What are the tell-tail indicators that a 2.5 has the dreaded timing chain issues? I just don't want to change an engine if it's possibly something else.
Just purchased a 2005 Jetta 2.5 with 172,000 miles for cheap. It won't idle smooth, and there seems to be a lot of engine noise. When I got the car there were all kinds of codes, because the car sat for 9 months and the battery went dead. I cleared the codes and then restarted the car and re-scanned ... multiple misfires and P2279 again ... (the PCV has been replaced).
Here's the initial scan (engine running) ...
Here's yesterday's scan (Ignition on - engine off) ...
Tuesday,14,November,2017,17:05:02:23114
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: 3VWPG71K55M620606 License Plate:
Mileage: 277680km-172542mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWPG71K55M620606 Mileage: 277680km-172542miles
Address 01: Engine Labels: 06A-906-032-BGQ.lbl
Part No SW: 06A 906 032 QC HW: Hardware No
Component: 2.5l R5/4V G 6605
Revision: 00000000 Serial number: VWZ7Z0E1483365
Coding: 0000003
VCID: 6FB8DBBF6B98A8DFB20-803A
15 Faults Found:
P0300 - 008 - - Intermittent - MIL ON
16688 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent - MIL ON
16689 - Cylinder 5
P0305 - 008 - Misfire Detected - Intermittent - MIL ON
18613 - Performance Malfunction in Cooling System
P2181 - 008 - - MIL ON
18080 - Coolant Fan Control 1
P1672 - 004 - Open or Short to Ground - Intermittent
17925 - Power Supply Relay for ECU
P1517 - 004 - Electrical Malfunction - Intermittent
17069 - ECM Power Relay Control Circuit
P0685 - 004 - Open Circuit - Intermittent
16804 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
18711 - Leak in Air Intake System
P2279 - 008 - - Intermittent - MIL ON
16685 - Cylinder 1
P0301 - 008 - Misfire Detected - Intermittent - MIL ON
16686 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent - MIL ON
16687 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent - MIL ON
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 008 - Incor. Correlation - MIL ON
16725 - Camshaft Position Sensor (G40)
P0341 - 008 - Implausible Signal - Intermittent
16706 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
Readiness: 0000 0100
Part No: 09G 927 750 AS
Component: AQ 250 6F 0649
Coding: 0000008
VCID: 025E820B480AB5B74DE-8056
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 - - Intermittent
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3FD84BFF7B78185F620-806A
57344 - Unknown Error Code
Unknown - 015 - - MIL ON
Part No: 1K0 820 047 EM
Component: Climatic PQ35 084 0404
VCID: 73B0D7CF07B08C3F568-8026
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000024936
Coding: 140D0E02400418000014000000140000000073035C
VCID: 392C25E7655C366F5C4-806C
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD011YYR
Coding: 0012627
VCID: 2E0606BBAC12E1D7F96-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 633 SME
Subsystem 3 - Serial number: 6342MSME08474E5AO
Subsystem 4 - Serial number: 6351HSME05714A40+
Subsystem 5 - Serial number: 6361HSME060944191
Subsystem 6 - Serial number: 63727SME05394844/
Subsystem 7 - Serial number: 63827SME054A5338%
00591 - Seat Belt Switch; Driver (E24)
010 - Open or Short to Plus - Intermittent - MIL ON
00592 - Seat Belt Switch; Passenger (E25)
01221 - Crash Sensor Side Airbag; Driver Side (G179)
00532 - Supply Voltage B+
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - Intermittent - MIL ON
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010021
VCID: 72BED2CB78AA85375DE-8026
015 - Cannot Be Tested at this Time - MIL ON
02413 - Switch for Selector Lever Position P Lock (F319)
Part No: 1K0 920 951 C
Component: KOMBIINSTRUMENT 3HL 0720
Coding: 0023203
Shop #: WSC 08305 993 56004
VCID: 290CF5A795FC86EF2C4-807C
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C2807B7
Coding: 3F3F0340071002
Shop #: WSC 08083 444 59261
Fault Frequency: 32
Reset counter: 106
Time Indication: 15
Component: IMMO 3HL 0720
01176 - Key
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001269
VCID: 36362EDB5442D917B16-8062
00100 - Drivers Interior Locking Button (E308)
00913 - Window Regulator Switch; Front Right Driver (E81)
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 303A18C3B626F727EBA-8064
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AM
Component: KSG 0401
Coding: 137803285B09050F880F049011A0
VCID: 7BA0FFEF2FE0C47F0E8-802E
Component: LIN BACKUP HORN H02 1301
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372823DF5348201FAA0-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
Component: Radio DE2 012 0014
Revision: 00012000 Serial number: VWZ4Z7E6022988
Coding: 0040400
Shop #: WSC 08083 444 59080
VCID: 1D64D177D1B46A4F50C-8048
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 313C1DC7BD2CFE2FE44-8064
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323E12CBB82AC5379DE-8066
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:04, VBatt start/end: 14.5V/14.4V)-----------
Wednesday,15,November,2017,14:43:17:23114
Mileage: 277700km-172554mi Repair Order:
VIN: 3VWPG71K55M620606 Mileage: 277700km-172554miles
Coding: 0000003
P0300 - 001 -
16686 - Cylinder 2
P0302 - 001 - Misfire Detected
16687 - Cylinder 3
P0303 - 001 - Misfire Detected
P2279 - 008 -
16685 - Cylinder 1
P0301 - 001 - Misfire Detected
Readiness: 0110 1101
Coding: 0000008
Coding: 0017025
Coding: 040D0E02400418000014000000140000000073035C
Coding: 00065493
Shop #: WSC 12345
Coding: 0012627
Coding: 0010021
Coding: 0023203
Coding: 0001269
01034 - Electric Window Thermal Protection Active; Driver
00912 - Window Regulator Switch; Front Left (E40)
Component: KSG 0401
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
End----------(Elapsed Time: 01:02, VBatt start/end: 12.3V/12.2V)-----------
