Hello guys,
I have coded an A5 tail lights this evening and everything worked as it should less the fog lights. Basicly when u press the fod light switch it nothing happens (the swich lights upf for 2 seconds and the turns itself off). The original values in adaptation channels were:
Channel/Old value/New value
181/65535/0
195/5124/5125
196/5156/5157
197/5251/5157
198/5283/5189
201/133/16388
202/165/16420
203/73/9
204/105/9
205/13/32772
206/45/32804
207/5/13
208/37/45
213/12594/17458
As I said all works as it should just i have no fog at all.
If you can help me out i would be gratefull.
Thank you
181/65535/0
195/5124/5125
196/5156/5157
197/5251/5157
198/5283/5189
201/133/16388
202/165/16420
203/73/9
204/105/9
205/13/32772
206/45/32804
207/5/13
208/37/45
213/12594/17458
Sunday,26,November,2017,13:56:40:25075
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8T3AA009302 License Plate:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 57
5F 6C
VIN: WAUZZZ8T3AA009302 Mileage: 195620km-121552miles
Address 01: Engine (J623-CGKA) Labels: 059-907-401-V1.clb
Part No SW: 8K1 907 401 K HW: 8K1 907 401 A
Component: 2.7TDI EDC17 H02 0008
Revision: 15H02---
Coding: 0114002C02070120
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM27TDI0118K1907401K 001009
ROD: EV_ECM27TDI.rod
VCID: 34669FD39F5773E136-8060
6 Faults Found:
4807 - EGR System
P0401 00 [096] - Insufficient Flow
5211 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Mileage: 195371 km
Date: 2017.11.24
Time: 21:46:24
Engine speed: 1552.00 /min
Normed load value: 99.6 %
Vehicle speed: 44 km/h
Coolant temperature: 44 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.340 V
Unlearning counter according OBD: 34
Crankshaft speed (RPM): 1552.0 /min
Vehicle speed: 41.94 km/h
Mean injection quantity: 56.69 mg/stroke
Fuel temperature: 21.6 °C
Fuel high pressure: actual: 454000 hPa
Rail pressure regulation: status-Bit 0: 00000101
Inj Crv st Inj Char Act Val 0-Bit 0: 00110100
5212 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Mileage: 195371 km
Date: 2017.11.24
Time: 21:46:25
Engine speed: 1536.50 /min
Vehicle speed: 48 km/h
Voltage terminal 30: 14.240 V
Unlearning counter according OBD: 53
Crankshaft speed (RPM): 1536.5 /min
Vehicle speed: 46.89 km/h
Mean injection quantity: 47.14 mg/stroke
Fuel temperature: 21.7 °C
Fuel high pressure: actual: 364600 hPa
4986 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [109] - Electrical Fault
Mileage: 188908 km
Date: 2017.08.29
Time: 13:30:33
Coolant temperature: 22 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.620 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Vehicle voltage terminal 30: 11580 mV
Coolant temperature: 22.5 °C
Glow status-Bit 0: 00000000
Glow status-Bit 8: 00000000
Glw Plg r LVS Ps: 14.06 %
Intake air temperature: 22.6 °C
5417 - Cylinder 5 Glow Plug Circuit (Q14)
P0675 00 [109] - Electrical Fault
Mileage: 188908 km
Date: 2017.08.29
Time: 13:30:33
5418 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 00 [109] - Electrical Fault
Mileage: 188908 km
Date: 2017.08.29
Time: 13:30:33
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K1 927 155 HW: 0AW 927 156 H
Component: 0AW 27 TDIRdW H02 0003
Revision: --H02--- Serial number: 0000000373
Coding: 000001
ASAM Dataset: EV_TCMVL381 A02006
ROD: EV_TCMVL381_AU57.rod
VCID: 71E856C7A0C506C91D-8024
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AM HW: 8K0 907 379 AM
Component: ESP8 front H04 0100
Coding: 1A0D08
VCID: 04060F1387770361C6-8050
02214 - Tire Pressure Warning
Fault Frequency: 25
Reset counter: 162
Mileage: 183381 km
Date: 2009.04.28
Time: 01:00:29
Hex Value: 0x4200
Hex Value: 0x4006
Hex Value: 0x1237
Hex Value: 0x18B4
Hex Value: 0x00FF
Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ
Component: BCM2 1.1 H90 0249
Coding: 050000
VCID: 000E0303936F1F41E2-8054
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000048634015
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 162
Mileage: 183376 km
Date: 2009.04.28
Time: 00:00:11
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 162
Mileage: 183376 km
Date: 2009.04.28
Time: 00:00:11
00956 - Key 2
Fault Status: 00100101
Reset counter: 178
Mileage: 195242 km
Date: 2017.11.21
Time: 20:41:10
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0073
