Results 1 to 6 of 6
Thread: A8 parking brake
    Jan 2017
    A8 parking brake
    Hello.
    P brake sometimes stops working for weeks.
    when the car isn't startet terminal 30 in P module is only 10.6v, like in instruments 11.7v
    In MVB i checked status of the button, it shows button foulty when applied.
    But after erasing the foult it just works for some time.
    Its the button, or the module, is there any way to check them?
    Thank you very mutch
    Tuesday,14,November,2017,18:41:45:54511
    VCDS Version: 17.8.0.1 (x64)
    VIN: WAUZZZ4E18N010457   License Plate: BF58LVY
    Mileage: 250210km-155473mi   Repair Order: Parking brake
    Chassis Type: 4E (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
              38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77
    VIN: WAUZZZ4E18N010457   Mileage: 250210km-155473miles
    0E-Media Player 1 -- Status: Cannot be reached 1100
    1E-Media Player 2 -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4E0 910 402 E    HW: 4E0 907 401 D
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H05---    Serial number: AUX3Z0H0339975
       Coding: 0011973
       Shop #: WSC 02313 785 00200
       VCID: 1E32563EC9633AB698-804A
       Part No SW: 4E1 910 156 Q    HW: 09L 927 156 A
       Component: AG6 09L 3,0 TDI RdW 0020
       Revision: --H01---    Serial number:        4414645
       VCID: 31689D82A8FDB5CE35-8064
    Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
       Part No SW: 4E0 910 517 J    HW: 4E0 614 517 BQ
       Component: ESP 5.7 allrad  H49 0540
       Coding: 0008357
       Shop #: WSC 02313 000 00000
       VCID: 2A5A8AEE852BC616F4-807E
    Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
       Part No SW: 4E0 910 131     HW: 4E0 907 181 A
       Component:     FBS AUDID3  H12 0200
       Revision: 02005112    Serial number: AUX3Z0H0339975
       Coding: 0412672
       Shop #: WSC 02311 785 00200
       VCID: 58BE0026EBC7848692-800C
    00191 - Passenger's Door Handle Touch Sensor (G416)
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 0
                        Reset counter: 148
                        Mileage: 250128 km
                        Date: 2017.11.13
                        Time: 16:09:14
       Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
       Component: Sitzmemory BFS H02  0010
       Revision: 00000000    Serial number: 5DS 008 795-03
       Coding: 4063328
       VCID: 244664D6E70F1066CE-8070
    Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
       Part No SW: 4E0 910 732 P    HW: 4E0 035 729
       Component: Interfacebox    H43 5140
       Revision: 00000000    Serial number: 343AD087603240
       VCID: 2F6C9BFABEC9A33E23-807A
       Subsystem 1 - Part No: 4E0 910 611
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000055669
       Subsystem 3 - Serial number: 0114.01.080000000100010090˙
       Subsystem 4 - Serial number: 010090˙
       Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
       Component: KLIMAAUTOMAT    017 0450
       Revision: 00000032    Serial number: 00000000141123
       Coding: 0018449
       VCID: 1C365C36DF7F28A676-8048
    00066 - Rear Right Footwell Heater (Z43)
                        Reset counter: 148
                        Mileage: 250109 km
                        Date: 2017.11.13
                        Time: 15:35:01
                        Voltage: 13.70 V
                        Reset counter: 200
                        Mileage: 250109 km
                        Date: 2017.11.13
                        Time: 15:47:42
    Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
       Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
       Component: ILM Fahrer      H16 0240
       Coding: 0133121
       VCID: 387EA0A64B87648672-806C
       Subsystem 1 - Part No: 4E2 910 113 C
       Component: Wischer WWS D3  H60 0440
       Coding: 00000035
       Shop #: WSC 02313
       Component: REGENLICHTSENSORH04 0002
       Coding: 00139548
       Shop #: WSC 02313
    Address 0E: Media Player 1
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276V7901282
    Address 15: Airbags        Labels: 4E0-910-655-94.lbl
       Part No SW: 4E0 910 655 E    HW: 4E0 959 655 K
       Component:    Airbag 9.41  H01 4210
       Revision: 91H01421    Serial number: 003CU00088CU
       Coding: 0431707
       VCID: 285E70E69B27F406E2-807C
       Subsystem 1 - Serial number: 63328RB4036BC574Q
       Subsystem 2 - Serial number: 63428RB4036BC6F7$
       Subsystem 3 - Serial number: 63528RB4036BC6E2Y
       Subsystem 4 - Serial number: 63628RB4036BC692U
       Subsystem 5 - Serial number: 63729RB40336D916O
       Subsystem 6 - Serial number: 63829RB40336D97F/
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
       Revision: 00H05000    Serial number: 90025080020024
       Coding: 0112141
       VCID: 26427EDE9133E276D0-8072
    Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
       Part No SW: 4E0 910 951 J    HW: 4E0 920 951 J
       Component: KOMBIINSTR. VDO H84 0620
       Revision: D03         Serial number: AUDID3H0100043
       Coding: 0032423
       Shop #: WSC 01742 444 119973
       VCID: 2C568CF68FDFD82606-8078
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
       Component: Heizgeraet      H08 0140
       Revision: 0000000C    Serial number: 00000009013887
       VCID: 1A3A5A2ED54B569664-804E
    00456 - Control Module for Access and Start Control (J518)
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B081128300
       Coding: F5F99F7F707A0E00
       VCID: 2D5081F2B4C5D12E11-8078
    02076 - Media Player Position 1 (R118)
                        Reset counter: 148
                        Mileage: 250109 km
                        Date: 2017.11.13
                        Time: 15:31:28
