Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: 2018 Audi A3 e-tron
    Administrator Andy's Avatar
    10 - Park/Steer Assist maps
    ;SW:5QA-919-294-B   HW:5QA-919-294 ---  Park/Steer Assist
    ;Component:PDC 8 KanalH07 0044, Coding:0470155811
    ;EV_EPHVA18AU3700000,009035,EV_EPHVA18AU3700000_009_AU37.rod
    ;Friday,08,December,2017,16:10:54:29905
    ;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
    ;VCID: 4BD9E467E2B1C17263D-801E
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
    IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
    IDE00845-Wheel circ.,1950 mm,2
    IDE01165-Park assist activation tone,On ,1
    IDE01167-Convertible offset for volume level 1,255 ,1
    IDE01168-Increment for convertible volume levels,255 ,1
    IDE01169-Audio reduction request,On ,1
    IDE02328-Distance to curb,15 cm,1
    IDE03782-Switch-off speed for parking assist,10 km/h,1
    IDE05274-Acoustic warning for rear lid assistant,not active ,1
    IDE11215-Automatic Activation,activated ,1
    MAS01426-Speaker volume for rear park assist,Stage 6 ,1
    MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
    MAS01428-Speaker volume for front park assist,Stage 4 ,1
    MAS01429-Speaker frequency for front park assist,Stage 6 ,1
    MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.159 1/m,6
    MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,1.308 1/m,6
    MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,0.807 m,6
    MAS12129-Customer-oriented off-road trip,not activated ,1
    Elapsed Time: 00:09
    ;Friday,08,December,2017,16:10:41:29905
    Group,Description,Actual
    IDE00018,Voltage terminal 15,12.8, V
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0.00, km/h
    IDE00322,Status of basic setting,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00325,Diagnostic mode,VW - diagnostic mode,
    IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
    IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
    IDE00973,Outside air temperature,5.00,
    IDE00974,Outside air temperature internally calculated,5.00,
    IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
    IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
    IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
    IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
    IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
    IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
    IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
    IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
    IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
    IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
    IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,ERROR,
    IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,ERROR,
    IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,ERROR,
    IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,ERROR,
    IDE01135-MAS01632,Decay time for left front park assist sensor-Status,ERROR,
    IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,ERROR,
    IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,ERROR,
    IDE01138-MAS01632,Decay time for right front park assist sensors-Status,ERROR,
    IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Speaker volume for rear park assist,Stage 4,
    IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 6,
    IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Speaker volume for front park assist,Stage 4,
    IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 4,
    IDE01163,Sound output for park assist in selector lever position P,OFF,
    IDE01164,Park assist button,not activated,
    IDE01165,Park assist activation tone,On,
    IDE01166,Supply voltage for park assist sensor,12.8, V
    IDE01167,Convertible offset for volume level 1,not installed,
    IDE01168,Increment for convertible volume levels,not installed,
    IDE01169,Audio reduction request,Yes,
    IDE01171,Convertible factory setting offset for volume level 1,not installed,
    IDE01172,Factory setting for increment for convertible volume levels,not installed,
    IDE01173,Audio reduction factory setting,No,
    IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
    IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,activated,
    IDE01411-MAS01426,Personalization 1 for park assist-Speaker volume for rear park assist,Stage 6,
    IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
    IDE01411-MAS01428,Personalization 1 for park assist-Speaker volume for front park assist,Stage 4,
    IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
    IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
    IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
    IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
    IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
    IDE01412-MAS01426,Personalization 2 for park assist-Speaker volume for rear park assist,Stage 4,
    IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 6,
    IDE01412-MAS01428,Personalization 2 for park assist-Speaker volume for front park assist,Stage 4,
    IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 4,
    IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
    IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,not activated,
    IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
    IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
    IDE01413-MAS01426,Personalization 3 for park assist-Speaker volume for rear park assist,Stage 4,
    IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 6,
    IDE01413-MAS01428,Personalization 3 for park assist-Speaker volume for front park assist,Stage 4,
    IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 4,
    IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
    IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,not activated,
    IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
    IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
    IDE01414-MAS01426,Personalization 4 for park assist-Speaker volume for rear park assist,Stage 4,
    IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 6,
    IDE01414-MAS01428,Personalization 4 for park assist-Speaker volume for front park assist,Stage 4,
    IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 4,
    IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
    IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,not activated,
    IDE01588,Driving direction,forwards,
    IDE01632,System condition of park assist,not active,
    IDE01633,Cause of park assist switching off,No shut-off requirement,
    IDE01943,Turn signal,not activated,
    IDE02486,Data logger triggering,not active,
    IDE03782,Switch-off speed for parking assist,10, km/h
    IDE03784,Temporary function limitation due to environmental influences,No,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
    MAS00464-MAS00107,Standard - ambient data 1-Month,1,
    MAS00464-MAS00108,Standard - ambient data 1-Day,8,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,1,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,78, km
    MAS01426,Speaker volume for rear park assist,Stage 6,
    MAS01427,Speaker frequency for rear park assist,Stage 4,
    MAS01428,Speaker volume for front park assist,Stage 4,
    MAS01429,Speaker frequency for front park assist,Stage 6,
    MAS10122,ARA operating condition,Initializing,
    MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
    ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,0, %
    Elapsed Time: 00:13
  2. Likes Uwe liked this post
  3. #12
    13 - Auto Dist. Reg maps
    ;SW:5Q0-907-572-G   HW:5Q0-907-572-G ---  Auto Dist. Reg
    ;Component:ACC BOSCH MQB H10 0571, Coding:D50087C119FFC428949C8055000026
    ;EV_ACCBOSCHVW416,001005,EV_ACCBOSCHVW416_001_VW37.rod
    ;Friday,08,December,2017,16:11:20:29905
    ;VCID: 3B39B4A7B21171F2D3D-806E
    IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
    IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
    IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
    IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
    IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
    IDE01795-Heated lens,On ,1
    IDE01949-Distance basic setting option,OFF ,1
    IDE03642-Presentation mode,not active ,1
    IDE04330-Transfer of release code for a SWaP function,00 ,1
    IDE05815-Sail function,Deactivating ,1
    IDE08935-Expanded restart function,OFF ,1
    IDE09564-Distance change via speed adjustment,OFF ,1
    IDE09565-Prioritized target object display,OFF ,1
    IDE10280-Constant delay after transfer request,Yes ,1
    Elapsed Time: 00:05
    ;Friday,08,December,2017,16:11:07:29905
    IDE00002,Transport mode,OFF,
    IDE00018,Voltage terminal 15,13.0, V
    IDE00102,Control Module temperature,17, C
    IDE00322,Status of basic setting,was not yet started,
    IDE01285,Counter of component protection malfunctions,00 00,
    IDE01788,Heated lens control signal,0.00, %
    IDE01794,ACC operating lever signal,00000000 01001000 ,
    IDE01985-MAS06854,FAZIT identification test sum-Version,81,
    IDE01985-MAS06855,FAZIT identification test sum-Test sum,72 A5 7A 7B,
    IDE03008-MAS12557,Stop process prevented-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,not active,
    IDE03008-MAS12559,Stop process prevented-Driving ahead Vehicles start moving: ACC passive,not active,
    IDE03008-MAS12560,Stop process prevented-Driving ahead Vehicles are starting: ACC off,not active,
