Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 2012 GTI 2.0L TSI CCTA ABS, ASR AIRBAG, TPM came 2 mornings
    Verified VCDS User GavGTI's Avatar
    Nov 2017
    Here is my JPPSG post
    Hi Jack, I cleared the DTC and did a fresh Auto-Scan.
    1. Volkswagen/GTI/2012/VI
    2. WVWFV7AJ2CWXXXXXX
    3. Stock (all parts used for repairs are OEM and done at the dealer)
    4. VCDS SCAN (see below)
    5. Most recent is the repair of the left rear ABS sensor (WHT-003-859) at 71450 miles
    a. At 61250 miles, during 60k service, tech found RH (small fan) INOP replace BOPTH S10 replace both cooling fans, 1 1K0-959-455-FR & 1 1K0-959-455-ET $$$! They also performed ECM software update. Old version-0010. New version-0040. And they did the 60K service as outline in manual.
    b. At 69532 miles, during 10k service, tech found oil leak, cause: Rear Main Crank seal leaking oil. They replaced seal. $$$! They also performed the water pump test and found that to be leaking; Replace water pump 1 06H-121-026-DD $$$! Tech also found a Fault in the ECM, cause: FAULT 2015 found in ECM, replace 1-06J-133-201-BH manifold, 4 06J-998-907-B repair kit, 1 G-001-780-M3 additive, 1 N-107-732-01 bolt, 1 06H-133-583-F hose. This was done once before when the care was younger. This is part of an extended warrantee in effect till 2021 year or 120K.
    6. When I received my interface cable I did the auto scan, and everything was 100% no faults. I suspected my battery was on it last leg being over three years old and I know this could cause issues. And in the morning when I started my car to go out I saw these symptoms on my dash, ABS, ASR, Airbag and TPMS warning lights illuminated. I suspected it maybe because of low voltage, because after driving the car around and restarting to go somewhere else, no warning lights. So, it did that for two mornings straight and then I made up my mind to replace my battery with the OEM battery before this causes more issues. The memory of my last ABS issue came back to haunt me and the cost of another 300 bucks. My dealer told me not to be surprise, if the rear right-side ABS sensor fails in a month or so, “because we see this recur in other VW cars.”
    7. All fuses tested good. Battery connections checked and okay. I’m going to forgo the load test since the battery is brand new.
    8. I use this manual 2010 – 2016 Golf VI GTI Golf R 5k. PDF Repair Manual CC 2010 ➤ , Eos 2006 ➤ , Golf 2004 ➤ , Golf 2009 ➤ , Passat 2006 ➤ , Passat CC 2009 ➤ , Tiguan 2008 ➤ 4-Cylinder Fuel Injection Engine (K1.8L and 2.0L engine, chain drive) engine ID CBFA & CCTA and Wiring Diagram
    9. Since I replace my battery with the OEM battery (my car does not have a BEM) with the same code my visual symptoms (warning lights are gone.) Just the Faults in the auto-scan remain.
