Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: 2018 Audi A3 e-tron
  1. #51
    Quote Originally Posted by Eric View Post
    They all seem to be there, just in a non-intuitive order since whoever assigned the MAS texts at VAG was shortsighted with the number of possible cells
    Sorry, I must need new glasses or something.
  2. #52
    US 2014 GTI Drivers Edition/DSG
    Quote Originally Posted by Andy View Post
    So it looks like 0 miles EV range indicates 24% battery, 344V and each cell between 3.578-3.585V.
    ....It looks like "full" 24 miles EV indicates 90% battery, 384V and each cell between 3.989-4.000V.
    Yea it seems like most all of the EV manufacturers are very conservative with cell charge, typically keeping a not insignificant upper and lower reserve of 10-20%
    It may not work at all on your audi, but there is an android volt app for a BT obd dongle you can use to monitor the various PID's to get a lot of stats they don't put on the dash.
    https://play.google.com/store/apps/d...om.MyGreenVolt
    and if you are not already aware of a good generic obd app I recommend torque pro @ https://play.google.com/store/apps/d...g.prowl.torque
    Another useful app for finding places to charge @ https://play.google.com/store/apps/d...tori.Plugshare
  3. Likes Andy liked this post
  4. #53
    Those seemed to be missing
    17 - AdpMap
    ;SW:8V0-920-894-A   HW:8V0-920-894-A ---  Instruments
    ;Component:FBenUSA       H16 0066, Coding:08440C516F88CF050283E8101B00000000000000
    ;EV_DashBoardFPKAU37X,001027,EV_DashBoardFPKAU37X.rod
    ;Tuesday,12,December,2017,15:36:41:20613
    ;VCDS Version: Beta 17.11.0  Data version: 20171026 DS285.1
    ;VCID: 3FC1C03CA62D39D2FF5-806A
    IDE00001-Production mode,not active ,3
    IDE00301-Distance,175 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,US English ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,15 H,1
    IDE00501-Minute,36 min,1
    IDE00502-Year,2017 yr,2
    IDE00503-Month,12 mon,1
    IDE00504-Day,12 d,1
    IDE00510-ESI: distance driven from inspection,100 km,3
    IDE00511-ESI: time from inspection,6 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,14500 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,poor oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,100 km,2
    IDE00819-Day counter,32 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,16000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 1 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.80 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.80 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.70 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
    IDE03329-Driving profiled for range remaining,8.10 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,miles ,3
    IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,°F ,3
    IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
    IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
    IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,32100 km,3
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,100 km,3
    IDE03352-FIX: Time since last time-dependent inspection,6 d,2
    IDE03372-Source for synchronization of time,GPS ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,OFF ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,No ,1
    IDE04169-Display correction of consumption and operating range: gas,100 %,1
    IDE05930-Service notification in days,30 d,1
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,No display ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE07221-Cylinder shut-off,Display ,1
    IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,0.00 A,8
    IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,1 ,8
    IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.00 ,8
    IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.10 ,8
    IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,1.10 ,14
    IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
    IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
    IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
    IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
    IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
    IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
    IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
    IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
    IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
    IDE10693-Initialize sensor for fuel level,No ,1
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,10.10 l/100km,14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
    IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
    IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
    IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
    IDE11472-MAS18773-Configuration of displayable contents-Acceleration_measurement,No display ,4
    IDE11472-MAS18774-Configuration of displayable contents-Drag_indicator,No display ,4
    IDE11472-MAS19086-Configuration of displayable contents-charge_symbol_colour,Standard ,4
    IDE12050-Acoustic: drive position R,not active ,1
    MAS03555-Lap counter,No display ,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
    ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21
    ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
    ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
    ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
    ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
    ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
    ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
    ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
    ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
    ENG99320-Developers_menu,not active ,1
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 °C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
    ENG126283-parameter_hmi,41 43 56 03 05 FF 1E 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
    ENG135292-phev_stat_intervall-,5.00 ,3
    ENG135292-phev_stat_intervall-,100 m,3
    ENG135292-phev_stat_intervall-,0 min,3
    ENG126281-ENG126398-SK2_Adjustment-max_number_of_writing_procedures,6 ,3
    ENG126281-ENG126400-SK2_Adjustment-timeout_request_immediate,150 s,3
    ENG126281-ENG126399-SK2_Adjustment-timeout_request_normal,300 s,3
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,active ,4
    Elapsed Time: 00:37
    17-MVB map
    ;Tuesday,12,December,2017,15:35:40:20613
    Group,Description,Actual
    IDE00019,Voltage terminal 30,13.10, V
    IDE00021,Engine speed,0, /min
    IDE00025,Coolant temperature,21.75, °C
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0, km/h
    IDE00191,Charge air pressure: actual value,0.00, %
    IDE00196,Engine oil temperature,19, °C
    IDE00301,Distance,175, km
    IDE00310,Outside air temperature,10.50, °C
    IDE00316-IDE00500,Time-Hour,15, H
    IDE00316-IDE00501,Time-Minute,35, min
    IDE00316-MAS00111,Time-Seconds,43, s
    IDE00317-IDE00502,Date-Year,2017, yr
    IDE00317-IDE00503,Date-Month,12, mon
    IDE00317-IDE00504,Date-Day,12, d
    IDE00322,Status of basic setting,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00510,ESI: distance driven from inspection,100, km
    IDE00511,ESI: time from inspection,6, d
    IDE00512,ESI: minimum value km-driving distance/inspection,14500, km
    IDE00513,ESI: maximum value km-driving distance/inspection,14500, km
    IDE00514,ESI: maximum value of time between inspections,730, d
    IDE00515,ESI: oil quality,poor oil quality,
    IDE00517,ESI: soot entry,0, km
    IDE00518,ESI: thermal load,100, km
    IDE00520,Phototransistor,56,
    IDE00695,ESI: service exceedance in km,Not available,
    IDE00696,ESI: service exceedance in days,Not available,
    IDE00697,ESI: remaining distance,15840, km
    IDE00698,ESI: remaining running time,359, d
    IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
    IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
    IDE00819,Day counter,32, d
    IDE00827,ESI: minimum value of time between inspections,365, d
    IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,1937, mm
    IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2005, mm
    IDE00935,ESI: Theoretical service interval,15000, km
    IDE01076,Time since ignition off,5810, s
    IDE01153,SIA: maximum value of distance to service,16000, km
    IDE01154,SIA: maximum value of time to service,365, d
    IDE01285,Counter of component protection malfunctions,0,
    IDE01985-ENG101043,FAZIT identification test sum-Checksum,7A 9E 4C 36,
    IDE01985-ENG99027,FAZIT identification test sum-Version,02,
    IDE02642,Outside temp.: displayed value,10.50, °C
    IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,9F,
    IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
    IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
    IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,54,
    IDE03349,FIX: Max. distance until next mileage-related inspection,32100, km
    IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
    IDE03351,FIX: Distance covered since last mileage-dependent inspection,100, km
    IDE03352,FIX: Time since last time-dependent inspection,6, d
    IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
    IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
    IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
    IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
    IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
    IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
    IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
    IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
    IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
    IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
    IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
    IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
    IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
    IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
    IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
    IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
    IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
    IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
    IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
    IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
    IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
    IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
    IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
    IDE03471-ENG126401,Vehicle configuration-intelligent_park_assist,Correct coding,
    IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,9.40, l
    IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,42.00, l
    IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,43.00, l
    IDE03472-MAS03809,Volume after refueling-Last reference quantity,9.40, l
    IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,0.80, l
    IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,13.50, l
    IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,13.50, l
    IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,0.80, l
    IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.00, l
    IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,0.00, l
    IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,0.00, l
    IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,0.00, l
    IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,0.00, l
    IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,0.00, l
    IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,0.00, l
    IDE03472-MAS03822,Volume after refueling-Last error status,00,
    IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
    IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
    IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
    IDE03472-MAS06153,Volume after refueling-Last distance,10, km
    IDE03472-MAS06154,Volume after refueling-Penultimate distance,0, km
    IDE03472-MAS06155,Volume after refueling-Third to last distance,0, km
    IDE03472-MAS06156,Volume after refueling-Fourth to last distance,0, km
    IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,82, Ohm
    IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,not_available,
    IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,1, Ohm
    IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,not_available,
    IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,not_available,
    IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,not_available,
    IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,not_available,
    IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,not_available,
    IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,303,
    IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,631,
    IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,not_available,
    IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,not_available,
    IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,not_available,
    IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,not_available,
    IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,not_available,
    IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,not_available,
    IDE03474-IDE00304,Calculated volume-Fuel level,40.60, l
    IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,81, Ohm
    IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,not_available,
    IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,not_available,
    IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,not_available,
    IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,40.30, l
    IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,not_available,
    IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,not_available,
    IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,not_available,
    IDE03474-IDE00802,Calculated volume-Full volume,42.00, l
    IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
    IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
    IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
    IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
    IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,40.30, l
    IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,not_available,
    IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,not_available,
    IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,not_available,
    IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.00,
    IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.00,
    IDE03474-ENG102894,Calculated volume-averaged_volume,40.30, l
    IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,40.30, l
    IDE03474-ENG101619,Calculated volume-calibrated_volume_total,40.30, l
    IDE03474-ENG126318,Calculated volume-gas_based_linking,0.50,
    IDE03474-ENG99553,Calculated volume-linking,0.0000000,
    IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.31, m/s
    IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.09, m/s
    IDE03474-ENG101623,Calculated volume-reference_volume,40.30, l
    IDE03474-ENG102479,Calculated volume-speed_based_linking,0.00,
    IDE03474-ENG99683,Calculated volume-version_of_application,8,
    IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0010281,
    IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
    IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
    IDE03475-MAS12387,Control button in instrument cluster-Button for daily distance driven,not active,
    IDE03477-IDE00500,GPS time-Hour,14, H
    IDE03477-IDE00500,GPS time-Hour,15, H
    IDE03477-IDE00501,GPS time-Minute,36, min
    IDE03477-IDE00501,GPS time-Minute,53, min
    IDE03477-IDE00502,GPS time-Year,2017, yr
    IDE03477-IDE00503,GPS time-Month,12, mon
    IDE03477-IDE00504,GPS time-Day,12, d
    IDE03477-MAS00111,GPS time-Seconds,5, s
    IDE03477-MAS00111,GPS time-Seconds,36, s
    IDE03477-MAS03493,GPS time-last synchronization year,2017, yr
    IDE03506,Distance: high resolution,00 02 AE DB,
    IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
    IDE03880-MAS03425,MOST address-Physical address,04 01,
    IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 1A,
    IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0C,
    IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0C,
    IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 1A,
    IDE03911-MAS01394,Service -interval- display: history 1-Block 5,FF FF FF FF,
    IDE03911-MAS01395,Service -interval- display: history 1-Block 6,FF FF FF FF,
    IDE03911-MAS01396,Service -interval- display: history 1-Block 7,FF FF FF FF,
    IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
    IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
    IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
    IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
    IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
    IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
    IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
    IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
    IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
    IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
    IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
    IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
    IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
    IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
    IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
    IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
    IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
    IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
    IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
    IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
    IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
    IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
    IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
    IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
    IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
    IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
    IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
    IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
    IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
    IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
    IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
    IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
    IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
    IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
    IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
    IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
    IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
    IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
    IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
    IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
    IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
    IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
    IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
    IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
    IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
    IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
    IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
    IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
    IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
    IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
    IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
    IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
    IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
    IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
    IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
    IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
    IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
    IDE04649-MAS06857,Activation for housing fan-Speed,0, /min
    IDE04649-ENG128738,Activation for housing fan-PWM_FAN,0, %
    IDE04649-ENG128737,Activation for housing fan-source_max_PWM_requested,none,
    IDE04649-ENG98933,Activation for housing fan-Status,OFF,
    IDE04649-ENG128733,Activation for housing fan-temperature_Boost,45, °C
    IDE04649-ENG128734,Activation for housing fan-temperature_chipled,57, °C
    IDE04649-ENG128736,Activation for housing fan-temperature_GPU,52, °C
    IDE04649-ENG128735,Activation for housing fan-temperature_KI,45, °C
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-IDE06026,Roller test bench mode: functional-Adaptation of brake pedal path sensor,not activated,
    IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
    IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
    IDE06924,Performance display,4093,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
    IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
    IDE07578-MAS00138,Operating range consumption with electric drive-1,0.00,
    IDE07578-MAS00139,Operating range consumption with electric drive-2,65533,
    IDE07578-ENG04221,Operating range consumption with electric drive-ERW_Energieinhalt,0.00,
    IDE07578-ENG114651,Operating range consumption with electric drive-s_erw_rw_batterie,65533, km
    IDE07578-ENG114652,Operating range consumption with electric drive-s_erw_rw_batterie_anz,65534, km
    IDE07578-ENG114648,Operating range consumption with electric drive-s_erw_rwds,0.00, A
    IDE07578-ENG114640,Operating range consumption with electric drive-s_erw_rwds_high,0.00, A
    IDE07578-ENG114644,Operating range consumption with electric drive-s_erw_rwds_low,10.00, A
    IDE07578-ENG114637,Operating range consumption with electric drive-s_erw_rwdv_antrieb_high_unclass,0.10, kWh/100 km
    IDE07578-ENG114641,Operating range consumption with electric drive-s_erw_rwdv_antrieb_low_unclass,25.00,
    IDE07578-ENG114645,Operating range consumption with electric drive-s_erw_rwdv_antrieb_unclass,1.90,
    IDE07578-ENG114638,Operating range consumption with electric drive-s_erw_rwdv_dcdc_high_unclass,0.00, kWh/100 km
    IDE07578-ENG114642,Operating range consumption with electric drive-s_erw_rwdv_dcdc_low_unclass,0.20,
    IDE07578-ENG114646,Operating range consumption with electric drive-s_erw_rwdv_dcdc_unclass,0.00,
    IDE07578-ENG114639,Operating range consumption with electric drive-s_erw_rwdv_tme_high_unclass,0.10,
    IDE07578-ENG114643,Operating range consumption with electric drive-s_erw_rwdv_tme_low_unclass,0.50,
    IDE07578-ENG114647,Operating range consumption with electric drive-s_erw_rwdv_tme_unclass,0.10,
    IDE07578-ENG114649,Operating range consumption with electric drive-s_erw_rwdv_unclass,2.10,
    IDE07646-ENG114675,Consumption for road-specif. range with electric drive-s_erw_endsteigung,0.00, %
    IDE07646-ENG114667,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_0,1.10, kWh/100 km
    IDE07646-ENG114668,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_1,25.00, kWh/100 km
    IDE07646-ENG114669,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_2,25.00, kWh/100 km
    IDE07646-ENG114670,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_3,25.00, kWh/100 km
    IDE07646-ENG114671,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_4,25.00, kWh/100 km
    IDE07646-ENG114672,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_5,25.00, kWh/100 km
    IDE07646-ENG114673,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_class_6,25.00, kWh/100 km
    IDE07646-ENG114653,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_0,1.10, kWh/100 km
    IDE07646-ENG114654,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_1,25.00, kWh/100 km
    IDE07646-ENG114655,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_2,25.00, kWh/100 km
    IDE07646-ENG114656,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_3,25.00, kWh/100 km
    IDE07646-ENG114657,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_4,25.00, kWh/100 km
    IDE07646-ENG114658,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_5,25.00, kWh/100 km
    IDE07646-ENG114659,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_high_class_6,25.00, kWh/100 km
    IDE07646-ENG04222,Consumption for road-specif. range with electric drive-s_erw_rwdv_antrieb_low_class,25.00, kWh/100 km
    IDE07646-ENG114674,Consumption for road-specif. range with electric drive-s_erw_str_klasse,0,
    IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
    IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
    IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
    IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
    IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
    IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
    IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
    IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,F8,
    IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
    IDE08239,Transponder ID Key 1,09 D7 BF D6,
    IDE08240,Transponder ID Key 2,09 D7 57 61,
    IDE08252-ENG101043,Test sum of adapted transponder-Checksum,C3 A1 24 B2,
    IDE08252-ENG99027,Test sum of adapted transponder-Version,01,
    IDE08343,Immobilizer Challenge,B6 CA F7 67,
    IDE08701-MAS07266,ESI: Status-Oil change: unit of dist. travelled,miles,
    IDE08701-MAS07267,ESI: Status-Oil change: dist. travelled,5000,
    IDE08701-MAS07268,ESI: Status-Oil change: stat. of dist. travelled,Service in,
    IDE08701-MAS07269,ESI: Status-Oil change: stat. of time,Service in,
    IDE08701-MAS07270,ESI: Status-Inspection: stat. of dist. travelled,Service in,
    IDE08701-MAS07271,ESI: Status-Inspection: unit of dist. travelled,miles,
    IDE08701-MAS07272,ESI: Status-Inspection: dist. travelled,19900,
    IDE08701-MAS07273,ESI: Status-Inspection: time,724,
    IDE08701-MAS07274,ESI: Status-Oil change warning,no warning,
    IDE08701-MAS07277,ESI: Status-Inspections warning,no warning,
    IDE08701-MAS07305,ESI: Status-Oil change: time,370,
    IDE08701-MAS07308,ESI: Status-Inspection: status time,Service in,
    IDE08701-MAS10768,ESI: Status-Daily mileage,100,
    MAS00077-ENG99298,Immobilizer-State,02 01 03 5B 02 00 00 00 03 00,
    MAS03121,Ring break diagnostic line status,Supply voltage,
    ENG126262-ENG114675,Consumption_for_distance_on_map-s_erw_endsteigung,0.00, %
    ENG126262-ENG114674,Consumption_for_distance_on_map-s_erw_str_klasse,0,
    ENG126262-ENG128739,Consumption_for_distance_on_map-s_vkmrw_rwdv_antrieb_low_class,11.70, l/100km
    ENG126262-ENG126309,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_0,10.10, l/100km
    ENG126262-ENG126310,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_1,10.00, l/100km
    ENG126262-ENG126311,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_2,10.00, l/100km
    ENG126262-ENG126312,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_3,10.00, l/100km
    ENG126262-ENG126313,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_4,10.00, l/100km
    ENG126262-ENG126314,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_5,10.00, l/100km
    ENG126262-ENG126315,Consumption_for_distance_on_map-s_vkmrw_rwdv_class_6,10.00, l/100km
    ENG126262-ENG126302,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_0,10.10, l/100km
    ENG126262-ENG126303,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_1,10.00, l/100km
    ENG126262-ENG126304,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_2,10.00, l/100km
    ENG126262-ENG126305,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_3,10.00, l/100km
    ENG126262-ENG126306,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_4,10.00, l/100km
    ENG126262-ENG126307,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_5,10.00, l/100km
    ENG126262-ENG126308,Consumption_for_distance_on_map-s_vkmrw_rwdv_high_class_6,10.00, l/100km
    ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,92, %
    ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,52, %
    ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,42, %
    ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,42, %
    ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,42, %
    ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
    ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
    ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
    ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
    ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
    ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
    ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
    ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
    ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
    ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
    ENG119883,ESI_mileage_per_day,100, km
    ENG107920-ENG98868,onboard_computer-Range,462, km
    ENG107920-ENG119788,onboard_computer-range_average_consumption,8.10, l/100km
    ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,0.00, kg/100 km
    ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,0.00, kg/100 km
    ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,0.00, kg/100 km
    ENG107920-ENG119789,onboard_computer-range_average_consumption_high,8.10, l/100km
    ENG107920-ENG119790,onboard_computer-range_average_consumption_low,11.70, l/100km
    ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,0.00, kg/100 km
    ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,0.00, kg/100 km
    ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,0.00, kg/100 km
    ENG107920-ENG126298,onboard_computer-range_cng,65534, km
    ENG107920-ENG126300,onboard_computer-range_cng_display_value,65534, km
    ENG107920-ENG119791,onboard_computer-range_display_value,462, km
    ENG107920-ENG126299,onboard_computer-range_lpg,65534, km
    ENG107920-ENG126301,onboard_computer-range_lpg_display_value,65534, km
    ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
    ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
    ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
    ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
    ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
    ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
    ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,121,
    ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
    ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
    ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
    ENG119885-ENG103300,Service_Key_current_data-Service_Data,7B 4A 00 23 C1 80 11 0C 0C 0D 2B 32 A8 00 00 00 63 30 67 11 C7 30 D4 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 FF FF 00 00 40 18,
    ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,55,
    ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
    ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
    ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
    ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
    ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
    ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
    ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
    ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
    ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
    ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
    ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
    ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
    ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
    ENG126266-ENG119811,SK2_counter_per_day-Counter_Key_ID_1,0,
    ENG126266-ENG119812,SK2_counter_per_day-Counter_Key_ID_2,0,
    ENG126266-ENG119813,SK2_counter_per_day-Counter_Key_ID_3,0,
    ENG126266-ENG119814,SK2_counter_per_day-Counter_Key_ID_4,0,
    ENG126266-ENG119815,SK2_counter_per_day-Counter_Key_ID_5,0,
    ENG126266-ENG119816,SK2_counter_per_day-Counter_Key_ID_6,0,
    ENG126266-ENG119817,SK2_counter_per_day-Counter_Key_ID_7,0,
    ENG126266-ENG119818,SK2_counter_per_day-Counter_Key_ID_8,0,
    ENG126267-ENG126385,SK2_pointer_and_label-SK2_label,FF FF FF FF,
    ENG126267-ENG126382,SK2_pointer_and_label-Write_Pointer_Pos_1,65535,
    ENG126267-ENG126383,SK2_pointer_and_label-Write_Pointer_Pos_2,65535,
    ENG126267-ENG126384,SK2_pointer_and_label-Write_Pointer_Pos_3,65535,
    ENG126263-ENG126381,SK2_received_data_from_datalogger-SK2_data,B4 D1 9D 00 01 01 FF FF 00 00 AF 23 8C FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
    ENG126268-ENG126392,SK2_state-difference_SK2_data_SK-master_key,Yes,
    ENG126268-ENG126394,SK2_state-last_reveived_end_identification,no_end_identification_received,
    ENG126268-ENG126391,SK2_state-limitation_normal_request,not active,
    ENG126268-ENG126386,SK2_state-SK2_function,not active,
    ENG126268-ENG126389,SK2_state-state_immediate_request,not active,
    ENG126268-ENG126388,SK2_state-state_normal_request,not active,
    ENG126268-ENG126390,SK2_state-state_waiting_for_retry,not active,
    ENG126268-ENG126393,SK2_state-transfer_SK2_data_finished_within_timeout,Yes,
    ENG126268-ENG126387,SK2_state-trigger_normal_request,no_trigger,
    ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
    ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
    ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
    ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
    ENG109340-ENG101740,tank_validation-s_vali_active,not active,
    ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,3276.80, l
    ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,3276.80, l
    ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
    ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
    ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
    ENG109340-ENG100160,tank_validation-s_vali_status,2, l
    ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,3277.20, l
    ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,3277.00, l
    ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,3317.20, l
    ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,3276.80, l
    ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,3276.80, l
    ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,3276.80, l
    ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,3317.00, l
    ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,3316.90, l
    ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,3317.20, l
    Elapsed Time: 01:00
  5. #54
    I enabled sport display/lap counter/oil temp via coding and ADP and did a soft reset, DTCs ensued
    HNU
    Tuesday,12,December,2017,15:53:28:20613
    VCDS Version: 17.11.0.0  HEX-NET CB: 0.4409.4
    VIN: WAUSPBFF8JA063478   License Plate:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 47
              4B 51 52 5F 6C 75 8C A5 BB BC C0 C6 CF D6 D7
    VIN: WAUSPBFF8JA063478   Mileage: 175km-108miles
    23-Brake Booster -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-CXUA)       Labels: None
       Part No SW: 04E 906 023 BL    HW: 04E 907 309 F
       Component: 1.4 TFSI hy   H22 5190
       Revision: X3H22---
       Coding: 021D0012636401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023BL 008008
       ROD: EV_ECM14TFS01104E906023BL.rod
       VCID: 6B99446C82D5757203D-803E
    20360 - Power Supply Terminal 15
              P3325 00 [167] - Implausible
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Coolant temperature: 22 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 13.340 V
                        Outside air temperature: 10 °C
                        Absolute intake pressure: 98 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel: tank fill level: 40.6 l
                        E-machine torque actual value: 0.0 Nm
                        Operating mode control expanded electrical driving: Correct result
                        Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                        High-volt. battery: charge state: abs. value: 55.34 %
    4715 - No Communication with Instrument Cluster
              U0155 00 [038] - -
              [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
    Readiness: 1110 1101
       Part No SW: 0DD 300 046 G    HW: 0DD 927 770 C
       Component: GSG DQ400E    H32 1601
       Revision: 00032056    Serial number: TFK01710300270
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021.rod
       VCID: 2C1B8770475BB24A4A7-8078
    10683 - No Communication with Instrument Cluster
              U0155 00 [046] - -
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Engine speed: 6.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 72 km/h
                        Control Module temperature: 56 °C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 17920
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
       Component: ESC           H62 0855
       Revision: 00000000    Serial number: 63067000000687
       Coding: 12FF40923826226F897B0A07A1CB2948021C44915085947218A1505482A802
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
       VCID: 7CBB7730F7BBE2CA9A7-8028
    8236 - Databus
              U1121 00 [046] - Missing Message
              [FCAN: Kombi_01 messagei is not received]
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0459644688
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C3BB730B73B22CADA7-8068
       Part No SW: 8V0 820 043 S    HW: 8V0 820 043 S
       Component: AC Automat    H03 0620
       Revision: 20002000    Serial number: 00000001381293
       Coding: 0300001001001000080000000000140001000000
       ASAM Dataset: EV_AirCondiFrontNARAU37X 001020
       ROD: EV_AirCondiFrontNARAU37X.rod
       VCID: 42C7C9C8D5DF543A90B-8016
       Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G395 pT-Sens1  H11 0009
       Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
       Component: J848 HV-PTC  200 0204
       Serial number: -00104.4U.6C20340044
       Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 6CD015D800PAG0MUFU02
       Subsystem 4 - Part No SW: 5QE 816 803 C    HW: 5QE 816 803 C
       Component: J842 eKK  H02 0006
       Serial number: IABB00000K0000000426
    459011 - Databus
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Unlearning counter according OBD-OBD Parameter: 40
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 01001730300664
       ROD: EV_BCMBOSCH_018.rod
       VCID: 064F15D8B977A81AFC3-8052
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 171010  043 0580
       Serial number:         171018215533
       Coding: 0A47F7
       Serial number: 21039790X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 29 06 2017  00001475
       Serial number: 00000000000000002774
       Sun Roof:
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST001URT7M00000
       Coding: 101F00
    558869 - Databus
              [Kombi_01 Datenbus fehlende Botschaft]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Serial number: 000308418617300
       Coding: 0470155811
       ROD: EV_EPHVA18AU3700000_009_AU37.rod
       VCID: 4BD9E4ECE295957263D-801E
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: D50087C119FFC428949C8055000026
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
       VCID: 3B39B42CB23525F2D3D-806E
    1080 - Databus
              [FAULT_TIMEOUT_KOMBI_01]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Control Module temperature: 31 °C
                        Voltage terminal 15: 13.0 V
       Serial number: 003GCR09AB57
       Coding: 9DFCFCC0002000009000001AC24800000065
       VCID: 47D1D8DCFEFD7112475-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A25101751432
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A02111750605
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001NM31Q
       Coding: 303334
       Subsystem 4 - Part No SW: -----------    HW: 480 000 211 17
       Serial number: 357000000006768C692S
       Subsystem 5 - Part No SW: -----------    HW: 480 000 211 17
       Serial number: 35800000000C63AC692X
       Subsystem 6 - Part No SW: -----------    HW: 480 400 611 17
       Serial number: 3510001C127FACA2E66L
       Subsystem 7 - Part No SW: -----------    HW: 480 400 611 17
       Serial number: 3520001AD275C8A14478
       Subsystem 8 - Part No SW: -----------    HW: 480 402 709 17
       Serial number: 3550002A1252D87021D-
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 709 17
       Serial number: 3560002A1252D872003Q
    1051904 - Databus
              [NWD: 0x30B Kombi_01Timeout]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Part No SW: 8V0 953 521 KF    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 01111704221174
       Coding: 6C18
       VCID: 08531BE0B363BE6A8EF-805C
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 894 A    HW: 8V0 920 894 A
       Component: FBenUSA       H16 0066
       Coding: 084C0C516F88CF050283FE101B00000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001027
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 3FC1C03CA62D39D2FF5-806A
       Part No SW: 3Q0 907 530 M    HW: 3Q0 907 530 D
       Component: GW MQB EV     618 6322
       Serial number: 25101710801069
       Coding: 0201001726F200005B00101E581000000001010100010000000300000000
       ROD: EV_GatewNF_VW48.rod
       VCID: 3935AE24B80917E2C11-806C
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20171026205450 21683
       Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
       Serial number: 0264015604
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
       Component: EBKV          H14 0211
       Serial number:   085460013127
       Coding: 03720100331A00030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
       ROD: EV_BrakeBoostBoschMQBOMG_004.rod
       VCID: 52E7F98805BFC4BA20B-8006
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0155
       Serial number: 05802861311017064918
    209664 - No Communication with Instrument Cluster
              U0155 00 [046] - -
              [iBoVAG_ComScl_Kombi_01_Timeout]
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       Revision: 00000000    Serial number: 17000317723003
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 342B9F109F6BEA8A127-8060
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0610
       Revision: --------
       Coding: 04C002
    1183837 - Databus
              [databus message missing - Kombi]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Control Module temperature: 39 °C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 0.00 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 12.90 V
       Serial number: 191017EJJ05486
       Coding: 005D1F205C00048000000003
       VCID: 43C9CCCCCAC55D329BD-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: D106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45CDD2D4C4F16302B59-8010
    22016 - Databus
              [KFC_KOMBI_01 Botschaft - CAN-Timeout]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Motor status: 00
                        Supply voltage: 13.00 V
                        Temperature: 20.0 °C
                        KFC: 56
                        KFA: 00 00
                        Environmental conditions: 25
                        uioUdNotFilt_xdu16: 13.22 V
                        uAdSensI_SwitchedKl30_xdu16: 13.21 V
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAH5F00ZPQ-
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 240B6F502F8B7A0A827-8070
       Serial number: 31101710800195
       Coding: 000000050100142A00112300040000000000000000000000000000000000
       VCID: 72A75908A5FFA4BAC0B-8026
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
       Component: LE Gen 3.3H15 1032
       Revision: 00H15000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM08530115G0907080E 001008
       ROD: EV_DMCM08530115G0907080E.rod
