Start stop button & close button
Carat10
Poland
C?ID=210097
Hi, I have beetle 2012 form Canada with CA, have two problem, I try repair but no idea:
Problem with start / stop button, I open car, go inside, click> ignition on, when I click again> nothing happens (normal car> ignition off), when push brake pedal and click> start engine, click again> ignition off, button is ok
Can not close car from key fob, open button & open trunk working, but when i click close nothing happens, remote control is ok, central locking in doors, bonnet etc .. are ok., Where i can view status button in unit?
Thanks for help
Please post Auto-Scan so people can see exactly what control modules this car has.
Carat10
Poland
C?ID=210097
Full scan ..............
Monday,13,November,2017,08:31:44:27911
VCDS Version: 17.8.0.1 (x64)
VIN: 3VWVA7AT2DM609496   License Plate: RED BEETLE
Mileage: 130km-80mi   Repair Order:
Chassis Type: AT-VW32 (6R0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 44 47 56 B9
VIN: 3VWVA7AT2DM609496   Mileage: 130km-80miles
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 FK    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 4353
   Revision: PAH04---    Serial number:
   Coding: 040301081C070160
   Shop #: WSC 65793 128 08224
   VCID: 79F9E5A830B4558ECD-802C
Readiness: 1110 1101
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3516
   Revision: 05351112    Serial number: 00001102180534
   Shop #: WSC 44551 111 44551
   VCID: 275DF3D09680137EEB-8072
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Reset counter: 40
                    Mileage: 134 km
                    Date: 2017.11.13
                    Time: 01:47:35
18290 - Powertrain Data Bus
            P1882 - 000 - Missing Message from Electric Parking Brake Controller
                    Reset counter: 40
                    Mileage: 134 km
                    Date: 2017.11.13
                    Time: 01:47:35
Address 03: ABS Brakes        Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 H31 01560156
   Coding: F14B6016492200038F0F06ED921F0041A71800
   Shop #: WSC 24478 002 1048576
   VCID: 2E5306F4797A423628-807A
No Faults Found
   Revision: 00085000    Serial number: 0180005023
   Coding: 030C1C
   ROD: EV_KESSYPQ35G.rod
   VCID: 3467149C9F5668E65E-8060
   Part No SW: 5C0 820 047 AA    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0203
   Revision: 2000908S    Serial number: 00000000250704
   Shop #: WSC 08305 993 28888
   VCID: 5FCDAB308E509BBED3-800A
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Date: 2017.10.29
                    Time: 01:10:13
Address 09: Cent. Elect.        Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 088 C    HW: 7H0 937 088 A
   Component: BCM25 KDR3    H74 0376
   Coding: 3BBC691B288B000008A82930640984C5ADC2620F60844C51B2A004000000
   VCID: 356129989C2C71EE69-FFFE
   Subsystem 1 - Part No: 6R0 959 801 AP  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT
   Coding: 0CBC30
No Faults Found
Address 15: Airbags
   Part No SW: 5C5 920 970 F    HW: 5C5 920 970 F
   Component: KOMBI         H23 0103
   Revision: X0023005    Serial number: 00000000000000
   Coding: 250A01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04712
   ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
   VCID: 2E5306F4717A423628-807A
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 E    HW: 1K0 907 951
   Component: J533  Gateway H38 0041
   Revision:   H38       Serial number: 22061203300217
   Coding: 254080
   Shop #: WSC 00066 123 12345
   VCID: 356129989C2C71EE69-8060
01304 - Radio
Address 25: Immobilizer
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Revision: 00000000    Serial number: 15000119995003
   Coding: 0100000000000000
   Shop #: WSC 55512 001 1048576
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306F188C6B4E54C63A-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 377D2390462083FE7B-8062
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 11.7 V
                        PD
                    Temperature: 13.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 47: Sound System (R12)       Labels: None
   Part No HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225319940684
   VCID: 55A18918346C51EE89-8000
Address 56: Radio
Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
   Part No SW: 5C5 919 527 C    HW: 5C5 919 527 C
   Component: ZUSATZANZEIGE H16 0014
   Coding: 05
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001007
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 31691D8860445DCE35-8064
End-------------------------(Elapsed Time: 02:31)--------------------------
