Thursday,16,November,2017,15:56:03:62774
VCDS Version: 17.8.0.1
VIN: WAUZZZ4G6CN129048 License Plate: VO12OJZ
Mileage: 170490km-105937mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42 44
46 47 52 53 55 56 57 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G6CN129048 Mileage: 170490km-105937miles
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
57-TV Tuner -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Malfunction 0110
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0005
Revision: 53H37---
Coding: 12254012057601020000
ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2647B5D859123B76D0-8072
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0003
Revision: --H10--- Serial number: 0000000711
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 2C5347F047FE012606-8078
18003 - Sensor for Gear Actuator 2
P17E1 00 [101] - Mechanical Malfunction
Reset counter: 40
Mileage: 170490 km
Date: 2017.11.15
Time: 16:20:47
Engine speed: 817 /min
Transmission input speed: 817 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 31 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 27A6C701E465E380EB00
VCID: 387B6BA083A6BD8672-806C
0605 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 107
Mileage: 167232 km
Date: 2017.06.27
Time: 20:00:38
VzRef: 82
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 29
Uz: B9
0630 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 109
Mileage: 167345 km
Date: 2017.07.07
Time: 12:44:54
VzRef: 1D
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 01
F-Type: 2D
Uz: BA
Part No SW: 4H0 907 064 BP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0333
Coding: 05B92F06000000000000
VCID: 78FBABA0CB267D86B2-802C
Serial number: 2312000002499003
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 07021200040752
Coding: 362200B82C
VCID: 2759B8DC5E18227EEB-8072
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001396308
Coding: 0907201009749FE289810083A0001800CF9DE7082F080101000108542F00
VCID: 77F9A89CC63872FEBB-8022
Component: WWS57X 120116 H35 0080
Serial number: 120123124743
Coding: 0045F7
Component: RLS H04 0003
Serial number: 20061270
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 06 02 2012 00001227
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000018011200010813
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000021121100010248
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 2578CE06000000000001
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 R HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0045
Revision: -------- Serial number: 56261203700268
Coding: B93B08
ASAM Dataset: EV_EPHVA2CAU57X0000 002011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 418D0644D07CFC4EC5-8014
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 285BBBE053062D06E2-807C
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 145
Mileage: 170452 km
Date: 2017.11.07
Time: 18:47:18
Control Module temperature: 11 °C
Voltage terminal 15: 14.567 V
Velocity_vehicle_reference: -0.89 m/s
Longitudinal_acceleration_vehicle_reference: 0.58 m/s²
144640 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 144
Mileage: 170407 km
Date: 2017.11.05
Time: 18:05:12
Control Module temperature: 23 °C
Voltage terminal 15: 14.400 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.47 m/s²
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG006TG8B
Coding: 30323436313330303539554A305234473053
VCID: 3667659889B24BF660-8062
Serial number: 3575HRB405H131GU4PQZ
Serial number: 3585HRB405513AMO4OMS
Serial number: 3515JRB405D1138AMPA1
Serial number: 3525JRB405J14KDQ6GN.
Serial number: 3554VRB406915A9MG8QU
Serial number: 3564VRB406915A9MGOO2
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LB1001JY
Coding: 0000FD
VCID: 3779689C86B8B2FE7B-8062
Component: E221 - MFL H08 0009
Serial number: 30 12 2011 11197109
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 982 R HW: 4G8 920 982 R
Component: TDieGb Acc H79 0416
Revision: 28460177 Serial number: 658250112592054
Coding: 338710001F112600010000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 43810C4CCA60EE5ED7-8016
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000387743
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 34635F909FCE59E65E-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790848648
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04028264747464545425363E
VCID: 33615C8C92C05EDE47-8066
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0064
Serial number: 05021200040833
Coding: 02
VCID: 306B53806BD665C63A-8064
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 E HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0781
Coding: 008003
ROD: EV_AirSuspe_VW51.rod
VCID: 2D554AF47CE4082E11-8078
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000023101818
Coding: 00781B0000006001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4203N58$0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-03
Coding: 0011102
VCID: 306B5380A3D665C63A-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F09.02.1200H020003CF24647ÿ
Subsystem 4 - Serial number: F24647ÿ
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16205E01628002080013
VCID: 418D0644D87CFC4EC5-8014
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0015313493
Coding: 101101010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326F598865DA57D64C-8066
Revision: 00002001 Serial number: 0169178750
Coding: 013B0E2220B93495832009842E0304000000000000000000000000000000
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Serial number: WOO14581261
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Serial number: 0000000AP00000782945
Subsystem 5 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Serial number: WOO14581384
Coding: 801F00
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84210203
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000025078
Coding: 030000
VCID: 1D359A340444F8AE81-8048
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16205E01628002080002
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000243329
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A5F41E84D0A1F16F4-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120202-0001-069
Coding: 11226F601000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109BW0C7547270
Coding: 010103010000000001
VCID: 2B5144EC4AF0061E0F-807E
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801100181201
Coding: 03000000
VCID: 2D554AF474E4082E11-8078
Part No SW: 4G0 035 670 P HW: 4G0 035 670 A
Component: H-BNT-EU H48 0939
Revision: -------- Serial number: 428B00C7539691
Coding: 050101010003F9EF7D10EB3E00000003000001000000000000
VCID: 306B538063D665C63A-8064
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB9400LX82
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LB200038
Component: CD-Database 3638
Reset counter: 101
Mileage: 170291 km
Date: 2017.10.28
Time: 13:37:54
Text: DUA009,Front,M,0,0,6
03623 - Invalid Secruity/Release Code
Reset counter: 70
Mileage: 167692 km
Date: 2017.07.16
Time: 15:56:58
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
03677 - Missing Secruity/Release Code
Reset counter: 31
Mileage: 164837 km
Date: 2017.03.19
Time: 20:11:20
Voltage: 12.10 V
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204001628002080002
VCID: 44830F50C76EE966EE-8010
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000168812426
Coding: 0109080000000000
VCID: 71ED9684A85C2CCE75-8024
02562 - Trailer; Brake Lamps
010 - Open or Short to Plus - Intermittent - MIL ON
Fault Status: 10101010
Reset counter: 144
Mileage: 170407 km
Date: 2017.11.05
Time: 18:05:12
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 C HW: 4H0 907 441 B
Component: SG Rueckfahrkamera 0161
Revision: --H05--- Serial number: 525 PA8J21G0M0
Coding: 1090005
VCID: 2759B8DC9618227EEB-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 018200396
Coding: 097205C011
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
Component: TSG HR H04 0212
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H25 0036
Revision: -------- Serial number: 262130025421000
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C5F2D46494F06E19-8030
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
U1113 00 [008] - -
Reset counter: 145
Mileage: 170452 km
Date: 2017.11.07
Time: 18:47:18
Control Module temperature: 12 °C
Voltage terminal 15: 14.540 V
Velocity_vehicle_reference: -0.84 m/s
Longitudinal_acceleration_vehicle_reference: 0.59 m/s²
U1113 00 [008] - -
Reset counter: 144
Mileage: 170407 km
Date: 2017.11.05
Time: 18:05:12
Control Module temperature: 25 °C
Voltage terminal 15: 14.670 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.49 m/s²
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000050302127
Coding: 04C23A1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316D568460DC6CCE35-8064
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 07:47)--------------------------
