Results 1 to 9 of 9
Thread: Activate DLA VW Arteon
    Oct 2016
    Stockholm Sweden
    A friend just bought the new Arteon as a company car. Surprisingly it does not have DLA (Dynamic Light Assist) but has all the harware so Im looking in to activate it.
    Is the Arteon platform maybe same as the Passat B8?
    Jun 2017
    Auto-Scan?
    How sure are you that the right hardware is present? Then it should be possible like for B8
    Oct 2016
    Stockholm Sweden
    The car is 500km away from me, so the plan is that when he does a tour in my direction Ill give it a try but want to be prepared. Cant get a auto scan right now.
    He says he has the LED lights with corner lights (WLH), sign assist (WQ3), Side/emergency/traffic jam assist (79D) and rain sensor, foldable mirrors (W17) with dynamic light package.
    Oct 2016
    Stockholm Sweden
    Confimed and works.
    Im so sorry I forgot who did the guide (a forum user from Swizerland I think) but worked just as expected.
    Scan before
    Wdnesday,03,January,2018,14:48:19:08489
    VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
    VIN: WVWZZZ3HZJE50XXXX   License Plate: AZP148
    Mileage: 6494km-4035mi   Repair Order:
    Chassis Type: 3H-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 29 2B 39 3C 42
              44 47 4B 52 5F 69 6C 6D 75 A5 A9 BB BC CA CF D6 D7
    VIN: WVWZZZ3HZJE504188   Mileage: 6494km-4035miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    BC-Door Rear Pass -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CUAA)       Labels: None
       Part No SW: 03N 906 026 A    HW: 03N 907 309
       Component: R4 2.0l BTD   H24 5164
       Revision: A1H24---
       Coding: 0125003A047605083000
       Shop #: WSC 05311 115 00305
       ASAM Dataset: EV_ECM20BTD01103N906026A 004006
       ROD: EV_ECM20BTD01103N906026A.rod
       VCID: 291A24D048D80B0EE6-807C
       Part No SW: 0DL 300 011 Q    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2001
       Revision: 00H06V07
       VCID: 3620FFAC896654F67B-8062
       Revision: 00000000    Serial number: 62057000001816
       Coding: 0DEC6B9454200B704778070840CB69B0D62AD0E2E0029675386250F8C2A9420000000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ROD: EV_Brake1UDSContiMK100IPB_035_VW48.rod
       VCID: 77BE32A8CEEC6DFEA0-8022
    4214 - Auto-Hold Switch
              C10CE 29 [008] - Signal Implausible
                        Reset counter: 135
                        Mileage: 6318 km
                        Date: 2018.01.01
                        Time: 16:42:48
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0448512496
       Coding: 1F20200723
       VCID: 3E30E78CA1569CB6A3-806A
       Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58142253
       Part No SW: 5G0 907 044 DQ    HW: 5G0 907 044 DQ
       Component: Climatronic   H04 2001
       Revision: 00001K10
       Coding: 1402011420411101111550000010192A
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 79BA3490F8F87B8ED6-802C
    655628 - Functional Limitation due to Energy Management
              B10CD 00 [008] -  -
                        Fault Frequency: 12
                        Reset counter: 171
                        Mileage: 1372 km
                        Date: 2017.10.20
                        Time: 13:42:44
       Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 034 0242
       Revision: --------    Serial number: 8658130717012J
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06404F6CB9060476AB-8052
       Component: WWS    170702  042 0607
       Serial number:         170713015341
       Component: RLHS  042 0105
       Serial number: S4Y17M08D10H22M36S20
       Coding: 00A8DD
       Light switch:
       Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
       Serial number: 10 04 2017  10000972
       Serial number: 000000000ZY171702LFX
       Serial number: 00000000000070355913
    545557 - Databus
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              U90D757 F7 [008] - No Release by Immobilizer
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617209
       Coding: 0271167951
       Shop #: WSC 05311 115 00061
       ROD: EV_EPHVA2CAU3700000_009_VW37.rod
       VCID: 50ECA9340BC21AC641-8004
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 32057FDB5DFFC728949C812481400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       ROD: EV_ACCBOSCHVW416.rod
    1538 - Sensor for Automatic Distance Control
              U4EC550 F0 [008] - Limited Visibility
                        Fault Frequency: 22
                        Reset counter: 175
                        Mileage: 2956 km
                        Date: 2017.11.11
                        Time: 15:10:55
                        Dynamic environmental data: 02 8D
                        Control Module temperature: 17 C
                        Voltage terminal 15: 14.3 V
                        Velocity_vehicle_reference: 8.72 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.72 m/s
    1396 - Sensor for Automatic Distance Control
                        Fault Frequency: 13
                        Reset counter: 175
                        Mileage: 2999 km
                        Date: 2017.11.11
                        Time: 20:02:39
                        Control Module temperature: 2 C
                        Voltage terminal 15: 11.5 V
                        Longitudinal_acceleration_vehicle_reference: -0.00 m/s
                        Status_ACC_System: ACC_Init
    1542 - Sensor for Automatic Distance Control
                        Fault Frequency: 16
                        Reset counter: 175
                        Mileage: 2956 km
