Fault Code Issues:( Audi Q7 4.2
atmclick
C?ID=318804
Hey guys!
Im still trying to work my way around VCDS, and have been reading up on the forums etc.
My 2007 Audi Q7 is not holding a charge, and it looks like there are a few open circuits..
I do have the Amp Fuse out,( I know the amp is messed up, and am in the process of getting it repaired.)
I Also have ESP Fuses out.
Here is the copy paste,
                Address 01: Engine       Labels: 079-907-560-BAR.clb
Control Module Part Number: 4L0 910 560 C    HW: 4L0 907 560 A
  Component and/or Version: 4.2l V8/4V          0060
           Software Coding: 01210009190F0160
            Work Shop Code: WSC 02101 444 59425
                      VCID: 281C24679B785506E2-807C
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Mileage: 182782 km
                    Date: 2017.10.08
                    Time: 18:13:07
                    RPM: 2071 /min
                    Load: 56.8 %
                    Speed: 46.0 km/h
                    Temperature: 93.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
002129 - Park/Neutral Switch Input Circuit
               P0851 - 004 - Short to Ground - Intermittent
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 20:16:44
..                    Load: 0.0 %
                    Temperature: 1.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 8.382 V
009523 - Ignition Switch; Run/Start Position Circuit
               P2533 - 002 - Open or Short to Ground
                    Fault Status: 01100010
                    Mileage: 182784 km
                    Temperature: 11.0°C
                    Temperature: 12.0°C
                    Voltage: 10.160 V
049425 - No Communication with Battery Energy Control Module
               U0111 - 008 -  - Intermittent
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:34
                    RPM: 664 /min
                    Load: 15.3 %
                    Temperature: 75.0°C
                    Temperature: 24.0°C
                    Voltage: 14.224 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:29
                    RPM: 717 /min
                    Load: 18.4 %
                    Temperature: 95.0°C
                    Temperature: 42.0°C
                    Voltage: 14.097 V
Readiness: 0010 0000
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
          52 55 56 61 62 65 67 6C 6D 6F 72 76 77
VIN:   Mileage: 182780km-113574miles
03-ABS Brakes -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
   Component: 4.2l V8/4V          0060
   Revision: --H16---    Serial number:
   Shop #: WSC 02101 444 59425
                    Mileage: 182782 km
                    Date: 2017.10.08
                    Time: 18:13:07
                    RPM: 2071 /min
                    Load: 56.8 %
                    Speed: 46.0 km/h
                    Temperature: 93.0°C
                    Temperature: 29.0°C
                    Voltage: 14.097 V
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 20:16:44
                    Temperature: 1.0°C
                    Temperature: 4.0°C
                    Voltage: 8.382 V
                    Mileage: 182784 km
                    Temperature: 11.0°C
                    Temperature: 12.0°C
                    Voltage: 10.160 V
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:34
                    RPM: 664 /min
                    Load: 15.3 %
                    Temperature: 75.0°C
                    Temperature: 24.0°C
                    Voltage: 14.224 V
               U0121 - 008 -
                    Fault Frequency: 111
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:29
                    RPM: 717 /min
                    Load: 18.4 %
                    Temperature: 95.0°C
                    Temperature: 42.0°C
                    Voltage: 14.097 V
   Part No SW: 09D 927 750 BR    HW: 09D 927 750 BR
   Component: AL 750 6A           0915
   Revision: 00H52000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 7F4EDF3B2E7632BEF3-802A
                    Reset counter: 197
                    Mileage: 44503 km
                    Date: 2009.10.15
                    Time: 10:30:05
Address 03: ABS Brakes
   Component: FBSAUDIC6 ELV   H31 0210
   Revision: 27120501    Serial number: 10601000413678
   Coding: 0000143
   VCID: 6386734BA2DEF65EF7-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H27 0080
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H45 0060
8 Faults Found:
01176 - Key
                    Fault Frequency: 62
                    Reset counter: 132
                    Mileage: 180439 km
                    Date: 2017.06.16
                    Time: 22:43:56
00191 - Passenger's Door Handle Touch Sensor (G416)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 37
                    Mileage: 180339 km
                    Date: 2017.06.11
                    Time: 20:24:50
00166 - Access/Start Authorization Switch (E415)
                    Fault Status: 00111110
                    Fault Frequency: 7
                    Reset counter: 109
                    Mileage: 180406 km
                    Date: 2017.06.16
                    Time: 21:58:51
                    Fault Frequency: 37
                    Reset counter: 132
00955 - Key 1
                    Fault Status: 00110010
                    Reset counter: 104
00532 - Supply Voltage B+
                    Reset counter: 132
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 18:59:01
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 109
                    Mileage: 182162 km
                    Date: 2017.08.24
                    Time: 00:25:21
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:38
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 331GL087527015
   Coding: 0002003
   Shop #: WSC 02116 444 04990
   VCID: 383CF4274BD8C58672-806C
   Subsystem 2 - Serial number: 00000001836152
   Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