       VCID: 29157E6448A9A762B11-807C
       Serial number: 221017EJL19794
       Coding: 005D17205E00048000000003
       Part No SW: 8V1 035 880 B    HW: 8V1 035 880
       Component: MU-P-LNS-US   054 1110
       Serial number: A702J0H2504957
       Coding: 017393020000000011220002041A00102F0029E5017001047E
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y071HF
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL113101700050389
       Component: Gracenote2  --- 3012
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [009] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in sound]
                        Reset counter: 14
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:55
                        Voltage terminal 30: 13.3 V
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: -1 °C
                        Temperature of MOST transceiver-Current: 47 °C
       Coding: 0273100102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       Component: OCULowMQBUS   009 0570
       Coding: 017393011082BA0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
       Component: BECM          H05 0921
       Serial number: V6130090
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006041
       ROD: EV_BECM09620115Q0915182.rod
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
       Component: BJB  H28 0240
       Cell Module Controller 1:
       Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D1  H14 0481
       Serial number: V013C1762330573
       Cell Module Controller 2:
       Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D2  H14 0481
       Serial number: V013C1762330568
       Cell Module Controller 3:
       Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D3  H14 0481
       Serial number: V013C1762330572
       Cell Module Controller 4:
       Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D4  H14 0481
       Serial number: V013C1762330571
       Cell Module Controller 5:
       Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D5  H14 0481
       Serial number: V013C1772630045
       Cell Module Controller 6:
       Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D6  H14 0481
       Serial number: V013C1772630046
       Cell Module Controller 7:
       Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D7  H14 0481
       Serial number: V013C1762330586
       Cell Module Controller 8:
       Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
       Component: 6D8  H14 0481
       Serial number: V013C1762330585
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0272
       Serial number: 27101711P11306
       Coding: 040307030000020101222346814E490080000E200120
       ROD: EV_MFKBoschMQBB_VW36.rod
    1122612 - Databus
              [TIMEOUT_Kombi_01]
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Control Module temperature: 36 °C
                        Outside air temperature: 11.0 °C
                        System run time: 2285.5 s
                        Voltage terminal 15: 13.1 V
                        mid: 01 CF
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    Address BB: Door Rear Drv
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 091017EJ913755
       Coding: 000C17204000048000000002
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
       Component: E_SOUND_SG    H09 0212
       Serial number: EN172301820000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 006013
       ROD: EV_ENoiseS1NNVW3707_006.rod
       VCID: 4AD7E1E8EDEF8C7A58B-801E
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AG    HW: 5QE 915 682 AG
       Component: OBC KOSTAL    H40 4013
       Revision: --------    Serial number: 0108170H10001Y
       Coding: 105168023000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
       ROD: EV_OBCSinglPhaseKLOMQB12P.rod
       VCID: 12673988C53F04BA60B-8046
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
       Revision: --------
       Coding: 04C002
       VCID: 3833AB2083030EEA3EF-806C
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 1771489CEEDD2192175-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 02:16, VBatt start/end: 11.9V/11.9V. VIgn 0.1V)------
    HUC
    Tuesday,12,December,2017,16:02:25:09701
    Data version: 20171026 DS285.1
    Chassis Type  FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 47 4B 51
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
       Revision: X3H22---
       VCID: 6BDFDFAB82A0157203D-803E
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
              U0155 00 [038] - -
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       VCID: 2C5D1CB7472ED24A4A7-8078
              U0155 00 [046] - -
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Driving position: N
       VCID: 7CFDECF7F7CE82CA9A7-8028
    8236 - Databus
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Coding: 030C0C
       VCID: 3C7D2CF7B74E42CADA7-8068
       VCID: 4281520FD5AA343A90B-8016
    459011 - Databus
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       VCID: 06098E1FB902C81AFC3-8052
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Sun Roof:
       Coding: 101F00
    558869 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Coding: 0470155811
       VCID: 4B9F7F2BE2E0F57263D-801E
       VCID: 3B7F2FEBB24045F2D3D-806E
    1080 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       VCID: 4797431BFE881112475-8012
       Coding: 333135
       Coding: 333135
       Occupant Detection:
       Coding: 303334
    1051904 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       Coding: 6C18
       VCID: 08158027B316DE6A8EF-805C
       VCID: 3F875BFBA65859D2FF5-806A
       VCID: 397335E3B87C77E2C11-806C
       VCID: 52A1624F05CAA4BA20B-8006
              U0155 00 [044] - -
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       VCID: 346D04D79F1E8A8A127-8060
       Revision: --------
       Coding: 04C002
    1183837 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
       VCID: 438F570BCAB03D329BD-8016
       Coding: D106
       VCID: 458B4913C4840302B59-8010
    22016 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        Motor status: 00
                        KFC: 56
                        KFA: 00 00
       VCID: 244DF4972FFE1A0A827-8070
    Interface not compatible.
       Revision: 00H15000
       VCID: 2953E5A348DCC762B11-807C
                        Reset counter: 14
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:55
       Coding: 00000000
    1122612 - Databus
                        Reset counter: 54
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
                        mid: 01 CF
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 091017EJ913756
       Coding: 04
       VCID: 4A917A2FED9AEC7A58B-801E
       VCID: 1221A24FC54A64BA60B-8046
    End-------------------------(Elapsed Time: 06:13)--------------------------
    On the plus side:
    Not sure if the g-meter is gonna come to life or stay still like in Shaun's A4.
  6. Likes Uwe, Andy, D-Dub liked this post
  7. #55
    subsequent HUC scan found the 08 slaves
    459011 - Databus
                        Mileage: 175 km
                        Date: 2017.12.12
                        Time: 15:47:40
  8. #56
    US 2014 GTI Drivers Edition/DSG
    missing message from missing accelerometer (gforce meter)?
  9. #57
    Administrator Andy's Avatar
    Quote Originally Posted by Andy View Post
    ;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect.
    ;Component:BCM MQBAB MNA H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
    ;Friday,08,December,2017,16:08:05:29905
    ;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
    ;VCID: 064F1553B953FC1AFC3-8052
    IDE00075,Vehicle speed,0.00, km/h
    IDE00322,Status of basic setting,was not yet started,
    IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
    IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
    IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
    IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
    IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not coded/not installed,
    IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not coded/not installed,
    IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not coded/not installed,
    IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not_defined,
    IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
    IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not coded/not installed,
    IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,not coded/not installed,
    IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
    IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
    IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
    IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measured value not available,
    IDE00973,Outside air temperature,4.50, °C
    IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
    IDE01066,Convertible top status,not coded/not installed,
    IDE01464-IDE04741,Rear window defogger-Rear window defogger button,not activated,
    IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
    IDE01464-MAS01580,Rear window defogger-Activation,not active,
    IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
    IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
    IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
    IDE01943-MAS01737,Turn signal-Diagnosis,normal,
    IDE01943-MAS02248,Turn signal-Signal state,not active,
    IDE01943-MAS03873,Turn signal-Duty cycle,0.0, %
    IDE01943-MAS04351,Turn signal-Connector terminal number,60,
    IDE01943-MAS04352,Turn signal-Connector number,Plug A,
    IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
    IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
    IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not activated,
    IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,closed,
    IDE02092-MAS02447,Tailgate condition-Release,Enabled,
    IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,not activated,
    IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,closed,
    IDE02486,Data logger triggering,not active,
    IDE02488-MAS01632,DWA Interior monitoring-Status,not coded/not installed,
    IDE02488-MAS04508,DWA Interior monitoring-Alarm detected,not coded/not installed,
    IDE02515-MAS01737,Low beam-Diagnosis,normal,
    IDE02515-MAS02248,Low beam-Signal state,not active,
    IDE02515-MAS03873,Low beam-Duty cycle,0.0, %
    IDE02515-MAS04351,Low beam-Connector terminal number,5,
    IDE02515-MAS04352,Low beam-Connector number,Plug C,
    IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
    IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
    IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
    IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
    IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
    IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
    IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
    IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
    IDE02614-MAS02788,Reversing light switch-CAN,not active,
    IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
    IDE02711,Rear Window Wiper,not active,
    IDE02743-MAS01737,High Beam-Diagnosis,normal,
    IDE02743-MAS02248,High Beam-Signal state,not active,
    IDE02743-MAS03873,High Beam-Duty cycle,0.0, %
    IDE02743-MAS04351,High Beam-Connector terminal number,72,
    IDE02743-MAS04352,High Beam-Connector number,Plug A,
    IDE02744-MAS01632,Steering wheel heater-Status,not coded/not installed,
    IDE02744-MAS02311,Steering wheel heater-Steering wheel heating button,not coded/not installed,
    IDE02744-MAS04136,Steering wheel heater-Current,0.00, A
    IDE02744-MAS09758,Steering wheel heater-Temperature sensor,-35, °C
    IDE02857-IDE03111,Activation current-Interior light,16, mA
    IDE02857-IDE05533,Activation current-Spray nozzle heater,422, mA
    IDE02857-IDE06012,Activation current-Search lights,0, mA
    IDE02857-MAS01554,Activation current-Left heated seat,0, mA
    IDE02857-MAS01556,Activation current-Right heated seat,0, mA
    IDE02857-MAS05942,Activation current-Windshield and rear window washer pump,0, mA
    IDE02857-ENG128454,Activation current-Cockpittaster_1,no error,
    IDE02857-ENG128455,Activation current-Cockpittaster_2,no error,
    IDE02857-ENG128456,Activation current-Cockpittaster_3,no error,
    IDE02857-ENG128457,Activation current-Cockpittaster_4,no error,
    IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
    IDE02857-ENG126436,Activation current-signal_horn,65533, mV
    IDE02957-MAS01737,Ambient lighting-Diagnosis,normal,
    IDE02957-MAS02248,Ambient lighting-Signal state,not active,
    IDE02957-MAS03873,Ambient lighting-Duty cycle,0.00, %
    IDE02957-MAS04351,Ambient lighting-Connector terminal number,61,
    IDE02957-MAS04352,Ambient lighting-Connector number,Plug C,
    IDE02957-MAS06670,Ambient lighting-Channel,Chan. A,
    IDE03111-MAS01737,Interior light-Diagnosis,not coded/not installed,
    IDE03111-MAS02248,Interior light-Signal state,not active,
    IDE03111-MAS03873,Interior light-Duty cycle,0.00, %
    IDE03111-MAS04351,Interior light-Connector terminal number,0,
    IDE03111-MAS04352,Interior light-Connector number,Plug A,
    IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
    IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
    IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,16.8, V
    IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
    IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,13.2, V
    IDE03310-MAS01737,Brake light-Diagnosis,normal,
    IDE03310-MAS02248,Brake light-Signal state,not active,
    IDE03310-MAS03873,Brake light-Duty cycle,0.0, %
    IDE03310-MAS04351,Brake light-Connector terminal number,60,
    IDE03310-MAS04352,Brake light-Connector number,Plug A,
    IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
    IDE03388-MAS02201,Left front heated seat: status-Temperature,9.50, °C
    IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
    IDE03389-MAS02201,Right front heated seat: status-Temperature,9.50, °C
    IDE03504-IDE02022,Personalized settings-Comfort opening,not_defined,
    IDE03504-IDE03679,Personalized settings-Adaptive light functions,not active,
    IDE03504-IDE04036,Personalized settings-High beam assistant: status,active,
    IDE03504-MAS01597,Personalized settings-Sunroof,active,
    IDE03504-MAS04322,Personalized settings-Masked continuous high beam,not active,
    IDE03504-MAS06456,Personalized settings-Autolock,active,
    IDE03504-MAS06457,Personalized settings-autounlock,active,
