Results 1 to 10 of 19
Thread: 2015 Audi S4 (Headlight Problems)
    Mar 2017
    >> Fixed all the other codes only have the below come up after I did a factory reset on the headlights thinking it would fix the auto adjusting issue. my initial problem was i had purchased the wrong light with adaptive steering, i got the light swapped out, but i still have the below codes come up. any help you can provide to help solve will be greatly appreciated.
    -As mentioned before, there is something wrong still when you have a
    [012 - Electrical Fault in Circuit] in the fault codes. Using the
    Factory Repair Manuals and Wiring diagrams it will be necessary to
    verify Powers, Grounds and wiring to these LED modules.
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Aug 2016
    Switzerland
    maybe let's start with an autoscan so we can see what it's made of --> http://forums.ross-tech.com/showthre...t-an-Auto-Scan
  3. Likes Uwe liked this post
    Mar 2017
    thank you for your response the auto scan came up clean only those issues still exist.
    Quote Originally Posted by mario01 View Post
    Please post it anyway. It shows what control modules are installed in the car.
  6. Likes Eric liked this post
    Mar 2017
    Tuesday,14,November,2017,14:25:32:39527
    VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4407.4
    VIN: WAUBGAFL9FA131388   License Plate:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
              6C 72 A9
    VIN: WAUBGAFL9FA131388   Mileage: 14560km-9047miles
    Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0007
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
       ROD: EV_ECM30TFS0218K5907551G.rod
       VCID: 3A38FE6DBDC5FE9684-806E
       Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
       Component: 0B5 30TFSINAR H03 0004
       Revision: --H03---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 291D1801
       VCID: 095A51A1A0A3250EDD-805C
       Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
       Component: BCM2 2.0      H15 0711
       Coding: 0D814040000000000000
       VCID: 05425D918CBB416EB9-8050
       Serial number: 3215000068858003
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 214
                        Mileage: 14198 km
                        Date: 2017.11.03
                        Time: 07:59:30
       Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: C1000000    Serial number: 01220420152414
       Coding: 6600228000
       VCID: 77BE2759C65723FEBB-8022
       Revision: 08016001    Serial number: 00001055265102
       Coding: 26000091863CAFE0010048C300003D0D0F9CD308A2090221000008004000030100000030000000
       Shop #: WSC 06325 123 12345
       VCID: 78BC2465CB492C86B2-802C
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA250315  H19 0461
       Serial number: 1503190607933
       Coding: 004577
       Serial number: 20253716
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000604150785
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01EB6811
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: B00944A7000000000001
                        Reset counter: 232
                        Mileage: 14560 km
                        Date: 2017.11.14
                        Time: 14:19:35
                        Reset counter: 232
                        Mileage: 14560 km
                        Date: 2017.11.14
                        Time: 14:19:35
       Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
       Component: AirbagVW-AU10 H51 0812
       Serial number: 003NDD134Y7F
       Coding: 303844354730383131304A55304C384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003114
       VCID: 4BD6ABA9E25F771E2F-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R150000Q1MF
       Serial number: 6334MSME505D7727J
       Serial number: 6344MSME4F482F02O
       Serial number: 6352QSME38580248F
       Serial number: 6362QSME275A3978T
       Serial number: 63732SME5A6E565CJ
       Serial number: 63832SME215A3D742
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862ODK000WJ
       Coding: 000036
       VCID: 48DC94A5FB299C0602-801C
       Part No SW: 8K0 920 983     HW: 8K0 920 983
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 63-71734G
       Coding: 8BB709000301D705020000
       VCID: 72A8164DAD3546D68C-8026
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z154140B2C
       Coding: 80C303FF00
       VCID: 4CD4A8B5EF51702626-8018
       Serial number: 8955916203
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0077
       Revision: AA000000    Serial number: 00000143928467
       Coding: 00581B00000000000000
       VCID: 3B36FB69BAFFC79E9F-806E
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0366922831
       Coding: 010211
       Shop #: WSC 06324 000 00000
       VCID: 3FCE8F79A6E7DBBEB3-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0366547138
       Coding: 010211
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H10 0305
