Hello Ross Tech Support,
I am working on below 2010 VW CC . The car engine and transmission was replaced. The transmission was changed from Manual to Automatic.
The other day Jeff helped me to re-code the ABS module (Big Thanks to Jeff). We coded the ABS module successfully with 0000380. After coding the ABS module there were couple lights left in the DASH, Red BRAKE light and Amber P for parking both are flashing.
When I check the ABS Module codes, I see below code which is for the Brake booster sensor. I have installed a working sensor from a running car but the fault code is still in the module.
Below is the full Auto Scan from the car. I appriciate if you could help me with fixing these errors.
Thanks,
PFaizulla
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795360670
Coding: 0000380
Shop #: WSC 05311 000 00000
VCID: 62E54324BD754656FC-8036
02543 - Vacuum Sensor for Brake Booster (G483)
Reset counter: 132
Mileage: 191527 km
Date: 2012.04.14
Time: 00:07:27
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 132
Hex Value: 0x0000
Wednesday,22,November,2017,14:49:47:15095
VCDS Version: 17.8.0.1 (x64)
VIN: WVWNL7ANXAE514197 License Plate: NOV 22
Mileage: 191520km-119005mi Repair Order:
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56
62 65 72 77
VIN: WVWNL7ANXAE514197 Mileage: 191520km-119005miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 997 029 J HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 1514
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 040401081C070360
Shop #: WSC 28940 002 104857
VCID: 3E5DD754694D42B6B8-806A
049717 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Temperature: 29.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
RPM: 1227 /min
Load: 48.6 %
Temperature: 21.0°C
Temperature: 17.0°C
Voltage: 11.303 V
Readiness: 0110 1101
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 3509
Revision: 05351113 Serial number: 00001106060243
Shop #: WSC 44551 111 44551
VCID: 256F1838ECDBF16ED9-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Reset counter: 40
Mileage: 191527 km
Date: 2012.04.14
Time: 00:07:46
18261 - Powertrain Data Bus
P1853 - 000 - Implausible Message from ABS Controller
Reset counter: 40
Mileage: 191527 km
Date: 2012.04.14
Time: 00:07:47
Coding: 0000380
Reset counter: 132
Mileage: 191527 km
Date: 2012.04.14
Time: 00:07:27
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 132
Hex Value: 0x0000
Reset counter: 132
Mileage: 191527 km
Date: 2012.04.14
Time: 00:07:27
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 221
Hex Value: 0x0000
Part No SW: 5K0 907 044 FE HW: 5K0 907 044 FE
Component: Climatronic H18 1112
Revision: 00001003
Coding: 0000001002
Shop #: WSC 01999 444 183143
VCID: 73CB3660DA8FDFDE87-8026
B10AB F0 [009] - Too Low
Reset counter: 131
Mileage: 191527 km
Date: 2017.11.21
Time: 19:55:05
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 D HW: 3AA 937 087 D
Component: BCM PQ47 H 413 0455
Revision: BB413001
Coding: 000000000000000000980211B4000D0440557C8841600D60648060200040
VCID: 3B5BDE40BA5F579E9F-806E
Subsystem 1 - Part No SW: 3C8 955 119 D HW: 3C8 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 12051 10 0603
Coding: 00B795
Component: RLS 200709 05 54 0402
Coding: 0330ED
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__302 VW10 HI 1916
Revision: 20013000 Serial number: 003E1PENEQNE
Coding: 0012338
VCID: 42A5A3A41DB52656DC-8016
Subsystem 1 - Part No: 3C8 959 339
Component: BF-Gewichtsens. 001 0003
Subsystem 2 - Serial number: 00000000003WUW
Subsystem 3 - Serial number: 0011.06.090000100000650194ÿ†63
Subsystem 4 - Serial number: 650194ÿ†6332MTS687031919 ÿ†63
Subsystem 5 - Serial number: 31919 ÿ†6342MTS694321899 ÿ†63
