paulmaca
New Member
- Joined
- Sep 10, 2014
- Messages
- 7
- Reaction score
- 2
- Location
- UK
- VCDS Serial number
- HC826742 (Improbable)
Have audi a4 avant 1.9tdi 130 on an 2002 plate which runs great and problem is starting .It is struggling to start hot and cold ,disconnecting coolant sensor because was originally a cold start problem but no difference and original audi replacement sensor (should fan come on when dissconected even when cold,seems wrong) Changed egr audi part because past its time ,changed thermostat and fitted new MAF original part but still no change to values, have added some values and would be gratefully for any input ie why would air pressure be so low and maf values way out, what to start checking first with multi metre or vcds also attached some engine values, also don't seem to get dash warning when maf or sensor disconnected but maf will give limp mode when disconected .Also tried checking for vacum leak using butane gas around egr fitting and air intake hoses to see if change in idle but nothing
18:41:13
250.0 mg/str MAF (specified) 230-310
475.3 mg/str MAF (actual) 210-350
0.0°KW Synchro. angle -3..+3°Ck.
1.0 Start synchro.
62.1°C Fuel Temp ~Amb.Temp.*C
0.0 % Fuel cooling state On:100%-Off:0%
36.0°C Intake Air Temp ~Amb.Temp.*C
27.7 mg/str IQ via MAF 47-60
465.5 mg/str MAF 900-1250
1041.3 Intake air press. 2100-2600
1041.3 Actual intake press. 2100-2600
19.9 % D.cycle MAP 35-80%
18:41:13
1.0 Start synchro.