    IDE03504-MAS06911,Personalized settings-Status Coming Home,active,
    IDE03504-MAS06912,Personalized settings-Status Leaving Home,active,
    IDE03504-MAS07014,Personalized settings-Tourist light,not active,
    IDE03504-MAS07967,Personalized settings-profile,1,
    IDE03504-MAS07971,Personalized settings-Electrical rear lid,not active,
    IDE03504-MAS07972,Personalized settings-Manual door unlock,all,
    IDE03504-MAS07973,Personalized settings-Rain closure,not active,
    IDE03504-MAS07978,Personalized settings-Mirror adjustment,INDIVIDUAL,
    IDE03504-MAS07980,Personalized settings-Mirror lowering,active,
    IDE03504-MAS07981,Personalized settings-Automatic mirror fold-in,not active,
    IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,active,
    IDE03504-MAS07983,Personalized settings-Virtual pedal,not active,
    IDE03504-MAS07984,Personalized settings-Automatic rear window wiper,active,
    IDE03504-MAS07985,Personalized settings-Coming Home set point,20, s
    IDE03504-MAS07986,Personalized settings-Leaving Home set point,60, s
    IDE03504-MAS07987,Personalized settings-Light intensity,normal,
    IDE03504-MAS07990,Personalized settings-Comfort flasher,active,
    IDE03504-MAS07991,Personalized settings-Comfort flasher set point,3,
    IDE03504-MAS07992,Personalized settings-Sliding beam range,active,
    IDE03504-MAS07993,Personalized settings-Rain light,active,
    IDE03504-ENG29901,Personalized settings-Touristenlicht Einstellwert,not active,
    IDE03638-MAS01737,static AFS light-Diagnosis,normal,
    IDE03638-MAS02248,static AFS light-Signal state,not active,
    IDE03638-MAS03873,static AFS light-Duty cycle,0.0, %
    IDE03638-MAS04351,static AFS light-Connector terminal number,6,
    IDE03638-MAS04352,static AFS light-Connector number,Plug B,
    IDE04213,Central locking button,not coded/not installed,
    IDE04213-IDE07357,Central locking button-Indicator light for central locking,not coded/not installed,
    IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
    IDE04347-IDE00104,Expanded environmental conditions-DTC,08 0E 00,
    IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 01 00 10 00 0C 63 00 00 03 63 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 05 F7 94 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 22 00 06 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 17 00 01 00 00 01 00 4F 64 07 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 04 4F 00 00 10 00 04 4C 07 87 00 20 00 00 40 C1 40 32 E9 0F 00 00 00 1C 05 68 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 03 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 01 01 00 00 00,
    IDE04925-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
    IDE04925-MAS02248,Daytime running lights-Signal state,not active,
    IDE04925-MAS03873,Daytime running lights-Duty cycle,0.0, %
    IDE04925-MAS04351,Daytime running lights-Connector terminal number,0,
    IDE04925-MAS04352,Daytime running lights-Connector number,Plug A,
    IDE05042-IDE05043,Emergency flasher button-Emergency flasher indicator lamp,On,
    IDE05042-MAS02158,Emergency flasher button-Actuation condition,Not operated,
    IDE05042-MAS03873,Emergency flasher button-Duty cycle,32.00, %
    IDE05045-IDE05183,Front windshield wiper module-Malfunction left,no error,
    IDE05045-IDE05184,Front windshield wiper module-Malfunction right,no error,
    IDE05045-MAS01632,Front windshield wiper module-Status,not active,
    IDE05045-MAS02282,Front windshield wiper module-Position,park position,
    IDE05045-MAS03638,Front windshield wiper module-Wipe speed,0, /min
    IDE05045-MAS05057,Front windshield wiper module-Number of wiper cycles,0,
    IDE05045-MAS05878,Front windshield wiper module-Stage,not coded/not installed,
    IDE05323-MAS01737,Fog light-Diagnosis,not coded/not installed,
    IDE05323-MAS02248,Fog light-Signal state,not active,
    IDE05323-MAS03873,Fog light-Duty cycle,0.0, %
    IDE05323-MAS04351,Fog light-Connector terminal number,0,
    IDE05323-MAS04352,Fog light-Connector number,Plug A,
    IDE05434-MAS01737,Rear entry light-Diagnosis,not coded/not installed,
    IDE05434-MAS02248,Rear entry light-Signal state,not active,
    IDE05434-MAS03873,Rear entry light-Duty cycle,0.00, %
    IDE05434-MAS04150,Rear entry light-Side,not_defined,
    IDE05434-MAS04351,Rear entry light-Connector terminal number,0,
    IDE05434-MAS04352,Rear entry light-Connector number,Plug A,
    IDE05533,Spray nozzle heater,active,
    IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
    IDE05719-MAS02339,Window washer system-Windshield washer system,not active,
    IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
    IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
    IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
    IDE05720-IDE04214,Front driver side door status-Key switch in door lock,Not operated,
    IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
    IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
    IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
    IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
    IDE05727-IDE02589,Front passenger side door status-Rotary latch status,closed,
    IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
    IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
    IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: released,
    IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
    IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
    IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
    IDE05730-MAS01737,Luggage compartment light-Diagnosis,not coded/not installed,
    IDE05730-MAS02248,Luggage compartment light-Signal state,not active,
    IDE05730-MAS03873,Luggage compartment light-Duty cycle,0.00, %
    IDE05730-MAS04351,Luggage compartment light-Connector terminal number,0,
    IDE05730-MAS04352,Luggage compartment light-Connector number,Plug A,
    IDE05739-MAS01737,Footwell light-Diagnosis,normal,
    IDE05739-MAS02248,Footwell light-Signal state,not active,
    IDE05739-MAS03873,Footwell light-Duty cycle,0.0, %
    IDE05739-MAS04351,Footwell light-Connector terminal number,72,
    IDE05739-MAS04352,Footwell light-Connector number,Plug C,
    IDE05742-IDE02515,Light switch position-Low beam,not activated,
    IDE05742-IDE05323,Light switch position-Fog light,not activated,
    IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
    IDE05742-MAS00063,Light switch position-OFF,operated,
    IDE05742-MAS02462,Light switch position-Automatic high beam assist,not activated,
    IDE05742-MAS03835,Light switch position-Parking light,not activated,
    IDE05742-MAS03836,Light switch position-Rear fog light,not activated,
    IDE05822-MAS01632,DWA Vehicle inclination sensor-Status,not coded/not installed,
    IDE05822-MAS04508,DWA Vehicle inclination sensor-Alarm detected,not coded/not installed,
    IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
    IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
    IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
    IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
    IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
    IDE05827,Alarm horn for anti-theft warning system,not coded/not installed,
    IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger by DWA Master,
    IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger by DWA Master,
    IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,No alarm,
    IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,No alarm,
    IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,2,
    IDE05829-ENG28562,Rear spoiler history data-Spoiler_Activation_Trigger,NoEntry,
    IDE05829-ENG28563,Rear spoiler history data-Spoiler_Activation_Trigger_Date,335544320,
    IDE05829-ENG28565,Rear spoiler history data-Spoiler_Activation_Trigger_Milage,0, km
    IDE05829-ENG28564,Rear spoiler history data-Spoiler_Activation_Trigger_Time,0,
    IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
    IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
    IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
    IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
    IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
    IDE05833-MAS00106,Anti-theft warning system: history data-Year,2000,
    IDE05833-MAS00107,Anti-theft warning system: history data-Month,0,
    IDE05833-MAS00108,Anti-theft warning system: history data-Day,0,
    IDE05833-MAS00109,Anti-theft warning system: history data-Hours,0,
    IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,0,
    IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,0,
    IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,0, km
    IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,No alarm,
    IDE05834-IDE01718,Driver info-Crash signal,not active,
    IDE05834-MAS00211,Driver info-Insufficient brake fluid,not active,
    IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
    IDE05834-MAS00213,Driver info-Insufficient coolant,not active,
    IDE05834-MAS00214,Driver info-Brake pad wear,not active,
    IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
    IDE05836-MAS03638,Rain recognition sensor-Wipe speed,0,
    IDE05836-MAS04806,Rain recognition sensor-Splash,not active,
    IDE05836-MAS04807,Rain recognition sensor-park position,active,
    IDE05837,Activation for signal horn,not active,
    IDE05838-MAS01794,Light recognition sensor-Freeway,OFF,
    IDE05838-MAS02248,Light recognition sensor-Signal state,active,
    IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
    IDE05838-MAS02851,Light recognition sensor-Brightness,12, lx
    IDE05838-MAS04808,Light recognition sensor-Rain,OFF,
    IDE05838-MAS04809,Light recognition sensor-Darkness,On,
    IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
    IDE05839-MAS01737,Parking light-Diagnosis,normal,
    IDE05839-MAS02248,Parking light-Signal state,active,
    IDE05839-MAS03873,Parking light-Duty cycle,100.0, %
    IDE05839-MAS04351,Parking light-Connector terminal number,2,
    IDE05839-MAS04352,Parking light-Connector number,Plug B,
    IDE05841-MAS06441,Central locking history data-Control-section / cause,Outside door handle sens.: frt. left,
    IDE05841-MAS07519,Central locking history data-Command,Unlocking of entire vehicle,
    IDE05841-MAS07942,Central locking history data-Additional information,KESSY ID sensor 1,
    IDE05841-ENG29969,Central locking history data-command_direction_locking,No_locking,
    IDE05841-ENG29970,Central locking history data-command_direction_unlocking,Door unlock,
    IDE05842-MAS00218,Comfort function history data-Driver door,not active,
    IDE05842-MAS00219,Comfort function history data-Front Passenger Door,not active,
    IDE05842-MAS00220,Comfort function history data-Left rear door,not active,
    IDE05842-MAS00221,Comfort function history data-Right rear door,not active,
    IDE05842-MAS06441,Comfort function history data-Control-section / cause,lock zylinder drver door,
    IDE05842-MAS07560,Comfort function history data-Top,not active,
    IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,not active,
    IDE05842-MAS07941,Comfort function history data-Operating command,Open,
    IDE06012-MAS01737,Search lights-Diagnosis,not coded/not installed,
    IDE06012-MAS02248,Search lights-Signal state,not active,
    IDE06012-MAS03873,Search lights-Duty cycle,0.0, %
    IDE06012-MAS04351,Search lights-Connector terminal number,0,
    IDE06012-MAS04352,Search lights-Connector number,Plug A,
    IDE06012-MAS15156,Search lights-terminal,not_defined,
    IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-20.3, °C
    IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,5.5, °C
    IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,46.5, %
    IDE06091-MAS04647,Humidity sensor: internal-Dew point,-30.9, °C
    IDE06096-IDE03111,Interior lighting-Interior light,0, %
    IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,92.5, %
    IDE06096-IDE05725,Interior lighting-Terminal 58xs dimmer,0.0, %
    IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,95.0, %
    IDE06096-MAS01634,Interior lighting-Supply voltage,100.0, %
    IDE06096-MAS04528,Interior lighting-Instrument panel and switch illumination dimmer switch,0, %
    IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not activated,
    IDE06324-MAS01580,Tank cap lock-Activation,not active,
    IDE06324-MAS06251,Tank cap lock-Contact switch,Open,
    IDE06470-MAS01737,Ambience lighting-Diagnosis,not coded/not installed,
    IDE06470-MAS02248,Ambience lighting-Signal state,not active,
    IDE06470-MAS03873,Ambience lighting-Duty cycle,0.0, %
    IDE06470-MAS04351,Ambience lighting-Connector terminal number,0,
    IDE06470-MAS04352,Ambience lighting-Connector number,Plug A,
    IDE06507-MAS13127,Button in center console-Status of button 1,not activated,
    IDE06507-MAS13128,Button in center console-Indicator lamp button 1,On,
    IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
    IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
    IDE06507-MAS13133,Button in center console-Status of button 3,not activated,
    IDE06507-MAS13134,Button in center console-Indicator lamp button 3,OFF,
    IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
    IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
    IDE06592-MAS05002,Status: special functions-Showroom mode,OFF,
    IDE06592-MAS05003,Status: special functions-Debug functions,OFF,
    IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
    IDE06644-MAS01288,Vehicle positioning system-Signal horn,not coded/not installed,
    IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
    IDE06644-MAS03835,Vehicle positioning system-Parking light,not coded/not installed,
    IDE06695-IDE01459,Energy management: last critical state-Energy management heat output control status,0,
    IDE06695-MAS00107,Energy management: last critical state-Month,0,
    IDE06695-MAS00108,Energy management: last critical state-Day,0,
    IDE06695-MAS06555,Energy management: last critical state-Maximum switch-off priority while driving,0,
    IDE06695-MAS06570,Energy management: last critical state-Number of critical operation cycles,0,
    IDE06695-ENG28924,Energy management: last critical state-Anz_erreichte_Max_Freigaben,0,
    IDE06695-ENG28921,Energy management: last critical state-Anz_krit_Betriebszyklen,0,
    IDE06695-ENG28922,Energy management: last critical state-Bedingung_Tab_NQ,0,
    IDE06695-ENG28920,Energy management: last critical state-min_prio_Tab_K,0,
