Hello friends,
Need a little bit of help. For some time the car has gone in and out of fault alarm from the intake flaps but otherwise har run good, knew I hade to change the flaps sometime... Now three weeks ago on a 200 km journey the DPF light came on and soon afterwards turned into flashing glo plug light and limp mode. Scanned and found glogged DPF and throttel body J338 fault + intake flaps, now we have changed both intake flaps and throttle body and a new particular filter all aftermarket products but still can not get the car out of limp mode?
Saturday,16,December,2017,14:56:56:31171
VCDS Version: 17.8.1.0 (x64)
VIN: WAUZZZ8K39A010226 License Plate: SKX-719
Mileage: 234980km-146009mi Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
VIN: WAUZZZ8K39A010226 Mileage: 234980km-146009miles
Address 01: Engine (J623-CAPA) Labels:| 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0004
Revision: --H01---
Coding: 010C002C180F0818
Shop #: WSC 06335 123 12345
ASAM Dataset: EV_ECM30LTDIA5 A02004
ROD: EV_ECM30LTDIA5_A02.rod
VCID: 2E6B3087716E863633-807A
5188 - Diesel Particulate Filter (Bank 1)
P242F 00 [167] - Restricted/Clogged
Mileage: 234980 km
Date: 2008.02.09
Time: 21:45:44
Engine speed: 679.00 /min
Normed load value: 23.9 %
Coolant temperature: 59 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.660 V
Engine speed: 679.0 /min
Vehicle speed: 0.00 km/h
Field regeneration status-Bit 0: 00000000
Field regeneration status-Bit 16: 00010000
Field regeneration status-Bit 24: 00000000
Field regeneration status-Bit 8: 00000000
Particul.filter diff.pressure: -1 hPa
Exh t Adap TP Flt Us: -270.0 °C
Exhaust gas vol.flow particulate filter: 81.6 m³/h
Distance since last regeneration: 0 m
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Mileage: 234980 km
Date: 2008.02.09
Time: 21:45:42
Engine speed: 679.50 /min
Voltage terminal 30: 14.700 V
Engine speed: 679.5 /min
Co Eng st: COENG_RUNNING
Limiting torque: 214.3 Nm
Vehicle acceleration: 0.000 m/s²
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 14700 mV
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Mileage: 234980 km
Date: 2008.02.09
Time: 21:45:44
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Coding: 1B8D00
VCID: 49A1631BE0C0C10E06-801C
Reset counter: 211
Mileage: 234980 km
Date: 2008.02.09
Time: 21:46:52
Hex Value: 0x0000
Hex Value: 0x0220
Hex Value: 0x0015
Hex Value: 0x31A7
Hex Value: 0x00FF
00493 - ESP-Sensor Unit (G419)
Reset counter: 211
Mileage: 234980 km
Date: 2008.02.09
Time: 21:46:55
Hex Value: 0x0000
Hex Value: 0x0220
Hex Value: 0x0005
Hex Value: 0x54A6
Hex Value: 0x00FF
03265 - Data Bus Chassis Sensors
Reset counter: 211
Mileage: 234980 km
Date: 2008.02.09
Time: 21:46:55
Hex Value: 0x0000
Hex Value: 0x0220
Hex Value: 0x001D
Hex Value: 0xB9A6
Hex Value: 0x00FF
Fault Status: 00101110
Reset counter: 251
Mileage: 234980 km
Date: 2008.02.09
Time: 21:47:09
Hex Value: 0x00C0
Hex Value: 0x4322
Hex Value: 0x001D
Hex Value: 0xBC99
Hex Value: 0x00FF
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H70 0134
Coding: 030200
Shop #: WSC 06335 000 00000
VCID: 3A430CD7B5265A969F-806E
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000014889006
Component: ELVAUDIB8 H35 0039
Serial number: 0208000015103014
Part No SW: 8T1 820 043 P HW: 8T1 820 043 P
Component: KLIMA 1 ZONE H05 0120
Revision: A1000000 Serial number: 0116.04.080037
Coding: 36000000
VCID: 3E4B00C7A90E76B6A3-806A
Fault Status: 00101101
Reset counter: 227
Mileage: 234064 km
Date: 2017.11.22
Time: 13:26:37
Temperature: 9.0°C
RPM: 2080 /min
Reset counter: 250
Mileage: 234970 km
Date: 2008.02.08
Time: 00:02:17
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000125443
Coding: 2600D091403400010001000300001D0D001C270800010001000000
VCID: 30572EFF635A90C621-8064
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150408 H06 0060
Serial number: SWFBIE 0000120
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
Component: E1 - LDS H07 0070
Serial number: 00000000000804081234
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD14NRLX
Coding: 30343434363030303030554A304C384B3053
VCID: 3C4F0ACFB71264A68D-8068
Serial number: 6334MSME29437078D
Serial number: 6344MSME3A110F54D
Serial number: 6352QSME5C41286FU
Serial number: 6362QSME572B1763K
Serial number: 63732SME602E343D1
Serial number: 63832SME610B1175W
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HDH000HT
Coding: 000013
VCID: 3D4907CBA4086DAEBA-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7BX66MH48
Coding: 0F04110003000008010100
VCID: 2D69378B7468FD2E0A-8078
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G083138828
Coding: 000303
VCID: 46BB6827F1DE2E76EB-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
Serial number: 1801302D030408
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007055904
Coding: 011002204000410001
VCID: 40B77E3FD3FA0046D1-8014
Revision: 00002001 Serial number: 0111042261
Coding: 0100062020390040012002
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 211
Mileage: 234974 km
Date: 2008.02.09
Time: 01:49:39
02615 - Fuel Tank Cap; Lock
Reset counter: 211
Mileage: 234978 km
Date: 2008.02.09
Time: 15:57:35
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 J HW: 8T0 035 223
Component: DSP STD H07 0210
Revision: S1700000
Coding: 0203010102
VCID: 35591FEB9C38B5EE72-8060
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007045934
VCID: 3FB57DC3AE047FBEA8-806A
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 10000000011408
Part No: 8K0 907 357 B
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 345F22EF5742ACE645-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 B HW: 8T1 035 186 B
Component: Concert3 H13 0150
Revision: 00000516 Serial number: AUZ5Z6H1048217
Coding: 05020082010285084159070000
VCID: 365B18E7813EBEF67B-8062
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000007029756
Coding: 010002204000210001
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: ConWys Trailer H09 0100
Revision: 1A001001 Serial number: 00000161077413
Coding: 0100000000000000
Shop #: WSC 00007 223 57222
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007042451
Part No SW: 8T0 862 335 B HW: 8T0 862 335 B
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005044971
Coding: 0010310
VCID: 394113DB7020518E96-806C