       Coding: 011C13204E00410001
       VCID: 56E04ADD219D3AF680-8002
       Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
       Component: RCEPS         H43 0510
       Revision: 00001000    Serial number: 0007695021
       Coding: 100000010001
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3E30F27DA1EDD2B6B8-806A
       Revision: 00002001    Serial number: 0364787982
       Coding: 0106023A00FA400580B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000975108
       Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J245 PS051  H08 0043
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H10 0305
       Shop #: WSC 06342 000 00000
       VCID: 55E24DD13C9B31EE89-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 30000000365146
       ROD: EV_ParkiBrake_VW51.rod
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156DZ0F8255260
       Coding: 020007020100000001
       VCID: 2404201527419866CE-8070
       Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
       Component: H-BNT-NA      H42 0901
       Revision: --------    Serial number: 523D30F7539548
       Coding: 110200000206A1EF55028B5E00000403140000000000000000
       Subsystem 1 - Part No: 8R0 060 884 CJ
       Component: NAR 2015  1102
       Component: DU7 High  H42 0104
       Serial number: A130DM0F3330527
       Serial number: 00000002208164
       Component: CD-Database  5950
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H08 0305
       Coding: 010C13204000210001
       VCID: 59FA41E15083158EAD-800C
       Revision: --H09---    Serial number: 525PA8-JA2908D
       Coding: 1000006
       VCID: 383CE4654BC9EC8672-806C
    02203 - Audio / Video Input 1
                        Reset counter: 2
                        Mileage: 14217 km
                        Date: 2017.11.04
                        Time: 08:18:02
                            Reverse OFF
                        Count: 3
                        Fault Status: 00101011
                        Reset counter: 2
                        Mileage: 14217 km
                        Date: 2017.11.04
                        Time: 08:19:37
                            Reverse OFF
                        Count: 3
       Component: TSG HR        H08 0305
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0006
       Serial number: 150407201034
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 72A8164DA53546D68C-8026
    End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
  8. Likes Uwe liked this post
  9. #6
    Mar 2017
    Any help or suggestions will be greatly appreciated. Thank you.
  10. #7
    Mar 2017
    Audi S4 DRL issue
    Fixed all the other codes only have the below come up after I did a factory reset on the headlights thinking it would fix the auto adjusting issue. my initial problem was i had purchased the wrong light with adaptive steering, i got the light swapped out, but i still have the below codes come up which came up after i did the factory reset as well only shows up when the headlights are turned on. DRL stay on when the headlights are off as they should, but turn off when the headlights are on, believe they should dim? any help you can provide to help solve will be greatly appreciated.
              6C 72 A9
      Revision: --H07---
      Revision: --H03---
      Coding: 000001
      Coding: 291D1801
    00955 - Key 1
                        Reset counter: 214
                        Mileage: 14198 km
                        Date: 2017.11.03
                        Time: 07:59:30
      Coding: 6600228000
      Coding: 004577
      Coding: 02005D
                        Reset counter: 232
                        Mileage: 14560 km
                        Date: 2017.11.14
                        Time: 14:19:35
                        Reset counter: 232
                        Mileage: 14560 km
                        Date: 2017.11.14
                        Time: 14:19:35
      Coding: 000036
      Coding: 80C303FF00
      Coding: 010211
      Coding: 010211
      Coding: 1000006
                        Reset counter: 2
                        Mileage: 14217 km
                        Date: 2017.11.04
                        Time: 08:18:02
                            Reverse OFF
                        Count: 3
                        Reset counter: 2
                        Mileage: 14217 km
                        Date: 2017.11.04
                        Time: 08:19:37
                            Reverse OFF
                        Count: 3
  11. #8
    Please don't start multiple threads for the same problem in the same car.
    Threads merged.
  12. #9
    Mar 2017
    Sorry about that. Just didn't get any replys thought i was in the wrong forum. Is there any actual help here? Or are these forums just setup to catch users without a license to use your software??
  13. #10
    I'm confident if someone had an idea what was up with your car, they would have posted.
    What exactly is this "Factory Reset" that you did?