    Tuesday,14,November,2017,20:14:05:53083
    VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
    VIN: WVWFV7AJ2CWxxxxx   License Plate: AFTER CLEARING DTC"s
    Mileage: 117300km-72886mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
    VIN: WVWFV7AJ2CWxxxxx   Mileage: 117300km-72886miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AS    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0040
       Revision: AAH18---    Serial number:
       Coding: 0403010A1C070160
       Shop #: WSC 35252 001 1048576
       VCID: 77AB151173C1B10F6A0-8022
    Readiness: 0000 0101
       Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2724
       Revision: 05351113    Serial number: 00001107280798
       VCID: 196F33A9A595477FBC4-804C
       Revision: 00H31001
       Coding: 114B600C492300FE881106E692200041B70800
       VCID: 7BA3092143E9956F0E8-802E
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0304
       Revision: 00001016
       Coding: 0000001002
       VCID: 00597ECD2A8FF6B75BA-8054
       Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 6F180A1A90272A04008800C17000054448010386534D8D60648020200040
       VCID: 3D27C7391D7D5B5F70C-8068
       Component: Wischer 05091  26  0512
       Coding: 009795
       Serial number: 003GVRA0KGF9
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3FDBBD3117F1494F620-806A
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--00060U5M00
       Serial number: 3572MSME39000263ZZZG
       Serial number: 3582MSME1A6B6562ZZZ+
       Serial number: 3512QSME42255D22ZZZQ
       Serial number: 3522QSME7E385B14ZZZ2
       Serial number: 35527SME49646628ZZZL
       Serial number: 35627SME606B6628ZZZM
       Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90422KHF000DD
       Coding: 589A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 78A9162D725FBE7763A-802C
       Component: E221__MFL-TAS  H08 0010
       Serial number: 0085037
       Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
       Coding: 270F01
       VCID: 3635D81538CB8807B16-8062
       Revision:   H42       Serial number: 020911F1001578
       Coding: 350000
       VCID: 3537DF19254D831FB8C-8060
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223REJ6N06
       VCID: 7EA500355CFB8047296-802A
       Component: IMMO          H03 0607
       VCID: 6A8D3C653CF31CE7E5E-803E
       Revision: A1001003    Serial number: 7660800500
       VCID: 290F0369F9F5D7FF2C4-807C
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2103
       Coding: 0001076
       VCID: 372BD5113341710FAA0-8062
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 74     3201
       Revision: 00H20000
       VCID: 3431E21D22379A178F2-8060
       Component: Tuer-SG         009 2117
       Coding: 0001076
       VCID: 323DE405D82394279DE-8066
       Part No SW: 1K0 035 164 C    HW: 1K0 035 164 C
       Component: LOW NAR SDARS H02 0004
       Revision: -----03S    Serial number: VWZ4Z6L3179074
       Coding: 01000400040005
       VCID: 221D144584C304A76DE-8076
                        Reset counter: 75
                        Mileage: 117305 km
                        Date: 2012.04.06
                        Time: 19:43:10
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007660754150
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 270B0551EF61E18F3A0-8072
    End----------(Elapsed Time: 01:00, VBatt start/end: 13.9V/13.9V)-----------
  2. #12
    Nov 2017
       Revision: 00H31001
       Revision: 00001016
       Coding: 0000001002
       Revision: 00110 AC
       Coding: 009795
       Coding: 00003131
       Coding: 589A140000
       Coding: 270F01
       Coding: 350000
       Coding: 0001076
       Revision: 00H20000
       Coding: 0001076
                        Reset counter: 75
                        Mileage: 117305 km
                        Date: 2012.04.06
                        Time: 19:43:10
       ROD: UHVNA.rod
    Here is my Broadcast
    4. VCDS SCAN
  3. #13
    Excellent keep an eye on everything and report back if any new issues occur please........
    If you would be so kind to let us know what you had to pay for or by posting your bill if you feel comfortable with that?
    You could also do 3 tests with VCDS to complete readiness.
    0x01-04-070/071/046
    or
    0x01-04-200 and step on brake and gas.......
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  4. #14
    Nov 2017
    0x01-04-070/071/046
    or
    Thanks Jack & Uwe for your help and patient with this newbie.
    If I had to do over again I would opted for the extended warrantee when I purchased my GTI (vehicle) but at the time I didn't want to add to the cost. I've been burned before in the past by warrantee's. But, if I knew repairs were that expensive it would have been well-worth-it. But onward thought the fog. "as the say" I will try to make as many repairs myself, or at least have a chance to shop-around on the cost.
    Fan repair: When the small fan when out they recommended I do both. Part & Labor $938.25
    Seal replacement: Replacement of rear main crank seal was very pricey, considering I did all the routine services at the dealer using there synthetic oil and for the seal to fail at 69K is kind of suspicious in my book. That repair was extremely pricey $1,246.50 and they gave me 10% and two months of sat radio.
    Water Pump: This was done at the same time as the Main Crank Seal. I would of thought this failure or leak should of fallen under defected pump by VW because I had read online about there being a recall on water pumps and I checked with the recall department and they said no, there is no defects with you engine. This cost was $861.29
    ABS: This repair I could of done myself but I had concerns about not being able to clear the Fault, So, off I went to the dealer. That cost was $349.67.