    IDE03010-MAS12557,Number of prevented stop processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
    IDE03010-MAS12559,Number of prevented stop processes-Driving ahead Vehicles start moving: ACC passive,0,
    IDE03010-MAS12560,Number of prevented stop processes-Driving ahead Vehicles are starting: ACC off,0,
    IDE03011-MAS12557,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting blocked,0,
    IDE03011-MAS12558,Number of requested start processes-Driving ahead Veh start mov.: ACC act.:autom. Starting possible,0,
    IDE03011-MAS12559,Number of requested start processes-Driving ahead Vehicles start moving: ACC passive,0,
    IDE03011-MAS12560,Number of requested start processes-Driving ahead Vehicles are starting: ACC off,0,
    IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
    IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
    IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
    IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 31 00,
    IDE04329-MAS01340,Status of all SWaP functions-Functions,Available,
    IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
    IDE04329-MAS02934,Status of all SWaP functions-Prerequisites met,Condition not met,
    IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
    IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
    IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
    IDE04334-MAS02643,Public key for SWaP function-Key,C9 37 8A 27 80 D8 2C 8D 73 BC DC 20 E7 9C 7C D0 9F 3A 9E EE 13 AB 53 8E 4B E5 96 5C 6B C2 9E CC 51 13 00 E5 1A 81 6F 28 6B 3D 28 B8 9B D9 80 37 13 BB 54 73 69 96 5B 5F D2 C8 3A 8E F0 69 43 40 DE 8E B4 F4 B1 6A A1 C3 06 F3 BC F8 5E 8B D2 E1 04 7E 13 4A 72 CF 2C 3B 52 8E 85 73 72 45 4A 66 7A 01 9A D2 C6 E1 DD 6E BD C7 AF 95 04 BB BA C2 E5 47 D4 58 9C 8C 57 D9 99 B2 E2 AC B3 81 23 6F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
    IDE04805-IDE02955,Driving profile selection-System status,Not available,
    IDE04805-MAS01447,Driving profile selection-Act.val.,1,
    IDE04805-MAS01448,Driving profile selection-Specified value,1,
    IDE05814,Individualization characteristic,71 FC FC 7C DD,
    IDE06307-MAS00106,Stop prevention history data-Year,2000,
    IDE06307-MAS00107,Stop prevention history data-Month,0,
    IDE06307-MAS00108,Stop prevention history data-Day,0,
    IDE06307-MAS00109,Stop prevention history data-Hours,0,
    IDE06307-MAS00110,Stop prevention history data-Minutes,0,
    IDE06307-MAS00111,Stop prevention history data-Seconds,0,
    IDE06307,Stop prevention history data,not active,
    IDE06308-MAS00106,Start request history data-Year,2000,
    IDE06308-MAS00107,Start request history data-Month,0,
    IDE06308-MAS00108,Start request history data-Day,0,
    IDE06308-MAS00109,Start request history data-Hours,0,
    IDE06308-MAS00110,Start request history data-Minutes,0,
    IDE06308-MAS00111,Start request history data-Seconds,0,
    IDE06308,Start request history data,not active,
    IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
    IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
    IDE07145-MAS06772,Component protection properties-Component protection generation,02,
    IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,02,
    IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
    IDE07145-MAS06775,Component protection properties-KS Standard software correct number,01,
    IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Slave,
    IDE07145-MAS06781,Component protection properties-Secure Hardware Extension,Not Used,
    IDE07145-MAS06782,Component protection properties-Master ECU Key,not administered by component protection,
    IDE07145-MAS06785,Component protection properties-GFA key,used,
    IDE07145-MAS06786,Component protection properties-SSW RND Generation,Not Used,
    IDE07145-MAS06787,Component protection properties-Indiv Key Generation,used,
    IDE07145-MAS06788,Component protection properties-SHE Secure Boot,Not Used,
    IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
    IDE07145-MAS07187,Component protection properties-KS Data version,01,
    IDE08768,Mirror deviation: horizontal,0.089,
    IDE08769,Mirror deviation: vertical,-0.593,
    IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
    IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
    IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
    IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
    IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
    IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
    IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
    IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
    IDE08936,Misalignment angle: horiz,0.147,
    IDE08937,Misalignment angle: horiz: fast algorithm,0.287,
    IDE09380-IDE01784,Performed adjustment-Misalignment angle,-0.11,
    IDE09380-MAS00106,Performed adjustment-Year,17,
    IDE09380-MAS00107,Performed adjustment-Month,11,
    IDE09380-MAS00108,Performed adjustment-Day,10,
    IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.08,
    IDE09380-MAS08805,Performed adjustment-Vertical offset angle,2.10,
    IDE09906,Vertical deadjustment,2.068,
    ENG107409,Longitudinal_acceleration_vehicle_reference,0.00, m/s
    ENG107860,Number_of_ANB_partial_bracings,0,
    ENG107861,Number_of_ANB_target_bracings,0,
    ENG107862,Number_of_ANB-CM,0,
    ENG00926,Number_of_boost_function_active,0,
    ENG00927,Number_of_deactivation_ASR_active,0,
    ENG00928,Number_of_deactivation_ESC_active,0,
    ENG00913,Number_of_Emergency_steer_assist,0,
    ENG00915,Number_of_fully_developed_deceleration_1,0,
    ENG00916,Number_of_fully_developed_deceleration_2,0,
    ENG06681,Number_of_mainwarnings,0,
    ENG03998,number_of_prewarnings,0,
    ENG00914,Number_of_Turn_off_assistant_intervention,0,
    ENG107928,Operating_time_ACC,5, min
    ENG00919,Operating_time_ACC_active_driving_programm_auto,0, min
    ENG00918,Operating_time_ACC_active_driving_programm_comfort,5, min
    ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
    ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
    ENG00921,Operating_time_ACC_active_timegap_1,4, min
    ENG00922,Operating_time_ACC_active_timegap_2,0, min
    ENG00923,Operating_time_ACC_active_timegap_3,0, min
    ENG00924,Operating_time_ACC_active_timegap_4,0, min
    ENG00925,Operating_time_ACC_active_timegap_5,0, min
    ENG00929,Operating_time_ACC_active_v-delta_0,5, min
    ENG00932,Operating_time_ACC_active_v-delta_large,0, min
    ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
    ENG00930,Operating_time_ACC_active_v-delta_small,0, min
    ENG00933,Operating_time_STA_active,0, min
    ENG00934,Operating_time_STA_off_activation_possible,0, min
    ENG00935,Status_ACC_System,ACC_Off_MainSwitch_Off,
    ENG08760,Sw_version_supplier,1037603449;PF_R28.3.0_VW.MQB_A1_GPevo14.0571_I3.3;0;Compiled by BBT2BP on Thu Apr  7 17:50:31 2016$!,
    ENG109878,Velocity_vehicle_reference,0.00, m/s
    Elapsed Time: 00:13
  4. Likes Uwe liked this post
  5. #13
    15 - Airbags maps
    ;SW:5Q0-959-655-J   HW:5Q0-959-655-J ---  Airbags
    ;Component:AirbagVW20    010 0830, Coding:9DFCFCC0002000009000001AC24800000065
    ;EV_AirbaVW20SMEVW37X,002144,EV_AirbaVW20SMEVW37X_VW37.rod
    ;Friday,08,December,2017,16:11:44:29905
    ;VCID: 47D1D857FED92512475-8012
    IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 DF ,18
    IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,activated ,4
    IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,activated ,4
    IDE06527-MAS00478-Adaptation pre-crash-Reserved,2 ,4
    MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
    MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,activated ,8
    MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
    MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
    MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
    MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
    MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,activated ,8
    MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,activated ,8
    MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
    MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
    MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
    MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,activated ,8
    MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
    MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
    MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated ,8
    MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
    MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
    MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,not defined ,8
    MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
    MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
    MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
    Elapsed Time: 00:02
    ;Friday,08,December,2017,16:11:33:29905
    IDE00821,Safety belt switch 2nd row driver side,not installed,
    IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
    IDE00823,Safety belt switch 2nd row center,not installed,
    IDE00824,Driver side 3rd row seat belt switch,not installed,
    IDE00825,Passenger side 3rd row seat belt switch,not installed,
    IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
    IDE00956,Occupation status: frt.passenger seat,Adult,
    IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
    IDE01101,Passenger side airbag igniter 2 ohm value,2.2, Ohm
    IDE01102,Driver's side airbag igniter ohm value,2.5, Ohm
    IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
    IDE01104,driver side rear airbag igniter ohm value,2.5, Ohm
    IDE01105,Ft. pass.side rear airbag igniter ohm value,2.5, Ohm
    IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
    IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
    IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
    IDE01109,Frt.pass. side knee airbag igniter ohm value,2.1, Ohm
    IDE01110,Driver side belt tensioner igniter ohm value,2.4, Ohm
    IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.4, Ohm
    IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
    IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
    IDE01114,Driver side belt force limiter igniter ohm value,2.4, Ohm
    IDE01115,side belt force limiter igniter ohm value,2.3, Ohm
    IDE01116,driver side rear belt tensioner igniter ohm value,2.4, Ohm
    IDE01117,Passenger side rear belt tensioner igniter ohm value,2.4, Ohm
    IDE01119,Battery open circuit igniter ohm value,no measured value present,
    IDE01193,Driver belt tensioner ohm value,400.0, Ohm
    IDE01194,Frt.pass. belt tensioner ohm value,too Low,
    IDE01195,Sitzbelegungserkennung Beifahrerseite Ohm-Wert,no measured value present,
    IDE01197,Key switch contact 1 ohm value,too High,
    IDE01198,Key switch contact 2 ohm value,too High,
    IDE01200,Driver seat position sensor current value,5.9, mA
    IDE01201,Frt.pass. seat position sensor current value,5.6, mA
    IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
    IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
    IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
    IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
    IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
    IDE01271,Number of rollover bar deployments,0,
    IDE01285,Counter of component protection malfunctions,0,
    IDE01555,Number of frontal crashes,0,
    IDE01556,Number of side crashes driver side,0,
    IDE01557,Number of side crashes frt.pass. side,0,
    IDE01558,Number of rear crashes,0,
    IDE01559,Number of rollover crashes,0,
    IDE02246,Number of activations of pedestrian protection,0,
    IDE02852,Igniter for battery interrupt: high voltage battery,correct,
    IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,3.1, Ohm
    IDE03870,Seat occupied recognition malfunction status,00,
    IDE03870,Seat occupied recognition malfunction status,0,
    IDE04805-IDE02955,Driving profile selection-System status,Available,
    IDE04805-IDE06419,Driving profile selection-Driving profile switchover,performed,
    IDE04805-MAS01447,Driving profile selection-Act.val.,2,
    IDE04805-MAS01448,Driving profile selection-Specified value,2,
    IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
    IDE06109,Right belt tensioner terminal 15,13.0, V
    IDE06110,Right belt tensioner supply voltage,correct,
    IDE06118,Right belt tensioner current consumption,no measured value present,
    IDE06119,Left belt tensioner tensioning cycles charac. curve 1,0,
    IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
    IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
    IDE06124,Right belt tensioner tensioning cycles charac. curve 2,0,
    IDE06127,Left belt tensioner terminal 15,13.1, V
    IDE06128,Left belt tensioner temperature,12.5, C
    IDE06129,Right belt tensioner temperature,11.5, C
    IDE06130,Left belt tensioner supply voltage,correct,
    IDE06131,Left belt tensioner current consumption,no measured value present,
    IDE06959,Seat occupant detection: diagnosis signal,1.0, %
    IDE06960,Seat occupant detection: msmt. signal,14.5, %
    IDE06961,Seat occupant detection: ref. signal,15.5, %
    MAS00001,Driver airbag igniter,correct,
    MAS00003,Passenger airbag igniter,correct,
    MAS00004,Front passenger airbag igniter 2,correct,
    MAS00005,Driver thorax airbag igniter,correct,
    MAS00006,Front passenger side airbag igniter,correct,
    MAS00007,Driver side rear thorax airbag igniter,correct,
    MAS00008,Passenger side rear thorax airbag igniter,correct,
    MAS00009,Driver head curtain airbag igniter,correct,
    MAS00010,Front passenger head curtain airbag igniter,correct,
    MAS00011,Driver knee airbag igniter,correct,
    MAS00012,Front passenger knee airbag igniter,correct,
    MAS00013,Driver side seat belt tension igniter,correct,
    MAS00014,Front passenger side seat belt tension igniter,correct,
    MAS00015,Driver seat belt tensioner igniter 2,correct,
    MAS00016,Front passenger side seat belt tensioner igniter 2,correct,
    MAS00017,Driver side belt force limiter igniter,correct,
    MAS00018,Front passenger side belt force limiter igniter,correct,
    MAS00019,Driver side rear safety belt tension igniter,correct,
    MAS00020,Passenger side rear safety belt tension igniter,correct,
    MAS00022,Igniter for battery interrupt,not installed,
    MAS00025,Driver seat belt switch,not connected,
    MAS00026,Front passenger side safety belt switch,not connected,
    MAS00030,Seat occupied recognition,assigned,
    MAS00031,Airbag deactivation status,On,
    MAS00032,Key switch terminal 1,not installed,
    MAS00033,Key switch terminal 2,not installed,
    MAS00035,Seat position sensor: driver side,Rear,
    MAS00036,Seat position sensor: front passenger side,Rear,
    MAS00037,Calibration status,0,
    MAS00044,Supply voltage: Terminal 15,13.1, V
    MAS01634,Supply voltage,correct,
    Elapsed Time: 00:11
  6. Likes Uwe liked this post
  7. #14
    16 - Steering wheel maps
    ;SW:8V0-953-521-KF   HW:5Q0-953-549-E ---  Steering wheel
    ;Component:Lenks. Modul  003 0140, Coding:6C18
    ;EV_SMLSKLOMQB,020002,EV_SMLSKLOMQB_020_AU37.rod
    ;Friday,08,December,2017,16:11:54:29905
    ;VCID: 08531B6BB347EA6A8EF-805C
    ENG126411-p_k_i,0.040 %/s,1
    ENG126415-p_k_i_offset,4 K,1
    ENG126410-p_k_p,13.0 %,1
    ENG126419-p_leistung_lrh,110 W,1
    ENG126417-p_n_fehler_p_verriegelt,250 ,1
    ENG120504-p_s_NWDF_spg,00000000  ,1
    ENG102189-p_t_blinker_entprellen,40 ms,1
    ENG102332-p_t_blinker_err_el_kurzschluss,200 ms,1
    ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms,1
    ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms,1
    ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s,1
    ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms,1
    ENG100988-p_t_blinker_err_gra_haengt_ein,300 s,1
    ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms,1
    ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s,1
    ENG100923-p_t_blinker_err_unplausibel,200 ms,1
    ENG103471-p_t_blinker_gra_entprellen,40 ms,1
    ENG101294-p_t_blinker_sperrzeit,100 ms,1
    ENG127114-p_t_entprellung_p_unplausibel,400 ms,1
    ENG104033-p_t_entprellzeit_ueberspannung,90000 ms,1
    ENG101392-p_t_entprellzeit_unterspannung,90000 ms,1
    ENG102689-p_t_fas_entprellen,40 ms,1
    ENG120505-p_t_gra_ea_error,200 ms,1
    ENG101014-p_t_grahebel_entprellen,40 ms,1
    ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms,1
    ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms,1
    ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms,1
    ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s,1
    ENG103536-p_t_grahebel_err_unplausibel,200 ms,1
    ENG126416-p_t_grenze_v,10 km/h,1
    ENG99436-p_t_hupe_entprellen,40 ms,1
    ENG102496-p_t_hupe_err_hinweis,2000 ms,1
    ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms,1
    ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s,1
    ENG101702-p_t_hupe_indien_entprellen,500 ms,1
    ENG126421-p_t_lrh_kurzschluss_entprellen,200 ms,1
    ENG126422-p_t_lrh_unterbrechung_entprellen,1000 ms,1
    ENG103999-p_t_p_verriegelt_entprellen,40 ms,1
    ENG126412-p_t_soll_0,39 C,1
    ENG126413-p_t_soll_1,43 C,1
    ENG126414-p_t_soll_2,47 C,1
    ENG100796-p_t_spannung_obere_schwelle,16.7 V,1
    ENG102338-p_t_spannung_untere_schwelle,8.5 V,1
    ENG100559-p_t_wischer_entprellen,40 ms,1
    ENG103039-p_t_wischer_err_el_kurzschluss,200 ms,1
    ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms,1
    ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms,1
    ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s,1
    ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms,1
    ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s,1
    ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms,1
    ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s,1
    ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms,1
    ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s,1
    ENG101592-p_t_wischer_intervall_entprellen,40 ms,1
    ENG103607-p_t_wischer_winterstellung,60 s,1
    ENG126423-p_temp_lenkradheizung_aus,50 C,1
    ENG126420-p_zeit_temperatur_statisch_lrh,300 s,1
    Elapsed Time: 00:26
    ;Friday,08,December,2017,16:11:51:29905
    IDE00030-ENG99298,Status of actuator test-State,not active,
    IDE00329-MAS00232,Buttons for multi-function display-MFI button UP,not coded/not installed,
    IDE00329-MAS00233,Buttons for multi-function display-MFI button DOWN,not coded/not installed,
    IDE00329-MAS00234,Buttons for multi-function display-MFI button RESET / OK,not coded/not installed,
    IDE00329-MAS00236,Buttons for multi-function display-MFI buttons: number 3/4,not coded/not installed,
    IDE00329-MAS00688,Buttons for multi-function display-Multifunction indicator,not coded/not installed,
    IDE00333,Driver assistance systems button,not activated,
    IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
    IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No malfunction detected,
    IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
    IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not activated,
    IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,Engaged ON,
    IDE00356-MAS00323,Cruise Control System (CCS): switch position-Decelerate tap,not activated,
    IDE00356-MAS00324,Cruise Control System (CCS): switch position-Accelerate tap,not activated,
    IDE00356-MAS00325,Cruise Control System (CCS): switch position-Setting,not activated,
    IDE00356-MAS00326,Cruise Control System (CCS): switch position-Activation,not activated,
    IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,not activated,
    IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Distance Regulation,
    IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not Used,not coded/not installed,
    IDE00356-MAS04522,Cruise Control System (CCS): switch position-Delay tip level 2,not activated,
    IDE00356-MAS04523,Cruise Control System (CCS): switch position-Accelerate tip level 2,not activated,
    IDE00356-MAS05138,Cruise Control System (CCS): switch position-Control unit,6 Position operating unit,
    IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,On,
    IDE02588-IDE01715,Terminal signals and start release-Status terminal S,On,
    IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
    IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,not activated,
    IDE02694-MAS01288,Signal horn activation-Signal horn,not activated,
    IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,not activated,
    IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 1,
    IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,not activated,
    IDE02696-IDE02711,Rear wiping: rear washing-Rear Window Wiper,not activated,
    IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,not activated,
    IDE02743,High Beam,not activated,
    IDE02744-MAS01632,Steering wheel heater-Status,OFF,
    IDE02744-MAS04136,Steering wheel heater-Current,0.00, A
    IDE02744-MAS09022,Steering wheel heater-PWM value,0, %
    IDE02744-MAS09758,Steering wheel heater-Temperature sensor,-50, C
    IDE02745-IDE00096,Ignition key removal lock-Selector lever position,Current,
    IDE02745-MAS08202,Ignition key removal lock-CAN p locked,Engaged and locked,
    IDE02745-MAS08203,Ignition key removal lock-CAN p locked: qualified,Not qualified,
    IDE02745-MAS08204,Ignition key removal lock-Hardware input: p_verriegelt,Open,
    IDE02745-MAS08205,Ignition key removal lock-CAN ESP valid speed,Qualified,
    IDE02745-MAS08206,Ignition key removal lock-CAN ESP speed,0, km/h
    IDE02745-MAS08207,Ignition key removal lock-CAN GWB obsolete transmission,Current,
    ENG120506-ENG100300,CCS_in_indic-lever-E: Blinkerhebel GRA Cancel,not activated,
    ENG120506-ENG103377,CCS_in_indic-lever-E: Blinkerhebel GRA Fehler,No malfunction detected,
    ENG120506-ENG103714,CCS_in_indic-lever-E: Blinkerhebel GRA OFF,not activated,
    ENG120506-ENG102330,CCS_in_indic-lever-E: Blinkerhebel GRA ON,not activated,
    ENG120506-ENG120475,CCS_in_indic-lever-E: Blinkerhebel GRA Speedlimiter,OFF,
    ENG120506-ENG103991,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Resume/Plus,not activated,
    ENG120506-ENG100605,CCS_in_indic-lever-E: Blinkerhebel GRA Tip Set/Minus,not activated,
    ENG120506-ENG120476,CCS_in_indic-lever-E: GRA_E_A,OFF,
    ENG120507-ENG100163,CCS_in_third_lever-E: 3.ter Hebel ADR Fehler,No malfunction detected,
    ENG120507-ENG99937,CCS_in_third_lever-E: 3.ter Hebel ADR Minus,not activated,
    ENG120507-ENG101800,CCS_in_third_lever-E: 3.ter Hebel ADR Plus,not activated,
    ENG120507-ENG101234,CCS_in_third_lever-E: 3.ter Hebel GRA Cancel,not activated,
    ENG120507-ENG103820,CCS_in_third_lever-E: 3.ter Hebel GRA Fehler,No malfunction detected,
    ENG120507-ENG99143,CCS_in_third_lever-E: 3.ter Hebel GRA OFF,operated,
    ENG120507-ENG100333,CCS_in_third_lever-E: 3.ter Hebel GRA ON,not activated,
    ENG120507-ENG101903,CCS_in_third_lever-E: 3.ter Hebel GRA Resume,not activated,
    ENG120507-ENG101230,CCS_in_third_lever-E: 3.ter Hebel GRA Set,not activated,
    ENG120507-ENG129309,CCS_in_third_lever-E: 3.ter Hebel GRA Speedlimiter,not activated,
    ENG120507-ENG126425,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Beschleunigen,not activated,
    ENG120507-ENG126426,CCS_in_third_lever-E: 3.ter Hebel GRA Tip 2 Verzgern,not activated,
    ENG120507-ENG120477,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Beschleunigen,not activated,
    ENG120507-ENG120478,CCS_in_third_lever-E: 3.ter Hebel GRA Tip Verzgern,not activated,
    ENG120507-ENG120476,CCS_in_third_lever-E: GRA_E_A,OFF,
    ENG126424-ENG126428,LRH-LRH_current,0.00, A
    ENG126424-ENG126430,LRH-LRH_level,low,
    ENG126424-ENG126429,LRH-LRH_status,OFF,
    ENG126424-ENG126427,LRH-LRH_temperature_NTC,204, C
    Elapsed Time: 00:02
  8. Likes Uwe liked this post
  9. #15
    23 - Brake Booster maps
    ;SW:5QE-909-059-G   HW:5QE-909-059-B ---  Brake Booster
    ;Component:EBKV          H14 0211, Coding:03720100331A00030002050500
    ;EV_BrakeBoostBoschMQBOMG,004003,EV_BrakeBoostBoschMQBOMG_004.rod
    ;Friday,08,December,2017,16:12:27:29905
    ;VCID: 52E7F903059B90BA20B-8006
    IDE08581-Recuperation,active ,1
    IDE11447-electro-mechanical brake booster,active ,1
    IDE11985-Expected OBD requirements,US OBD ,1
    IDE80011-MAS05513-Analysis 11-Bit 0,OFF ,1
    IDE80011-MAS05514-Analysis 11-Bit 1,OFF ,1
    IDE80011-MAS05515-Analysis 11-Bit 2,OFF ,1
    IDE80011-MAS05516-Analysis 11-Bit 3,OFF ,1
    IDE80011-MAS05517-Analysis 11-Bit 4,OFF ,1
    IDE80011-MAS05518-Analysis 11-Bit 5,OFF ,1
    IDE80011-MAS05519-Analysis 11-Bit 6,OFF ,1
    IDE80011-MAS05520-Analysis 11-Bit 7,OFF ,1
    IDE80012-MAS05513-Analysis 12-Bit 0,OFF ,1
    IDE80012-MAS05514-Analysis 12-Bit 1,OFF ,1
    IDE80012-MAS05515-Analysis 12-Bit 2,OFF ,1
    IDE80012-MAS05516-Analysis 12-Bit 3,OFF ,1
    IDE80012-MAS05517-Analysis 12-Bit 4,OFF ,1
    IDE80012-MAS05518-Analysis 12-Bit 5,OFF ,1
    IDE80012-MAS05519-Analysis 12-Bit 6,OFF ,1
    IDE80012-MAS05520-Analysis 12-Bit 7,OFF ,1
    IDE80013-Analysis 13,00 00 00 ,3
    IDE80015-Analysis 15,On ,1
    IDE80016-Analysis 16,On ,1
    IDE80017-Analysis 17,On ,1
    IDE80018-Analysis 18,OFF ,1
    IDE80019-Analysis 19,00 00 00 00 ,4
    IDE80020-Analysis 20,00 00 00 00 ,4
    Elapsed Time: 00:03
    ;Friday,08,December,2017,16:12:23:29905
    IDE00019,Voltage terminal 30,33,
    IDE00021,Engine speed,00,
    IDE00025,Coolant temperature,36,
    IDE00075,Vehicle speed,00,
    IDE00085,Normed load value,00,
    IDE00086,Accelerator position,25,
    IDE00097,OBD - requirements for which this vehicle is designed,02,
    IDE00102,Control Module temperature,12.825, C
    IDE00601-ENG30035,Monitoring status since erasing DTC memory-MIL_Status,OFF,
    IDE00601-ENG30057,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
    IDE00601-ENG30070,Monitoring status since erasing DTC memory-Readiness_State,00,
    IDE00601-ENG30155,Monitoring status since erasing DTC memory-Supported_Info,00,
    IDE00601-ENG30156,Monitoring status since erasing DTC memory-Supported_Info_Readiness,04,
    IDE00602,Monitoring status in current driving cycle,00,
    IDE03680-IDE00019,Supply voltages-Voltage terminal 30,13.1, V
    IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,13.1, V
    IDE03680-MAS06928,Supply voltages-Supply voltage pedal travel sensor,5.0, V
    IDE05793-IDE06045,Brake activation-Output DTM status,No activation,
    IDE05793-MAS11301,Brake activation-Timer,0, s
    IDE05816-IDE00075,Input signals from data bus-Vehicle speed,0.0, km/h
    IDE05816-IDE00086,Input signals from data bus-Accelerator position,0.0, %
    IDE05816-IDE00643,Input signals from data bus-Minimum torque of electric machine,0.0,
    IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
    IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.0, bar
    IDE05816-IDE03660,Input signals from data bus-Longitudinal acceleration,-0.0, m/s
    IDE05816-IDE05221,Input signals from data bus-E-machine torque actual value,0.0,
    IDE05816-IDE07152,Input signals from data bus-Fall-back level,not active,
    IDE05816-IDE07667,Input signals from data bus-Desired torque of regeneration,0.0,
    IDE05816-IDE09126,Input signals from data bus-Vehicle switch-off time,136.0,
    IDE05816-IDE09127,Input signals from data bus-Status: switch-off time,calculated,
    IDE05816-MAS01078,Input signals from data bus-Vehicle type,Hybrid vehicle,
    IDE05816-MAS05179,Input signals from data bus-ABS intervention,not active,
    IDE05816-MAS05187,Input signals from data bus-MSR intervention,not active,
    IDE05816-MAS06150,Input signals from data bus-Terminal 50,not active,
    IDE05816-MAS08112,Input signals from data bus-Drive readiness,Not ready,
    IDE05816-MAS08788,Input signals from data bus-Driving Cycle,not recognized,
    IDE05816-MAS12319,Input signals from data bus-Alternator failure,no error,
    IDE05816-MAS13659,Input signals from data bus-Warm air cycle,not recognized,
    IDE05816-MAS14468,Input signals from data bus-OBD type,Type 2,
    IDE05816-MAS14473,Input signals from data bus-OBD Normed Trip,Unknown,
    IDE05816-MAS14474,Input signals from data bus-OBD Minimum Trip,not fulfilled,
    IDE06422-ENG103176,IUMPR_1-General Denominator,3,
    IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,69,
    IDE06422-ENG100120,IUMPR_1-Milage,70, km
    IDE06422-ENG101622,IUMPR_1-Record Number,1,
    IDE06423-ENG101817,IUMPR_2-Denominator,3,
    IDE06423-ENG103772,IUMPR_2-DFCC Value,03 69,
