Results 1 to 10 of 13
Thread: 2018 Audi TTRS - 2.5L DAZA
    Oct 2017
    Canada
    Enjoy!
    Thursday,30,November,2017,11:19:32:64901
    VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4408.4
    VIN: WUACSAFVXJ1xxxxxx   License Plate:
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
              6C
    Address 01: Engine (------DAZA)       Labels: None
       Part No SW: 8S0 907 404 G    HW: 07K 907 309 E
       Component: 2.5l R5/4V TF H22 0002
       Revision: 53H22000
       Coding: 1A250032242600053620
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM25TFS0118S0907404G 001002
       ROD: EV_ECM25TFS0118S0907404B.rod
       VCID: 3A38E92FBDA21C9684-806E
    Readiness: 1110 0101
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2111
       Revision: 00H06V07
       ROD: EV_TCMDQ500021_001_VW36.rod
       VCID: 2E10D57F71EAC03628-807A
       Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
       Component: ESC           H42 0050
       Revision: 00000000    Serial number: 62996000000833
       Coding: 99AAF08D6A9915A900970869839A900635990F56A80010C10960AC
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
       ROD: EV_Brake1UDSContiMK100IPB_061.rod
       VCID: 48DC83E7F34E7E0602-801C
       Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0445868300
       Coding: 030C0C1720
       VCID: 3E30E53FA18A30B6B8-806A
       Part No SW: 8S0 820 043     HW: 8S0 820 043
       Component: AC Automat    H05 0040
       Revision: 20010000    Serial number: 17130000009000
       Coding: 400050100001041100
       ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
       ROD: EV_AirCondiVAPrehAU33x.rod
       VCID: 6C941F778776722646-8038
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: C06191B800PAG0MUFU03
       Operating and display unit 1 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
       Component: E774 BuA_1  H07 0020
       Serial number: 00000000000000000117
       Operating and display unit 2 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Serial number: 00000000000000041272
       Operating and display unit 3 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
       Operating and display unit 5 for air conditioning:
       Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
       Component: E778 BuA_5  H07 0020
       Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
       Component: BCM MQBAB HNA H36 0253
       Serial number: 01001715700115
       ROD: EV_BCMBOSCH_018.rod
       VCID: 085C43E7B3CEBE06C2-805C
       Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
       Component: 43x LL 170412  038 0371
       Serial number: 00000001704100300252
       Coding: 1BC7F7
       Serial number: 62871098
       Coding: 00005D
       Subsystem 3 - Part No SW: 8V0 941 531 S    HW: 8V0 941 531 S
       Serial number: 12 02 2015  00001202
       Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H08 0050
       Serial number: 0000009600363Z023002
       Coding: 150000
       Garage Door Opener Operating Unit:
       Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
       Component: GTO BF  H05 0010
       Serial number: 20170428185734 01007
       Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000069925220
       Valve Block 1 In Driver Side Front Seat:
       Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
       Component: N475 VB1 FSv  H07 0021
       Serial number: 7008173235E171501945
       Coding: 810500
       Valve Block 1 In Passenger Side Front Seat:
       Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
       Component: N477 VB1 BFSv  H07 0021
       Serial number: 7008173235E171501431
       Coding: 810500
       Revision: --------    Serial number: 39331716804547
       Coding: 0070150011
       VCID: 43C694CBCA685D5ED7-8016
    Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
       Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0082
       Serial number:       080617012
       ASAM Dataset: EV_AudiMagneRide 002008
       ROD: EV_AudiMagneRide_002_AU37.rod
       VCID: 45C28AD3C45C636EF9-8010
       Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
       Serial number: 003M9R0077G5
       Coding: BFCCF0C000800000A000001FC24800000065
       VCID: 4FEEA8FB1620A93E43-801A
       Occupant Detection:
       Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH000000000007E8683
       Coding: 303333
       Subsystem 2 - Part No SW: -----------    HW: 480 002 306 17
       Serial number: 357000000006B1E8652P
       Subsystem 3 - Part No SW: -----------    HW: 480 002 306 17
       Serial number: 358000000003B1E8652N
       Subsystem 4 - Part No SW: -----------    HW: 480 011 505 17
       Component: SideSensor_Dr  005 0108
       Serial number: 351001A0979AC5C38EAX
       Subsystem 5 - Part No SW: -----------    HW: 480 402 605 17
       Serial number: 3550002A324F384651C2
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 605 17
       Serial number: 3560002C32439CA273FC
       Part No SW: 8S0 907 129 AS    HW: 8S0 907 129 AS
       Component: Lenks. Modul  H07 0150
       Revision: --------    Serial number: 91335QF600675
       Coding: 2058
       ASAM Dataset: EV_SMLSKLOMQB 050001
       ROD: EV_SMLSKLOMQB_009_AU37.rod
       VCID: 0B567CEBA2B8D51EEF-805E
    Address 17: Instruments (J285)       Labels:* Redir Fail!