    Oil Changes: 10K service cost $119.For the 60K service I had a coupon 20% off $267.84 From now on I plan to DIY oil change and use Liqu Moly oil.
    As far as the other Scans you requested Jack, I will try to get them done today some time.
    Thanks again for all your help.
  5. #15
    Thank you for this data nevertheless OP..........
  6. #16
    Nov 2017
    0x01-04-070/071/046
    or
    Well Jack here goes... I finally picked up on the "What is Jack talking about"post
    Thursday	16	November	2017	15:01:27:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
    1K0 907 115 AS		2.0l R4/4V TFSI     0040
    	Group A:	'070				Group B:	 Not Running				Group C:	 Not Running
    		Evap. Emissions	Lambda Control	Evap. Emissions	EVAP Valve
    	TIME	Sol. Valve (Open)		Sol. Valve (Flow)	Test	TIME					TIME
    Marker	STAMP	 %	 %			STAMP					STAMP
    	0.01	5.1	0	 	Test OFF
    	0.15	5.1	0	 	Test OFF
    	0.28	5.1	0	 	Test OFF
    	0.43	5.1	0	 	Test OFF
    	0.57	5.1	0	 	Test OFF
    	0.71	5.1	0	 	Test OFF
    	0.84	5.1	0	 	Test OFF
    	0.98	5.1	0	 	Test OFF
    	1.13	5.1	0	 	Test OFF
    	1.26	5.1	0	 	Test OFF
    	1.41	5.1	0	 	Test OFF
    	1.57	5.1	0	 	Test OFF
    	1.69	5.1	0	 	Test OFF
    	1.83	5.1	0	 	Test OFF
    	1.97	5.1	0	 	Test OFF
    	2.11	5.1	0	 	Test OFF
    	2.25	5.1	0	 	Test OFF
    	2.4	5.1	0	 	Test OFF
    	2.53	5.1	0	 	Test OFF
    	2.67	5.1	0	 	Test OFF
    	2.82	5.1	0	 	Test OFF
    	2.96	5.1	0	 	Test OFF
    	3.1	5.1	0	 	Test OFF
    	3.24	5.1	0	 	Test OFF
    	3.38	5.1	0	 	Test OFF
    	3.52	5.1	0	 	Test OFF
    	3.66	5.1	0	 	Test OFF
    	3.8	5.1	0	 	Test OFF
    	3.93	5.1	0	 	Test OFF
    	4.08	5.1	0	 	Test OFF
    	4.22	5.1	0	 	Test OFF
    	4.38	5.1	0	 	Test OFF
    	4.52	5.1	0	 	Test OFF
    	4.65	5.1	0	 	Test OFF
    	4.8	5.1	0	 	Test OFF
    	4.94	5.1	0	 	Test OFF
    	5.08	5.1	0	 	Test OFF
    	5.22	5.1	0	 	Test OFF
    	5.36	5.1	0	 	Test OFF
    	5.5	5.1	0	 	Test OFF
    	5.64	5.1	0	 	Test OFF
    	5.79	5.1	0	 	Test OFF
    	5.93	5.1	0	 	Test OFF
    	6.06	5.1	0	 	Test OFF
    	6.21	5.1	0	 	Test OFF
    	6.35	5.1	0	 	Test OFF
    	6.49	5.1	0	 	Test OFF
    	6.63	5.1	0	 	Test OFF
    	6.76	5.1	0	 	Test OFF
    	6.91	5.1	0	 	Test OFF
    	7.05	5.1	0	 	Test OFF
    	7.18	5.1	0	 	Test OFF
    	7.33	5.1	0	 	Test OFF
    	7.49	5.1	0	 	Test OFF
    	7.63	5.1	0	 	Test OFF
    	7.77	5.1	0	 	Test OFF
    	7.91	5.1	0	 	Test OFF
    	8.05	5.1	0	 	Test OFF
    	8.19	5.1	0	 	Test OFF
    	8.33	5.1	0	 	Test OFF
    	8.49	5.1	0	 	Test OFF
    	8.63	5.1	0	 	Test OFF
    	8.77	5.1	0	 	Test OFF
