Audi A1 that drops into limp mode shortly after startup when cold but fine when warm.
VIN: WAUZZZ8X0CB212311 License Plate:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X0CB212311 Mileage: 103730km-64454miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: R4 1.6l TDI H63 9978
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F0A99A5E6176FBEE8-802A
10117 - Fuel Pressure Regulation Valve 2 Control Difference
P229B 00 [167] - Pressure too High
Mileage: 103732 km
Date: 2017.12.16
Time: 16:06:30
Engine speed: 990.75 /min
Normed load value: 32.9 %
Coolant temperature: 7 °C
Intake air temperature: 5 °C
Voltage terminal 30: 14.118 V
Fuel high pressure: actual value-FUP_FIL: 35.675 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Engine status-SF_ENG_STATE: IS
Fuel temperature-TFU: 6 °C
Fuel Metering Valve-VCV: 24.918 %
Fuel Pressure Regulator Valve-PCV: 0.000 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 25592.041 kPa
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 330448E9436E00B4CC2812E3C2D200920C00
Shop #: WSC 00046 000 00000
VCID: 7F0A99A5EA176FBEE8-802A
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030006789104
VCID: 3460868957D17CE645-8060
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 0E000A2CA805F100201841E000000154438B6C0A00CF4122DC0087830041
VCID: 4088DA59D369D046D1-8014
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
007 - Short to Ground
Fault Status: 01100111
Reset counter: 208
Mileage: 87361 km
Date: 2017.02.10
Time: 12:59:16
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ000C9YR
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 499EC77DE853110E06-801C
Serial number: 3554VRB405N0U2UUFGVE
Serial number: 3575HRB406114JQMAP0L
Serial number: 3585HRB405J14JQM6G4U
Rear Impact Crash Sensor:
Serial number: 3515ZRB405B0QMN2AHD5
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Revision: FF010016 Serial number: 20120204100023
Coding: 1184004000
VCID: 397EB7BDB8B3818E96-806C
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb
Part No SW: 8X0 920 980 D HW: 8X0 920 980 D
Component: KOMBI_MEDIUM H03 0180
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
VCID: 4088DA59DB69D046D1-8014
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P1212802B6
Coding: FBCF005A000100010153
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Serial number: 00000000007100327882
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 02121100000000000267
Component: IMMO H03 0180
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
Component: TSG FA H09 0409
Coding: 011802200101000100
VCID: 4C90FE69EF2104263D-8018
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6A89E5EAF75F3E38-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
Component: TSG BF H09 0409
VCID: 4B92FD75EA2F031E34-801E
Part No SW: 8X0 035 183 E HW: 8X0 035 183 D
Component: RMC Cnct H52 0775
Coding: 01010000000051070023000103010000010000
VCID: 397EB7BDB0B3818E96-806C
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462AK0C2520731
