Audi A3 8V Cruise Control retrofit
kimbr
Oslo, Norway
C?ID=132499
Hi.
I have now retrofitted a cruise control to my A3 8V 2015-model.
I have coded it in the steering wheel coding, but long coding helper on the engine module dosen’t exist.
Does anyone know what I can change the code to in the ECU to get the cruise control to work?
Address 01: Engine (J623-CYVB) Labels: None
Part No SW: 04E 906 027 CJ HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 7798
Revision: R5H21---
Coding: 02250032240401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
ROD: EV_ECM12TFS01104E906027CJ.rod
VCID: 6EFD1B31B196504A3B-803B
kimbr
Oslo, Norway
C?ID=132499
Thanks, but that did not work.
I got an error with the start-stop function when I did that.
kimbr
Oslo, Norway
C?ID=132499
Do you have any other suggestions? I am eager to start using my CC...
Dana
Western PA, USA
Post the Auto-Scan in the current condition and if you have one saved prior to any modifications please post it as well.
Edit, also let us know if you retrofitted the Curise Control via Stalk/Lever -or- the Curise Control via Multi-Function Steering Wheel type. Pert numbers couldn't hurt is you have those handy.
kimbr
Oslo, Norway
C?ID=132499
I have retrofitted a cruise Control stalk.
I get this error in the instruments panel when I change the coding:
"Automatic start/stop: system fault! Function unavailable".
Here are a full scan, after I have change the coding. I deleted all the fault codes before I changed the coding.
Friday,19,September,2014,13:08:19:00341
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8V0FA026843   License Plate:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
   Revision: R5H21---
   Coding: 02250032242401082000
   ROD: N/A
   VCID: 6EFD1B31B196506E79B-803B
No ASAM data for: "EV_ECM12TFS01104E906027CJ" (AU37)
17158 - ROD - Unknown Error Code
          - 00 [047]
                    Fault Frequency: 7
                    Mileage: 750 km
                    Date: 2014.09.16
                    Time: 08:03:32
17149 - ROD - Unknown Error Code
          - 00 [175]
                    Fault Frequency: 9
                    Mileage: 750 km
                    Date: 2014.09.16
                    Time: 08:03:32
   Part No SW: 0CW 300 047 S    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5202
   Revision: 00043014    Serial number: CU501406255937
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 4BBBB2A5E2C445463E5-801E
   Revision: 00000000    Serial number: 61824000000195
   Coding: 12F16AA224221272017F060441C62548562448806082A4F2002100788608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 45AF849DC4A0B336E81-8010
8291 - Databus
                    Fault Frequency: 18
                    Reset counter: 115
                    Mileage: 750 km
                    Date: 2014.09.16
                    Time: 08:03:30
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [008] - -
                    Fault Frequency: 9
                    Reset counter: 115
                    Mileage: 750 km
                    Date: 2014.09.16
                    Time: 08:03:32
   Serial number: 003M2R07F20Z
   Coding: 98CCC0000C0000005C5400CA004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 000 107 14
   Serial number: 357670000006DB49301W
   Subsystem 2 - Part No SW: -----------    HW: 480 000 107 14
   Serial number: 3586700000039B49301Q
   Subsystem 3 - Part No SW: -----------    HW: 480 402 306 14
   Serial number: 3516502C71617D20B0EA
   Subsystem 4 - Part No SW: -----------    HW: 480 402 306 14
   Serial number: 3526502BF169752480CH
   Subsystem 5 - Part No SW: -----------    HW: 480 401 505 14
   Serial number: 3556502B9157E9E1633N
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 2286502A31697524411Z
   Pedestrian protection crash sensor; passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 2296502A31697521120U
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 207 14
   Serial number: 2306502C5156E9E0D2FS
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02071404400972
   Coding: A418
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 862DC3913926F82E21B-80D3
   Part No SW: 8V0 920 871     HW: 8V0 920 871
   Component: KOMBI         H02 4291
   Coding: 07A40A082B8000080100AA001000000000000000
   VCID: F9D7B86D78D887D65C9-80AC
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002164113
   Coding: 030100042F0864005B000248100B00000001010000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_AU37.rod
   VCID: 42A59F81D58E840ECD3-8017
   Serial number: 24 06 2014  C0070782
   Serial number: 7023143703
   Serial number: 20061406070851
   Coding: 00108F204000040000001002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40A19589DB82961EDB7-8015
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 41A7908DD0889F16D49-8014
   Serial number: 21061404081506
   Coding: 001087204000040000001002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3FA39675A67CE9E6A2D-806A
   Part No SW: 8V0 035 842 B    HW: 8V0 035 842 B
   Component: MU-S-D-ER     041 0420
   Serial number: A7E00706142707
   Coding: 01730300FF0A000011111101000A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 364DF351894628AE71B-8063
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY304D5F
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: C1000010061400020005
Dana
Western PA, USA
01-Engine:
OK, according to the limited #01 coding information that is available and the PR codes located by VIN (7L6 - Start/stop system with regenerative braking), the vehicle should have start-stop installed. Tweaking the CCS installed bit alone in the 01-Engine coding shouldn't cause Start/Stop issues but the fault code descriptions would be helpful, which leads me to the next concern..
