Results 1 to 5 of 5
Thread: 2007 Eos Top inop
    Nov 2017
    2007 Eos Top inop
    Hello
    This is my first time posting. Customer stated top will not open. Found cracked third brake light. Water destroyed pump, latch, latch assist module and blew 40 amp fuse to roof module. Replace pump, latch, latch assist module and wire ends to to latches and even replaced roof module. After normalizing windows and doing a capacity discharge 3 time, sunroof rolls back and you can hear pump running and unlocking C segment but C Segment does not lift. Close roof to make light on dash go out. Check faults. Has 02805 fault. System interference. Check Roof Binary Data in Closed Position, all are correct. One problem I see is the trunk assist module is not working and pull the trunk down at all. Factory wiring diagram shows power and ground, which are all OK, and three signal wires going to roof module. There is no faults for latch assist module. Has anyone seen this problem with the latch assist module before and will this cause a problem with the roof not opening? I also saw previous blog on Eos roof problems. I tried basic setting to make roof open and did not find a value block to initiate this process. Any ideas or help would be greatly appreciated.
    Welcome to the forum.
    Would you be so kind as to post an Auto-Scan from this car for context, please?
    Nov 2017
    Monday,13,November,2017,09:02:56:61823
    VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
    VIN: WVWFA71F07V006316   License Plate:
    Chassis Type: 1F (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 47 52 56 62
              63 65 72 73
    VIN: WVWFA71F07V006316   Mileage: 194310km-120738miles
    26-Auto Roof -- Status: Malfunction 0010
    63-Entry Assist,D -- Status: OK 0000
    73-Entry Assist, P -- Status: OK 0000
       Part No SW: 1Q0 907 115 E    HW: 1Q0 907 115 B
       Revision: --H14---    Serial number: VWX7Z0F53NK9MK
       Coding: 041C010A1C070160
       Shop #: WSC 22600 444 53940
       VCID: AE1044C339E6BA36A8-80FA
    Readiness: 0010 0101
       Part No SW: 02E 300 043 F    HW: 02E 927 770 AE
       Component: GSG DSG         070 1157
       Revision: 04507000    Serial number: 00000605180645
       Shop #: WSC 44551 111 44551
       VCID: 977E8127A67C5BFEDB-80C2
       Revision: 00H11001
       Coding: 0021218
       Shop #: WSC 00020 000 00000
       VCID: F3A695B79244D7DE07-80A6
       Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
       Component: ClimatronicPQ35 093 0101
       Revision: 00093002    Serial number: 00000000000000
       VCID: AB164DD70AF4CF1E8F-80FE
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000005709453
       Coding: F58C8F0340041500470000000F00000000285D035C0000
       VCID: B73E61A7C6BC7BFEFB-80E2
       Component: Wischer 300606 020  0501
       Coding: 00038805
       Shop #: WSC 00020
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     100606 014  1201
       Coding: 00208933
       Shop #: WSC 00020
       Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
       Component: SDAR SIRIUS     H03 0120
       Revision: 00000000    Serial number: AUZ4Z7F3029964
       VCID: AC144ECB0FFAC82686-80F8
                000 -  -
                        Reset counter: 28
                        Mileage: 194315 km
                        Time: 09:45:44
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 13 Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B3000FN9L
       Coding: 0012595
       VCID: BA387893F5AE669604-80EE
       Subsystem 1 - Part No: 1Q0 959 339
       Component: BF-Gewichtsens. 006 0003
       Subsystem 2 - Serial number: 37T2B
       Subsystem 3 - Serial number: 0001.01.000000600000000000†63
       Subsystem 4 - Serial number: 000000†6332SRB403610A96X†63
       Subsystem 5 - Serial number: 10A96X†6342SRB4036BCA211†63
       Subsystem 6 - Serial number: BCA211†6372URB40147CF8FN†63
       Subsystem 7 - Serial number: 7CF8FN†6382URB40147D01E2
       Subsystem 8 - Serial number: 7D01E2
       Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
       Component: J0527           035 0070
       Coding: 0012021
       VCID: 8346C577C2E4E75E17-80D6
       Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
       Revision: V0003000    Serial number: VWX7Z0F53NK9MK
       Coding: 0023203
       VCID: B22850B32DDE9ED6CC-80E6
       Revision:   H12       Serial number: 3100106606879E
       Coding: 3FBF23620F065000
       Part No SW: 1Q0 919 965     HW: 1Q0 919 965
       Component: Kompass         002 0001
       Revision: 00002000    Serial number: 1350208TK3KZ02
       VCID: F9BAA79FB028AD8E4D-80AC
       Component: IMMO            VDD 1610
       Shop #: WSC 64973 001 1048576
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 G    HW: 1Q0 959 255 G
       Component: Verdecksteuergeraet 0860
       Revision: 0033100R    Serial number: 151890154
       Coding: 0655360
       VCID: BC347E8BFF9A58A616-80E8
    02805 - System Interference
                000 -  -
                        Reset counter: 28
                        Mileage: 194315 km
                        Time: 09:48:00
                        Voltage: 13.30 V
                        Voltage: 13.40 V
                        Voltage: 4.90 V
                        Error Code: 12
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2737
       Coding: 0001207
       Shop #: WSC 22578 444 13900
       VCID: B42456ABD7CA90E6DE-80E0
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
                000 -  -
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 93908A800186281B0804040FB0080E04888C00
       Shop #: WSC 12345 123 12345
       VCID: F4A496AB974AD0E61E-80A0
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No SW: 1Q0 035 456 B    HW: 1Q0 035 456 B
       Component: DSP 10 Kanal        0013
       Revision: 00010000    Serial number: 00000000002465
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 B
       Coding: 0001206
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0019
       Revision: 00017000    Serial number: VWZ5Z7F2086550
       Coding: 0010011
       VCID: A404A6EB672A00664E-80F0
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
    Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
       Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
       Component: J572  EASYENTRY FS  0603
       Revision: 00H01000    Serial number: 5DS008646-01--
       Component:    RDK              0420
       Coding: 0000000
                        Fault Status: 01110101
                        Mileage: 194315 km
                        Time: 09:45:33
       Part No: 1Q0 959 704
       Coding: 0000128
    Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
       Component: J573  EASYENTRY BFS 0603
    End----------(Elapsed Time: 01:42, VBatt start/end: 14.1V/14.0V)-----------
  4. Likes Uwe liked this post
    Nov 2017
    HS1: 1 1 1 1 0 1 1 0 0 1 1 0 - :HS13 Hall Sensor Status In closed position.
    Nov 2017
    Update.
    Found problem with new latch. Replaced latch again. Now trunk assist module now shows roof module unlocked. Roof now operates correctly.
  7. Likes Uwe liked this post
