Results 21 to 30 of 39
Thread: 2008 Touareg 7L no response from Key
  1. #21
    I know used can't be matched with traditional tools and this page has never contained a procedure:
    http://wiki.ross-tech.com/wiki/index...edit&redlink=1
    .. so I'm not entirely sure if it could be matched with VCDS. If you can manage to match it with VCDS the PIN would be required at the least. If it starts and runs at this time you may want to have the new column matched at the dealer.
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #22
    Jul 2014
    thanks for responding just found out through carfax that the steering column was replaced on 02/08/2017 at a vw dealer. so im kind of thinking n360 is not the issue. also all three keys that belong to the car where on one ring. its happens once every two weeks. from my testing i see their is voltage drop of 1.0 volt on pin 1 of n360. on n360 connector disconnected pin #1 has 10.9 volts,pin 2 and 3 have zero volts with key off. when turning key on the only thing that changes is pin 2 briefly spikes to 4.something volts. key off n360 connected pin 1 still 10.9 volts, pins 2 and 3 zero volts. when key is turned to on position pin 1 drops to 10.1volts, pin 2 briefly spikes to 11 volts and pin three briefly spikes to .35 volts. let me know what else i can test. thanks for looking
  4. #23
    What is status of kessy internally for water Ingres?
  5. Likes Dana, Jetta ,97 liked this post
  6. #24
    Jul 2014
    /\ thanks for responding have not pulled kessy, i'm sure you are aware the location is under the dash do they suffer from water leaks?
  7. #25
    Oh why yes they do sir..... Inspect internals
  8. Likes Dana liked this post
  9. #26
    Jul 2014
    /\ first thing Monday
  10. Likes Dana liked this post
  11. #27
    Jul 2014
    ok back on this again, have not taken kessy out yet. their is a tsb with not much info "97 09 02 May 12, 2009 2020310". pulled harnes out from A pilar, have found three splices brown/ red, black and a much thicker black that has four wires spliced together. from the tsb pic it looks like the wire should be pink? just want to check this wire before i pull the Kessy. also dose anyone know what if any codes this will set or if my condition apply?
  12. #28
    Jun 2014
    Are your batteries OK? Just askin.
  13. #29
    Jul 2014
    3 month old agm 49, tested 100% state of health and state of charge. it seems 00288 has many definitions, the def on mine is impauseble signal. the few posts that i found from owners on club touareg is they had replaced the n360 but still had issues every 2 months or so, eventually they replaced the kessy and their troubles went away. still looking to see if anyone knows the wire color on that tsb "97 09 02 May 12, 2009 2020310" ?
  14. #30
    WD ????????????????
