Results 1 to 10 of 13
Thread: Hex-Net issues
    New User
    Nov 2017
    Hex-Net issues
    Iím working on setting up my Hex-Net and it was truth to update firmware then got stuck. Iíve read some instructions about holding the reset button when plugging in for atleast 10 seconds etc.
    none of that worked on mine, and now i canít seem to get past the Test stage
    Port status:OK
    Interface: Not Found!
    Any new places to start looking or researching?
    Is this by chance a second-hand HEX-NET with a serial a serial number ending in 953?
    If so, it looks like it needs to get over the CB 0.42xx hump.
    Please see this thread:
    http://forums.ross-tech.com/showthread.php?3757
    New User
    Nov 2017
    You sir are spot on. I will work to complete exactly what the thread you sent is saying. I appreciate the link.
    New User
    Nov 2017
    It appears i can get all the way to the point of checking for updates on web browser step 3C and then it stops. It pulls up a darker window stating ďchecking for updatesĒ The it just goes away and thatís that.
    Can you post the results of (from VCDS-Mobile) [Options] -> [Self Test] -> [Advanced network test]
    Is it in Infrastructure Mode?
    What happens if you do [Options] -> [Self Test] -> [Advanced Network Test]?
  7. #7
    New User
    Nov 2017
    It seems to have a kinda ďprocessing ď status bar that seems to just go on forever but i get zero results, well atleast about 5min in
    There was one screen that did say mode: infrastructure.
    Found and tried the :45 reset button with exact timing it... still no change.
  8. #8
    That sounds like it's not connected to an infrastructure network, or that the network it's on doesn't have outside internet access. Try network config again and make sure it's in infrastructure mode and connected to your wifi router.
  9. #9
    New User
    Nov 2017
    Tried network config and confirmed itís connected to router Through the router. Shows that it is connected.
  10. #10
    New User
    Nov 2017
    Iím thinking Iím stuck in infrastructure mode and resetting doesnít seem to help.
