Stuck in limp mode
   #21
Janfi
C?ID=186110
This is what I found under advanced info, is there anything helpful here?
Address 01: Engine
Control Module Part Number: 8K0 907 401 F
Component and/or Version: 3.0TDI EDC17 H01 0004
Software Coding: 010C002C180F0818
Work Shop Code: WSC 00011
VCID: 2E6B3087716E863633-807A
Advanced Identification/FAZIT
Identification: BPG-810
Revision: --H01---
Date: 30.03.08
Manufacturer number: 1480
Test stand number: 0182
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(application): 0/0/0
Programming Status: 00000000
Flash Date: 00.00.00
Flash Date: 0000.00.00
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 8K0 907 401
Workshop System Name: J623
ASAM Dataset: EV_ECM30LTDIA5
ASAM Dataset Revision: A02004
Car Info
Chassis Number: WAUZZZ8K39A010226
Engine code: CAPA
VCDS Info:
Labels: 059-907-401-V1.CLB
Readiness: No script available
ROD: EV_ECM30LTDIA5_A02.rod
   #22
Vasco Ferraz
Portugal
C?ID=288561
Did you enter the security access code?
Mine is 12233.
   #23
Janfi
C?ID=186110
Mine is 12233.
No, luck there either "invalid code" Somtething is simply preventig me from cleareing DTC:s, but what?
   #24
Vasco Ferraz
Portugal
C?ID=288561
I read again the wiki for your car and even though this is for emergency regeneration I believe that you might also need a security code to reset the G450 sensor.
1.6l/2.0l R4 & 3.0l V6 CR-TDI (UDS)
For engine controllers that use the UDS protocol (as shown on the top left corner of the Open Controller screen), Security Access is not typically needed when Service regeneration of particle filter while standing is supported.
Prerequisites (General):
Ignition ON
Engine ON (Idle)
Fuel Tank at least 1/4 full
Transmission in Neutral/Park
Coolant Temperature above 70 °C
Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
Engine Hood Closed
[Select]
[01 - Engine]
[Basic Settings - 04]
Use the pulldown menu and select Service regeneration of particle filter
[Go!]
[Show Measuring Data]
It would be useful to select items such as "Particle filter, soot mass calculated", "Particle filter, soot mass measured", and "Particle filter, time since last regeneration" to observe and verify the progress of the regeneration.
Due to the way UDS works, there may be differences in the locations and specific description for the values so you may need to search for the values you need.
Follow the Instructions on the Screen. These may include pressing and/or holding the brake, clutch, or accelerator.
[Done, Go Back]
[Close Controller, Go Back - 06]
Note; If Basic Setting Operation Service regeneration of particle filter is not available it may not be supported by the EDC. In those cases Adaptation Channel Service regeneration of particulate filter while driving would be supported instead. A Security Access code may be required for Regeneration while Driving.
   #25
Janfi
C?ID=186110
The only security code i see in the bubbel is 27971 "Particle Filter Emergency Regeneration" no other code is shown. And this I use with no sucsess.
   #26
Janfi
C?ID=186110
An uppdate on this thread.
I have tried to recode the controller but still cannot get to the DTC:s for DPF. As I am fast running out of options I am now planning on putting a new ECU on this car, I have found a used ECU with the same HW number as mine and now I have some questions:1. The ECU is from a car that has 30,000 km more on the display than mine, will my car get this new km reading?
2. The company selling this ECU offers it with keys and keyholder, do I need these keys?
3. Can I recode this controller with the codestring from my old ECU?
   #27
Address 01: Engine
Component and/or Version: 3.0TDI EDC17 H01 0004<<<<<<<<<<<<<<<<< Firmware update needed, not a controller 0008 or higher!
See caption above OP...........
   #28
Janfi
C?ID=186110
Here is an update to the thread. Before I started buying ECU:s I took the car to the dealer a second time and it was there for nine days! Then they called me and said the problem is solved, when I asked what they have found I got only wage answers like: "well we hade to go thru everything that you and the local garage hade done and initializing every part agin and then puff it worked"?? Some hint on what happened I still tink I have. The day before the car was ready the dealers tec called my local garage to tell the owner that "hey the pressure sensor is broke here" and when he was informed that the sensor is new and Audi original and driven only from there garage to the dealer, he wanted to end that phone call??
But the car is now out of limp mode and so far it is working. The car still has the ABS fault it got in the process, and a new scan says that the ABS coding and can bus coding is wrong, at least I have not changed any codes. Can you guys advice me if I can change the codes back to what it was before ( see scan in beginning) or do you have any better idea.