       Part No SW: 8S0 920 790 C    HW: 8S0 920 790 C
       Component: FBenRDW       H42 0325
       Coding: 082F1041398900080222ECC09800801000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 393AF623B8A4178E8D-806C
       Part No SW: 8S0 907 468 F    HW: 8S0 907 468 E
       Component: GW MQB TT3    022 0304
       Serial number: 18061710522153
       Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 013005
       ROD: EV_GatewContiAU33X.rod
       Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
       Component: J453 MFL  H01 0002
       Serial number: 20161128210705 RD087
       Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
       Serial number: 3892414104
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7762
       Serial number: HA1-00029.04.17
       Coding: 0701
       ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
       VCID: 4DD2B2F31C2C9B2E31-8018
       Part No SW: 8S0 907 566     HW: 4H0 907 566 F
       Component: SWA Master    H08 0060
       Serial number: 0444426572
       Coding: 030211
       VCID: 7CB42F37F716E2A6D6-8028
       Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
       Component: SWA Slave  H08 0060
       Serial number: 0444138121
       Coding: 030211
       Serial number: 090617EF925417
       Coding: 001F53225C00040100000402
       Coding: 8106
       ROD: EV_SteerAssisMQB_013_VW37.rod
       Part No SW: 8S0 035 466 A    HW: 8S0 035 466
       Component: MIB2_amp_P_TT H10 0440
       Revision: 00000001    Serial number: AUZ8ZAH5C004NZ9
       Coding: 0133040000AA2A2AAA0000010000
       ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
       ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
       VCID: 3424C7179FC6EAE65E-8060
       Serial number: 100617EFA07729
       Coding: 001F53225E00040100000402
       VCID: 42C891CFD5725456DC-8016
    Address 55: Headlight Range (J745)       Labels:* None
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 0362001123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
       VCID: 3620FD1F89BAF8F660-8062
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
       Part No SW: 8S0 035 025 F    HW: 8S0 035 025 B
       Component: MU-H-LNS-US   054 1135
       Serial number: A707F0HS001679
       Coding: 013364020000000011220002041A00002F0000E0007000047E
       VCID: 302CCB076BDED6C63A-8064
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
       Component: ControlUnit_H  H30 0206
       Serial number: APVAK108061700010130
       Component: Gracenote2  --- 3012
       Part No SW: 5Q0 980 556 A    HW: 5Q0 980 556
       Component: RVC Compact   H08 0172
       Coding: 0233640102002001000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 383CF32783AE0E8672-806C
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V)-----------
  2. Likes jyoung8607, Eric, Uwe, D-Dub liked this post
  3. #2
    Jun 2017
    @automat
    Could you create an adpmap of unit 5f?
    Stoke on Trent, England
    Is that a typo 2.5 or do you know something ETKA doesn't?
    Manufacturer: Audi, Date(s) Used: 05/2016-, Model: Audi TTRS Coupe/Roadster, Engine Code: DAZA, 294Kw, 400PS, 2.0 Ltr, 4 Cyls
    Manufacturer: Audi, Date(s) Used: 02/2017-, Model: Audi RS3 Sportback/Limousine, Engine Code: DAZA, 294Kw, 400PS, 2.0 Ltr, 4 Cyls
    As taken from my new VAG Engine & Transmission Codes app.
    New User Keith
    EC Sales Term Ltr kW Hp Cyl Mounting time Remark
    DAZA S 2.5 294 400 5 05/2016
    You should use Partslink24.
  6. Likes Uwe liked this post
    AFAIK the RS3 and TTRS have used the 2.5L 5-cylinder in all versions?
  8. Likes Uwe liked this post
  9. #6
    Oct 2017
    Canada
    @automat
    I stopped posting them because it's time consuming, but have most if not all of the adpmaps from the cars I post auto-scans of. These vehicles I have access once in a lifetime only so I grab as much as I can from them...