Subsystem 6 - Serial number: 21899 ÿ†6351HTS6HLFJ26KJ ÿ†63
Subsystem 7 - Serial number: J26KJ ÿ†6361HTS68941V8KJ ÿ†63
Subsystem 8 - Serial number: 1V8KJ ÿ†63727TS6NMJF46KJ ÿ†63
Subsystem 9 - Serial number: F46KJ ÿ†63827TS6U3BF46KR ÿ
Subsystem 10 - Serial number: F46KR ÿ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Revision: FF010040 Serial number: 20110624301516
Coding: 098A200000
Shop #: WSC 00015 115 12345
VCID: 6BFB2E0082BF071E4F-803E
Component: E221__MFL-TK6 H06 0022
Coding: E20000
49675 - Control Circuit for Ignition Key Lock Solenoid
B114A 13 [009] - Open Circuit
Reset counter: 131
Mileage: 191527 km
Date: 2017.11.21
Time: 23:07:58
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 J HW: 3C8 920 970 J
Component: KOMBI H02 0206
Coding: 240F00
Shop #: WSC 05314 115 12345
VCID: 334BF6609A0F9FDE47-8066
Part No SW: 7N0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H41 1620
Revision: H41 Serial number: 200611F2001136
Coding: 461006
Shop #: WSC 05314 123 12345
VCID: 3957C448B063658E8D-806C
Reset counter: 130
Mileage: 191527 km
Date: 2012.04.12
Time: 21:08:46
Part No SW: 3C0 959 433 AP HW: 3C0 959 433 AP
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 09453 444 17265
VCID: 78D1014C0BE9BC86B2-802C
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
02823 - Requirements for Locking the Steering Column Lock not met
Fault Status: 01110000
Reset counter: 132
Mileage: 191527 km
Date: 2012.04.13
Time: 23:24:11
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660293303
Shop #: WSC 05314 000 00000
VCID: 2977140840C3D50EFD-807C
Address 37: Navigation
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1533
Revision: 71009005 Serial number: 00000902698702
Coding: 0001207
VCID: 40A1A9AC13B93446CA-8014
Fault Status: 01100101
Reset counter: 132
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.302 1101
Revision: 1AH03256 Serial number: 00091630036502
Coding: 0000258
Shop #: WSC 44579 001 1048576
VCID: 3A55DB4475656E9684-806E
Component: KSG PQ46 RDK 052 0412
Coding: 13910F8001862E521204141FF08A0F0E085C01
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1620
Coding: 00000008
VCID: 6FC33A10BEA7FB3E63-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1533
Revision: 71009005 Serial number: 00000754798707
Coding: 0001206
VCID: 41A7ACA818B33D4EC5-8014
Part No SW: 3C8 907 801 C HW: 3C8 907 801 C
Component: J540 EPB3 VW-13618 0005
Revision: 010 Serial number: 00000000056820
Coding: 0010000
VCID: 2A75EB0485C5DE16F4-807E
03182 - Clutch Position Sensor (G476)
Fault Status: 11111010
Reset counter: 131
Voltage: 11.70 V
Count: 57
Hex Value: 0x1261
Hex Value: 0x0001
Hex Value: 0x1010
Component: AFS-Steuergeraet 0148
Coding: 3503304
VCID: 3449F57C570198E65E-8060
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0008
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0008
Coding: 00000053
01537 - Vehicle Level Sensor; Supply Voltage
Fault Status: 11101000
Fault Frequency: 23
Reset counter: 132
Mileage: 191527 km
Date: 2012.04.13
Time: 22:51:17
Voltage: 11.22 V
ABS 1
00497 - Sensor for Vehicle Leveling; Rear
007 - Short to Ground - MIL ON
Fault Status: 11100111
Fault Frequency: 26
Reset counter: 132
Voltage: 11.22 V
ABS 1
Fault Frequency: 26
Reset counter: 132
Voltage: 11.22 V
ABS 1
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0034
Revision: -----19S Serial number: VWZ4Z7J1110517
Coding: 0500040004
VCID: 61E74C2878735D4EE5-8034
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000994111
Coding: 0001168
VCID: 3147FC68A813ADCE35-8064
Component: RDK 0453
Coding: 0100101
Address 72: Door, Rear Right
Address 77: Telephone
End-------------------------(Elapsed Time: 02:08)--------------------------
Thanks,
PFaizulla