    	8.92	5.1	0	 	Test OFF
    	9.07	5.1	0	 	Test OFF
    	9.2	5.1	0	 	Test OFF
    	9.35	5.1	0	 	Test OFF
    	9.49	5.1	0	 	Test OFF
    	9.63	5.1	0	 	Test OFF
    	9.76	5.1	0	 	Test OFF
    	9.91	5.1	0	 	Test OFF
    	10.05	5.1	0	 	Test OFF
    	10.19	5.1	0	 	Test OFF
    	10.33	5.1	0	 	Test OFF
    	10.47	5.1	0	 	Test OFF
    	10.62	5.1	0	 	Test OFF
    	10.76	5.1	0	 	Test OFF
    	10.91	5.1	0	 	Test OFF
    	11.05	5.1	0	 	Test OFF
    	11.19	5.1	0	 	Test OFF
    	11.33	5.1	0	 	Test OFF
    	11.47	5.1	0	 	Test OFF
    	11.61	5.1	0	 	Test OFF
    	11.75	5.1	0	 	Test OFF
    	11.89	5.1	0	 	Test OFF
    	12.04	5.1	0	 	Test OFF
    	12.17	5.1	0	 	Test OFF
    	12.32	5.1	0	 	Test OFF
    	12.46	5.1	0	 	Test OFF
    	12.6	5.1	0	 	Test OFF
    	12.73	5.1	0	 	Test OFF
    	12.88	5.1	0	 	Test OFF
    	13.02	5.1	0	 	Test OFF
    	13.16	5.1	0	 	Test OFF
    	13.3	5.1	0	 	Test OFF
    	13.44	5.1	0	 	Test OFF
    	13.57	5.1	0	 	Test OFF
    	13.73	5.1	0	 	Test OFF
    	13.88	5.1	0	 	Test OFF
    	14.01	5.1	0	 	Test OFF
    	14.16	5.1	0	 	Test OFF
    	14.3	5.1	0	 	Test OFF
    	14.44	5.1	0	 	Test OFF
    	14.58	5.1	0	 	Test OFF
    	14.71	5.1	0	 	Test OFF
    	14.86	5.1	0	 	Test OFF
    	15	5.1	0	 	Test OFF
    	15.13	5.1	0	 	Test OFF
    	15.29	5.1	0	 	Test OFF
    	15.42	5.1	0	 	Test OFF
    	15.57	5.1	0	 	Test OFF
    	15.7	5.1	0	 	Test OFF
    	15.85	5.1	0	 	Test OFF
    	15.99	4.7	0	 	Test OFF
    	16.12	5.1	0	 	Test OFF
    	16.27	5.1	0	 	Test OFF
    	16.41	5.1	0	 	Test OFF
    	16.55	5.1	0	 	Test OFF
    	16.68	5.1	0	 	Test OFF
    	16.83	5.1	0	 	Test OFF
    	16.97	5.1	0	 	Test OFF
    	17.11	5.1	0	 	Test OFF
    	17.24	5.1	0	 	Test OFF
    	17.38	5.1	0	 	Test OFF
    	17.53	5.1	0	 	Test OFF
    	17.67	5.1	0	 	Test OFF
    	17.81	5.1	0	 	Test OFF
    	17.96	5.1	0	 	Test OFF
    	18.1	5.1	0	 	Test OFF
    	18.24	5.1	0	 	Test OFF
    	18.38	5.1	0	 	Test OFF
    	18.52	5.1	0	 	Test OFF
    	18.65	5.1	0	 	Test OFF
    	18.79	5.1	0	 	Test OFF
    	18.93	5.1	0	 	Test OFF
    	19.08	5.1	0	 	Test OFF
    	19.21	5.1	0	 	Test OFF
    	19.36	5.1	0	 	Test OFF
    	19.5	5.1	0	 	Test OFF
    	19.64	5.1	0	 	Test OFF
    	19.79	5.1	0	 	Test OFF
    	19.93	5.1	0	 	Test OFF
    	20.07	5.1	0	 	Test OFF
    	20.2	5.1	0	 	Test OFF
    	20.34	5.1	0	 	Test OFF
    	20.48	5.1	0	 	Test OFF
    	20.62	5.1	0	 	Test OFF
    	20.76	5.1	0	 	Test OFF
    	20.9	5.1	0	 	Test OFF
    	21.04	5.1	0	 	Test OFF
    	21.19	5.1	0	 	Test OFF
    	21.32	5.1	0	 	Test OFF
    	21.47	5.1	0	 	Test OFF
    	21.6	5.1	0	 	Test OFF
    	21.75	5.1	0	 	Test OFF