Monday,29,January,2018,19:30:31:31171
VCDS Version: 18.1.0.2 (x64)
VIN: WAUZZZ8K39A010226   License Plate:
Mileage: 236140km-146730mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
VIN: WAUZZZ8K39A010226   Mileage: 236140km-146730miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401 F    HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0004
   Revision: --H01---
   Coding: 010C002C180F0018
   Shop #: WSC 45291 002 1048576
   ASAM Dataset: EV_ECM30LTDIA5 A02004
   VCID: 2E6B3087716E863517-807A
5308 - Throttle Body Actuator Bank 1 (J338)
          P0638 00 [032] - Implausible Signal
                    Mileage: 236047 km
                    Date: 2018.01.26
                    Time: 17:11:51
                    Engine speed: 1551.00 /min
                    Normed load value: 64.7 %
                    Vehicle speed: 94 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 14.700 V
                    Engine speed: 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Thr Vlv r: 100.00 %
                    Ambient temperature: -13.6 °C
                    Intake air temperature: -13.0 °C
                    Throttle valve output stage: 5.00 %
                    Vehicle voltage terminal 30: 12280 mV
   Part No SW: 8K0 907 379 S    HW: 8K0 907 379 S
   Component: ESP8 quattro  H04 0210
   Coding: 1B0D00
   VCID: 49A1631BE0C0C10D22-801C
                    Fault Frequency: 34
                    Reset counter: 246
                    Mileage: 235648 km
                    Date: 2018.01.18
                    Time: 15:41:37
                    Hex Value: 0x0100
                    Hex Value: 0x4782
                    Hex Value: 0x003C
                    Hex Value: 0x03B9
                    Hex Value: 0x00FF
03159 - TPMS Functionality in ESP
                    Fault Frequency: 12
                    Reset counter: 246
                    Mileage: 235658 km
                    Date: 2018.01.24
                    Time: 10:00:30
                    Hex Value: 0x4300
                    Hex Value: 0x4206
                    Hex Value: 0x121A
                    Hex Value: 0x0DB4
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 M    HW: 8K0 907 064 M
   Component: BCM2 1.1      H70 0134
   Coding: 030200
   Shop #: WSC 06335 000 00000
   VCID: 3A430CD7B5265A95BB-806E
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000014889009
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000015103014
   Part No SW: 8T1 820 043 P    HW: 8T1 820 043 P
   Component: KLIMA 1 ZONE  H05 0120
   Revision: A1000000    Serial number: 0116.04.080037
   Coding: 36000000
   VCID: 3E4B00C7A90E76B587-806A
   Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
   Component: BCM1 1.0      H21 0253
   Revision: 05021001    Serial number: 00000000125443
   Coding: 26005091403400010001000300001D0D001C070800010001000000
   VCID: 30572EFF635A90C505-8064
   Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150408  H06 0060
   Serial number: SWFBIE 0000120
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 941 531 F    HW: 8K0 941 531 F
   Component: E1 - LDS  H07 0070
   Serial number: 00000000000804081234
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD14NRLX
   Coding: 30343434363030303030554A304C384B3053
   VCID: 3C4F0ACFB71264A5A9-8068
   Serial number: 6334MSME29437078D
   Serial number: 6344MSME3A110F54D
   Serial number: 6352QSME5C41286FU
   Serial number: 6362QSME572B1763K
   Serial number: 63732SME602E343D1
   Serial number: 63832SME610B1175W
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HDH000HT
   Coding: 000013
   VCID: 3D4907CBA4086DAD9E-8068
   Part No SW: 8K0 920 930 C    HW: 8K0 920 930 C
   Component: KOMBIINSTR.   H15 0221
   Revision: 00000000    Serial number: 7BX66MH48
   Coding: 0F04110003000008000000
   VCID: 2D69378B7468FD2D2E-8078
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G083138828
   Coding: 000303
   VCID: 46BB6827F1DE2E75CF-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H03 0150
   Serial number: 1801302D030408
                    Reset counter: 235
                    Mileage: 235648 km
                    Date: 2018.01.18
                    Time: 15:41:39
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007055904
   Coding: 011002204000410001
   VCID: 40B77E3FD3FA0045F5-8014
   Revision: 00002001    Serial number: 0111042261
   Coding: 0100062020390040012002
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 235
                    Mileage: 235648 km
                    Date: 2018.01.18
                    Time: 15:51:19
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 235
                    Mileage: 235648 km
                    Date: 2018.01.18
                    Time: 15:51:51
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 J    HW: 8T0 035 223
   Component: DSP STD       H07 0210
   Revision: S1700000
   Coding: 0203010102
   VCID: 35591FEB9C38B5ED56-8060
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007045934
   VCID: 3FB57DC3AE047FBD8C-806A
   Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
   Component: EPB Audi B8   H04 0050
   Revision: 00000003    Serial number: 10000000011408
   Part No: 8K0 907 357 B
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 345F22EF5742ACE561-8060
   Part No SW: 8T1 035 186 B    HW: 8T1 035 186 B
   Component: Concert3      H13 0150
   Revision: 00000516    Serial number: AUZ5Z6H1048217
   Coding: 05020082010285084159070000
   VCID: 365B18E7813EBEF55F-8062
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007029756
   Coding: 010002204000210001
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: ConWys Trailer H09 0100
   Revision: 1A001001    Serial number: 00000161077413
   Coding: 0100000000000000
   Shop #: WSC 00007 223 57222
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007042451
   Part No SW: 8T0 862 335 B    HW: 8T0 862 335 B
   Component: FSE_255x BT     H26 0350
   Revision: 00000000    Serial number: 00000005044971
   Coding: 0010310
   VCID: 394113DB7020518DB2-806C
End-------------------------(Elapsed Time: 03:05)--------------------------
Clean and adapt J338 or replace if faulty & perform TSB for firmware update.....
