2008 Touareg 7L no response from Key
ivagp
C?ID=95551
Okay never had this situation before and keyless entry will open doors with key or with just key fob in pocket but when I try to hit the start button nothing happens to the no lights come on on the dash also when I do it with the key turning left turning right nothing happens and no communication to give you guys scan the best I can do is the VIN number which is wvgcb77l58d048206. Thanks for looking
ivagp
C?ID=95551
Bye putting the flash to pass and brake pedal able to go into 05 start authorization I was able to pull 00288. Any ideas any suggestions thank you very much
00288 is only a part of the fault code. ;)
Been here?
ivagp
C?ID=95551
yes i have, any info on getting the steering column to unlock? so we could move it around
ivagp
C?ID=95551
Trying to communicate just now and cannot get to communicate with anything even with brake pedal flasher and high beams. Just disconnected battery I'm going to see if in about an hour to try to communicate again
ivagp
C?ID=95551
She's alive after hard reboot with battery cables touching each other no codes yet. How much time we got before it happens again?:popcorn:
ivagp
C?ID=95551
Scan coming soon probably on Monday battery is dead by now.
ivagp
C?ID=95551
Okay cars back and it happend again same thing no communication after a hard reboot communication again and can start the vehicle again. here's the auto scan.
ivagp
C?ID=95551
Oops this is the first time trying to do with my mobile did not figure it out I have a start authorization code 00288 until I figure out how to post an auto scan that's the code and start authorization
Bad ground or blown fuse causing an open relay pole.........
ivagp
C?ID=95551
VCDS Mobile 0.4407.0.4
VIN: WVGCB77L58D048206
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 28 36 46 47 55 56 65
	 68 6D 6E 76
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine	Labels: 079-907-560-BAR.clb
	Part No SW: 7L0 907 560 E	HW: 7L0907560E
	Component: 4.2l V8/4V           0030
	Revision: 79H02---	Serial Number: VWX3Z0G6686549
	Coding: 04210009590F0160
	Shop #: WSC 31414 790 00001
	VCID: 33298CCF25DD79CD2E012574D-5160
Address 02: Auto Trans	Labels: 09D-927-750.lbl
	Part No SW: 09D 927 750 GE	HW: 09D927750GE
	Component: AL 750 6A            1092
	Revision: 00H61000	Serial Number:
	Coding: 0004216
	VCID: 77B178DF712555EDD2A931849-5160
No fault codes found.
Address 03: ABS Brakes	Labels: 7L0-907-379-MK25E1.clb
	Part No SW: 7L0 907 379 L	HW: 7L0907379L
	Component: ESP ALLRAD MK25E1    0303
	Revision: 00H53001
	Coding: 0004354
	VCID: 42C7D90B6A67C545B597C808A-8017
Address 05: Acc/Start Auth.	Labels: None
	Part No SW: 7L0 909 137 B	HW: 5WK48517ÿX
	Component: 11 Kessy             6840
	Revision: 68406620	Serial Number: VWX3Z0G6686549
	Coding: 0147688
	Shop #: WSC 31132 002 1048576
	VCID: 322789CBDAC775C525F73848A-8067
	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
	Component: ELV                  XXXX
00288 - Steering Column Lock Actuator (N360)
Address 08: Auto HVAC	Labels: 7L6-907-044.clb
	Part No SW: 7L6 907 044 AF
	Component: CLIMAtronic 2+2      4331
	Coding: 0020030
	VCID: 78B37BE37C3B5F95DBB33AB0C-802D
	Subsystem 1 - 	Part No SW: 7L6-907-049-F
	Component: CLIMAtronic FOND     0503