    	21.9	5.1	0	 	Test OFF
    	22.04	5.1	0	 	Test OFF
    	22.18	5.1	0	 	Test OFF
    	22.31	5.1	0	 	Test OFF
    	22.46	5.1	0	 	Test OFF
    	22.59	5.1	0	 	Test OFF
    	22.73	5.1	0	 	Test OFF
    	22.88	5.1	0	 	Test OFF
    	23.02	5.1	0	 	Test OFF
    	23.16	5.1	0	 	Test OFF
    	23.3	5.1	0	 	Test OFF
    	23.44	5.1	0	 	Test OFF
    Thursday	16	November	2017	15:07:10:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
    Marker	STAMP					STAMP					STAMP
    	0.02	1	Brakes	Full Throt	10 Times
    	0.13	1	Brakes	Full Throt	10 Times
    	0.27	1	Brakes	Full Throt	10 Times
    	0.42	1	Brakes	Full Throt	10 Times
    	0.55	1	Brakes	Full Throt	10 Times
    	0.69	1	Brakes	Full Throt	10 Times
    Friday	17	December	2018	15:01:27:53083-VCID:77AB151173C1B10F6A0-8023	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.3
    1K0 907 115 AS		2.0l R4/4V TFSI     0041
    	Group A:	'071				Group B:	 Not Running				Group C:	 Not Running
    Thursday	16	November	2017	15:02:14:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
    		Reed Contact	Malfunction	Test Status	Leak Diagnostic
    	TIME	Condition	Message		Test Status	TIME					TIME
    	0.01	Reed Closed	Abort	 	Test OFF
    	0.15	Reed Closed	Abort	 	Test OFF
    	0.29	Reed Closed	Abort	 	Test OFF
    	0.43	Reed Closed	Abort	 	Test OFF
    	0.57	Reed Closed	Abort	 	Test OFF
    	0.7	Reed Closed	Abort	 	Test OFF
    	0.86	Reed Closed	Abort	 	Test OFF
    	1.14	Reed Closed	Abort	 	Test OFF
    	1.27	Reed Closed	Abort	 	Test OFF
    	1.42	Reed Closed	Abort	 	Test OFF
    	1.56	Reed Closed	Abort	 	Test OFF
    	1.7	Reed Closed	Abort	 	Test OFF
    	1.84	Reed Closed	Abort	 	Test OFF
    	1.98	Reed Closed	Abort	 	Test OFF
    	2.11	Reed Closed	Abort	 	Test OFF
    	2.26	Reed Closed	Abort	 	Test OFF
    	2.39	Reed Closed	Abort	 	Test OFF
    	2.54	Reed Closed	Abort	 	Test OFF
    	2.68	Reed Closed	Abort	 	Test OFF
    	2.81	Reed Closed	Abort	 	Test OFF
    	2.95	Reed Closed	Abort	 	Test OFF
    	3.1	Reed Closed	Abort	 	Test OFF
    	3.25	Reed Closed	Abort	 	Test OFF
    	3.39	Reed Closed	Abort	 	Test OFF
    	3.52	Reed Closed	Abort	 	Test OFF
    	3.67	Reed Closed	Abort	 	Test OFF
    	3.81	Reed Closed	Abort	 	Test OFF
    	3.94	Reed Closed	Abort	 	Test OFF
    	4.08	Reed Closed	Abort	 	Test OFF
    	4.22	Reed Closed	Abort	 	Test OFF
    	4.37	Reed Closed	Abort	 	Test OFF
    Thursday	16	November	2017	15:06:00:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
    	Group A:	'200				Group B:	 Not Running				Group C:	 Not Running
    		Status Counter	Status	Status	Status