- 00 [047]
- 00 [175]
Release 12.12.2 isn't up to date which explains that missing ROD file in the engine and lack of fault codes descriptions. That wasn't an issue in the 1st post so I suspect you have a Beta release installed. It would be highly recommended to use Beta 14.8.1 for this retrofit so please post the current scan with it if you need further assistance.
16-Steering wheel:
I see 2 possible configurations in the #16 module coding:
  • Cruise Control controlled via Turn Signal Lever
  • Cruise Control controlled via Separate Lever
You currently have the Separate Lever type enabled, is that the stalk type or do you have the Turn Signal Lever hardware installed instead? If you have a scan saved prior to any modifications please post it (or link us to it if you already have it posted online somewhere).
kimbr
Oslo, Norway
C?ID=132499
Hi.
Here you have a full scan before and after with 14.8.1 beta.
The steering wheel coding is ok, I have already change the coding there.
I changed the coding from 02250032240401082000 to 02250032242401082000 in engine, as you suggested.
Before:
Thursday,09,October,2014,16:45:23:00341
VCDS Version: 14.8.1.0 (x64)
Data version: 20140905
Mileage: 1294km-804mi   Repair Order:
VIN: WAUZZZ8V0FA026843   Mileage: 1294km-804miles
   Revision: R5H21---
   VCID: 4BBBB2A5E2C445627C-801E
   VCID: 45AF849DC4A0B312AA-8010
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Revision: 20026000    Serial number: 00000000367118
   Coding: 03000004000000001000000000001000
   VCID: 334BCA459A343DA214-8066
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011418501993
   Coding: 04041A46C24122FD43C44004001C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 002155899B02563AD9-8055
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
   Component: WWS370 140618  042 0580
   Serial number:         140625000958
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22848121
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 15 04 2014  00001141
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231418600162
   Coding: 0000050011
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3B5BE265B264F5E2CC-806E
   Pedestrian protection crash sensor; front passenger side:
   Coding: A418
   VCID: 062D4391B926780AE3-8053
   VCID: 79D7386DF8D807F29E-802C
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   ROD: EV_GatewLear.rod
   VCID: 42A59F81D58E842A8F-8017
   VCID: 40A19589DB82963A99-8015
   Coding: 8103
   ROD: EV_SteerAssisMQB_AU37.rod
   VCID: 41A7908DD0889F3296-8014
   VCID: 3FA39675A67CE9C2E0-806A
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 018A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75CF345DD4C06392FA-8020
   VCID: 364DF3518946288A33-8063
   Sound System:
End-------------------------(Elapsed Time: 03:00)--------------------------
After:
Thursday,09,October,2014,16:57:53:00341
   Revision: R5H21---
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 1294 km
                    Date: 2014.10.09
                    Time: 16:53:20
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 1294 km
                    Date: 2014.10.09
                    Time: 16:53:21
8291 - Databus
                    Reset counter: 163
                    Mileage: 1294 km
                    Date: 2014.10.09
                    Time: 16:53:19
          P1647 00 [008] - -
                    Reset counter: 163
                    Mileage: 1294 km
                    Date: 2014.10.09
                    Time: 16:53:20
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0000050011
   Coding: A418
   Coding: 8103
   Sound System:
End-------------------------(Elapsed Time: 03:01)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Sorry, but i always wanted to do this :)
I'm so stealing that! :cool:
Dana
Western PA, USA
Hi.
Before:
   Revision: R5H21---
   Coding: A418
After:
   Revision: R5H21---
17158 - Databus
          P1647 00 [167] - -
   Coding: A418
I looked through each of the scans but I wasn't able to spot a discrepancy. I however am not entirely sure if the new #16 module coding -or- #01 module coding directly caused the new faults.
What was the original (pre-retrofit) coding of #16?
If you code #16 back to the original value with the new (CCS) #01 coding and clear faults, do any of those reoccur?
kimbr
Oslo, Norway
C?ID=132499
I removed the coding for CCS in #16, and entered your coding in #01, but I got the same error and fault codes.
I'm pretty sure the coding in #16 is correct, since there is a drop down menu there, where I choose the correct CCS.
It seems to me the new coding for #01 is wrong, and has something to do with the start/stop function.
Since I get this error with the start/stop function in the instruments panel, and fault codes in #01 and #03 when I change it.