00714 - Centre Right Vent Positioning Motor (V111)
02508 - Temperature Sensor for Refrigerant (G454)
	010 - Open or Short to Plus
00445 - Loss of Refrigerant
	015 - Cannot Be Tested at this Time
Address 09: Cent. Elect.	Labels: 7Lx-937-049-V2.clb
	Part No SW: 7L6 937 049 AF	HW: 7L6937049AF
	Component: 2001J519
	Serial Number: --------------
	Shop #: WSC 00000 000
	VCID: 80439303A4EB9755630392104-80D5
Address 0F: Digital Radio	Labels: 8E0-035-593-SIR.lbl
	Part No SW: 8E0 035 593 M	HW: 8E0035593M
	Component: SDAR SIRIUS     H07  0150
	Revision: 00000000	Serial Number: AUZ4Z7G0211678
	Coding: 0000100
	VCID: 33298CCF25DD78CD2E012574D-8066
Address 15: Airbags	Labels: 7L0-959-655.lbl
	Part No SW: 7L0 959 655	HW: 7L0959339F
	Component: J234  3A VW8T        0250
	Revision: 92011025	Serial Number: 0039P003GN92
	Coding: 0013121
	VCID: FAB7E1EBC237CD852DC7D0A82-80AF
	Subsystem 1 - 	Part No SW: 7L0-959-339-F
	Component: BF-Gewichtsens. 007  0010
	Serial Number: 3NMMT
Address 16: Steering wheel	Labels: 7L6-953-549.lbl
	Part No SW: 7L6 953 549 F
	Component: J527                 3601
	Coding: 0010011
Address 17: Instruments	Labels: 7L6-920-xxx-7L6.lbl
	Part No SW: 7L6 920 975 L	HW: 7L6920975L
	Component: J285 KOMBI-INST.     7320
	Revision: KHH05V03
	Coding: 0007201
	Shop #: WSC 14080 412 468518
	VCID: 45CDC2177B49F67D90B5EB2C3-8010
Address 19: CAN Gateway	Labels: 6N0-909-901-19.lbl
	Part No SW: 6N0 909 901	HW: 7L6920975L
	Component: J533  GW-K-CAN TP20  7320
	Coding: 77E2FFB963066002
	VCID: F0A3C3C3944B83D5936342504-80A5
Address 1C: Position Sensing	Labels: 7L6-919-879.lbl
	Part No SW: 7L6 919 879 B	HW: 7L6919879B
	Component: Kompass         001  0001
	Revision: 00001000	Serial Number: 1439802T0NLA02
	VCID: 46CFC51B464FFD6599BF14586-8013
Address 22: AWD	Labels: 0A-22.lbl
	Part No SW: 0AD 927 755 BG
	Component: TRANSFERCASE         0126
	VCID: 81459607AFE19B5D6C0D9F1C7-5184
Address 28: Failed to respond
Address 36: Seat Mem. Drvr	Labels: None
	Part No SW: 7L0 959 760
	Component: Sitzverstellung      0702
	VCID: F7B1F8DFF125D0ED52A9B1849-80A2
Address 46: Central Conv.	Labels: 7L0-959-933.lbl
	Part No SW: 7L6 959 933 A
	Component: 19 HSG               0600
	Coding: 0000085
	VCID: 40C3D303646BD255A383D2104-4B1E
	Subsystem 1 - 	Part No SW: 7L0-959-701-P
	Component: Tuersteuergeraet FS  6302
	Subsystem 2 - 	Part No SW: 7L0-959-702-P
	Component: Tuersteuergeraet BF  6302
	Subsystem 3 - 	Part No SW: 7L0-959-703-D
	Component: Tuersteuergeraet HL  0201
	Subsystem 4 - 	Part No SW: 7L0-959-704-D
	Component: Tuersteuergeraet HR  0201
01134 - Alarm Horn (H12)
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
Address 47: Sound System	Labels: 7Lx-035-4xx-47.lbl
	Part No SW: 7L6 035 466 A	HW: 7L6035466A
	Component: DSP 10 Kanal         0003
	Revision: 00001000	Serial Number: 00000000005825
	VCID: 322789CBDAC771C525F73848A-8067
Address 55: Xenon Range	Labels: 7L6-907-357-A.lbl
	Part No SW: 7L6 907 357 A	HW: 7L6941329B
	Component: AFS-Steuergeraet     0001
	Revision:   H02   	Serial Number:
	Coding: 1290371
	VCID: 3935BEE707B1869DE43D67BCF-806C
	Subsystem 1 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Lst.-Modul l     X008
	Coding: 0000019
	Subsystem 2 - 	Part No SW: 7L6-941-329-B	Labels: 3D0-941-329.clb
	Component: AFS-Lst.-Modul r     X008
