mk7 retrofit pdc/ops
paul-e
Pirate
Walking the Plank
LP/IP
hello I am new here and I have a question.
I own a golf 7 variant 2014 and retrofit a pdc / ops set.
I am working on coding but do not get it working
when I put in the reverse happens nothing and when I press the button then the light blinks and my screen goes to the parking view but without a car symbol.
and I do not get any bleep.
I have used the description of carsystems.
my car has a gateway low, is that maybe the problem ???
can someone help me please
paul-e
Pirate
Walking the Plank
LP/IP
here my auto scan
note, he gave an error ROD file not found????
i have to say that when i had disconnect the gateway connector i accidentally turned on the ignision and get instantly an error ,and after installation i had to clear the error for the airbag thats all.
please help
Removed.  Data from clone/pirate copies of VCDS is not welcome here.
paul-e
Pirate
Walking the Plank
LP/IP
what is wrong with the post?????
is it the vcds version ?,got it from a friend, is it not the same as the one at the side to download.
what must i do now
plaese help
paul-e
Pirate
Walking the Plank
LP/IP
Data was from pirate/clone version of VCDS.
Buy a real one and Get Verified.
i downloaded on your site and checked the car again.
i hope that this is oke for you to give my some helping ansers please.
paul-e
Pirate
Walking the Plank
LP/IP
No. I don't think you understand how this works. The license to use our software is embedded in the cable you buy from us (or one of our authorized resellers). You are using a cable with a cloned/pirated license.
ejne
Slovakia
C?ID=136992
golfi_vend
Tartu, Estonia
C?ID=195131
You can't just do coding for cruise. Cruise is SWAP function. There are workarounds, but not with vcds.
If you want to buy swap You must buy whole kit from VW.
