Results 11 to 20 of 29
Thread: New to me 2006 Jetta Non working wipers
    Wiper motor, V216
    T4p/1, ro/ws 2.5mm˛, from SB19 (30A), terminal 30
    T4p/2, br, 2.5mm˛, ground connection around left headlight area
    T4p/4, li/ws, 0.35mm˛, LIN to J519 F3
    So... do you have power/ground on /1 and /2? Can they carry load (light up a fog light bulb for example)?
    Data... that is /4 and it runs to the J519.
    Now to toss an extra item into the mix... do you have a rain/light sensor (G397)? I don't think you do, but if so, that sensor will be tied into the same LIN bus for the wiper motor as well.
    Jef
  2. Likes Jack@European_Parts liked this post
  3. #12
    Dec 2017
    01117 - Generator Terminal DF Load Signal
    This fault didn't show up in my earlier auto scan, what is it referencing to?
    Jeff, I will do my best to decode your last post, this is all new and greek to me LOL!
    Friday,01,December,2017,21:18:36:59552
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
    VIN: 3VWST71K66M773440   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWST71K66M773440   Mileage: 334490km-207842miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AB    HW: 028 101 223 8
       Component: R4 1,9L EDC G000SG  7550
       Revision: --H01---    Serial number: VWZ7Z0F3301138
       Coding: 0050071
       VCID: 6393528E275B321F273-8036
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0021122
       VCID: 71BF28C6EDA7908FA5F-8024
       Part No: 1K0 820 047 EC
       Component: Climatic PQ35   090 0505
       VCID: 698F40A6C577684FEDF-803C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000253641
       Coding: 14018E234004180000140000001400000008730B5C
       Shop #: WSC 23301 444 00792
       VCID: 2A0DFFAA00F1A357245-807E
       Subsystem 1 - Component: Fehler Lin-Slave 01
    02071 - Local Databus
                        Reset counter: 33
                        Mileage: 334491 km
                        Voltage: 11.70 V
                        Reset counter: 73
                        Mileage: 334491 km
                        Voltage: 12.55 V
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 33
                        Mileage: 334491 km
                        Voltage: 11.70 V
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7F5044210
       VCID: 2B03FAAE0F0BBA5FDF3-807E
                        Reset counter: 33
                        Mileage: 334491 km
                        Time: 06:17:14
       Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
       Component: 39 AIRBAG VW8R  032 7900
       Revision: 03032000    Serial number: 0038FD042AJV
       Coding: 0013113
       VCID: 392FD0E6F55718CF5DF-806C
       Subsystem 1 - Part No: 1K0 959 339 E
       Component: BF-Gewichtsens. 006 0005
       Subsystem 2 - Serial number: 6332MSME0D35450EF
       Subsystem 3 - Serial number: 6342MSME0D351D60D
       Subsystem 4 - Serial number: 6351HSME091C174AB
       Subsystem 5 - Serial number: 6361HSME091D1C49H
       Subsystem 6 - Serial number: 63727SME08254B4C6
       Subsystem 7 - Serial number: 63827SME086C4B5DK
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0000021
       VCID: 78A915E28EDDC1C7621-802C
       Part No: 1K0 920 952 L
       Component: KOMBIINSTRUMENT 3HL 4312
       Coding: 0023203
       Shop #: WSC 23317 444 85571
       VCID: 3333E2CED73BE29F973-8066
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800105C1284CC
       Coding: 3D3F0B60071002
       Component: IMMO            3HL 4312
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       VCID: 3635DBDAC449F7B7B0D-8062
       Part No: 1K1 909 144 K
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 137803281B09058F880F048051A0
       VCID: 74B121D292B5A5A74E9-8020
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 372BD6DEC3430EBFABB-8062
       Part No SW: 1K0 035 180 A    HW: 1K0 035 180 A
       Component: Radio DE2       008 0011
       Revision: 00008000    Serial number: VWZ4Z7E2009284
       Coding: 0040400
       VCID: 1E65237A4CB95FF748D-804A
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
       VCID: 313FE8C62D27D08FE5F-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 323DE7CA2821EB979C5-8066
       Revision: 00800000    Serial number:
       VCID: 2D07F4B6311FB46FC17-8078
                014 - Defective
    End----(Elapsed Time: 01:13, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
  4. #13
    Dec 2017
    Jef,
    SB19 30a (is this the fuse box location by the battery? If so, terminal 19 30a fuse, yes I can power a fog light using the ground by left headlight. This ground was tight and clean although I disconnected to clean anyway and re-tightened. I need to get a bently manual I'm sure will help understand the info your are providing.