    02077 - Media Player Position 2 (R119)
                        Reset counter: 188
                        Mileage: 250109 km
                        Date: 2017.11.13
                        Time: 15:44:24
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0390
       Revision: 00046002    Serial number: AUZ5ZBH4071932
       Part No SW: 4E0 910 158     HW: 4E0 919 158 C
       Component: KLIMA-STG. FOND 017 0230
       Revision: 00000020    Serial number: 00000000065482
       Coding: 0000000
       VCID: 61C82DC2B89D454EE5-8034
    Address 34: Level Control        Labels: 4E0-910-553.lbl
       Part No SW: 4E0 910 553 L    HW: 4E0 907 553 H
       Component: LUFTFDR.-CDC    H07 6340
       Coding: 0015510
       Component: Sitzmemory FS  H02  0010
       Coding: 4063338
       Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1050
       Revision: 00000000    Serial number: 364AP087752082
       Shop #: WSC 00385 210 90050
       VCID: 306E9886A3F7BCC63A-8064
    Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
       Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
       Component: Dachknoten D3   H05 0090
       Serial number: 00000735300080
       Coding: 0035968
       VCID: 1D305132C46521AE81-8048
    Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 802 F
       Component: Türsteuer.FS BRM005 0180
       Coding: 0028462
       VCID: 204E68C6F3170C46AA-8074
    Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
       Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
       Component: Komfortgeraet   H10 0030
       Revision: 00300010    Serial number:  W040801210222
       Coding: 0004349
       VCID: 2B548FEA8AD1DF1E0F-807E
       Component: Heckdeckel   P27H08 0090
       Component: Neigungssensor  H05 0020
    Address 47: Sound System        Labels: 4E0-910-223.lbl
       Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
       Component: DSP-High D3     H03 0120
       Revision: PROD_01     Serial number: 00000000112916
       Coding: 0000023
       Shop #: WSC 25720 001 1048576
    Address 4F: Centr. Electr. II        Labels: None
       Part No SW: 4E0 910 280 A    HW: 4E0 907 280 D
       Component: ILM Beifahrer   H11 0070
       Revision:             Serial number: 00000000016979
       Coding: 0010101
    Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
       Part No SW: 4E1 910 802 B    HW: 4E2 959 801 F
       Component: Türsteuer.BF BRM005 0180
       Coding: 0028462
    Address 53: Parking Brake        Labels: 4E0-910-801.clb
       Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
       Component: EPB  A4EC0230   H03 0230
       Revision: --H03---
       Coding: 0000221
    02443 - Control Head
                        Fault Status: 00111100
                        Reset counter: 200
                        Mileage: 250136 km
                        Date: 2017.11.13
                        Time: 23:06:29
                        Voltage: 12.63 V
                        Count: 40
       Coding: 0000018
       Shop #: WSC 54503 001 1048576
       VCID: 295875E2802DCD0EFD-807C
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H01 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 396A3087588388
       VCID: 2E5286FEB9C3AA3628-807A
    Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
       Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
       Component: J0644 BEM       H12 0550
       Revision: 00000000    Serial number: 00000000000553
       Subsystem 1 - Part No: 4E0 915 105 A
       Component: von VA0  2801100837
       Coding: 344530393135313035412056413032383031313030383337
       Shop #: WSC 00000 128 00289
    Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
       Component: Türsteuer.HL BRM005 0180
       Coding: 0028462
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H46 0630
       Revision: 00000000    Serial number: 00000801070453
       Shop #: WSC 12336 024 394758
       VCID: 3662AE9E419392F660-8062
    Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
       Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
       Component: Türsteuer.HR BRM005 0180
       Coding: 0028462
    Address 76: Park Assist        Labels: 4E0-910-283.lbl
       Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
       Component: Parkhilfe 8-Kan H12 0040
       Revision: 00H12000    Serial number: 08720801100041
       Coding: 0201008
       VCID: 234467CAE201175EB7-8076
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 C    HW: 4F1 862 335
       Component: BTA             H10 0960
       Revision: 00H10000    Serial number: 00000007556875
       Coding: 0060001
    End-------------------------(Elapsed Time: 03:16)--------------------------
    Address 53: Parking Brake (4E0 910 801 D)
    18:49:39
    10.66 V Battery Voltage (Terminal 30)
    Not Oper. Parking Brake Switch
    Looks like a problem with the EPB control switch or its wiring.
    Agree with Uwe and I would recommend a battery OP.
    Consider installing a solar charger to supplement the system for standby.
    At this mileage range it would be wise to change the switch and take calipers apart to clean & lube everything up real good, this so the stepper motors on the calipers move free with least amount of load.
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  5. Likes Uwe liked this post
  6. #4
    Jan 2017
    P brake is working good i've done adaptation and all.... after replasement.
    i'll check the switch and wiring on weekend.
    thank you
    Jan 2017
    p.s. Solar support is great.
    But in Northern Ireland its mostly cloudy
  8. Likes Jack@European_Parts liked this post
  9. #6
    This explains allot my friend...........
    Solar still work's to a degree on cloudy days too and every little bit counts.