Dana
Western PA, USA
01-Engine
As far as I can tell the new 01 coding includes Cruise Control System (CCS - PR-8T2/8T6) installed and the old coding was Cruise Control System (CCS - PR-8T0) NOT installed. I do not have any alternative coding function suggestions.
It looks like this controller supports Adaptation (or Long Adaptation) function: Activation of start-stop function so I would make sure it is ON/Activated with each 01 coding variant to rule out a conflict.
16-Steering Wheel
I'm not entirely clear on the original, or pre-retrofit, coding of 16. If you already confirmed the wiring is present at the connector (to/from the engine and/or GAN GW, whichever this vehicle happens to use) and the Adv. measuring values/Adaptation channels with GRA or gra are reporting correctly I would like to believe it is correct.
Side note; It looks like factory installed CCS via the MFSW in NAR market MQB models do not use coding modifications due to the addition of that function in the 19-CAN Gateway. Our MQB A3 scan collection is limited but CCS would be standard equipment on those as well.
You may want to send this one to the dealer for SVM configuration. If you go that route please post the final scan so we can see what we missed!
m_bolc
San José, Costa Rica
C?ID=230356
Hello!
I just finished using VCDS for the first time on my 8V A3. That was a lot of fun.
Newbie question: do I need to buy anything to activate cruise control through multifunction steering wheel? I'm understanding that cruise control may be used through the MFSW. If so, can you guide me through the coding process? I saw the 5G coding page but didn't really understand it.
Dana
Western PA, USA
Hello!
That depends on the factory wiring and installed module(s). Please post the complete Auto-Scan before any modifications here for review.
m_bolc
C?ID=230356
Hello Dana,
Here is the auto scan:
Thursday,27,November,2014,18:12:27:29892
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8V2FA000583   License Plate: TBR043
Mileage: 9198km-5715mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2FA000583   Mileage: 9198km-5715miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 B    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 6387
   Revision: WAH08---
   Coding: 02110012230400082000
   ASAM Dataset: EV_ECM12TFS01104E906016B 001008
   ROD: EV_ECM12TFS01104E906016B.rod
   VCID: 2149CBAF30BD2E29405-8074
   Revision: 00000000    Serial number: 606040000015FD
   Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100080608
   VCID: 7BF5D9C7F291A4F93A9-802E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000054640
   Coding: 00000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 377D05F78E3940999E1-8062
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011406500433
   Coding: 04040842C001027D03044004B30407000000000000000000000000000000
   VCID: 79F9C3CFF8AD96E9285-802C
   Component: WWS370 140225  041 0580
   Serial number:         140227184035
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
   Component: G397_RLS  H06 0002
   Serial number: 20143063
   Coding: 06885D
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 29 11 2013  00001158
   Serial number: 000000000ZY140231TB1
   Serial number: 00000000000058976888
   Serial number: 003M2R05LNY8
   Coding: 98CCC000000000005C540000004800000065
   VCID: 4B954907E2B1D479CA9-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35767000000685500F0O
   Subsystem 2 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35867000000885500F0R
   Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
   Serial number: 35165029F14D3E72E40M
   Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3526502C112F6291710.
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
   Serial number: 3556502C513013F3D10/
   Revision: --------    Serial number: 07031404220752
   Coding: 0408
   VCID: 0603B833B953E911557-8053
   Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
   Component: KOMBI         H02 2220
   Coding: 07850200228000080500BA00100000
   VCID: 3C771ADBB71F63C1733-8069
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1164
   Revision: --------    Serial number: 0001674704
   Coding: 01010008200864005B000208000B00000001000000000000000000000000
   VCID: 3E7310D3A10371D15D7-806B
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 20 02 2014  B1311502
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 22021403110883
   Coding: 00100E20C100040100001002
   Coding: 0102
   VCID: 41896B2FD0FD0E29205-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 04031403110700
   Coding: 00100620CD00040100001002
   VCID: 3D7117DFAC056AC944D-8068
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E00403140672
   Coding: 01730000FF0A000021220001001A00002F0001440100010002
   VCID: 346732FB9F4FAB81BB3-8061
   Serial number: AUZ8Z9DY301DHC
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000019021400010341
End-------------------------(Elapsed Time: 02:47)--------------------------
I'd like to know if there is a possibility to also enable start-stop.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
No, you're missing too many vital components. So unless you plan on replacing a few control modules and add components to the car worth a 4 figure number of Euros's it's probably not worth it. ;)
mtl
Slovenia
C?ID=153305
Has this retrofit coding been resolved and the cruise control worked?
XPepino
Czech Republic
C?ID=91614
Hello
Does anyone already retrofitted cruise control to Audi A3 8V ?
I saw that Audi sell it like control switch and activating document.
Is there any way to activate without document ?
(I already have switch installed :-/ )
Thank you