    IDE06695-ENG28919,Energy management: last critical state-min_prio_Tab_M,0,
    IDE06695-ENG28923,Energy management: last critical state-min_prio_Tab_NQ,0,
    IDE06695-ENG99063,Energy management: last critical state-Year,2000,
    IDE06864-MAS01737,Daytime running lights-Diagnosis,not coded/not installed,
    IDE06864-MAS02248,Daytime running lights-Signal state,not active,
    IDE06864-MAS03873,Daytime running lights-Duty cycle,0.0, %
    IDE06864-MAS04351,Daytime running lights-Connector terminal number,0,
    IDE06864-MAS04352,Daytime running lights-Connector number,Plug A,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,Not Used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE07145-MAS09609,Component protection properties-Status IKA start key,not active,
    IDE07145-MAS09610,Component protection properties-Status GFA Key,valid,
    IDE07145-MAS09611,Component protection properties-Status Master ECU Key,stored,
    IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
    IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,42.80, %
    IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
    IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,801.9, Hz
    IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
    IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
    IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
    IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
    IDE07344-MAS02282,Sunroof shade-Position,126, %
    IDE07344-MAS02447,Sunroof shade-Release,active,
    IDE07344-MAS03656,Sunroof shade-Reverse,not active,
    IDE07344-MAS05563,Sunroof shade-Norming,not normed,
    IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,not activated,
    IDE07345,Sunroof front closed position switch,not activated,
    IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,closed,
    IDE07346,Sunroof shade switches,not activated,
    IDE08125-MAS01458,Left cabin heater-Operating condition,not coded/not installed,
    IDE08125-MAS06651,Left cabin heater-PTC heater element: current consumption,not coded/not installed,
    IDE08125-MAS06652,Left cabin heater-Blower motor: speed,not coded/not installed,
    IDE08125-MAS06653,Left cabin heater-Indicator light for head area heater,not coded/not installed,
    IDE08126-MAS01458,Right cabin heater-Operating condition,not coded/not installed,
    IDE08126-MAS06651,Right cabin heater-PTC heater element: current consumption,not coded/not installed,
    IDE08126-MAS06652,Right cabin heater-Blower motor: speed,not coded/not installed,
    IDE08126-MAS06653,Right cabin heater-Indicator light for head area heater,not coded/not installed,
    IDE08177-MAS06456,Central locking-Autolock,not active,
    IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
    IDE08177-MAS09894,Central locking-Status exterior skin,closed,
    IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
    IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
    IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
    IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
    IDE08177-ENG09185,Central locking-Load_compartment_closing,not coded/not installed,
    IDE08211-MAS00106,History data control module reset-Year,2017,
    IDE08211-MAS00107,History data control module reset-Month,11,
    IDE08211-MAS00108,History data control module reset-Day,9,
    IDE08211-MAS00109,History data control module reset-Hours,0,
    IDE08211-MAS00110,History data control module reset-Minutes,0,
    IDE08211-MAS03129,History data control module reset-Reset counter,7,
    IDE08211-MAS06734,History data control module reset-last cause of reset,Analysis 1,
    IDE08343,Immobilizer Challenge,66 F0 F5 DC,
    IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,0, mA
    IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,0, mA
    IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
    IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
    IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
    IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
    IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
    IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
    IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,1136, mA
    IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,1248, mA
    IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
    IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
    IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,32, mA
    IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,32, mA
    IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,0, mA
    IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,0, mA
    IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,0, mA
    IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,0, mA
    IDE08949-MAS07885,Operating current: light driver-Conn. pin 18,0, mA
    IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,0, mA
    IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,0, mA
    IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,0, mA
    IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,0, mA
    IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
    IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
    IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
    IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,0, mA
    IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,0, mA
    IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,0, mA
    IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,0, mA
    IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
    IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,13, mA
    IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,20, mA
    IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,20, mA
    IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,16, mA
    IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
    IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
    IDE09850-MAS07146,Garage Door Opener Operating Unit-Button 1,not coded/not installed,
    IDE09850-MAS07147,Garage Door Opener Operating Unit-Button 2,not coded/not installed,
    IDE09850-MAS07148,Garage Door Opener Operating Unit-Button 3,not coded/not installed,
    IDE11134-IDE01943,Light sequence HU test result-Turn signal,not installed / not active,
    IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
    IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
    IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
    IDE11134-IDE03310,Light sequence HU test result-Brake light,not installed / not active,
    IDE11134-IDE03638,Light sequence HU test result-static AFS light,not installed / not active,
    IDE11134-IDE05323,Light sequence HU test result-Fog light,not installed / not active,
    IDE11134-IDE05839,Light sequence HU test result-Parking light,not installed / not active,
    IDE11134-IDE06470,Light sequence HU test result-Ambience lighting,not installed / not active,
    IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,not installed / not active,
    IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
    IDE11134-MAS03835,Light sequence HU test result-Parking light,not installed / not active,
    IDE11134-MAS03836,Light sequence HU test result-Rear fog light,not installed / not active,
    IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
    IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
    IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
    IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
    IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
    IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
    IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
    IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
    IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
    IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
    IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
    IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
    IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED not installed,
    IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
    IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
    IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
    IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
    IDE11943-MAS01737,Signature light-Diagnosis,not coded/not installed,
    IDE11943-MAS02248,Signature light-Signal state,not active,
    IDE11943-MAS03873,Signature light-Duty cycle,0.0, %
    IDE11943-MAS04351,Signature light-Connector terminal number,0,
    IDE11943-MAS04352,Signature light-Connector number,Plug A,
    IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
    IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
    IDE12060,Headlight range adjustment counter,00 00 00 00,
    IDE12212,Cause control module incorrectly coded,Not Present,
    IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
    IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
    IDE12940-IDE02711,Lever functions of the steering column electronics-Rear Window Wiper,not coded/not installed,
    IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not_defined,
    IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not_defined,
    IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not_defined,
    IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
    IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
    IDE12940-MAS01288,Lever functions of the steering column electronics-Signal horn,not coded/not installed,
    IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
    IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
    IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
    IDE12940,Lever functions of the steering column electronics,not coded/not installed,
    IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
    IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
    IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
    IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
    IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
    IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
    MAS00043-IDE00019,Supply voltage: Terminal 30-Voltage terminal 30,13.15, V
    MAS00043-IDE05835,Supply voltage: Terminal 30-Supply voltage for central locking,13.15, V
    MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,13.20, V
    MAS00043-IDE05968,Supply voltage: Terminal 30-Voltage terminal 30 right,13.15, V
    MAS00043-IDE08734,Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system,5.00, V
    MAS00043-IDE08735,Supply voltage: Terminal 30-Supply voltage for seat heater,13.15, V
    MAS00043-MAS00362,Supply voltage: Terminal 30-Battery voltage,5.00, V
    MAS00043-MAS07472,Supply voltage: Terminal 30-Battery voltage BEM,13.20, V
    MAS00043-MAS07473,Supply voltage: Terminal 30-Test voltage rear window defogger,0.06, V
    MAS00043-MAS07474,Supply voltage: Terminal 30-Test voltage windshield defogger,0.00, V
    MAS00179-MAS04422,Brake Light Switch-Brake light signal via CAN,OFF,
    MAS00179-MAS07313,Brake Light Switch-Brake light signal via HW,OFF,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
    MAS00464-MAS00107,Standard - ambient data 1-Month,1,
    MAS00464-MAS00108,Standard - ambient data 1-Day,8,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
    MAS00829-MAS00244,Access and start authorization-Awakening wire,operated,
    MAS00829-MAS01763,Access and start authorization-Signal Strength,-46,
    MAS00829-MAS07866,Access and start authorization-Duration: last awakening wire actua.,0, ms
    MAS01281-MAS01737,Back-up light-Diagnosis,normal,
    MAS01281-MAS02248,Back-up light-Signal state,not active,
    MAS01281-MAS03873,Back-up light-Duty cycle,0.0, %
    MAS01281-MAS04351,Back-up light-Connector terminal number,11,
    MAS01281-MAS04352,Back-up light-Connector number,Plug C,
    MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,not activated,
    MAS01431-IDE01839,Vehicle key with remote control-Battery charge condition,Not available,
    MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
    MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
    MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
    MAS01431-MAS06362,Vehicle key with remote control-Code in detection area,Not available,
    MAS01490-IDE02744,Energy management-Steering wheel heater,Enabled,
    MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
    MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
    MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
    MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
    MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
    MAS01490-MAS01632,Energy management-Status,not active,
    MAS01490-MAS02390,Energy management-Shutoff,31,
    MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
    MAS01490-MAS05796,Energy management-Emergency shut-down,0,
    MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
    MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
    MAS01490-MAS06552,Energy management-Seat heater front,Enabling stage 3,
    MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
    MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
    MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,5,
    MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
    MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
    MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
    MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
    MAS01490-MAS06560,Energy management-Short distance drive,0,
    MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
    MAS01597-IDE03114,Sunroof-Comfort function,not active,
    MAS01597-MAS01979,Sunroof-Adapting,Adapted,
    MAS01597-MAS02282,Sunroof-Position,0, %
    MAS01597-MAS02447,Sunroof-Release,active,
    MAS01597-MAS03656,Sunroof-Reverse,not active,
    MAS01597-MAS05563,Sunroof-Norming,normed,
    MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
    MAS03835-MAS01737,Parking light-Diagnosis,normal,
    MAS03835-MAS02248,Parking light-Signal state,active,
    MAS03835-MAS03873,Parking light-Duty cycle,100.0, %
    MAS03835-MAS04351,Parking light-Connector terminal number,39,
    MAS03835-MAS04352,Parking light-Connector number,Plug B,
    MAS03836-MAS01737,Rear fog light-Diagnosis,normal,
    MAS03836-MAS02248,Rear fog light-Signal state,not active,
    MAS03836-MAS03873,Rear fog light-Duty cycle,0.0, %
    MAS03836-MAS04351,Rear fog light-Connector terminal number,60,
    MAS03836-MAS04352,Rear fog light-Connector number,Plug A,