    IDE06423-ENG99150,IUMPR_2-Numerator,11,
    IDE06423-ENG101622,IUMPR_2-Record Number,1,
    IDE08586-IDE00805,Status: electromechanical power brake-Dead volume,-255.0, mm
    IDE08586-IDE02955,Status: electromechanical power brake-System status,ready for operation,
    IDE08586-IDE06673,Status: electromechanical power brake-Initialization status,completed successfully,
    IDE08586-IDE11447,Status: electromechanical power brake-electro-mechanical brake booster,active,
    IDE08586-IDE11985,Status: electromechanical power brake-Expected OBD requirements,US OBD,
    IDE08586-MAS08092,Status: electromechanical power brake-Basic setting: electromechanical power brake,performed,
    IDE08586-MAS10343,Status: electromechanical power brake-Correction factor_1,0.0000,
    IDE08586-MAS10344,Status: electromechanical power brake-Correction factor_2,0.0000,
    IDE08587-MAS02925,Power brake displays-Brake system indicator lamp,--no display--,
    IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
    IDE08587-MAS08098,Power brake displays-Note - text message,--no display--,
    IDE08587-MAS08100,Power brake displays-Warnings - text message,--no display--,
    IDE08588-IDE06373,Sensor signals for electromechanical power brake-Rotor position of drive motor for electric drive,-0.39,
    IDE08588-MAS08107,Sensor signals for electromechanical power brake-Brake pedal position sensor pulse width,16.4, %
    IDE08588-MAS08108,Sensor signals for electromechanical power brake-Brake pedal sensor 2 pulse width,84.0, %
    IDE08588-MAS08109,Sensor signals for electromechanical power brake-Input rod path sensor: plausibilized,0.0, mm
    IDE08588-MAS08110,Sensor signals for electromechanical power brake-Brake pedal actuation,OFF,
    IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,-0.066, mm
    IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.0000, Nm
    IDE08588-MAS11260,Sensor signals for electromechanical power brake-Brake pedal position sensor distance,-0.078, mm
    IDE08588-MAS11261,Sensor signals for electromechanical power brake-Brake pedal position sensor 2 distance,0.012, mm
    IDE08589-IDE06673,Status of brake press. accum.-Initialization status,Wait for reference run permission,
    IDE08589-IDE08581,Status of brake press. accum.-Recuperation,active,
    IDE08589-MAS08113,Status of brake press. accum.-Brake pressure accum. basic setting,performed,
    IDE08590-IDE00019,Supply voltages for brake press. accum.-Voltage terminal 30,13.4, V
    IDE08591,Control module temp. brake press. accum.,15, C
    IDE08597-IDE06045,Activation brake press. accum.-Output DTM status,No activation,
    IDE08597-MAS11301,Activation brake press. accum.-Timer,0, s
    IDE11836,Query of the supported PIDs (0x01 - 0x20),98,
    IDE11837,Query of the supported PIDs (0x21 - 0x40),00,
    IDE11838,Query of the supported PIDs (0x41 - 0x60),C0,
    IDE11839,Query of the supported InfoTypes (0x01 - 0x20),14,
    IDE80001-IDE80011,Analysis 1-Analysis 11,00,
    IDE80001-IDE80012,Analysis 1-Analysis 12,00,
    IDE80001-IDE80013,Analysis 1-Analysis 13,00 00 00,
    IDE80001-IDE80015,Analysis 1-Analysis 15,0.0078, mm
    IDE80002,Analysis 2,00 00,
    IDE80002,Analysis 2,00,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,26,
    MAS10353-IDE00634,Brake press. accum. current-Vehicle electrical system current,0.0, A
    MAS10353-MAS10347,Brake press. accum. current-max. veh. elec. sys. current during last pressurization,0.3, A
    MAS10354-MAS10348,Sensor signals for break press. accum.-Act. volume,0.00, mm
    MAS10354-MAS10349,Sensor signals for break press. accum.-System volume,4656.4, mm
    MAS10354-MAS10350,Sensor signals for break press. accum.-Target volume,469.6, mm
    MAS10354-MAS10351,Sensor signals for break press. accum.-Maximum volume,0.00, mm
    MAS10354-MAS10352,Sensor signals for break press. accum.-Resting volume,0.00, mm
    ENG101413,Calibration Identification,5QEB 0211@P(#((S,
    ENG101413,Calibration Identification,2,
    ENG101413,Calibration Identification,5QE057A 0155xxxx,
    ENG99697,Calibration Verification Number,02 DC 15 8A,
    ENG100152,ECUNAME,EBBC-ElecBrkBstCtrl,
    ENG100152,ECUNAME,1,
    Elapsed Time: 00:04
  10. Likes Uwe liked this post
  11. #16
    29 - Left Light maps
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Left Light
    ;Component:LCM_MQB       H06 0017, Coding:
    ;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
    ;Friday,08,December,2017,16:12:37:29905
    ;VCID: 42C7C943D5FB003A90B-8016
    IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
    IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
    IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
    IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
    IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
    IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
    IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
    IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
    IDE01550-Service position,not active ,1
    Elapsed Time: 00:01
    ;Friday,08,December,2017,16:12:33:29905
    IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,56,
    IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,2,
    IDE00773,Terminal 15 status via CAN,On,
    IDE03680-MAS01468,Supply voltages-Terminal 15,Not available,
    IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,13.00, V
    IDE06876-MAS01482,Signature light bulb-Hardwareversion,3,
    IDE06876-MAS01483,Signature light bulb-Softwareversion,2,
    IDE06876-MAS12381,Signature light bulb-Software subversion,04,
    IDE06876-ENG14244,Signature light bulb-Software_sub_version_Textual,numerical value: no text,
    IDE06926-IDE02068,History memory: reset counter-Time stamp,FA FE 10 47 00,
    IDE06926-MAS09176,History memory: reset counter-Reset reason,Watchdog Reset,
    IDE08742-MAS01155,Operating time-Control module,7.88, H
    IDE08742-MAS03835,Operating time-Parking light,3.12, H
    IDE08742-MAS09325,Operating time-Daytime running lights,0.00, H
    IDE08742-MAS09330,Operating time-Cover for low beam headlight,0.00, H
    IDE08742-MAS09332,Operating time-Turn signal,0.19, H
    IDE08742-MAS09333,Operating time-Side-marker light,3.11, H
    IDE08742-MAS09334,Operating time-Parking light,0.00, H
    IDE09492-MAS01155,Temperatures-Control module,26.00, C
    IDE09492-MAS09339,Temperatures-extern. temperature sensor 1,27.00, C
    IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,29.00, C
    IDE09768-MAS04121,LED channel 1-Voltage,0.00, V
    IDE09768-MAS04136,LED channel 1-Current,0, mA
    IDE09768-MAS09022,LED channel 1-PWM value,0.00, %
    IDE09768-MAS09327,LED channel 1-LED brightness class,2,
    IDE09768-MAS09328,LED channel 1-Primary function,no function,
    IDE09768-MAS09329,LED channel 1-Secondary function,no function,
    IDE09769-MAS04121,LED channel 2-Voltage,0.00, V
    IDE09769-MAS04136,LED channel 2-Current,0, mA
    IDE09769-MAS09022,LED channel 2-PWM value,0.00, %
    IDE09769-MAS09327,LED channel 2-LED brightness class,3,
    IDE09769-MAS09328,LED channel 2-Primary function,Turn signal,
    IDE09769-MAS09329,LED channel 2-Secondary function,Turn signal,
    IDE09770-MAS04136,High side channel 1-Current,1060, mA
    IDE09770-MAS09022,High side channel 1-PWM value,100.00, %
    IDE09770-MAS09326,High side channel 1-Function,Supply for power output stage for headlamp aux. functions,
    IDE09771-MAS04136,High side channel 2-Current,0, mA
    IDE09771-MAS09022,High side channel 2-PWM value,0.00, %
    IDE09771-MAS09326,High side channel 2-Function,no function,
    IDE09772-MAS04136,High side channel 3-Current,0, mA
    IDE09772-MAS09022,High side channel 3-PWM value,0.00, %
    IDE09772-MAS09326,High side channel 3-Function,Side-marker light,
    IDE09774-MAS03835,Number of activations-Parking light,53,
    IDE09774-MAS09325,Number of activations-Daytime running lights,0,
    IDE09774-MAS09330,Number of activations-Cover for low beam headlight,0,
    IDE09774-MAS09332,Number of activations-Turn signal,1693,
    IDE09774-MAS09333,Number of activations-Side-marker light,52,
    IDE09774-MAS09334,Number of activations-Parking light,0,
    IDE09775-MAS09336,High temperature operating times for control unit-C,0.00, H
    IDE09775-MAS09337,High temperature operating times for control unit-between 105C and 115C,0.00, H
    IDE09775-MAS09338,High temperature operating times for control unit-over 115C,0.00, H
    IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,36.24, %
    IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,0.00, %
    IDE09795-MAS09344,Operating times for motor of headlight range adjustment-over 60%,0.00, %
    IDE09828-MAS00890,Head lamp variant-via CAN,E0 44,
    IDE09828-MAS01155,Head lamp variant-Control module,E0 44,
    IDE09916-MAS09563,Data set names-Number of data set names,01,
    IDE09916-MAS09564,Data set names-Data set ID,28929,
    IDE09916-MAS09565,Data set names-Data set name,A3PALEDetron,
    IDE10175,Capturing statistic data: status,active,
    IDE10301-MAS01155,Number of excess temp. protection activations-Control module,0,
    IDE10301-MAS03835,Number of excess temp. protection activations-Parking light,0,
    IDE10301-MAS09325,Number of excess temp. protection activations-Daytime running lights,0,
    IDE10301-MAS09332,Number of excess temp. protection activations-Turn signal,0,
    IDE11124-MAS12195,Headlight beam adjusting motor-Reference run status,performed,
    IDE11124-MAS12196,Headlight beam adjusting motor-Fault position,not approached,
    IDE11124-MAS12199,Headlight beam adjusting motor-Adjustment speed,normal,
