EPB Audi A6
Bronze
Sweden
C?ID=253519
Hi.
Audi A6 2.0TDI-2014
Updated VCDS Hex-net.
I want to deactivate the epb so I can change the rear brake pads.
I click on 53-Parking brake, 04-Basic settings.
The problem is that I can´t type in 007 and then press Go. The line after the go-button is grey and can´t be used for typing. It doesn´t look the same as in the guides I´ve been watching.
Have you been here?
Bronze
Sweden
C?ID=253519
Ah, no I haven´t.
I do recognize that menu though, I´ll try it out tomorrow.
Big thanx.
Bronze
Sweden
C?ID=253519
Ah, no I haven´t.
Big thanx.
It didn´t work out as planned.
When I press go I get this error: "Conditions not correct or request sequence error."
Bronze
Sweden
C?ID=253519
Friday,08,December,2017,19:16:57:53852
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
VIN: WAUZZZ4G0EN100079   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62
          69 72
VIN: WAUZZZ4G0EN100079   Mileage: 174244km-108270miles
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 3113
   Revision: 45H25---
   Coding: 12034012243401080000
   ASAM Dataset: EV_ECM20TDI01103L906018LB 003009
   ROD: EV_ECM20TDI01103L906018LB.rod
   VCID: F5A2AA295413EAEE32-80A0
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
   Component: 0AW_20TDI_RdW H06 0003
   Revision: --H06---    Serial number: 0000000189
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: B93A6619388B4E8E16-80EC
   Coding: 06A19F016085F980FB00
   VCID: BA3879153D8D45961F-80EE
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01A93046000000000000
   VCID: F9BAA619700B8E8E56-80AC
   Serial number: 0213000374200010
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
   Component: KLIMA 2 ZONEN H14 0094
   Serial number: 06121300111540
   Coding: 34020008A1
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: E89CF35D13A10706B9-80BC
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001666624
   Coding: 2600E01040349FE00181008300001D0C0F9CE70826090201000004606100
   VCID: EE9085453945D936F3-80BA
   Component: WWS57X 131201  H36 0080
   Serial number:         131202234905
   Coding: 0045F7
   Serial number: 22046432
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 05 12 2013  00000370
   Serial number: F10880E6000000000001
   Revision: 11001001    Serial number: 61061334302048
   Coding: 09C307
   VCID: F1AA9E39207BC6CEEE-80A4
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Revision: --------    Serial number: 003JG00G2Y15
   Coding: 3032343631324E303039554A304C34473053
   VCID: B6206D250995A1F6FB-80E2
   Serial number: 3575HRB401250J5OE8F0
   Serial number: 3585HRB401250J5OIPNU
   Serial number: 3515JRB401G50QDIOPB%
   Serial number: 3525JRB400Q50Q3SA0UW
   Serial number: 3554VRB404V26M6K111C
   Serial number: 3564VRB401450Q3OBP4M
   Revision: 00000000    Serial number: 20131205000391
   Coding: 000015
   VCID: B02C5B3DE3F18FC6A1-80E4
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 932 S    HW: 4G8 920 932 S
   Component: TDieRdw       H58 0621
   Revision: 29460235    Serial number: 658071213596007
   Coding: 13A610000B410008010000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: BFCE080126AF60BE28-80EA
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001202478
   Coding: 00CD074400
   ROD: EV_GatewPkoUDS_001.rod
   VCID: F2A89135257DFDD617-80A6
   Serial number: 4236521903
   Voltage stabilizer:
          U140B 00 [009] - -
                    Reset counter: 183
                    Mileage: 174244 km
                    Date: 2017.12.07
                    Time: 20:54:24
                    Voltage terminal 30: 10.9 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 28 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7207FZGX
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: B32654311AE7B4DEDC-80E6
   Coding: 011C16004000620002080002
   VCID: C7DE10E1767F287E90-8092
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0028096063
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B2285135E5FDBDD6D7-80E6
   Revision: 00002001    Serial number: 0321873402
   Coding: 013A0620A0B900008320090420010F470000000000000000000000000000
   VCID: C6C01DE5717531766B-8092
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000910496
   ROD: EV_ParkiBrake_AU57.rod
   VCID: AC144F4DC7D9EB269D-80F8
   Serial number: 131209-0002-116
   Coding: 112296101002A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: AD124249FCC3E22E8A-80F8
   Coding: 010814004000620002080002
   VCID: C9DA16D9606BDE0E86-809C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00000322134259
   Coding: 0109080000000000
   VCID: F1AA9E39287BC6CEEE-80A4
End----(Elapsed Time: 01:40, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
Hmm... The EPB control module you have is almost exactly identical to the one in the car that procedure was developed and tested on, so I would think the procedure should apply to yours as well.