    MAS07959-IDE00787,Remote start history data-Cause for cancellation,Vehicle movement recognized,
    MAS07959-MAS00107,Remote start history data-Month,0,
    MAS07959-MAS00108,Remote start history data-Day,0,
    MAS07959-MAS00109,Remote start history data-Hours,0,
    MAS07959-MAS00110,Remote start history data-Minutes,0,
    MAS07959-MAS07960,Remote start history data-Stop or cancel cause,Remote start function active,
    MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
    MAS08228-MAS02851,Light sensor-Brightness,22860, lx
    MAS08228-MAS04121,Light sensor-Voltage,25.4, V
    MAS13141,Test voltage,0, V
    ENG116910,Control unit internal measured value (supplier),00 00 00 01 1A 00 1A 00 64 00 00 0B 51 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 09 50 B6 00 00 0C 13 00 00 07 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 0A 00 06 00 00 00 00 00 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 05 00 01 00 00 00 00 4F 64 07 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 14 4F 00 00 10 00 04 4C 07 87 00 20 00 00 40 C1 40 32 E9 0F 00 00 00 25 72 6D 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 09 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 00 00 00 00 00,
    ENG117285-ENG115839,Cycle_Protection_Counter-central_locking_cycle_protection_counter,0,
    ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
    ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin C14 Kessy Weckleitung,
    ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
    ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
    ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
    ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
    ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
    ENG116813-ENG28575,Entwicklermesswerte_CONTI-KurzSchlussZaehler,0,
    ENG116909-ENG107391,LIN activity-LIN 1,active,
    ENG116909-ENG107392,LIN activity-LIN 2,active,
    ENG116909-ENG114948,LIN activity-LIN 3,active,
    ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
    ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
    ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
    ENG116793,Monitor 1,00 00 00 00 00 00 00 00,
    ENG116802,Monitor 10,00 00 00 00 00 00 00 00,
    ENG116794,Monitor 2,00 00 00 00 00 00 00 00,
    ENG116795,Monitor 3,00 00 00 00 00 00 00 00,
    ENG116796,Monitor 4,00 00 00 00 00 00 00 00,
    ENG116797,Monitor 5,00 00 00 00 00 00 00 00,
    ENG116798,Monitor 6,00 00 00 00 00 00 00 00,
    ENG116799,Monitor 7,00 00 00 00 00 00 00 00,
    ENG116800,Monitor 8,00 00 00 00 00 00 00 00,
    ENG116801,Monitor 9,00 00 00 00 00 00 00 00,
    ENG128380,Parametermonitor_0,84 14 64 64 AA 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 FA 64 05 C8 1E 00 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 3C 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 02 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 05 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,C8 02 32 00 5A FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 5A 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 1E 0A 0B 0B 01 64 64 03 0A 05 01 0A 46 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116809,Parametermonitor_4,04 04 14 04 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 00 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG116812,Parametermonitor_FF,00 00 05 51 32 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
    ENG126653-MAS00107,Personalized_Account_Key_History-Month,0,
    ENG126653-MAS00108,Personalized_Account_Key_History-Day,0,
    ENG126653-MAS00109,Personalized_Account_Key_History-Hours,0,
    ENG126653-MAS00110,Personalized_Account_Key_History-Minutes,0,
    ENG126653-MAS01551,Personalized_Account_Key_History-Key number,0,
    ENG126653-ENG28771,Personalized_Account_Key_History-Account,0,
    ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
    ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
    ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
    ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
    ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
    ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
    ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
    ENG126654-MAS00107,Personalized_Signals-Month,0,
    ENG126654-MAS00108,Personalized_Signals-Day,0,
    ENG126654-MAS00109,Personalized_Signals-Hours,0,
    ENG126654-MAS00110,Personalized_Signals-Minutes,0,
    ENG126654-ENG30061,Personalized_Signals-Perso_Aktiv,0,
    ENG126654-ENG28925,Personalized_Signals-Perso_Bedienstelle,0,
    ENG126654-ENG28926,Personalized_Signals-Perso_Freigabe_Verstellung,0,
    ENG126654-ENG28772,Personalized_Signals-Perso_Konto,0,
    ENG126654-ENG28775,Personalized_Signals-Perso_Status,0,
    ENG126654-ENG28773,Personalized_Signals-Perso_Steuerung,0,
    ENG126654-ENG28774,Personalized_Signals-Perso_Steuerungs_parameter,0,
    ENG116792-ENG115817,Power up history-Funktionsanforderung,19,
    ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
    ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
    ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
    ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
    ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
    ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
    ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
    ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
    ENG116790-MAS00711,Supply voltage history-Odometer reading,11, km
    ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
    ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,13.1, V
    ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.1, V
    ENG116791,Temperatures,4.50, °C
    ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
    ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
    ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,not activated,
    ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
    ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,4.5, °C
    ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,not activated,
    ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
    ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Parking light,not activated,
    ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,13.1, V
    ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,not activated,
    ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,not activated,
    ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,Pin C14 Kessy Weckleitung,
    ENG116907-ENG09169,Zusaetzliche Umgebungsdaten-LDS 0-Stellung,operated,
    ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
    ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
    Elapsed Time: 00:52
    Neat! This morning while charging with the doors locked, my car alarm triggered. Turns out it was due to "IDE05833-MAS04478,Anti-theft warning system: history data-Cause for alarm activation,OBD_alarm, ", I had an Ultragauge plugged in there that apparently woke up when the Vbatt changed while the big battery was charging:
    ;Thursday,14,December,2017,10:20:21:29905
    Group,Description,Actual
    IDE00030,Status of actuator test,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00973,Outside air temperature,0.50, °C
    IDE01285,Counter of component protection malfunctions,0,
    IDE02857-IDE05533,Activation current-Spray nozzle heater,472, mA
    IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,13.1, V
    IDE03388-MAS02201,Left front heated seat: status-Temperature,4.00, °C
    IDE03389-MAS02201,Right front heated seat: status-Temperature,4.00, °C
    IDE03504-MAS07982,Personalized settings-Activation sound: theft warning system,not active,
    IDE04347-IDE00104,Expanded environmental conditions-DTC,08 87 15,
    IDE04347-IDE07836,Expanded environmental conditions-Log data,00 00 00 01 00 1A 00 1A 64 00 00 0B 51 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 03 FB F2 00 00 0C 13 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0B 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 0C 00 01 00 00 01 00 4E 64 07 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 14 4F 00 00 10 00 04 4C 07 87 00 20 00 00 00 00 00 00 00 00 00 00 00 2A 98 F1 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 00 00 00 00 00,
    IDE05042-MAS03873,Emergency flasher button-Duty cycle,34.50, %
    IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,Alarm trigger by DWA Master,
    IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,Alarm trigger by DWA Master,
    IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,61,
    IDE05833-MAS00106,Anti-theft warning system: history data-Year,2017,
    IDE05833-MAS00107,Anti-theft warning system: history data-Month,12,
    IDE05833-MAS00108,Anti-theft warning system: history data-Day,14,
    IDE05833-MAS00109,Anti-theft warning system: history data-Hours,8,
    IDE05833-MAS00110,Anti-theft warning system: history data-Minutes,58,
    IDE05833-MAS00111,Anti-theft warning system: history data-Seconds,7,
    IDE05833-MAS00711,Anti-theft warning system: history data-Odometer reading,203, km
    IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
    IDE05838-MAS02475,Light recognition sensor-Brightness infrared,4000, lx
    IDE05838-MAS02851,Light recognition sensor-Brightness,1722, lx
    IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
    IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
    IDE05841-MAS06441,Central locking history data-Control-section / cause,Remote control,
    IDE05841-MAS07942,Central locking history data-Additional information,Rem. ctrl. no. 1,
    IDE05842-MAS00219,Comfort function history data-Front Passenger Door,active,
    IDE05842-MAS00221,Comfort function history data-Right rear door,active,
    IDE05842-MAS06441,Comfort function history data-Control-section / cause,radio remote control number_1,
    IDE05842-MAS07561,Comfort function history data-Sun roof/tilt roof,active,
    IDE06091-IDE01440,Humidity sensor: internal-Windshield temperature,-23.2, °C
    IDE06091-MAS04629,Humidity sensor: internal-Sensor temperature,2.5, °C
    IDE06091-MAS04630,Humidity sensor: internal-Relative humidity,57.0, %
    IDE06091-MAS04647,Humidity sensor: internal-Dew point,-30.8, °C
    IDE06096-IDE05724,Interior lighting-Terminal 58xt dimmer,100.0, %
    IDE06096-IDE05726,Interior lighting-Terminal 58xd dimmer,96.0, %
    IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,46.40, %
    IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,803.8, Hz
    IDE08343,Immobilizer Challenge,2E 9D 87 41,
    IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,1120, mA
    IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,1232, mA
    IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,22, mA
    IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,21, mA
    IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,21, mA
    MAS00043-IDE05967,Supply voltage: Terminal 30-Voltage terminal 30 left,13.15, V
    MAS00464-MAS00108,Standard - ambient data 1-Day,14,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,56,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,18,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,203, km
    MAS00829-MAS01763,Access and start authorization-Signal Strength,-69,
    MAS01490-MAS02390,Energy management-Shutoff,46,
    ENG116910,Control unit internal measured value (supplier),00 00 00 01 0D 00 1A 00 64 00 00 0B 51 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 00 04 C0 7A 00 00 0C 13 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 C6 00 01 00 00 00 00 4F 64 07 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 81 14 4F 00 00 10 00 04 4C 07 87 00 00 00 00 40 C1 40 32 E9 0F 00 00 00 2C E6 B1 00 3B 00 00 00 00 00 00 00 00 00 00 09 00 03 01 00 00 00 00 02 00 00 00 00 00 00 00 00 8F 03 00 00 00 00 00,
    ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
    ENG116792-ENG115817,Power up history-Funktionsanforderung,10,
    ENG116791,Temperatures,0.50, °C
    ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside air temperature,0.5, °C
    ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,gueltiges Funktelegramm,
    Elapsed Time: 00:52
    I'm doing some tests now using a HEX-NET in low power mode to see if it gets triggered. Apparently this is a problem with other cars/devices.
  10. Likes Uwe, Eric liked this post
  11. #58
    Administrator Andy's Avatar
    09 map after SA 31347
    ;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect. --- SA: 31347
    ;Component:BCM MQBAB MNA H36 0253, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BCMMQB,018001,EV_BCMBOSCH_018.rod
    ;Friday,29,December,2017,15:27:54:56403
    ;VCDS Version: Beta 17.12.0 (x64)  Data version: 20171213 DS285.1
    ;VCID: 064046C0B9FB7E1AF5F-8052
    IDE01550-Service position,133.197670 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active ,8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,OFF ,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °,16
    IDE03638-ENG116676-static AFS light-Upper speed threshold,32.0 km/h,16
    IDE03638-ENG116674-static AFS light-Vorschrift,OFF ,16
    IDE03787-Activate left/right hand drive switch-over,No_Menue ,1
    IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
    IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
    IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,installed ,8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),Yes ,8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,1 Alarm ,8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
    IDE05144-Read parameter address,00 00 00 ,3
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,28.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,27.50 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,41.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,40.50 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,63.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,62.50 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED not installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remotestart,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,21.197781 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,not active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,2 ,19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.00 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,0 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,0 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,0 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,0 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,0 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,0 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,active ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,not installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