    IDE11124-MAS12206,Headlight beam adjusting motor-Motor position (percent of max. adjustment stroke),36.80, %
    IDE11124-MAS12207,Headlight beam adjusting motor-Low beam inclination,-449.50, mm
    IDE11125-MAS12195,Dynamic cornering light adjusting motor-Reference run status,not performed,
    IDE11125-MAS12196,Dynamic cornering light adjusting motor-Fault position,not approached,
    IDE11125-MAS12199,Dynamic cornering light adjusting motor-Adjustment speed,normal,
    IDE11125-MAS12206,Dynamic cornering light adjusting motor-Motor position (percent of max. adjustment stroke),0.00, %
    IDE11125-MAS12209,Dynamic cornering light adjusting motor-Swivel angle,Unknown,
    IDE11276-MAS01482,Power output stage for headlamp aux. functions-Hardwareversion,Not available,
    IDE11276-MAS01483,Power output stage for headlamp aux. functions-Softwareversion,Not available,
    IDE11276-MAS12381,Power output stage for headlamp aux. functions-Software subversion,0F,
    IDE11276-ENG14244,Power output stage for headlamp aux. functions-Software_sub_version_Textual,Not available,
    IDE11347-MAS12195,Variable headlamp positioning motor-Reference run status,not performed,
    IDE11347-MAS12196,Variable headlamp positioning motor-Fault position,not approached,
    IDE11347-MAS12199,Variable headlamp positioning motor-Adjustment speed,normal,
    IDE11347-MAS12212,Variable headlamp positioning motor-Calibrated light index setting,Unknown,
    Elapsed Time: 00:03
  12. Likes Uwe liked this post
  13. #17
    2B - Steer. Col. Lockmaps
    ;SW:5Q0-905-861-A   HW:5Q0-905-861-A ---  Steer. Col. Lock
    ;Component:ELV-MQBA      H01 0120, Coding:5D00000000000000
    ;EV_ELVMarquMQB,004111,EV_ELVMarquMQB.rod
    ;Friday,08,December,2017,16:12:49:29905
    ;VCID: 342B9F9B9F4FBE8A127-8060
    Elapsed Time: 00:01
    ;Friday,08,December,2017,16:12:40:29905
    IDE00019,Voltage terminal 30,13.100, V
    IDE00021,Engine speed,0.00, /min
    IDE00021-MAS02248,Engine speed-Signal state,valid,
    IDE00075-MAS02248,Vehicle speed-Signal state,valid,
    IDE01766-MAS03714,Distance impulses-Left front wheel,1,
    IDE01766-MAS03715,Distance impulses-Right front wheel,0,
    IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
    IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
    IDE01766-MAS05509,Distance impulses-Left front wheel signal state,valid,
    IDE01766-MAS05510,Distance impulses-Right front wheel signal state,valid,
    IDE01766-MAS05511,Distance impulses-Left rear wheel signal state,valid,
    IDE01766-MAS05512,Distance impulses-Right rear wheel signal state,valid,
    IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
    IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
    IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
    IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
    IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
    IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
    IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
    IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
    IDE02571-MAS05507,Terminal 50: line status-Actual value engine control module,OFF,
    IDE02572-MAS02350,Starter button: status-Switch contact 1,not activated,
    IDE02572-MAS02351,Starter button: status-Switch contact 2,not activated,
    IDE02573,End switch for steering column: unlocked: status,operated,
    IDE02574,End switch for steering column: locked: status,not activated,
    IDE02575,Unlocking motor: activation status,not activated,
    IDE02576,Locking motor: activation status,not activated,
    IDE02577,Steering column twisting: status,not twisted,
    IDE02578,Play protection status,not activated,
    IDE02579,Park selector lever position,Engaged and locked,
    IDE02580,Number of unlocks,77,
    IDE02581-MAS02312,Drive train uncoupling-Powertrain (engine),decoupled,
    IDE02582-MAS00179,Brake activation: switch status-Brake Light Switch,OFF,
    IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
    IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
    IDE02586-MAS02398,ID sensor authenticated in vehicle-ID sensor 1,No,
    IDE02586-MAS02399,ID sensor authenticated in vehicle-ID sensor 2,No,
    IDE02586-MAS02400,ID sensor authenticated in vehicle-ID sensor 3,No,
    IDE02586-MAS02401,ID sensor authenticated in vehicle-ID sensor 4,No,
    IDE02587,ID sensor search: status,not active,
    IDE02589-MAS02255,Rotary latch status-Status of rotary latch in driver door,closed,
    IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
    IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
    IDE02682-MAS02250,Disengage starter-Disengage request,No,
    IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
    IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
    IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
    IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
    IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
    IDE03527-IDE00660,CAN signals-Drive readiness,not active,
    IDE03527-IDE03410,CAN signals-Yellow warning lamp,not active,
    IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
    IDE03527-MAS04444,CAN signals-Wake-up,not active,
    IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
    IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
    IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
    IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
    IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
    IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
    IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
    IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
    IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
    IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
    IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
    IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
    IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
    IDE06746-IDE02578,Locking requirements-Play protection status,Condition met,
    IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
    IDE06746-IDE07029,Locking requirements-Terminal status via CAN,Condition not met,
    IDE06746-MAS02349,Locking requirements-Learn mode,Condition met,
    IDE07028,Time until shut-off terminal S,4.14e+006, ms
    IDE08440,Recommendation energy management,no restriction,
    IDE09068-IDE00020,Status: automatic terminal shut-off-Terminal 15 status,Condition met,
    IDE09068-IDE00021,Status: automatic terminal shut-off-Engine speed,Condition met,
    IDE09068-IDE00325,Status: automatic terminal shut-off-Diagnostic mode,Condition not met,
    IDE09068-IDE02579,Status: automatic terminal shut-off-Park selector lever position,Not coded,
    IDE09068-IDE06983,Status: automatic terminal shut-off-Diesel emissions re-treatment: status,Condition met,
    IDE09068-IDE08099,Status: automatic terminal shut-off-Status engine speed,Condition met,
    IDE09068-IDE08440,Status: automatic terminal shut-off-Recommendation energy management,Condition not met,
    IDE09068-MAS06473,Status: automatic terminal shut-off-Status vehicle standstill,Condition met,
    IDE09068-MAS08076,Status: automatic terminal shut-off-Exiting the vehicle,Condition not met,
    IDE09068-MAS08788,Status: automatic terminal shut-off-Driving Cycle,Condition not met,
    IDE09068-MAS08789,Status: automatic terminal shut-off-Valid distance impulses,Condition met,
    IDE09068-MAS08790,Status: automatic terminal shut-off-Driver absence,Condition met,
    MAS01493,Engine running,not active,
    MAS03129,Reset counter,2,
    MAS03607,Engine stop in start-stop mode active,not active,
    MAS05104,Driver request: start engine,not active,
    MAS09771,Driver information comfort switching,No switch-off,
    ENG111213-ENG111202,Activated_Fault_Reactions-CoCo permanent reset,No,
    ENG111213-ENG111201,Activated_Fault_Reactions-KL50 disabled,No,
    ENG111213-ENG111200,Activated_Fault_Reactions-Locking disabled / Clamp change up disabled,No,
    ENG125217,Active_requirement_light_lag,not activated,
    ENG120012-ENG100326,CAN Message CLS_02-Can State,active,
    ENG120012-ENG119946,CAN Message CLS_02-Time to Timeout ZV_02,1940, ms
    ENG120012-ENG119966,CAN Message CLS_02-ZV_gesafet_extern_soll,0,
    ENG120012-ENG119965,CAN Message CLS_02-ZV_verriegelt_extern_soll,0,
    ENG120020-ENG119995,CAN Message ESCL_01-ELV_Anf_Klemme_15,1,
    ENG120020-ENG119996,CAN Message ESCL_01-ELV_Anf_Klemme_50,0,
    ENG120020-ENG119994,CAN Message ESCL_01-ELV_Anf_Klemme_S,1,
    ENG120020-ENG120001,CAN Message ESCL_01-ELV_Anlernmodus,0,
    ENG120020-ENG119998,CAN Message ESCL_01-ELV_Entriegelt,1,
    ENG120020-ENG120000,CAN Message ESCL_01-ELV_Lebenszustand,1,
    ENG120020-ENG120003,CAN Message ESCL_01-ELV_LED_Gelb,0,
    ENG120020-ENG120002,CAN Message ESCL_01-ELV_LED_Rot,0,
    ENG120020-ENG120009,CAN Message ESCL_01-ELV_P_verriegelt,0,
    ENG120020-ENG120007,CAN Message ESCL_01-ELV_Txt_Defekt,0,
    ENG120020-ENG120005,CAN Message ESCL_01-ELV_Txt_Lkg_Bewegen,0,
    ENG120020-ENG120008,CAN Message ESCL_01-ELV_Txt_P_Gang,0,
    ENG120020-ENG120004,CAN Message ESCL_01-ELV_Txt_Panikabschaltung,0,
    ENG120020-ENG120006,CAN Message ESCL_01-ELV_Txt_Werkstatt,0,
    ENG120020-ENG119997,CAN Message ESCL_01-ELV_Verriegelt,0,
    ENG120020-ENG119999,CAN Message ESCL_01-ELV_ZAT_betaetigt,0,
    ENG120016-ENG100326,CAN Message ESP_10-Can State,active,
    ENG120016-ENG119984,CAN Message ESP_10-ESP_10_BZ,3,
    ENG120016-ENG119985,CAN Message ESP_10-ESP_10_CRC,186,