   Subsystem 4 - Serial number: 010535ÿ
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 66
                    Reset counter: 133
                    Time Indication: 15
00658 - Control Head
                    Reset counter: 40
                    Mileage: 182380 km
                    Date: 2017.09.27
                    Time: 19:23:33
                    Reset counter: 132
                    Time Indication: 15
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Component: KLIMABETAETIGUNGH05 0040
   Revision: 00---008    Serial number: 00000000028362
   Coding: 0524328
   VCID: 618A7943B8C2E44EE5-8034
                    Fault Frequency: 25
                    Reset counter: 93
                    Mileage: 182066 km
                    Date: 2017.08.03
                    Time: 16:33:44
                    Voltage: 9.20 V
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:39
                    Bin. Bits:   001111
   Part No SW: 4F0 910 279 F    HW: 4F0 907 279 A
   Component: ILM Fahrer      H15 0180
   Coding: 0114123
   VCID: 2C14D8778F80792606-8078
   Component: Wischer AU716   H11 0030
   Coding: 00064792
   Shop #: WSC 31414
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150059
   Shop #: WSC 31414
02748 - Solenoid for Bi-Xenon Shutter; Left
                    Fault Status: 01111011
                    Reset counter: 93
                    Mileage: 180524 km
                    Date: 2017.06.19
                    Time: 10:43:00
                    Reset counter: 132
                    Mileage: 182740 km
                    Date: 2017.10.04
                    Time: 17:43:00
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.27
                    Time: 22:06:00
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.27
                    Time: 22:08:00
Address 0E: Media Player 1
Address 0F: Digital Radio
   Component: 73 AIRBAG AUDI8RH37 0210
   Revision: 02H37000    Serial number: 0038QD021Y89
   Coding: 0014131
   VCID: 2B16DB6B8A8E7E1E0F-807E
   Subsystem 1 - Part No: 4L0 910 339
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 6332QSME0E330965F
   Subsystem 3 - Serial number: 6342QSME0E06107FJ
   Subsystem 4 - Serial number: 6352QSME0E023807B
   Subsystem 5 - Serial number: 6362QSME0E102773C
   Subsystem 6 - Serial number: 63734SME0C591B1FC
   Subsystem 7 - Serial number: 63834SME0C5A0A051
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Revision: 00H02000    Serial number: 90026061120004
   Coding: 0012242
   VCID: 271E275B96665A7EEB-8072
   Component: E0221           H07 0090
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 18:58:14
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:39
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
   Component: KOMBIINSTR. M73 H16 0070
   Revision: 00400000    Serial number: 53K55WV46
   Coding: 2641263
   Shop #: WSC 60635 000 1048576
   VCID: 2306334BE25EB65EB7-8076
                    Reset counter: 132
                    Mileage: 180406 km
                    Date: 2017.06.15
                    Time: 06:03:33
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:32
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D06421805B
   Coding: F5D7FE77347A02
   VCID: 6C9418774F00B92646-8038
                    Reset counter: 89
                    Mileage: 182775 km
                    Date: 2017.10.05
                    Time: 13:11:46
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:39
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:57:54
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:31
   Part No SW: 4F0 910 760     HW: 4L0 959 760
   Component: Sitzmemory FS   H01 0100
   Revision: 00000000    Serial number: 00000000896401
   Coding: 0082954
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:41
Address 37: Navigation
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F20.04.0600H0500000010027ÿ
   Subsystem 4 - Serial number: 010027ÿ
                    Fault Frequency: 11
                    Reset counter: 107
                    Mileage: 182140 km
                    Date: 2017.08.18
                    Time: 14:40:06
02857 - Supply Voltage for Lane Change Assistance Control Module 2
                    Fault Frequency: 11
                    Reset counter: 107
                    Mileage: 182140 km
                    Date: 2017.08.18
                    Time: 14:40:09
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.27
                    Time: 13:04:22
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0051915
   VCID: 2F2ECF7BBE96023E23-807A
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:39
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01012824010000
   Coding: 7632925
   VCID: 312AC903A8A214CE35-8064
01134 - Alarm Horn (H12)
                    Reset counter: 93
                    Mileage: 168065 km
                    Date: 2016.12.23
                    Time: 03:07:39
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:41
02956 - Lamp in Trunk/Hatch Lid; Left
                    Fault Status: 00101001
                    Reset counter: 130
                    Mileage: 182775 km
                    Date: 2017.10.05
                    Time: 13:08:46
                    Bin. Bits:  010 000
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:30
Address 47: Sound System
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000024455
   Coding: 0012001
   VCID: 5EF042BF89BCDBB6D8-800A
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:00
                    Voltage: 13.800 V
                    Temperature: 4.0°C
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:00
                    Voltage: 13.900 V
                    Temperature: 5.0°C
                    Reset counter: 132
                    Mileage: 182784 km
                    Date: 2017.11.10
                    Time: 11:44:00
                    Voltage: 8.200 V
