Results 1 to 8 of 8
Thread: Need for long code abs skoda fabia (ABS9.0)
    Jul 2017
    Kosovo
    Thursday,07,December,2017,08:33:05:44995
    VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4401.4
    VIN: TMB1SB5J0D3103841   License Plate:
    Mileage: 88320km-54879mi   Repair Order:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: TMB1SB5J0D3103841   Mileage: 88320km-54879miles
    Address 01: Engine (J623-CAYA)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 NG    HW: 03L 906 023 LK
       Component: 1,6l R4 CR td H33 9970
       Revision: --H33---    Serial number:
       Coding: 00114016000400080000
       Shop #: WSC 13765 031 00046
       ASAM Dataset: EV_ECM16TDI02103L906023NG 003007
       ROD: EV_ECM16TDI02103L906023LL.rod
       VCID: 78AAE10E2259B7F7621-802C
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
       Part No SW: 6R0 907 379 AR    HW: 6R0 907 379 AQ
       Component: ABS9.0 front  H01 0001
       Serial number: --------------
       ASAM Dataset: EV_Brake1ABS90BOSCH 003017
       ROD: EV_Brake1ABS90BOSCH_VW25.rod
       VCID: 0E46A7D630DD9947D8D-805A
    0887 - Control Module
              C104A F0 [024] - Incorrect VIN
                        Reset counter: 214
                        Mileage: 32285 km
                        Date: 2015.10.10
                        Time: 00:00:20
    0883 - Control module not coded
              U1013 00 [024] - -
                        Reset counter: 215
                        Time: 00:00:00
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 5J0 820 045 D    HW: 5J0 820 045 D
       Component: Man AC        H02 0202
       Revision: 0004SH02
       VCID: 2616FF76B8EDF10700D-8072
       Part No SW: 6R7 937 086 M    HW: 6R7 937 086 M
       Component: PQ25 BCM      H30 0555
       Revision: -3------    Serial number: --------------
       Coding: 64980B3808010000002008002C2B08C00000400F60000000020010000000
       Shop #: WSC 13765 790 00046
       VCID: 4DC460DAFDDBE25FE17-8018
       Subsystem 1 - Part No SW: 6R0 959 801 AJ    HW: 6R0 959 801 AJ  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  006 5210
       Coding: 020000
       Subsystem 2 - Part No SW: 6R0 959 802 AQ    HW: 6R0 959 802 AQ  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  006 5210
       Coding: 020000
       Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
       Component: VW10AirbagT21 H10 0020
       Revision: --------    Serial number: 003GW00GD172
       Coding: 003231
       ROD: EV_AirbaVW10BPAVW250_VW31.rod
       VCID: 49CC54CA0933FE7FCDF-801C
       Part No SW: 5J0 920 811 D    HW: 5J0 920 811 D
       Component: KOMBI         H03 0306
       Coding: 120800
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
       VCID: 280AF14EB279E777321-807C
       Part No SW: 6N0 909 901     HW: 6R7 937 086 M
       Component: GW-K-CAN TP20 H30 0555
       Revision: -3------
       Coding: 032200
       VCID: 70BAD92E4AA9EFB7AA1-8024
       Component: IMMO          H03 0306
       VCID: 6A8ECB466CF51567E45-803E
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 10110
       Shop #: WSC 13765
       VCID: 303A192E8369AFB7EA1-8064
    00566 - Steering Assistance Operation
       Part No SW: 5J0 035 152 A    HW: 5J0 035 152 A
       Component: Radio         H10 0010
       Revision: R0000000    Serial number: SKZAZ6M6104615
       Coding: 050002000006
       VCID: 201AE96EDAC91F377A1-8074
    00856 - Radio Antenna
                        Fault Status: 01101011
                        Reset counter: 185
                        Mileage: 88324 km
                        Date: 2017.12.07
                        Time: 17:30:24
    End----------(Elapsed Time: 00:42, VBatt start/end: 12.3V/12.3V)-----------
    Jul 2017
    Kosovo
    This is all PR-CODE
    A9E AZ0 B0A B64 C00 C0P D37 E0A EA0 FOY FB0 FC0 G02 G0C GR0 H2Z J0N K8G L07 L0L NOV NC1 NG0 NM1 PKC PSN Q1A QA0 QE0 QG1 Q16 QJ2 QN2 QV0 RAA SIG TF3 U0C UF0 UG0 V0A VF0 VK0 VL0 0A2 0AS 0BA 0C0 0EJ 0F9 OKA 0N2 0P0 0RA 0SS 0TA 0UA 0XL 0Y1 0YA 1AC 1C1 1D0 1E0 1EE 1G2 1JA 1KT 1L1 1MG 1N2 INK IPA 1Q0 1RX 1S1 1SA 1U0 1W0 1X0 1Z0 1ZG 2A0 2B1 2C5 2G5 2JG 2LB 2V1 2WA 3B3 3C0 3CA 3FA 3GA 3H0 3J1 3L3 3LE 3N0 3NC 3Q1 3RC 3S4 3U1 3W3 3ZB 4A0 4B1 4GF 4K3 3KC 4L2 4LA 4N1 4P2 4QU 4R2 4SE 4TB 4UE 4X0 4XC 4YA 4Z5 5C8 5D1 5DX 5J0 5K7 5N2 5RQ 5SJ 5TC 6A0 6E0 6EA 6F0 6FF 6KJ 6M0 6N0 6NJ 6PA 6Q4 6R1 6SC 6XD 6Y0 7A0 7AA 7B0 7E0 7JQ 7K0 7L3 7M5 7MQ 7N0 7P0 7PC 7Q0 7QA 7X0 8AK 8BB 8GG 8KT 8L3 8M1 8N4 8P1 8Q1 8QL 8RE 8TO 8TC 8V0 8W0 8WB 8X0 8Y4 8Z5 9AB 9GB 9HA 9M0 9P0 9Q1 9T0 9TA 9U0 9W0 9W3 9Y1
    What size brakes on car?
    41DC2C7D212308C3821C346D845210420801 CAYx Series
    41DC2C7D212308C3821C346D845210421401
    41DC2C7D212308C3821C346D845210421400
    41DC2C7D212308C3821C346D845210420800
    41DC2C7D212308C3821C346D845210401400 LHD
    41DC2C7D212308C3821C346D845210401401 TPMS LHD
    41DC2C7D212308C3821C346D845210400801 Alternate ESP function
    Please let me know if it codes..........no Skoda's here........
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  4. Likes Baholli, Uwe liked this post
    Jul 2017
    Kosovo
    Jack thank you very much for help but this is not my car , and my client don't have time to wait cause he need very much for car soo i says my client : When you have time come on and we find longcode for your skoda .Thank you all for everything Jack ,Iichel and Uwe for help.All the best
    Aug 2016
    Switzerland
    CAYA = 75hp 1.6 TDI = 256mm fronts, 200mm rear drums.
    I'm feeling like the codes from Jack should work
    My guesses:
    410124DB002300C3821C246D005200400000
    and
    410124DB002300C3821C246D005200800000
  8. Likes Baholli, Uwe, Jack@European_Parts liked this post
  9. #6
    What is the status on this from Kosovo?
    REPORT!
  10. Likes Baholli liked this post
  11. #7
    Aug 2016
    Switzerland
    NostraJackAss has spoken
  12. Likes Baholli, Jack@European_Parts, Uwe liked this post
  13. #8
    Jul 2017
    Kosovo
    i tell my client for longcode abs but he's actually in germany when he come on Kosova i make autoscan for you.thank you very much for interesing
  14. Likes Jack@European_Parts liked this post
