       Component: ESC           H75 0333
       Coding: 20EE6A9220231275007A060401C7240456044800608024F200290020C0
       Shop #: WSC 00049 770 00104
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
       ROD: EV_Brake1UDSContiMK100ESP_008.rod
       VCID: 3A42BCA2BD175191E7-806E
       Part No SW: 5F0 907 044 A    HW: 5F0 907 044 A
       Revision: 00001K05
       Coding: 00000004200100011105004000101000
       Shop #: WSC 12345 123 12345
       ROD: EV_ACClimaBHBVW37X_002.rod
       VCID: 247E62DA2F933761AD-8070
       Air quality sensor:
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011308700426
       Coding: 08001946C2C102FB4BE44000401C07081008000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 46BAD852F9EF257193-8012
       Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 130318  041 0574
       Serial number:         130326035958
       Coding: 0BC5FD
       Component: RLFS  024 0042
       Serial number: Y13M04D06H03M24S39S2
       Coding: 00885D
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231308202247
       Coding: 0031051011
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       ROD: EV_EPHVA18AU3700000_VW37.rod
       Part No SW: 3Q0 959 655 R    HW: 3Q0 959 655 R
       Component: Airbag VW20   011 0186
       Revision: --------    Serial number: 003NPP5V7JX%
       Coding: 98CCC000000000005C0000CC000800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 4DA8E77E1C99D62952-8018
       Subsystem 1 - Part No SW: -----------    HW: 454 001 603 13
       Serial number: 3576U0000009B1343C08
       Subsystem 2 - Part No SW: -----------    HW: 454 002 403 13
       Serial number: 3586U000000A76243C0A
       Subsystem 3 - Part No SW: -----------    HW: 454 801 403 13
       Serial number: 3516R2A107300000000M
       Subsystem 4 - Part No SW: -----------    HW: 454 801 403 13
       Serial number: 3526R84A42100000000T
       Subsystem 5 - Part No SW: -----------    HW: 454 801 302 13
       Serial number: 3556V76EAD400000000I
       Part No SW: 5Q0 953 507 AN    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 04041304220068
       Coding: AC00
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 023204429547D951FF-8056
       Part No SW: 5F0 920 870 F    HW: 5F0 920 870 F
       Component: KOMBI         336 0556
       Coding: 07A502086984000800087A02000000
       ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
       VCID: 2B6C89E6424DF8196C-807E
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000508532
       Coding: 030100F42B086400EF0006481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 345E929A9F73A7E13D-8060
       Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
       Component: E221__MFL-PR6  H03 0100
       Serial number: 000000000A0645050313
       Coding: 002000
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000004050365332
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Serial number: 0000057243659
       Coding: 00100320DC00020000001000
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000151396
       Coding: 310000
       Coding: 11
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D48B7BEAC3966A9C2-8068
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Serial number: 0000056244561
       VCID: 01300B4E9041C249E6-8054
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000131183
       Coding: 290000
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Component: LWR-ECU       005 0070
       Coding: 048A000009000000
       ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
       VCID: 75D86F9ED489FEE9CA-8020
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 5F0 035 846     HW: 5F0 035 846
       Component: MU-S-N-ER     039 0171
       Serial number: E1F03103130409
       Coding: 04731001FF0A000021110001000800002F0106040100010046
       ASAM Dataset: EV_MUStd6C1PASE 002030
       ROD: EV_MUStd6C1PASE_VW37.rod
       VCID: 65F83FDE64290E697A-8030
       Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
       Component: ABTmin_Std_Nv  H45 0020
       Serial number: SEZ8Z9N5600CUK
       Subsystem 2 - Part No SW: 5F0 919 866 C    HW: -----------
       Component:  ECE 2013  --- 0021
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0050
       Serial number: 00000039868
       Coding: 0101010001000004000500000000000100
       ROD: EV_MFKBoschAU370.rod
    End-------------------------(Elapsed Time: 03:23)--------------------------
  2. Likes jyoung8607, Uwe liked this post
  3. #2
    May 2017
    Autoscan after ACC and Seat Sound System retrofit
    After successful ACC and Seat Sound System retrofit
    Tuesday,14,November,2017,16:54:18:18632
    VCDS Version: 17.8.0.1
    Dealer/Shop Name: workshop
    Workshop Code: 124 12345 012345
    Mileage: 115265km-71622mi   Repair Order:
    Chassis Type: 5F-SE37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5
    VIN: VSSZZZ5FZDR039344   Mileage: 115265km-71622miles
    Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
       Revision: WAH08---
       Coding: 01250032236401080000
       Shop #: WSC 12345 124 12345
       VCID: 20766ECA3B8B2B46AA-8074
    Readiness: 1110 0001
       ROD: EV_TCMDQ200021_VW26.rod
       VCID: 49A0D36EE8F1CA0E1D-801C
       Revision: 00000000    Serial number: 60246000001255
       Coding: 20EE6A9224231175007A060441C7240456248800608224F21621F070C008
       ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
       VCID: 7AC27CA2FD979196C4-802E
    Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
       Revision: 00001K05
       Coding: 00000004200100011105005000101000
       VCID: 247E62DA2F933766CE-8070
       Air quality sensor:
       VCID: 46BAD852F9EF2576F0-8012
       Coding: 0FC5FD
       Coding: 03885D
    Address 10: Park/Steer Assist (J791)       Labels:| User\5Q0-919-294.lbl
       Coding: 0071051051
       VCID: 3A42BCA2BD17519684-806E
    Address 13: Auto Dist. Reg (J428)       Labels:. User\5Q0-907-567.lbl
       Part No SW: 5Q0 907 567 L    HW: 5Q0 907 567 L
       Component: ACC3          H10 0098
       Serial number: 14051403090731
       Coding: 00011400FE030B
       ASAM Dataset: EV_ACCBoschMQB 001024
       ROD: N/A
       VCID: 44BEC25ACFD31766EE-8010
    No ASAM data for: "EV_ACCBoschMQB" (SE37)
       VCID: 4DA8E77E1C99D62E31-8018
       Coding: EC00
       ROD: EV_SMLSKLOMQB_009_SE37.rod
       VCID: 023204429547D9569C-8056
    Address 17: Instruments (J285)       Labels:| User\5G0-920-XXX-17.lbl
       Part No SW: 5F0 920 873     HW: 5F0 920 873
       Component: KOMBI         303 6420
       Coding: 07E502086D84000801897A030000000000000000
       Shop #: WSC 00123 123 12345
       ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
       VCID: 68E636EA933B130622-803C
    Address 19: CAN Gateway (J533)       Labels:| User\5Q0-907-530-V1.lbl
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1224
       ROD: EV_GatewLear_013_VW37.rod
       VCID: 75D86F9ED489FEEEA9-8020
       Coding: 002000
       Coding: 00180320DC00020000001000
       Coding: 310000
       Coding: 11
       VCID: 3D48B7BEAC3966AEA1-8068
       VCID: 01300B4E9041C24E85-8054
       Coding: 290000
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Coding: 047300010000000021110001000800002F0106040100010046
       VCID: 65F83FDE64290E6E19-8030
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\5Q0-980-653.lbl
       Coding: 0101010001040304000500000100000100
    End-------------------------(Elapsed Time: 03:36)--------------------------
  4. Likes jyoung8607, Uwe, golfi_vend liked this post
  5. #3
    Võru, Estonia
    Do you have TMC working on Your car in Finland? If so I'd like a admap from 5F. Thanks!!!
    The world is my oyster...
    May 2017
    Nope. Unfortunately TMC does not work here
    Which is incredibly stupid.......