    ENG120016-ENG119993,CAN Message ESP_10-ESP_QBit_Wegimpuls_HL,0,
    ENG120016-ENG119992,CAN Message ESP_10-ESP_QBit_Wegimpuls_HR,0,
    ENG120016-ENG119990,CAN Message ESP_10-ESP_QBit_Wegimpuls_VL,0,
    ENG120016-ENG119991,CAN Message ESP_10-ESP_QBit_Wegimpuls_VR,0,
    ENG120016-ENG119989,CAN Message ESP_10-ESP_Wegimpuls_HL,0,
    ENG120016-ENG119988,CAN Message ESP_10-ESP_Wegimpuls_HR,0,
    ENG120016-ENG119986,CAN Message ESP_10-ESP_Wegimpuls_VL,1,
    ENG120016-ENG119987,CAN Message ESP_10-ESP_Wegimpuls_VR,0,
    ENG120016-ENG119951,CAN Message ESP_10-Time to Timeout ESP_10,1880, ms
    ENG120014-ENG100326,CAN Message Gateway_71-Can State,active,
    ENG120014-ENG119687,CAN Message Gateway_71-ESP_21_alt,0,
    ENG120014-ENG119968,CAN Message Gateway_71-ESP_QBit_v_Signal,0,
    ENG120014-ENG119967,CAN Message Gateway_71-ESP_v_Signal,0.00, km/h
    ENG120014-ENG119947,CAN Message Gateway_71-Time to Timeout Gateway_71,920, ms
    ENG120019-ENG100326,CAN Message Gateway_73-Can State,active,
    ENG120019-ENG119976,CAN Message Gateway_73-MO_Drehzahl_01,0.00, /min
    ENG120019-ENG119977,CAN Message Gateway_73-MO_QBit_Drehzahl_01,0,
    ENG120019-ENG119684,CAN Message Gateway_73-Motor_12_alt,0,
    ENG120019-ENG119948,CAN Message Gateway_73-Time to Timeout Gateway_73,500, ms
    ENG120015-ENG100326,CAN Message Kessy_04-Can State,active,
    ENG120015-ENG119978,CAN Message Kessy_04-KY_ID_Geber 1_im_Fzg,0,
    ENG120015-ENG119979,CAN Message Kessy_04-KY_ID_Geber 2_im_Fzg,0,
    ENG120015-ENG119980,CAN Message Kessy_04-KY_ID_Geber 3_im_Fzg,0,
    ENG120015-ENG119981,CAN Message Kessy_04-KY_ID_Geber 4_im_Fzg,0,
    ENG120015-ENG119982,CAN Message Kessy_04-KY_ID_Geber_Suche,0,
    ENG120015-ENG119950,CAN Message Kessy_04-Time to Timeout Kessy_04,1880, ms
    ENG120013-ENG100326,CAN Message Motor_14-Can State,active,
    ENG120013-ENG119969,CAN Message Motor_14-MO_Aussp_Anlass,0,
    ENG120013-ENG119970,CAN Message Motor_14-MO_BLS,0,
    ENG120013-ENG119971,CAN Message Motor_14-MO_Fahrer_bremst,0,
    ENG120013-ENG119975,CAN Message Motor_14-MO_HYB_Fahrbereitschaft,0,
    ENG120013-ENG119973,CAN Message Motor_14-MO_Interlock,1,
    ENG120013-ENG119681,CAN Message Motor_14-MO_Kl_50,0,
    ENG120013-ENG119972,CAN Message Motor_14-MO_Qbit_Fahrer_bremst,0,
    ENG120013-ENG119974,CAN Message Motor_14-MO_StartStopp_Motorstopp,0,
    ENG120013-ENG119949,CAN Message Motor_14-Time to Timeout Motor_14,940, ms
    ENG120010-ENG100326,CAN Message term._Status_01-Can State,active,
    ENG120010-ENG119944,CAN Message term._Status_01-Time to Timeout Klemmen_Status_01,960, ms
    ENG120010-ENG119680,CAN Message term._Status_01-ZAS_Kl_15,1,
    ENG120010-ENG119679,CAN Message term._Status_01-ZAS_Kl_S,1,
    ENG120011-ENG100326,CAN Message TSG_FT_01-Can State,active,
    ENG120011-ENG119964,CAN Message TSG_FT_01-FT_Tuer_geoeffnet,0,
    ENG120011-ENG119945,CAN Message TSG_FT_01-Time to Timeout TSG_FT_01,920, ms
    ENG120018-ENG100326,CAN Message WFS_01-Can State,active,
    ENG120018-ENG119952,CAN Message WFS_01-Time to Timeout WFS_01,1940, ms
    ENG120018-ENG119983,CAN Message WFS_01-WFS_Schluessel_Ist,2,
    ENG111214-ENG119959,CAN Request-Clamp generation,active,
    ENG111214-ENG119958,CAN Request-Diagnostic connection,active,
    ENG111214-ENG119961,CAN Request-Immobilizer authentication,not active,
    ENG111214-ENG119960,CAN Request-Move,not active,
    ENG111215-ENG119959,CAN Request-Clamp generation,active,
    ENG111215-ENG119958,CAN Request-Diagnostic connection,active,
    ENG111215-ENG119961,CAN Request-Immobilizer authentication,not active,
    ENG111215-ENG119960,CAN Request-Move,not active,
    ENG111211-ENG111203,Endposition_Button_Blocked_Contact-Button Blocked Contact 1,not activated,
    ENG111211-ENG111204,Endposition_Button_Blocked_Contact-Button Blocked Contact 2,operated,
    ENG111217-ENG111209,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 1,operated,
    ENG111217-ENG111210,Endposition_Button_Unlocked_Contact-Button Unlocked Contact 2,not activated,
    ENG111212-ENG111184,Errorcounter-AD-Converter corrupt,0,
    ENG111212-ENG111176,Errorcounter-CoCo RAM-Check,0,
    ENG111212-ENG111177,Errorcounter-CoCo ROM-Check,0,
    ENG111212-ENG111194,Errorcounter-CPU-Test CoCo,0,
    ENG111212-ENG111192,Errorcounter-CPU-Test HaCo,0,
    ENG111212-ENG111186,Errorcounter-Enable CoCo incorrect active KL15,0,
    ENG111212-ENG111187,Errorcounter-Enable CoCo incorrect active locking,0,
    ENG111212-ENG111178,Errorcounter-Endposition locked not reached,0,
    ENG111212-ENG111181,Errorcounter-Endposition switches implausible,0,
    ENG111212-ENG119957,Errorcounter-Error clamp15: - Steeringlock isn't unlock,0,
    ENG111212-ENG111185,Errorcounter-HaCo CoCo communication disturbed,0,
    ENG111212-ENG111175,Errorcounter-HaCo EEPROM-Check,0,
    ENG111212-ENG111173,Errorcounter-HaCo RAM-Check,0,
    ENG111212-ENG111174,Errorcounter-HaCo ROM-Check,0,
    ENG111212-ENG111196,Errorcounter-KL15 ELV locked,0,
    ENG111212-ENG111188,Errorcounter-No CoCo enable KL15,0,
    ENG111212-ENG111189,Errorcounter-No CoCo enable locking,0,
    ENG111212-ENG111182,Errorcounter-Particle,0,
    ENG111212-ENG111195,Errorcounter-Program sequence CoCo,0,
    ENG111212-ENG111193,Errorcounter-Program sequence HaCo,0,
    ENG111212-ENG111190,Errorcounter-Reset HaCo CoCo failed,0,
    ENG111212-ENG111191,Errorcounter-Reset SBC HaCo failed,0,
    ENG111212-ENG119956,Errorcounter-Return address,00 00 00 00,
    ENG111212-ENG111183,Errorcounter-SBC-Error,0,
    ENG111212-ENG111197,Errorcounter-SDA-Error,0,
    ENG111212-ENG111179,Errorcounter-Shortcut motor driver highside,0,
    ENG111212-ENG111180,Errorcounter-Shortcut motor driver lowside,0,
    ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
    ENG125220-MAS00107,History last automatic terminal switch off-Month,1,
    ENG125220-MAS00108,History last automatic terminal switch off-Day,6,
    ENG125220-MAS00108,History last automatic terminal switch off-Day,7,
    ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
    ENG125220-MAS00110,History last automatic terminal switch off-Minutes,2,
    ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
    ENG125220-MAS00111,History last automatic terminal switch off-Seconds,33,
    ENG125220-MAS00111,History last automatic terminal switch off-Seconds,28,
    ENG125220-MAS00111,History last automatic terminal switch off-Seconds,44,
    ENG125220-MAS00111,History last automatic terminal switch off-Seconds,6,
    ENG125220-MAS00111,History last automatic terminal switch off-Seconds,21,
    ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,17, km
    ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,17, km
    ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,17, km
    ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,13, km
    ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,12, km
    ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
    ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
    ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
    ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
    ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
    ENG111218-ENG98599,Last reset reason-external,WAKEUP_SST1,
    ENG111218-ENG98656,Last reset reason-internal,NOT_INTERNAL,
    ENG125219-ENG125224,Status_Selective_catalytic_reduction-Count_engine_start,OK,
    ENG125219-ENG125223,Status_Selective_catalytic_reduction-Selective_catalytic_reduction_install,not installed,
    ENG125218,Suppression_ignition_message,not activated,
    ENG120017-ENG100326,Timeout CAN Messages-Can State,active,
    ENG120017-ENG119953,Timeout CAN Messages-Time to Timeout Diagnose_01,4560, ms
    ENG120017-ENG119951,Timeout CAN Messages-Time to Timeout ESP_10,1820, ms
    ENG120017-ENG119947,Timeout CAN Messages-Time to Timeout Gateway_71,900, ms
    ENG120017-ENG119948,Timeout CAN Messages-Time to Timeout Gateway_73,480, ms
    ENG120017-ENG119950,Timeout CAN Messages-Time to Timeout Kessy_04,1840, ms
    ENG120017-ENG119944,Timeout CAN Messages-Time to Timeout Klemmen_Status_01,1000, ms
    ENG120017-ENG119949,Timeout CAN Messages-Time to Timeout Motor_14,1000, ms
    ENG120017-ENG119954,Timeout CAN Messages-Time to Timeout Systeminfo_01,4560, ms
    ENG120017-ENG119945,Timeout CAN Messages-Time to Timeout TSG_FT_01,980, ms
    ENG120017-ENG119952,Timeout CAN Messages-Time to Timeout WFS_01,2000, ms
    ENG120017-ENG119946,Timeout CAN Messages-Time to Timeout ZV_02,1860, ms
    Elapsed Time: 00:08
  14. Likes Uwe liked this post
  15. #18
    Administrator Andy's Avatar
    39 - Right Light maps
    ;SW:8S0-907-397-D   HW:8S0-907-397-D ---  Right Light
    ;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW41.rod
    ;Friday,08,December,2017,16:12:56:29905
    ;VCDS Version: Beta 17.11.0 (x64)  Data version: 20171026 DS285.1
    Elapsed Time: 00:01
    ;Friday,08,December,2017,16:12:52:29905
    Group,Description,Actual
    IDE00030,Status of actuator test,not active,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE02486,Data logger triggering,not active,
    IDE08742-MAS01155,Operating time-Control module,7.29, H
    IDE08742-MAS03835,Operating time-Parking light,3.11, H
    IDE08742-MAS09332,Operating time-Turn signal,0.18, H
    IDE09492-MAS01155,Temperatures-Control module,27.00, C
    IDE09492-MAS09340,Temperatures-extern. temperature sensor 2,28.00, C
    IDE09769-MAS09327,LED channel 2-LED brightness class,4,
    IDE09770-MAS04136,High side channel 1-Current,1080, mA
    IDE09774-MAS03835,Number of activations-Parking light,52,