    IDE10298-Alternating park position 1,18.197784 °,2
    IDE10299-Alternating park position 2,21.197781 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,1.00 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
    MAS05055-lower turn position,26.197776 °,2
    MAS05056-upper turn position,166.197637 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,1000 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,0.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,0.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,0.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,0.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,0.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,0.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,0.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,0.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,0.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,0.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,0.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,0.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,0.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,0.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,0.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,NOT-DEFINED ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,NOT-DEFINED ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,NOT-DEFINED ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,NOT-DEFINED ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,NOT-DEFINED ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,NOT-DEFINED ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,NOT-DEFINED ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,NOT-DEFINED ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,NOT-DEFINED ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,NOT-DEFINED ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,NOT-DEFINED ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,NOT-DEFINED ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,NOT-DEFINED ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,NOT-DEFINED ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,NOT-DEFINED ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,60 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,bewusste Aktivierung Fahrer Dauerhaft ,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x1 Stunden ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Keine_Spannungsanforderung ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,6400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,separate ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Keine_Spannungsanforderung ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,8 s,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
    ENG122934-erase_error_table,55 00 00 ,3
    ENG122933-error_mask,0 bit,2
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141685-Front_wash_function,10 ,2
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,500 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,not active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,2000 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG117394-Head area heater-blower_speed,0 ,2
    ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,not active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,89.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,83.0 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,75.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,68.0 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,61.0 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,56.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,47.0 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,40.0 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,33.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,127 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,5D ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,36 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,6 - LED Lichtmodul ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Coming Home oder Leaving Home aktiv ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,127 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,5E ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,40 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,6 - LED Lichtmodul ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Coming Home oder Leaving Home aktiv ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,85 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,35 ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,0A ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Coming Home oder Leaving Home aktiv ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,85 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,36 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,1A ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Coming Home oder Leaving Home aktiv ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,minimize ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,3F ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Brake light ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,Blinken links aktiv (beide Phasen) ,16
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,Blinken links Dunkelphase ,16
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,minimize ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,40 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Brake light ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,Blinken rechts aktiv (beide Phasen) ,16
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,Blinken rechts Dunkelphase ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,04 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,46 - LED Kleinleistung ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Ambientelicht 2 ,16
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,minimize ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,0 ,16
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,127 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,127 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,not active ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Blinken links Hellphase ,16
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,Blinken links Dunkelphase ,16
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,minimize ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,0 ,16
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,127 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,127 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,not active ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,Blinken rechts Dunkelphase ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,80 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,50 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,80 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,50 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv ,16
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,beidseitiges Dauerparklicht ,16
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,minimize ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,37 - allgemeine LED bis 12W ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,Left high beam ,16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,37 - allgemeine LED bis 12W ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Right high beam ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,61 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,36 - LED Kleinleistung ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1 ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,62 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,36 - LED Kleinleistung ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,6 - LED Lichtmodul ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,6 - LED Lichtmodul ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 1E 50 09 00 32 00 00 00 00 00 00 2B 1A 00 2A 08 1E 50 0A 00 32 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,2B 0A 00 35 08 1E 55 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 1E 55 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2650 mm,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,84.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,20.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,4.10 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,4.70 mm/%,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,4.50 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.30 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.30 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.30 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_2 ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,70.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.10 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,10 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,10 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,10 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,10 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,550 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,680 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,5.0 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,5 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,10.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,not active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,60.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,5.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,20.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.55 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-1.10 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-2.40 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-2.80 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,0.30 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,0.20 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.80 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-4.60 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.20 ,20
    ENG122979-ENG141954-Networking-A/C electronics,installed ,8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Networking-Head area heater,not installed ,8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Networking-UGDO,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,not active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
    ENG124714-OCU-,not installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,0 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,0 Hz,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,0 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,0 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,not active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,Audi ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG122927-RLS_close_glazing,2.5 s,1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
    ENG122929-RLS_LIN_Communication,4 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,100 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,200 lx,1
    ENG122930-RLS_tunel_gateway_recognize,5 s,1
    ENG122935-RLS_Washer_Front,15 s,1
    ENG122926-RLS_wiper_position_parking,15 s,1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,1000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,1000 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,1000 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Sollspannungsanforderung 13.5 ,10
    ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor,Not available ,6
    ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor,Not available ,6
    ENG141684-SFT271875-Slave_systems_identification-Light switch,Not available ,6
    ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module,Not available ,6
    ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit,Not available ,6
    ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System,Not available ,6
    ENG141684-SFT271896-Slave_systems_identification-Alarm horn,Not available ,6
    ENG141684-SFT271904-Slave_systems_identification-Sun Roof,Not available ,6
    ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module,Not available ,6
    ENG141684-SFT271928-Slave_systems_identification-Roof Blind,Not available ,6
    ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender,Not available ,6
    ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left,Not available ,6
    ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right,Not available ,6
    ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left,Not available ,6
    ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left,Not available ,6
    ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right,Not available ,6
    ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right,Not available ,6
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,SMLS ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,10.0 min,10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,100 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,150 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,nur wenn freigegeben ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
    ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba,not active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,42 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,62 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,not active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,not active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
    Elapsed Time: 01:41
  12. Likes Eric liked this post
  13. #59
    Quote Originally Posted by Andy View Post
    I'm doing some tests now using a HEX-NET in low power mode to see if it gets triggered.
    I think it will depend on how you set up the HEX-NET. If you have it wake/sleep strictly based on Vign, I bet it will be just fine. But if you have it set to wake based on Vbatt, then I could see where there might be issues like that. Since Vign on pin 1 is a VAG-specific thing, we can do that, but I bet the generic OBD-II devices do their wake/sleep based strictly on Vbatt..
  14. Likes PetrolDave, Eric, Andy liked this post