	Coding: 0000019
Address 56: Radio	Labels: 7L6-035-180-56.lbl
	Part No SW: 7L6 035 180 C	HW: 7L6035180C
	Component: Radio DE2            0008
	Revision: 00005000	Serial Number: VWZ4Z4GN014221
	Coding: 0001010
	VCID: 2D1D9AB7C3F92E3D78C5E30CB-8078
Address 65: Tire Pressure	Labels: 7L6-907-273.lbl
	Part No SW: 7L6 907 273 E	HW: 7L6907273E
	Component: J0502 RDK            0006
	Revision: 00004006	Serial Number: 00000900009547
	Coding: 0040008D8D0000000000000000
	VCID: 3A37A1EB02B78D85ED4790A82-806F
02214 - Tire Pressure Warning
Address 68: Wiper Electr.	Labels: 7L0-955-119-V2.clb
	Part No SW: 7L6 955 119 B
	Component: J400__ Front Wiper   5301
	Coding: 0001397
	VCID: 3935BEE707B1829DE43D67BCF-806C
Address 6D: Trunk Elect.	Labels: 7L6-959-107.clb
	Part No SW: 7L6 959 107 A	HW: 7L6959107A
	Component: J605  HECKKLAPPE     1210
	Revision: --H05---	Serial Number: --------025355
	Coding: 0122110
Address 6E: Ctrl Head Roof	Labels: 7L6-919-044.lbl
	Part No SW: 7L6 919 044 Q	HW: 7L6919044Q
	Component: J702  Dachdisplay    0400
	Revision: --30004S	Serial Number: 00000000050543
Address 76: Park Assist	Labels: None
	Part No SW: 7L0 919 283 F
	Component: 0E Einparkhilfe      1107
ivagp
C?ID=95551
Thanks Jeff you need to be connected to vcds mobile with interface to be able to post auto scan from your mobile
ivagp
C?ID=95551
dose anybody think 005634 could be related to 00288? is their a way to find a time stamp on these faults.
Have you checked with VCDS? It's possible it might retrieve freeze-frame data that VCDS-Mobile doesn't.
ivagp
C?ID=95551
/\ will check,more info 2 keys are on one ring found this tsb "96 09 03 December 2, 2009 2021774"?
ivagp
C?ID=95551
here is the windows scan
Wednesday,24,January,2018,15:05:53:13440
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4407.4
Dealer/Shop Name: ivagp
VIN: WVGCB77L58D048206   License Plate:
Mileage: 186740km-116034mi   Repair Order:
Chassis Type: 7L (6N0)
          68 6D 6E 76
VIN: WVGCB77L58D048206   Mileage: 186740km-116034miles
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 7L0 907 560 E    HW: 7L0 907 560 E
   Revision: 79H02---    Serial number: VWX3Z0G6686549
   VCID: B32676E7D30168DEDC-5160
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0010 0101
   Part No SW: 09D 927 750 GE    HW: 09D 927 750 GE
   Revision: 00H61000    Serial number:
   Coding: 0004216
   VCID: F7BE82F787F944FE20-5160
   Part No SW: 7L0 907 379 L    HW: 7L0 907 379 L
   Revision: 00H53001
   Coding: 0004354
   VCID: C2C8232399BBD15647-8096
                    Fault Frequency: 12
                    Reset counter: 171
                    Mileage: 185726 km
                    Date: 2017.10.25
                    Time: 00:03:05
                    Count: 192
                    Count: 12545
                    Count: 294
                    Count: 3
   Part No SW: 7L0 909 137 B    HW: 5WK 485 17
   Revision: 68406620    Serial number: VWX3Z0G6686549
   Coding: 0147688
   VCID: B22873E3291B61D6D7-80E6
   Part No: 7L6 907 044 AF
   Coding: 0020030
   VCID: F8BC81CB8FE74B8629-80AC
   Subsystem 1 - Part No: 7L6 907 049 F
                    Temperature: 52.0°C
                    Absolute Pres.: 15.0 bar
                    Load: 96.0 %
                    Temperature: 43.0°C
                    Temperature: 33.0°C