    	TIME					TIME					TIME
    	0.06	18	Brakes	Full Throt	10 Times
    	0.21	18	Brakes	Full Throt	10 Times
    	0.34	18	Brakes	Full Throt	10 Times
    	0.49	18	Brakes	Full Throt	10 Times
    	0.64	18	Brakes	Full Throt	10 Times
    	0.78	18	Brakes	Full Throt	10 Times
    	0.93	18	Brakes	Full Throt	10 Times
    	1.06	18	Brakes	Full Throt	10 Times
    	1.2	18	Brakes	Full Throt	10 Times
    	1.36	18	Brakes	Full Throt	10 Times
    	1.52	18	Brakes	Full Throt	10 Times
    	1.66	18	Brakes	Full Throt	10 Times
    	1.81	18	Brakes	Full Throt	10 Times
    	1.95	18	Brakes	Full Throt	10 Times
    	2.08	18	Brakes	Full Throt	10 Times
    	2.22	18	Brakes	Full Throt	10 Times
    	2.37	18	Brakes	Full Throt	10 Times
    	2.5	18	Brakes	Full Throt	10 Times
    	2.64	18	Brakes	Full Throt	10 Times
    	2.78	18	Brakes	Full Throt	10 Times
    	2.93	18	Brakes	Full Throt	10 Times
    	3.07	18	Brakes	Full Throt	10 Times
    	3.22	18	Brakes	Full Throt	10 Times
    	3.36	18	Brakes	Full Throt	10 Times
    	3.5	18	Brakes	Full Throt	10 Times
    	3.64	18	Brakes	Full Throt	10 Times
    	3.78	18	Brakes	Full Throt	10 Times
    	3.93	18	Brakes	Full Throt	10 Times
    	4.07	18	Brakes	Full Throt	10 Times
    	4.22	18	Brakes	Full Throt	10 Times
    	4.36	18	Brakes	Full Throt	10 Times
    	4.5	18	Brakes	Full Throt	10 Times
    	4.64	18	Brakes	Full Throt	10 Times
    	4.78	18	Brakes	Full Throt	10 Times
    	4.93	18	Brakes	Full Throt	10 Times
    	5.08	18	Brakes	Full Throt	10 Times
    	5.22	18	Brakes	Full Throt	10 Times
    	5.37	18	Brakes	Full Throt	10 Times
    	5.51	18	Brakes	Full Throt	10 Times
    	5.64	18	Brakes	Full Throt	10 Times
    	5.78	18	Brakes	Full Throt	10 Times
    	5.92	18	Brakes	Full Throt	10 Times
    	6.07	18	Brakes	Full Throt	10 Times
    	6.22	18	Brakes	Full Throt	10 Times
    	6.36	18	Brakes	Full Throt	10 Times
    	6.5	18	Brakes	Full Throt	10 Times
    	6.64	18	Brakes	Full Throt	10 Times
    	6.78	18	Brakes	Full Throt	10 Times
    	6.93	18	Brakes	Full Throt	10 Times
    	7.08	18	Brakes	Full Throt	10 Times
    	7.22	18	Brakes	Full Throt	10 Times
    	7.37	18	Brakes	Full Throt	10 Times
    	7.5	18	Brakes	Full Throt	10 Times
    	7.64	18	Brakes	Full Throt	10 Times
    	7.78	18	Brakes	Full Throt	10 Times
    	7.92	18	Brakes	Full Throt	10 Times
    	8.06	18	Brakes	Full Throt	10 Times
    	8.21	18	Brakes	Full Throt	10 Times
    	8.36	18	Brakes	Full Throt	10 Times
    	8.5	18	Brakes	Full Throt	10 Times
    	8.65	18	Brakes	Full Throt	10 Times
    	8.79	18	Brakes	Full Throt	10 Times
    	8.92	18	Brakes	Full Throt	10 Times
    	9.07	18	Brakes	Full Throt	10 Times
