New to me 2006 Jetta Non working wipers
MTShaun
C?ID=323037
Hello all, this is my first post to this forum as I just received my Vag-com last night! Thank for having me!
In the last month I acquired my 2006 Jetta 1.9 tdi with 204k miles (now with 207,8xx). I bought it knowing the wipers didn't work thinking big deal, fuse right?! Well wrong. I've checked all fuses, hood switch works, washer fluid sprays work. I got a used motor/transmission assembly from local salvage yard, same status. I drove the car to a dealer 2 hours away for them to tell me they couldn't figure out the problem and I needed to schedule another appointment. They did tell me 3 modules were not communicating... no other details although they didn't charge me either so not much to complain about there.. I have also verified battery power to wiper motor plug, have continuity thorough ground wire and signal wire was showing 10.X volts. I have pulled my dash apart and checked pins and plugs at j519 module and j527 module in steering wheel and continuity to as many wires as I can trace. It was apparent some one else has been in there before as the J527 module had a sticker on the case that was peeled back. I have invested about 16 hours into figuring out this issue and has become apparent that I needed the Vag-com. I will post my auto scan below, I see there are a couple things in the scan I didn't know was an issue as well like the heater element and radio issue. I wonder if someone has changed the original radio to a lower option stock radio because XM radio sent me a 2 month trial radio offer but this one does not have satellite option. As far as I can tell the car is completely stock. I also had and airbag light come on after I had taken the dash and steering column apart (did all this with battery disconnected) which I was able to clear. Bulb out indicator was on until I discovered city light bulbs were missing, appears as someone replaced headlights and failed to install bulbs.
If I've missed any info please ask, I am trying my best for this 1st time around. Never used vag-com before and I do not have a service manual although this will be my next investment so suggestions are greatly appreciated of which one to get.
Thank you in advance for any help offered, I am very handy and competent just needing input where to go from here.
Best Regards
Friday,01,December,2017,11:37:35:59552
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
VIN: 3VWST71K66M773440   License Plate:
Mileage: 334470km-207830mi   Repair Order: 001
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWST71K66M773440   Mileage: 334470km-207830miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0F3301138
   Coding: 0050071
   VCID: 6393528E275B321F273-8036
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021122
   VCID: 71BF28C6EDA7908FA5F-8024
   Part No: 1K0 820 047 EC
   Component: Climatic PQ35   090 0505
   VCID: 698F40A6C577684FEDF-803C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000000253641
   Coding: 14018E234004180000140000001400000008730B5C
   Shop #: WSC 23301 444 00792
   VCID: 2A0DFFAA00F1A357245-807E
   Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
                    Reset counter: 32
                    Mileage: 334470 km
                    Voltage: 13.00 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 32
                    Mileage: 334470 km
                    Voltage: 13.00 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7F5044210
   VCID: 2B03FAAE0F0BBA5FDF3-807E
                    Reset counter: 32
                    Mileage: 334470 km
                    Time: 22:33:01
   Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
   Component: 39 AIRBAG VW8R  032 7900
   Revision: 03032000    Serial number: 0038FD042AJV
   Coding: 0013113
   VCID: 392FD0E6F55718CF5DF-806C
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0D35450EF
   Subsystem 3 - Serial number: 6342MSME0D351D60D
   Subsystem 4 - Serial number: 6351HSME091C174AB
   Subsystem 5 - Serial number: 6361HSME091D1C49H
   Subsystem 6 - Serial number: 63727SME08254B4C6
   Subsystem 7 - Serial number: 63827SME086C4B5DK
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78A915E28EDDC1C7621-802C
   Part No: 1K0 920 952 L
   Component: KOMBIINSTRUMENT 3HL 4312
   Coding: 0023203
   Shop #: WSC 23317 444 85571
   VCID: 3333E2CED73BE29F973-8066
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105C1284CC
   Coding: 3D3F0B60071002
   Component: IMMO            3HL 4312
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 3635DBDAC449F7B7B0D-8062
   Part No: 1K1 909 144 K
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74B121D292B5A5A74E9-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372BD6DEC3430EBFABB-8062
   Part No SW: 1K0 035 180 A    HW: 1K0 035 180 A
   Component: Radio DE2       008 0011
   Revision: 00008000    Serial number: VWZ4Z7E2009284
   Coding: 0040400
   VCID: 1E65237A4CB95FF748D-804A
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313FE8C62D27D08FE5F-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323DE7CA2821EB979C5-8066
   Revision: 00800000    Serial number:
   VCID: 2D07F4B6311FB46FC17-8078
            014 - Defective
End----------(Elapsed Time: 01:08, VBatt start/end: 13.0V/13.0V)-----------
Welcome to the VCDS forums OP and thank you for posting an auto-scan........