                    Load: 68.0 %
                    Temperature: 95.0°C
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2001
   Revision: -0004---    Serial number: --------------
   Coding: 220008002F043C000000000000000000
   VCID: 804CE92BD737034611-80D4
   Revision: 00000000    Serial number: AUZ4Z7G0211678
   Coding: 0000100
   VCID: B32676E7D20168DEDC-80E6
                    Reset counter: 130
                    Mileage: 186741 km
                    Date: 2017.12.16
                    Time: 00:16:23
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Revision: 92011025    Serial number: 0039P003GN92
   Coding: 0013121
   VCID: FAB89BC3B1EB59965F-80AE
   Subsystem 1 - Part No: 7L0 959 339 F
   Subsystem 2 - Serial number: 3NMMT
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ
   Subsystem 4 - Serial number: 000000ÿ
   Part No: 7L6 953 549 F
   Coding: 0010011
   Part No SW: 7L6 920 975 L    HW: 7L6 920 975 L
   Revision: KHH05V03
   Coding: 0007201
   VCID: C5C2383F8C95E66E62-8090
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 975 L
   VCID: F0ACB9EBE39713C6E1-80A4
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Revision: 00001000    Serial number: 1439802T0NLA02
   VCID: C6C03F33B193ED766B-8092
   Part No: 0AD 927 755 BG
   VCID: 814AEC2FD93D0A4E1E-5160
Address 28: HVAC, Rear
   Part No: 7L0 959 760
   VCID: F7BE82F782F944FE20-80A2
   Part No: 7L6 959 933 A
   Coding: 0000085
   VCID: C0CC292B92B7C34651-4B1E
   Subsystem 1 - Part No: 7L0 959 701 P
   Subsystem 2 - Part No: 7L0 959 702 P
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
   Part No SW: 7L6 035 466 A    HW: 7L6 035 466 A
   Revision: 00001000    Serial number: 00000000005825
   VCID: B22873E32D1B61D6D7-80E6
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Revision:   H02       Serial number:
   Coding: 1290371
   VCID: B93A44CFF46D928E16-80EC
   Coding: 00000019
   Coding: 00000019
   Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
   Revision: 00005000    Serial number: VWZ4Z4GN014221
   Coding: 0001010
   VCID: AD12609F34253E2E8A-80F8
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Revision: 00004006    Serial number: 00000900009547
   VCID: BA385BC3F16B99961F-80EE
                    Reset counter: 127
                    Mileage: 186677 km
                    Date: 2017.11.25
                    Time: 10:05:56
                    (no units): 77.0
   Part No: 7L6 955 119 B
   Coding: 0001397
   VCID: B93A44CFF06D928E16-80EC
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     061207 046  0204
   Coding: 00208933
   Shop #: WSC 31414
   Part No SW: 7L6 959 107 A    HW: 7L6 959 107 A
   Revision: --H05---    Serial number: --------025355
   Coding: 0122110
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 Q    HW: 7L6 919 044 Q
   Revision: --30004S    Serial number: 00000000050543
   Part No: 7L0 919 283 F
End----(Elapsed Time: 02:42, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Looks like those two codes (005634 & 00288) don't have time stamps....
ivagp
C?ID=95551
Any info Nobody?
ivagp
C?ID=95551
just pulled the motor off the steering column. looking at the circuit board all the solder joints look good. if i get a used or new column do i have to program or code it?