    	9.2	18	Brakes	Full Throt	10 Times
    	9.35	18	Brakes	Full Throt	10 Times
    	9.5	18	Brakes	Full Throt	10 Times
    	9.64	18	Brakes	Full Throt	10 Times
    	9.78	18	Brakes	Full Throt	10 Times
    	9.93	18	Brakes	Full Throt	10 Times
    	10.06	18	Brakes	Full Throt	10 Times
    Thursday	16	November	2017	15:03:03:53083-VCID:77AB151173C1B10F6A0-8022	VCDS Version: Release 17.8.0 (x64)	Data version: 20170721 DS276.2
    	Group A:	'071				Group B:	'046				Group C:	 Not Running
    		Reed Contact	Malfunction	Test Status	Leak Diagnostic		Engine Speed	Catalytic Converter	Catalytic	Cat. Conversion
    	TIME	Condition	Message		Test Status	TIME	(G28)	Bank 1 Temp.	Conversion Bank 1	Test Bank 1	TIME
    Marker	STAMP					STAMP	 /min	C			STAMP
    	0.15	Reed Closed	Abort	 	Test OFF	0.01	760	294	0	Test OFF
    	0.42	Reed Closed	Abort	 	Test OFF	0.28	760	294	0	Test OFF
    	0.72	Reed Closed	Abort	 	Test OFF	0.58	760	294	0	Test OFF
    	1.02	Reed Closed	Abort	 	Test OFF	0.86	720	294	0	Test OFF
    	1.3	Reed Closed	Abort	 	Test OFF	1.15	760	294	0	Test OFF
    	1.58	Reed Closed	Abort	 	Test OFF	1.45	720	294	0	Test OFF
    	1.86	Reed Closed	Abort	 	Test OFF	1.72	760	294	0	Test OFF
    	2.14	Reed Closed	Abort	 	Test OFF	2	760	294	0	Test OFF
    	2.42	Reed Closed	Abort	 	Test OFF	2.28	720	294	0	Test OFF
    	2.7	Reed Closed	Abort	 	Test OFF	2.56	760	288	0	Test OFF
    	3	Reed Closed	Abort	 	Test OFF	2.86	720	288	0	Test OFF
    	3.28	Reed Closed	Abort	 	Test OFF	3.15	720	288	0	Test OFF
    	3.56	Reed Closed	Abort	 	Test OFF	3.42	720	288	0	Test OFF
    	3.85	Reed Closed	Abort	 	Test OFF	3.7	720	288	0	Test OFF
    	4.13	Reed Closed	Abort	 	Test OFF	3.99	760	288	0	Test OFF
    	4.41	Reed Closed	Abort	 	Test OFF	4.27	760	288	0	Test OFF
    	4.69	Reed Closed	Abort	 	Test OFF	4.55	760	288	0	Test OFF
    	4.97	Reed Closed	Abort	 	Test OFF	4.83	720	288	0	Test OFF
    	5.26	Reed Closed	Abort	 	Test OFF	5.11	720	288	0	Test OFF
    Thursday,16,November,2017,14:20:30:53083
       Revision: 00H31001
       Revision: 00001016
       Coding: 0000001002
       Revision: 00110 AC
       Coding: 009795
       Coding: 00003131
       Coding: 589A140000
       Coding: 350000
       Coding: 0001076
       Coding: 0001076
                        Reset counter: 78
                        Mileage: 117334 km
                        Date: 2006.14.12
                        Time: 17:39:19
       ROD: UHVNA.rod
    End----------(Elapsed Time: 01:21, VBatt start/end: 13.9V/13.8V)-----------
  7. Likes Jack@European_Parts, Uwe liked this post
  8. #17