    IDE09774-MAS09332,Number of activations-Turn signal,1602,
    IDE09774-MAS09333,Number of activations-Side-marker light,51,
    IDE09775-MAS09336,High temperature operating times for control unit-C,0.01, H
    IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,36.26, %
    Elapsed Time: 00:03
  16. Likes Uwe liked this post
  17. #19
    3C - Lane Change maps
    ;SW:3Q0-907-566-F   HW:3Q0-907-566 ---  Lane Change
    ;Component:MRR1Rear      H21 0610, Coding:04C002
    ;EV_RearRadarS1BoschVW48X,001007,EV_RearRadarS1BoschVW48X.rod
    ;Friday,08,December,2017,16:13:05:29905
    ;VCID: 3B39B4A7B21171F2D3D-806E
    IDE00001-MAS15623-Production mode-Deactivation of lane change assistance and exit warning,not active ,3
    IDE00001-MAS15624-Production mode-Deactivation of Cross traffic assistant rear and pre sense rear,not active ,3
    IDE00820-Activating and deactivating all development messages,not activated ,1
    IDE05394-Brightness characteristic of warning display,normal ,1
    Elapsed Time: 00:03
    ;Friday,08,December,2017,16:13:00:29905
    IDE00018,Voltage terminal 15,12.90, V
    IDE00019,Voltage terminal 30,Measured value not available,
    IDE00020,Terminal 15 status,Measured value not available,
    IDE00075,Vehicle speed,0.00, km/h
    IDE00102,Control Module temperature,21, C
    IDE00322,Status of basic setting,not active,
    IDE00925,Yaw rate,-127, /s
    IDE01352,Temperature unit,C,
    IDE01441,Back-up light,OFF,
    IDE01763,Dimming,3,
    IDE02049,Trailer detected,Unknown,
    IDE02389,Ambient brightness,0, %
    IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,253,
    IDE03197-MAS02477,Rain/Light Recognition Sensor-Front brightness,0,
    IDE03197-ENG09275,Rain/Light Recognition Sensor-Brightness_forwards_Textual,numerical value: no text,
    IDE03504-MAS03692,Personalized settings-Key 1,0,
    IDE03504-MAS03693,Personalized settings-Key 2,0,
    IDE03504-MAS03694,Personalized settings-Key 3,0,
    IDE03504-MAS03695,Personalized settings-Key 4,0,
    IDE03505-MAS03692,Personalized settings dimming-Key 1,4,
    IDE03505-MAS03693,Personalized settings dimming-Key 2,3,
    IDE03505-MAS03694,Personalized settings dimming-Key 3,3,
    IDE03505-MAS03695,Personalized settings dimming-Key 4,3,
    IDE05068,Driver side warning light flashing cycle,Unknown,
    IDE05069,Frt.pass. side warning light flashing cycle,Unknown,
    IDE05070,Curve radius,4093, m
    IDE05071,Lane change assistance button,not activated,
    IDE05075,Status of driver side warning light,OFF,
    IDE05076,Status of frt.pass. side warning light,OFF,
    IDE05089,Dynamic calibration: distance traveled,0, km
    IDE05090,Measured receiving power lane change assist. 1,1, %
    IDE05091,Measured receiving power lane change assist. 2,54, %
    IDE05092,Measured angle lane change assist. 1,-38.80,
    IDE05093,Measured angle lane change assist. 2,40.30,
    IDE05094,Static angle offset lane change assist. 1,-1.18,
    IDE05095,Static angle offset lane change assist. 2,-0.39,
    IDE05393,Currently used key,Key 2,
    IDE07159-MAS01155,Control module switch-off: counter-Control module,0,
    IDE07159-MAS05583,Control module switch-off: counter-Data bus,0,
    IDE09232,Vehicle speed from radar measurement,0.00, km/h
    IDE09387,Dynamic angle offset lane change assist.,-0.65,
    IDE09388,Rear cross traffic assistant: warning levels,Stage 0,
    IDE09780,System condition ctrl. mod.,Terminal 15 on,
    IDE09781,Syst. condition lane change assistance,Available,
    IDE09782,System condition rear cross traffic assistant,Available,
    IDE09783,System condition pre sense rear,Temporary malfunction,
    IDE09784,Functional status of lane change assist.,passive,
    IDE09785,Function condition rear cross traffic assistant,OFF,
    IDE09786,Function condition pre sense rear,passive,
    ENG112308,ECU_Serial_Number,31 35 2E 31 30 2E 31 37 37 37 31 31 32 31 35 33,
    Elapsed Time: 00:04
  18. Likes Uwe liked this post
  19. #20
    42 - Door Elect, Driver maps
    ;SW:5Q0-959-593-E   HW:5Q0-959-593-B ---  Door Elect, Driver
    ;Component:TSG FS        020 0041, Coding:005D1F205C00048000000003
    ;EV_DCUDriveSideEWMAXKLO,006003,EV_DCUDriveSideEWMAXCONT.rod
    ;Friday,08,December,2017,16:13:53:29905
    ;VCID: 43C9CC47CAE109329BD-8016
    IDE00001-Production mode,00000000 00000000 00000000  ,3
    IDE02332-Deactivate production mode,00000000 00000000 00000000  ,3
    ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
    Elapsed Time: 00:12
    ;Friday,08,December,2017,16:13:11:29905
    IDE00310,Outside air temperature,5.0, C
    IDE00322,Status of basic setting,was not yet started,
    IDE01766-MAS02248,Distance impulses-Signal state,OK,
    IDE02262,synchronous mirror adjustment,not installed,
    IDE02267-IDE00773,Supply voltage for door control module: front: driver side-Terminal 15 status via CAN,active,
    IDE02267-IDE01715,Supply voltage for door control module: front: driver side-Status terminal S,active,
    IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,13.1, V
    IDE02668,Central window regulator switch,not installed,
    IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
    IDE04216-MAS01458,Mirror heater-Operating condition,not_active,
    IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
    IDE04216-MAS04247,Mirror heater-Button,not activated,
    IDE04217,Fuel filler door release button,not activated,
    IDE04218,Turn signal in exterior rear-view mirror,not active,
    IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,not activated,
    IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,not activated,
    IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,not activated,
    IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,not activated,
    IDE04220,Driver power window button,not activated,
    IDE04411,Child Safety Lock Switch,not activated,
    IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
    IDE04539-MAS02228,Mirror memory-X coordinate,255, %
    IDE04539-MAS02229,Mirror memory-Y coordinate,255, %
    IDE04539-MAS02476,Mirror memory-install,not installed,
    IDE04540,Mirror adjustment (X/Y-direction),Position center,
    IDE04580,Dimming of inside door handle lighting,92, %
    IDE04581,Dimming for interior ambient lighting,255, %
    IDE04586,Mirror fold-in activation,not active,
    IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
    IDE05720-IDE04213,Front driver side door status-Central locking button,not activated,
    IDE05720-IDE04214,Front driver side door status-Key switch in door lock,not activated,
    IDE05720-MAS06256,Front driver side door status-Status door lock,Signal from door lock: released,
    IDE05725,Terminal 58xs dimmer,0, %
    IDE05726,Terminal 58xd dimmer,15, %
    IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
    IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not activated,
    IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
    IDE06206-MAS02039,Front window regulator status: driver side-Force limitation,not active,
    IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.0, %
    IDE06206-MAS02098,Front window regulator status: driver side-Power window control standardized,Yes,
    IDE06206-MAS03548,Front window regulator status: driver side-Motor current,0, A
    IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
    IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
    IDE06469,Ambient illumination for speaker,0, %
    IDE06933,Front window regulator relay: driver side,Open,
    IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.5, %
    IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.5, %
    IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.5, %
    IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.5, %
    IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.5, %
    IDE07110-MAS01632,Recognition of motor variant for window regul.-Status,not recognized,
    IDE07110-MAS04606,Recognition of motor variant for window regul.-Parameter set,15,
    IDE07222,Window regulator child lock: driver side,Not available,
    IDE07405-IDE03114,Enable driver front window regulator relay-Comfort function,No,
    IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
    IDE07409-MAS01632,Excessive temper. disconnect: front window regulator: driv.side-Status,not active,
    IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,4, C
    IDE07413,Comfort function for front window regulator: driver side,not active,
    IDE07543,Vehicle speed,0.0, km/h
    IDE08061,Child safety lock button 2,not installed,
    IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
    IDE08697-MAS07303,Number of driving cycles without opening door-Actual number of driving cycles without opening door,0,
    IDE09335,Mirror fold-in: current consumption,0.0, A
    IDE09798,Play protection: mirror fold-in,not active,
    MAS00464-MAS00106,Standard - ambient data 1-Year,2017,
    MAS00464-MAS00107,Standard - ambient data 1-Month,1,
    MAS00464-MAS00108,Standard - ambient data 1-Day,8,
    MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
    MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
    MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
    MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,6,
    MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,1248, km
    MAS01872,Rear lid remote release button,not activated,
    MAS02099,Switch for inside door handle,not installed,
    MAS02100,Switch for outside door handle,not installed,
    MAS02101,Child safety,active,
    MAS06010,Ambient light,255, %
    Elapsed Time: 00:41
