Mufufu
New Member
Hello guys and merry christmas
Last night my car decided to, not join the happy holiday. Or atleast need some attention.
Car: Golf mk6 estate, 2011, 169997 km, 1,6TDi with chip modification for econemy.
Errors: Glowplug lamp blinks, DPF and catalyst lights.
Symptoms: Poor acceleration
The DPF lights up, I removed it last time by driving like 20min with 3000rpm.
I wanted to repeat that success, however this time Glowplug lamp blinks, DPF and catalyst lid up.
As mentioned the car is chip modified and add diesel additiv (Bell Air)
Here is the error code:
Under one of your guides, it says you can force emergency regeneration. I have UDS protocol, but when I click go, it says I need a security access - Which I dont have.
Hope you can help my family and me.
Thursday,14,December,2017,19:23:23:08834
VCDS Version: 17.8.0.1 (x64)
VIN: WVWZZZ1KZBM675168 License Plate: AZ66434
Mileage: 169990km-105626mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 69 72
VIN: WVWZZZ1KZBM675168 Mileage: 169990km-105626miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 997 557 T HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9980
Revision: --H43--- Serial number: 00000000000000
Coding: 10114016032401080000
Shop #: WSC 00066 000 00195
ASAM Dataset: EV_ECM16TDI02103L997557T 003002
ROD: EV_ECM16TDI02103L997557S_VW36.rod
VCID: 4D9101E41CF39C2E31-8018
16848 - Diesel Particulate Filter
P2458 00 [173] - Regeneration Duration
Mileage: 169975 km
Date: 2017.12.14
Time: 18:40:21
Engine speed: 3395.25 /min
Normed load value: 14.9 %
Vehicle speed: 92 km/h
Coolant temperature: 84 °C
Intake air temperature: 10 °C
Voltage terminal 30: 14.569 V
Dynamic environmental data: 20 96
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 0.16 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 16.74 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 854 km
Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 12596.0189 s
Particle filter: difference pressure-DIP_PF: 8.04 hPa
Particle filter: offset for differential press.-DIP_PF_AD[0]: -2.24 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
Readiness: 1 1 0 0 0
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B200D092900FF880C04EA90210051310000
VCID: 7BF59F3CFAC7E29EDF-802E
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00066 000 00173
VCID: 6ED3A668B1B5873668-803A
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0046
Revision: BC011001
Coding: 00180E3A982D02C040080080500081E447610088425D05626480C7200041
Shop #: WSC 00066 123 12345
VCID: 3B755F3CBA47229E9F-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11021 26 0512
Coding: 009795
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6R017VKP
Coding: 00003536
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 326B7218650DE3D64C-8066
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME09545258ZZZV
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6510565AZZZW
Serial number: 3511HSME65620925ZZZG
Serial number: 3521HSME4B160A25ZZZL
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422JLK001KY
Coding: 5080140000
Shop #: WSC 00066 000 00081
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 70EFB810AB8191C67A-8024
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H23 0210
Revision: X0023007 Serial number:
Coding: 170D00
Shop #: WSC 00066 123 00173
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
VCID: 2C576C604729B52606-8078
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 176
Mileage: 165286 km
Date: 2017.10.13
Time: 11:54:14
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 06021101200032
Coding: 352002
VCID: 31697D14680BD8CE35-8064
Part No SW: 5K0 953 234 HW: 5K0 920 871 A
Component: IMMO H23 0210
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
ROD: EV_ImmoUDSMM9RM10_VW21.rod
VCID: 6ADBAA788D5D6B1634-803E
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0001946786
Coding: 0200B4
Shop #: WSC 01383 790 50316
VCID: 5BB5FFBC5207029EBF-800E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005479920
Coding: 000090
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346774005719EDE65E-8060
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0001906150
Coding: 0200B4
VCID: 5CB7FCA0570905A6B6-8008
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005542949
Coding: 000090
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L9104535
Coding: 0100040004
VCID: 65C1D9446C43446E19-8030
Fault Status: 00101011
Reset counter: 191
Mileage: 169977 km
Date: 2012.05.06
Time: 18:46:02
Reset counter: 191
Mileage: 169977 km
Date: 2012.05.06
Time: 18:46:02
Reset counter: 191
Mileage: 169977 km
Date: 2012.05.06
Time: 18:46:02
Reset counter: 191
Mileage: 169977 km
Date: 2012.05.06
Time: 18:46:02
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71E9BD14A88B98CE75-8024
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790390482
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0100
Revision: 3A001001 Serial number: 00000134313140
Coding: 0100000100000000
VCID: 306F78106301D1C63A-8064
End-------------------------(Elapsed Time: 02:50)--------------------------