    Enjoy!
    ;SW:8S0-035-025-F   HW:8S0-035-025-B ---  Information Electr.
    ;Component:MU-H-LNS-US   054 1135, Coding:013364020000000011220002041A00002F0000E0007000047E
    ;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU37.rod
    ;Monday,04,December,2017,07:58:40:64901
    ;VCDS Version: Release 17.8.1 (x64)  Data version: 20171130 DS276.6
    ;VCID: 302CCB076BDED6C621-8064
    IDE00346-Summertime-automatic,automatic ,1
    IDE00768-Country identification: country of sale,CA ,2
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes ,3
    IDE01996-ENG99724-Installation list: specified installations-ECU coded,No ,3
    IDE01996-ENG137645-Installation list: specified installations-ECU coded 2,No ,3
    IDE02121-CD eject button,Enabled ,1
    IDE02122-Developer mode,not activated ,1
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
    IDE02502-Confirmation of installation change,1F 75 ,2
    IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
    IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0 ,8
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15 ,8
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0 ,8
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15 ,8
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0 ,8
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11 ,8
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0 ,8
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8 ,8
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present ,30
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present ,30
    IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,function_off_hmi_off ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,On ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
    IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.4 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
    IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_NAR ,30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present ,30
    IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,Deactivated ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
    IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
    IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
    IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
    IDE03580-Country code for mobile network,0 ,2
    IDE03902-Automatic ring break diagnostic,No automatic start ,1
    IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
    IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
    IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP ,1
    IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
    IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
    IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1 ,2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1 ,2
    IDE04521-Sporadic ring break detection,Visual ,1
    IDE04549-Telephone data services,On ,1
    IDE04550-Bluetooth: Sniff mode,OFF ,1
    IDE05111-Fee-based traffic information (TMC),65535 ,2
    IDE06697-Audio management mute function,Muting of audio sources ,1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Value_from_BAP_protocol ,1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Value_from_BAP_protocol ,1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0 ,16
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0 ,16
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE10668-Internal SIM card: use,automatic ,1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBV,3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB,3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s,3
    IDE11105-Brand-specific display of connect application, ,256
    IDE11153-Surroundings display: virtual camera positions-,32767 ,330
    IDE11153-Surroundings display: virtual camera positions-,65535 ,330
    IDE11153-Surroundings display: virtual camera positions-,4294967295 ,330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
    IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
    IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
    IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
    IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
    IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
    IDE11503-Satellite radio tuner: pre-activated subscription,02 ,1
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
    IDE11638-Bluetooth Audio Codec,FF ,1
    MAS00951-Bluetooth,On ,1
    MAS03690-Telephone,Data & language service active ,1
    MAS03782-WLAN,On ,1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
    ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAN_MIB ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,10
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,RLE ,10
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,LVDS_map_MMI_dashboard ,10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,10
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_MMI_dashboard ,10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,10
    ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
    ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
    ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
    ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
    ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
    ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
    ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
    ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
    ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
    ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
    ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
    ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
    ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
    ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
    ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
    ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
    ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
    ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
    ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
    ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
    ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
    ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
    ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
    ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
    ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
    ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
    ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
    ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
    ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
    ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
    ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
    ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
    ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
    Elapsed Time: 00:40
  10. #7
    Oct 2017
    Canada
    AFAIK the RS3 and TTRS have used the 2.5L 5-cylinder in all versions?
    So does the RSQ3
  11. Likes PetrolDave liked this post
  12. #8
    Quote Originally Posted by automat View Post
    So does the RSQ3
    I always forget the RSQ3 - just seems something wrong about RS being followed by Q
  13. Likes Uwe, Eric liked this post
  14. #9
    Jun 2017
    Guess what?
    It is possible to enable the Audi TT Heartbeat Sound via coding
    With the newest VCDS Beta there exist two new channels in unit 5F:
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,activated ,30
    It works for me (RS3, 2018) when I turn on the ignition. Not yet when turning off the ignition. Perhaps I need to actually drive.
    @automat
    Would you mind creating an adpmap of 5F with the newest VCDS Beta?
  15. #10
    Stoke on Trent, England
    EC Sales Term Ltr kW Hp Cyl Mounting time Remark
    DAZA S 2.5 294 400 5 05/2016
    You should use Partslink24.
    Sorry its a typo which I've now changed to 2.5
    New User Keith
