Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: 2008 Touareg 7L no response from Key
  1. #31
    Jul 2014
    i have the WD, found three splices. in the tsb the wire looks to be pink?
  2. #32
    Jul 2014
    /\ my ? is from post 27
  3. #33
    IDK and I don't care because I use the WD pin for pin location to verify because colors can be wrong in WD sometimes!
  4. #34
    Jul 2014
    opened up kessy, no water damage to my eyes. https://imgur.com/a/Kmjeb
  5. #35
    Jul 2014
    i have looked at the wiring diagram and pulled a bunch of relays in an effort to stop n360 from operating with no success, dose anyone know what fuse or relay can stop n360? i know the three wires going to n360 come from the kessy, and the kessy is power by the j519.
  6. #36
    Jul 2014
    not trying to defeat the n360, just to find where the hell it starts from
  7. #37
    00288 - Steering Column Lock Actuator (N360)
    Replace N360 or overlay pin for pin if 0x05 and 0x09 are in order and tracks have the ability to carry current.
    Authenticate the diagnostic stack for N360 status using variable resistor to test in blocks of Kessy.
  8. #38
    Jul 2014
    n360 was replaced 02/17 by previous owner, still same issue. quote from jack "Authenticate the diagnostic stack for N360 status using variable resistor to test in blocks of Kessy" where do i find this info? the only thing i find off is the volts pin #1 at n360, it is about 10.8 with key off and dips down to 10.2 when you insert the key.
  9. #39
    You either need to compare it to another vehicle or do what I say and create your own test path if the RTFB has no information.
    You should be familiar with the aforementioned tools in my last post and how to implement them no?
    If not you better start.........