                        Date: 2017.11.11
                        Time: 15:10:59
                        Velocity_vehicle_reference: 6.90 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.28 m/s
    1397 - Sensor for Automatic Distance Control
                        Fault Frequency: 13
                        Reset counter: 175
                        Mileage: 2999 km
                        Date: 2017.11.11
                        Time: 20:02:39
       Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0130
       Serial number: 21071741350244
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 393AF490B878BB8E96-806C
       Part No SW: 3Q0 959 655 BP    HW: 3Q0 959 655 BP
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003WAPF0MWEO
       Coding: 98CCC0C00C8000005C5400CF000840000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW21TS6VW48X_VW27.rod
       VCID: 0D527040DC70772EEA-8058
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G8857705B0206R00312
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G8857706B0207R01402
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 002 207 17
       Serial number: 35700000000C2B90082G
       Subsystem 4 - Part No SW: -----------    HW: 454 002 007 17
       Serial number: 35800000000B6BB0082M
       Subsystem 5 - Part No SW: -----------    HW: 454 802 507 17
       Serial number: 351008410D410000000/
       Subsystem 6 - Part No SW: -----------    HW: 454 802 507 17
       Serial number: 35200D617D410000000C
       Subsystem 7 - Part No SW: -----------    HW: 454 801 507 17
       Serial number: 3550044F36A10000000D
       Pedestrian Protection Driver:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 507 17
       Component: PedP_Sensor_D  304 0149
       Serial number: 228004428C4100000004
       Subsystem 9 - Part No SW: -----------    HW: 454 801 407 17
       Component: PedP_Sensor_P  304 0149
       Serial number: 2290092565F10000000D
       Pedestrian Protection Center:
       Subsystem 10 - Part No SW: -----------    HW: 454 801 407 17
       Component: PedP_Sensor_C  304 0149
       Serial number: 2300083859A100000006
       Subsystem 11 - Part No SW: -----------    HW: 454 002 505 17
       Component: PedP_Sens_D_2  008 0887
       Serial number: I0M000000006F2888427
       Subsystem 12 - Part No SW: -----------    HW: 454 002 505 17
       Component: PedP_Sens_P_2  008 0887
       Serial number: I0N0000000030388842Y
       Part No SW: 5Q0 953 521 AH    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170724100986
       Coding: 0810
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 78BC3194C3F26286A9-802C
       Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
       Component: KOMBI         406 3193
       Coding: 07A4101BFF8C000801806B0B1001000800000000
       Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       ROD: EV_AuxilParkiHeateWOS_VW37.rod
       VCID: 3A38EB9CBD7EB0969F-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000290049
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 22071710523692
       Coding: 0B0300345F017300FB00027E9C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 3326C6B89A1441DE5C-8066
       Serial number: 29170001587790017301
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
       Serial number: 2681634404
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: U13DCAC  H26 0780
       Serial number: 0063036
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  209 2002
       Serial number: HA1-00025.06.17
       Coding: 0301
       ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
       VCID: 4AD8BB5CED9E20160F-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C28860C480CF6EE2-8010
    0033 - Supply voltage
                        Reset counter: 146
                        Mileage: 3718 km
                        Date: 2017.11.17
                        Time: 08:34:24
       Serial number: 17000198352010
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 71AA0CB0A08833CE6E-8024
                        Reset counter: 145
                        Mileage: 5638 km
                        Date: 2017.12.13
                        Time: 21:40:13
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
       Component: MRR1Rear      H20 0510
       Revision: --------
       Coding: 14C002
    267010 - Databus
                        Reset counter: 174
                        Mileage: 6292 km
                        Date: 2018.01.01
                        Time: 12:25:57
                        Control Module temperature: 16 C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 69.77 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 13.70 V
       Serial number: 0000269983696
       Coding: 003F5A02D000028000001000
       VCID: 47DE8268FE8CDD7E10-8012
       Coding: 9307
       Shop #: WSC 00015 115 00305
       ROD: EV_SteerAssisMQB_013_VW37.rod
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 465     HW: 3Q0 035 465
       Component: MIB2_amp_P_VW H60 0440
       Revision: 00000001    Serial number: VWZ8Z1HJD00TG6R
       Coding: 1284010001AA0A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 6B961ED882A4D91E54-803E
       Serial number: 30071710521287
       Coding: 000000050100045207102F01020000000000000000000000000000000000
       Shop #: WSC 05311 000 08193
       ROD: EV_MultiModulContiVW48X_VW27.rod
       VCID: 72A803BCA58E08D697-8026
       Serial number: 0000269247598
       Coding: 003F5002DE00028000001000
       VCID: 46C08F6CF986C476EB-8012
       Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
       Component: MU-S-N-ER     851 0842
       Coding: 02840301000000005111000200080A031F0506E4012000008E