    no rain/light sensor
    Lin to j519 F3 can you give me some guidance on what and how to test?
  5. #14
    May 2017
    Maybe stupid question but you have had your bonnet closed when you've tested the wipers with replacement motor? They are disabled if the bonnet is open and won't move an inch.
    Security measure by Volkswagen
  6. #15
    Dec 2017
    downtime, not a stupid question as it may help someone reading this post later on.. but yes I am aware of the hood switch and have verified its working and is closed when I test the wiper motors i've installed. As I understand it, the reason for this switch is because without it and the hood open the wipers would crash into the hood if wipers were turned on.
    Thank you for your question.
  7. #16
    May 2017
    Good Just wanted to check because it may not be so clear to everyone as you wrote.
    If you get your hands on another salvaged motor, try that. I still suspect that the electronics in the motor are kaput. The error codes and the problems you have are exactly the same when I fried our Golf Plus' motors probably due to a bad quality xenon set. Yes, that had cross-wiping wipers and 2 motors. Was quite expensive to fix them even with salvaged motors.
  8. Likes Vasco Ferraz liked this post
  9. #17
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    And if you apply 12V directly into the motor terminals? If it is good it should move.
    For precaution do that with the motor completely disconnected from the car electronics.
    Vasco Ferraz
  10. #18
    May 2016
    Voltage: 11.70 V
    Reset counter: 73
    Mileage: 334491 km
    Voltage: 12.55 V
    Reset counter: 33
    Mileage: 334491 km
    Voltage: 11.70 V
    something we all forget. Get busy working on a system and should have battery charger on @ all times as we have the doors open, ect. Noted voltages low here, should be enough to run wipers, but just saying..............
    LARIMORE
  11. Likes Eric, Uwe, Vasco Ferraz, MTShaun liked this post
  12. #19
    Dec 2017
    Ok its been a while since I posted on this problem, I just got home this morning from sometime out of state. Awaiting on my table was a brand new wiper motor so I connected it right away, ran vcds and same codes are present. Cleared codes and ran again, no change. It is very clear to me now that it is not the wiper motor itself. It is evident that a previous owner had replaced the wiper motor and I myself have installed 2 salvage yard motors and now a brand new one... I am leaning towards the J519 put could use some input on how to verify a bad J519 prior to changing/ purchasing another one. Jeff mentioned verifying data, I am no were close to an experienced individual on these types of test but can follow directions very well, please someone help. A recap of what I have already done... checked all fuses several times, changed motor with three different ones, took car to dealership 200 miles round trip (they were not much help, wanted me to come back for more diag time) bought vcds to help diag myself( so new to these types of problems and troubleshooting process) traced 12v battery power to plug at motor, tested ground at motor plug (good), can see voltage on signal wire at motor plug (not sure what it is supposed to be... seeing 10.x volts.) wiper stem works as it should per vcds, unplugged connectors at J519 to verify all pins were intact, also checked pins on J527 in steering column and checked for broken wires as best I could. Is there coding on the J519 that could be out of whack? Read something about possible coding but the dealership told me no? I am about at my wits end on this, I have countless hours chasing my tail. Thanks for all previous input and future input, I will not give up, its not in my dna..
  13. #20
    Dec 2017
    I'm also nervous that someone before me has already swapped out the j519 and didn't copy/transfer the original code over to a new one. No way for me to know but is a possibility right? how would I verify original coding or coding is correct?