What is the status of stalk switches in VCDS blocks....?
Take a power probe or led test light and connect it to the can wires without applying power with the probe then pull the stalk or change position of speeds and see if any COM flash changes on blink of LED.
Is power and ground at motor sufficient?
Have you coded or adapted the wiper motor as per the RTFB?
Faults are pretty clear on local DB.......see WD and verify the twisted pair for CAN.
http://forums.ross-tech.com/showthr...a-you-should-have-a-baseline-understanding-of-!
JPPSG
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
downtime
C?ID=280813
Are you sure the motor assembly you got as replacement is ok? There's no CAN connection to wiper motor as it's on LIN bus. So there shouldn't be any CAN wires going to it. As far as I remember the LIN bus works on single wire.
The error you see is usually indicator that the wiper motor assembly is dead. You might get signal to the plug but the problem is inside the assembly, there's a controller chip that fries and it does not communicate with the BCM anymore. Same effect happens if you install bad quality aftermarket xenon set.
I would return the salvaged the part you got and get another one just to make sure.
I presume Jetta has only one motor for the wipers?
MTShaun
C?ID=323037
Thank you both for your quick replies.
I am playing with VCDS and figuring out some cool stuff! The wiper switch in the vcds blocks appears to be working because the status changes with each adjustment. I am not sure the motor assembly I got from the salvage yard is good or not, how can I test it? Also as I wrote in my initial post, I checked continuity to ground, it appears sufficient. The main power wire is same as battery voltage and the signal wire is 10+/- volts depending on selector stock. I don't know what is sufficient here...
The Jetta does only have one motor for the wipers in which I have become an expert in removing and installing during all my troubleshooting :)
If I get a good motor assembly would the car recognize it right away or would programming through vcds be in order?
Jef
HQ
You need to verify you have good power, ground and data at the wiper motor. If any of those is not to factory design, those fault codes will get flagged. If all 3 are to factory design, then bad wiper motor, or in some rare cases... bad J519. So tell me about your headlights....
MTShaun
C?ID=323037
I removed my wiper motor, salvage yard will refund me but they don't have another one. I did find one at another yard so I will pick this one up and give it a try. I will keep all of you posted on the results of this next replacement!
MTShaun
C?ID=323037
My headlights are factory replacements it looks like. They use the same wiring with h7 halogen bulbs.
Jef
HQ
MTShaun
C?ID=323037
Ok, so I put in another wiper motor. Same status no luck, I'm thinking it must the J519 Jef? On your chart I have power and ground at the motor, how do I check Data?
Jef
HQ
Wiper motor, V216
T4p/1, ro/ws 2.5mm², from SB19 (30A), terminal 30
T4p/2, br, 2.5mm², ground connection around left headlight area
T4p/4, li/ws, 0.35mm², LIN to J519 F3
So... do you have power/ground on /1 and /2? Can they carry load (light up a fog light bulb for example)?
Data... that is /4 and it runs to the J519.
Now to toss an extra item into the mix... do you have a rain/light sensor (G397)? I don't think you do, but if so, that sensor will be tied into the same LIN bus for the wiper motor as well.
MTShaun
C?ID=323037
01117 - Generator Terminal DF Load Signal
This fault didn't show up in my earlier auto scan, what is it referencing to?
Jeff, I will do my best to decode your last post, this is all new and greek to me LOL!
