I read that these cars should go to recirc mode when you put it in reverse.
Mine does not do it, 2013 q7 tdi. I would like to activate this feature.
Can someone share what im sure is a quick tweak in the hvac setting?
Thanks in advance
Here is an older scan for the module numbers.
Thanks in advance
Tuesday,24,October,2017,15:44:54:31519
VCDS Version: 17.1.3.0 (x64)
VIN: WA1VMAFE0DD011141 License Plate: BUG
Mileage: 102220km-63516mi Repair Order: 2
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE0DD011141 Mileage: 102220km-63516miles
Address 01: Engine (J623-CNRB) Labels: 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI EDC17 H21 0008
Revision: 54H21--- Serial number:
Coding: 2A2A4012257600050000
Shop #: WSC 18787 002 104857
ASAM Dataset: EV_ECM30TDI0114L2910401A 001009
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 224B36FC35B4EE51DF-8076
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 2222
Coding: 001378
Shop #: WSC 14630 002 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 7BF52B98F29E7F99BC-802E
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0623729
Shop #: WSC 31414 790 00001
VCID: 3467C0A4574070E13D-8060
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702034839
Coding: 0000135
VCID: 25412DE0EC9A1969BA-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000357867
Coding: 0304A036
VCID: 25412DE02C9A1969BA-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0047740013
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0139123
VCID: 6ED312CC79EC1A310B-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels: 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961234800156
Coding: 29011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3467C0A49F4070E13D-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031111
VCID: 275D27E896960B7988-8072
Reset counter: 135
Mileage: 102229 km
Date: 2017.10.24
Time: 15:38:18
Temperature: 17.0°C
Voltage: 11.78 V
Bin. Bits: 01000
Hex Value: 0x0411
Hex Value: 0x0006
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0C11H
Coding: 0014131
VCID: 2B55DBD88A7E2F196C-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME6C27357AR
Subsystem 3 - Serial number: 6342QSME232D106EH
Subsystem 4 - Serial number: 6352QSME6B28447EX
Subsystem 5 - Serial number: 6362QSME08271E54J
Subsystem 6 - Serial number: 63734SME78253C746
Subsystem 7 - Serial number: 63834SME78252B723
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H08000 Serial number: 90026122820064
Coding: 0012252
VCID: 285F24D49B88040181-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 G HW: 4L0 920 985 G
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGF41EH1E
Coding: 8BD664040D00CF05020205
VCID: 387FF4948B28948111-806C
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M131030078
Coding: 00C303
VCID: 3F8D9F88AE06A3B9D0-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000004120910881
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000000359061
Coding: 0000006
VCID: 68DF64D45B08C40141-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000048415537
Coding: 00581B00000011110000
VCID: 326BC6BC6D547ED12F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH02 0050
Revision: 00H02000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E53D2CCB96C5A314B-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H02 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F07.01.1300H02000AMS14088ÿ
Subsystem 4 - Serial number: S14088ÿ
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000049940409
Coding: 011F57205E40440004
VCID: 489F8454FBC8E40161-801C
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01894028310000
Coding: 3569941
VCID: 387FF4944B28948111-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000011942
Coding: 030000
VCID: 295921D040823D099E-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190069603
Coding: 0758477
VCID: 234533F8E2AEE759D4-8076
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000131257
Coding: 0012001
VCID: 5EB3420C894C8AB1BB-800A
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000049024740
VCID: 479D8768F6D6EB7968-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156A.0D7681283
Coding: 020007010000000000
VCID: 224B36FC3DB4EE51DF-8076
Part No SW: 4L2 035 746 C HW: 4L2 035 746 A
Component: H-BNT-NA H44 0624
Revision: -------- Serial number: 224AM0D7516113
Coding: 180200060004EBEF710003456F632003140000000100000000
VCID: 2E53D2CC796C5A314B-807A
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Component: DU7 High H42 0104
Serial number: A130A-0D2637987
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002080403
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000049074220
Coding: 010E57204040230004
VCID: 46838A6CF1DCF27193-8012
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
VCID: 244730E4E7A0E061AD-8070
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0067633
Coding: 020C010001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED312CCB1EC1A310B-803A
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD718C44FF0E82125-8038
Subsystem 3 - Serial number: RD19.01.13--H57001001B0075ÿ
Subsystem 4 - Serial number: 1B0075ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 132363126-----
Coding: 0003595
VCID: 26432AEC919C1271B3-8072
Component: J_245_EE16_SKB10H13 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H13 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H13 0220
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000049077966
End-------------------------(Elapsed Time: 04:57)--------------------------