Could it be that your voltage is simply too low (VBatt start/end: 11.6V/11.5V. VIgn 11.5V) and causing this module to say, "Conditions not correct"? The procedure does explicitly call for a battery charger to be used...
Bronze
Sweden
C?ID=253519
I was thinking the same as I wrote it.
I have a c-tek batterycharger hooked up but I installed it directly to the battery.
Is it ok? I read somewhere that it´s supposed to be installed directly to the main lead, wherever that is, to ensure enough system voltage and not just battery voltage.
It's best to connect it to the jump-start terminals under the hood of the car.
It's OK to connect the positive directly to the battery, but the negative needs to go to the chassis of the car somewhere, otherwise the BMS only sees the current coming out of the battery, not the "net" current.
How many amps can your charger produce?
Bronze
Sweden
C?ID=253519
It ranges between 0,8-3,6A
Bronze
Sweden
C?ID=253519
That's, uhm, inadequate for your car. ;)
So my only options are either buying a new charger or leave it to a workshop?
Under my 25 years as a carowner I´ve allways repaired them myself, everything from oilchange to timimgbelts etc.
This part of car evolution is just sad :rolleyes:
It doesn´t even have an oilstick....
How much amps do I need and why? I´ve had cars with bigger batteries than this.
Thanx in advance, this is an extremely good forum.
Bronze
Sweden
C?ID=253519
Now I have an C-tek MXS 10 which generates 10A and can work as a suply if the battery is disconnected. It should be well enough.
The error is still the same though.
What am I doing wrong?? Why is the conditions wrong?? And what condition in gods name?? I´m going insane, it took me 1 hour to fix the front pads and 4 Days and still not done with the rear.
1. I choose "53"
2. I choose basic settings
3. I choose "Start linig change mode"
4. I press "Go"
5. Fault message.
The question is not how big the battery is; the question is how much current does the car pull from the battery with the ignition on and the engine not running? You want a charger that can supply at least that much current, plus a bit more. Based on the ~11.5V readings in your Auto-Scan, that's not happening with your charger. In fact, those readings are indicative of a rather low state-of-charge in the battery, or a battery that's on its last legs. Have you ever pulled the battery history data from this car?
I'm not convinced that 10A is enough for this car, but it's a step in the right direction.
1. I choose "53"
4. I press "Go"
5. Fault message.
Start by fully charging your battery overnight with the ignition off.
Did you cycle the EPB on and then off again first?
Bronze
Sweden
C?ID=253519
Do you mean deactivate/activate the epb with brakepedal down and when should I do this?
Before 1 or just before I press Go?
I´m charging the battery now....wouldn´t have been very easy to have a faultcode ”low battery voltage” instead of the other mumbojumbo :rolleyes:?
Activate and de-activate. I would do it just before accessing the module.
Ask Audi. VCDS can only show you what your car is willing to tell it. ;)
Bronze
Sweden
C?ID=253519
Battery fully charged and charger set on supply mode. All worked out just fine and rear pads are now changed!
Too bad my IPhone crashed down with a broken display as result....it would have been cheaper to leave the car to the shop :cool:
Thanx for all the help!