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 312ACCB0600873CE2E-8064
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT2200273
       Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
       Component: ECE1 2017/18  --- 0820
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0450620771
       Coding: 0100000202000000
       VCID: 42C8937CD5AEF856C7-8016
       Coding: 0184030163002017000040
       Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0261
       Revision: --------    Serial number: 31454100700000
       Coding: 0B28
       Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
       Component: OCULowMQBLGE  H17 0717
       Revision: --------
       Coding: 02840301EA42380D3F1CBE020045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004044
       ROD: EV_OCULowMQBLGE_004_VW27.rod
       VCID: 3C34ED84B74A8EA68D-8068
       Part No SW: 3Q0 980 654 J    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0273
       Serial number: 20071711P11883
       Coding: 000408040000040100221347C150A9009C000E300000
       ROD: EV_MFKBoschMQBB_VW36.rod
    1275 - Camera Interference
              C1104 00 [008] -  -
                        Reset counter: 61
                        Mileage: 3433 km
                        Date: 2017.11.14
                        Time: 17:57:50
                        Control Module temperature: 38 C
                        Outside air temperature: 2.5 C
                        Vehicle speed: 28.83 km/h
                        System run time: 10827.6 s (second)
                        Voltage terminal 15: 13.0 V
                        mid: 01 63
                        Camera_state: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 3
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 3G8 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0003
       Serial number: 170630200893
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       012 0032
       Serial number: 0000269908600
       Coding: 000A50020100028000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       ROD: EV_DCURearDriveMAXCONT_VW37.rod
       VCID: 49DA8450E8982B0E06-801C
       Component: TSG HBFS      012 0032
       Serial number: 0000269908314
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
       ROD: EV_DCURearPasseMAXCONT_VW37.rod
    65605 - Switch for Interior Door Handle
              B132E 29 [008] - Signal Implausible
                        Reset counter: 164
                        Mileage: 6138 km
                        Date: 2017.12.21
                        Time: 21:06:29
    65637 - Switch for Exterior Door Handle
              B132F 29 [008] - Signal Implausible
                        Reset counter: 164
                        Mileage: 6138 km
                        Date: 2017.12.21
                        Time: 21:06:29
       Part No SW: 4M0 907 594 K    HW: 4M0 907 594
       Coding: 608000748301
       ROD: EV_SunRoofCONTIAU736.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       VCID: 373EF2A88E6CADFE60-8062
    1311234 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Reset counter: 174
                        Mileage: 6292 km
                        Date: 2018.01.01
                        Time: 12:25:57
                        Control Module temperature: 15 C
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
       VCID: 16601F2CE9A6B4F65B-8042
    End----------(Elapsed Time: 03:09, VBatt start/end: 12.2V/12.1V)-----------
    Scan after
    Wednesday,03,January,2018,15:20:43:08489
    VIN: WVWZZZ3HZJE504188   License Plate: AZP148
    Mileage: 6495km-4035mi   Repair Order:
    VIN: WVWZZZ3HZJE50XXXX   Mileage: 6494km-4035miles
       Revision: A1H24---
    Readiness: 1110 1011
       Revision: 00H06V07
       Coding: 1F20200723
       Revision: 00001K10
       Coding: 00A8DD
       Light switch:
       Coding: 0271167951
       Coding: 80000D
       Coding: 80000D
       Coding: 0810
       Coding: 9309
       Coding: 2DFFFF
       Analog clock:
       Coding: 0301
       Revision: --------
       Coding: 14C002
       Coding: 9307
       Coding: 000000050100045207106F01020000000000000000000000000000000000
       Shop #: WSC 05311 123 08193
       Coding: 0B28
       Revision: --------
       Coding: 000408040000040100221347C150A9009C000E300040
       Revision: --------
       Coding: 14C002
    End----------(Elapsed Time: 02:57, VBatt start/end: 12.1V/12.0V)-----------
  5. Likes murmeltier, Uwe, hadez16, jyoung8607 liked this post
    Verified VCDS User murmeltier's Avatar
    Dec 2015
    Switzerland
    The Arteonis the same as the Passat B8. Did you use the following instructions to activate it:
    https://www.vcdsschweiz.ch/en/activa...ht-assist-dla/
    Thanks for your feedback !
    Oct 2016
    Stockholm Sweden
    Yes!
    The only thing that confused me was de basic setting procedure for the lights. It stated "not running" with green letters and the lights did not move like they usually do during this process.
    So I did the basic setting several times with the same result trying to figure this out, but that still cleared the basic setting error code.
    Thank you for this write up murmeltier.
  8. Likes murmeltier liked this post
    Jun 2017
    So it seems that VCDS still has some problems with the basic settings via module 4B
  10. #8
    Dec 2016
    DE
    Please re-try using the current beta: www.ross-tech.com/vcds/download/beta/current.php
  11. #9
    Oct 2016
    Stockholm Sweden
    Sorry, no can do. The car is since yesterday 500km way gone from my location. I have the beta installed but never came to think of using it.