Friday,01,December,2017,21:18:36:59552
VIN: 3VWST71K66M773440   Mileage: 334490km-207842miles
   Coding: 0050071
   Revision: 00H13001
   Coding: 0021122
                    Reset counter: 33
                    Mileage: 334491 km
                    Voltage: 11.70 V
                    Reset counter: 73
                    Mileage: 334491 km
                    Voltage: 12.55 V
                    Reset counter: 33
                    Mileage: 334491 km
                    Voltage: 11.70 V
                    Reset counter: 33
                    Mileage: 334491 km
                    Time: 06:17:14
   Coding: 0013113
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Coding: 0000021
   Coding: 0023203
   Coding: 0001269
   Coding: 0001269
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
            014 - Defective
End----(Elapsed Time: 01:13, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
MTShaun
C?ID=323037
Jef,
SB19 30a (is this the fuse box location by the battery? If so, terminal 19 30a fuse, yes I can power a fog light using the ground by left headlight. This ground was tight and clean although I disconnected to clean anyway and re-tightened. I need to get a bently manual I'm sure will help understand the info your are providing.
no rain/light sensor
Lin to j519 F3 can you give me some guidance on what and how to test?
downtime
C?ID=280813
Maybe stupid question but you have had your bonnet closed when you've tested the wipers with replacement motor? They are disabled if the bonnet is open and won't move an inch.
Security measure by Volkswagen :)
MTShaun
C?ID=323037
downtime, not a stupid question as it may help someone reading this post later on.. but yes I am aware of the hood switch and have verified its working and is closed when I test the wiper motors i've installed. As I understand it, the reason for this switch is because without it and the hood open the wipers would crash into the hood if wipers were turned on.
Thank you for your question.
downtime
C?ID=280813
Good :) Just wanted to check because it may not be so clear to everyone as you wrote.
If you get your hands on another salvaged motor, try that. I still suspect that the electronics in the motor are kaput. The error codes and the problems you have are exactly the same when I fried our Golf Plus' motors probably due to a bad quality xenon set. Yes, that had cross-wiping wipers and 2 motors. Was quite expensive to fix them even with salvaged motors.
Vasco Ferraz
Portugal
C?ID=288561
And if you apply 12V directly into the motor terminals? If it is good it should move.
For precaution do that with the motor completely disconnected from the car electronics.
Larry Manton
C?ID=112505
Voltage: 11.70 V
Reset counter: 73
Mileage: 334491 km
Voltage: 12.55 V
Reset counter: 33
Mileage: 334491 km
Voltage: 11.70 V
something we all forget. Get busy working on a system and should have battery charger on @ all times as we have the doors open, ect. Noted voltages low here, should be enough to run wipers, but just saying..............
LARIMORE
MTShaun
C?ID=323037
Ok its been a while since I posted on this problem, I just got home this morning from sometime out of state. Awaiting on my table was a brand new wiper motor so I connected it right away, ran vcds and same codes are present. Cleared codes and ran again, no change. It is very clear to me now that it is not the wiper motor itself. It is evident that a previous owner had replaced the wiper motor and I myself have installed 2 salvage yard motors and now a brand new one... I am leaning towards the J519 put could use some input on how to verify a bad J519 prior to changing/ purchasing another one. Jeff mentioned verifying data, I am no were close to an experienced individual on these types of test but can follow directions very well, please someone help. A recap of what I have already done... checked all fuses several times, changed motor with three different ones, took car to dealership 200 miles round trip (they were not much help, wanted me to come back for more diag time) bought vcds to help diag myself( so new to these types of problems and troubleshooting process) traced 12v battery power to plug at motor, tested ground at motor plug (good), can see voltage on signal wire at motor plug (not sure what it is supposed to be... seeing 10.x volts.) wiper stem works as it should per vcds, unplugged connectors at J519 to verify all pins were intact, also checked pins on J527 in steering column and checked for broken wires as best I could. Is there coding on the J519 that could be out of whack? Read something about possible coding but the dealership told me no? I am about at my wits end on this, I have countless hours chasing my tail. Thanks for all previous input and future input, I will not give up, its not in my dna..
MTShaun
C?ID=323037
I'm also nervous that someone before me has already swapped out the j519 and didn't copy/transfer the original code over to a new one. No way for me to know but is a possibility right? how would I verify original coding or coding is correct?