Revision: AA000000 Serial number: 00001001321077
Coding: 00017025002C00000000
VCID: 4384CC0FC2F9C459BF-8016
03321 - Switch for Height Adjustment: Down
Fault Status: 00100011
Reset counter: 148
Mileage: 194198 km
Date: 2017.10.30
Time: 11:23:02
03319 - Switch for Cushion Angle: Down
Reset counter: 148
Mileage: 194198 km
Date: 2017.10.30
Time: 11:23:02
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0160
Revision: A1000000 Serial number: 01090720091396
Coding: 36120000
VCID: 7DF07AF7E49D72A989-8028
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000307621
Coding: 260050914134AF010009000300005D5D001C438802010101000000
Shop #: WSC 20346 133 174564
VCID: 3C76B7F3BF07BBA1FE-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 100709 H14 0070
Serial number: SWF09070105418
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10533053
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000107090311
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Fault Status: 00101100
Reset counter: 177
Mileage: 191596 km
Date: 2017.09.22
Time: 01:35:00
03395 - Control Module for High Beam Assistant
Reset counter: 22
Mileage: 188842 km
Date: 2017.08.27
Time: 12:15:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840919000692
Coding: 300101
VCID: 408EC303D3EFDF41A2-8014
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD042RUM
Coding: 30313433363030303030554A304C38543053
VCID: 4188C607D0E5D649AD-8014
Serial number: 6334MSME4822575EK
Serial number: 6344MSME4936146DK
Serial number: 6352QSME60313B348
Serial number: 6362QSME1F310F38O
Serial number: 63732SME3A324D1E6
Serial number: 63832SME3B324E22+
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IGA000IR
Coding: 000036
VCID: 3D70BAF7A41DB2A9C9-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 D HW: 8T0 920 931 D
Component: KOMBIINSTR. H33 0253
Revision: 00100000 Serial number: BYI76U179
Coding: 0F07000003000008000000
VCID: 387EABE38B3F97811A-806C
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0101
Revision: EB700052 Serial number: 5200E096250008
Coding: 00C303
VCID: 52AAF94B0D835DD104-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 190838E4240609
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H10 0073
Revision: AA000000 Serial number: 00001001313399
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 J HW: 8T0 959 793 D
Component: TSG FA H07 1301
Coding: 011012225000120102
Shop #: WSC 20972 001 1048576
VCID: 50AEF343038F2FC132-8004
Fault Frequency: 13
Reset counter: 176
Mileage: 193011 km
Date: 2017.10.05
Time: 11:37:00
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0118388302
Coding: 011A0E80003900850320000000000000
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 80
Reset counter: 253
Mileage: 126988 km
Date: 2015.07.30
Time: 20:14:41
02615 - Fuel Tank Cap; Lock
Fault Frequency: 80
Reset counter: 253
Mileage: 126988 km
Date: 2015.07.30
Time: 20:14:41
Reset counter: 162
Mileage: 183376 km
Date: 2009.04.28
Time: 00:00:11
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009057110
VCID: 4486CF13C7F7C36186-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 10000000275913
VCID: 34669FD3975773E136-8060
Part No: 8K5 907 357
Shop #: WSC 06324 000 00000
VCID: 77FC68DF06A158F9D3-8022
Part No SW: 4F0 035 056 B HW: 4F0 035 056
Component: Radio U STD H45 0020
Revision: AB001007 Serial number: 342G0097634599
Coding: 010003020100000001
VCID: 1F4C607F0ED1C0B9FB-804A
Address 57: TV Tuner (R78i) Labels: None
Part No SW: 4F0 919 129 B HW: 4F0 919 129
Component: HybridTV-DVB H06 0230
Revision: R0060000 Serial number: 76300802363101
Coding: 01020000
VCID: 2B5484AF4A692C1967-807E
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 666 D HW: 8T1 035 666 D
Component: H-BN-EU H41 0047
Revision: -------- Serial number: 483G 097527740
Coding: 010100020106A1EF01000F1E000000030001
VCID: 3B74B4EFBA09BC99F7-806E
Subsystem 1 - Part No: 8R0 060 884 E
Component: EUR 2009/2010 5805
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356GI091030630
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000317864
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J9790EX
Coding: 1020008
VCID: 387EABE34B3F97811A-806C
End-------------------------(Elapsed Time: 02:54)--------------------------
Thank you