                    Temperature: 77.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0051915
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Component: AFS 1           H01 0010
   Coding: 0000021
                    Reset counter: 40
                    Mileage: 182136 km
                    Date: 2017.08.12
                    Time: 19:36:53
                    Fault Status: 11100100
                    Reset counter: 93
                    Mileage: 182792 km
                    Date: 2017.11.26
                    Time: 22:08:30
Address 56: Radio
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000013194
   Shop #: WSC 03106 444 84416
   VCID: 64847057A7D0F1660E-8030
   Component: von VA0  1234567890
   Coding: 344630393135313035442056413031323334353637383930
   Shop #: WSC 13918 002 1048576
                    Fault Frequency: 23
                    Mileage: 182784 km
                    Date: 2017.10.27
                    Time: 17:42:44
                    Reset counter: 132
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 20:19:00
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Coding: 0051722
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:39
   Revision: 00050100    Serial number: 00000900021699
   Coding: 0062424
   VCID: 2208364FFD44BF56BC-8076
                    Fault Status: 11101101
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 22:08:35
                    (no units): 0.0
                    Voltage: 14.20 V
                    (no units): 36.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 67: Voice Control
   Part No SW: 4L0 910 441     HW: 4L0 907 441
   Component: J772__Rearview      0020
   Revision: --H10---    Serial number: 525PA8-J630243
   Coding: 1000101
7 Faults Found:
02283 - Video Connection to Output [End Unit]
                    Fault Frequency: 58
                    Reset counter: 130
                    Mileage: 170639 km
                    Date: 2017.02.11
                    Time: 15:01:16
                        Reverse ON
                    Count: 4
                    Reset counter: 132
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 18:58:09
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Fault Status: 01101101
                    Reset counter: 93
                        Reverse OFF
                    Count: 3
02203 - Audio / Video Input 1
                    Reset counter: 104
                    Mileage: 182056 km
                    Date: 2017.08.01
                    Time: 16:16:59
                        Reverse OFF
                    Count: 3
                    Reset counter: 93
                        Reverse OFF
                    Count: 3
                    Reset counter: 104
                    Mileage: 182056 km
                    Date: 2017.08.01
                    Time: 16:16:59
                        Reverse OFF
                    Count: 3
03005 - Video change-over
                    Fault Status: 00101110
                    Reset counter: 93
                    Mileage: 182784 km
                    Date: 2017.11.27
                    Time: 22:04:45
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 A
   Component: ValeoHeckdeckel H20 0280
   Revision: --H20001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD29.04.06--H20001001A0092ÿ
   Subsystem 4 - Serial number: 1A0092ÿ
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:38
   Component: ILM HINTEN 2    H05 0040
   Revision: AAH05044    Serial number: 001565502-----
   Coding: 0003843
   Shop #: WSC 02132 444 57211
   VCID: 26002A5F916C4376D0-8072
   Component: J_245_EE14_SKB09H10 0160
   Component: J_394_EE14_SKB09H10 0160
   Component: J_392_EE14_SKB09H10 0160
                    Fault Frequency: 11
                    Reset counter: 132
                    Mileage: 182142 km
                    Date: 2017.08.12
                    Time: 19:38:01
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:38
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Coding: 0051722
02123 - Door Warning Light / Entry Light
                    Reset counter: 92
                    Mileage: 180458 km
                    Date: 2017.06.19
                    Time: 01:10:49
                    Reset counter: 133
                    Mileage: 182784 km
                    Date: 2017.11.26
                    Time: 21:50:38
   Part No SW: 4F0 910 283 D    HW: 4F0 919 283 D
   Component: Parkhilfe 4-Kan H09 0030
   Revision: 00H09000    Serial number: 11720606103961
   Coding: 0021246
   VCID: 25022D53EC6A486ED9-8070
01543 - Parking Aid Warning Chime (H15)
                    Fault Status: 01101001
                    Fault Frequency: 11
                    Reset counter: 75
                    Mileage: 182246 km
                    Date: 2017.09.24
                    Time: 13:09:43
                    Reset counter: 132
                    Mileage: 182784 km
                    Date: 2017.11.15
                    Time: 21:27:56
Address 77: Telephone
End-----(Elapsed Time: 02:08, VBatt start/end: 9.6V/9.8V. VIgn 9.8V)-------
Larry Manton
C?ID=112505
See voltages all over the place here, noted an 07, would have this battery load tested too start with.
As Nostra Jack would say, anything over 4 years is a gift, I always hope for more, and on that subject is this a OEM type battery, before we chase our tails.
Larimore
atmclick
C?ID=318804
Hey Larry,
Thanks for chiming in.
When I accessed the Battery Reg,
I noticed that the coding for serial said 1234567, or something along that line.
I dont believe it is coded correctly.. Still havent had the chance to take the seat off and look to see whats installed.
I bought this suv knowing it had an issue, but thought it was just related to the leaking sunroof. Had that fixed. So no more water issues.
atmclick
C?ID=318804
Thanks for your response Jack. Any reason you’d point those two out amongst the rest?
Thanks !
