Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 06 new beetle P0411 secondary air injection insufficient flow detected
    Nov 2017
    OK Jack here we go.
    Thursday,16,November,2017,19:48:14:61840
    VCDS Version: 17.8.0.1 (x64)
    VIN: 3VWRF31YX6M330145   License Plate:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    VIN: 3VWRF31YX6M330145   Mileage: 137310km-85320miles
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 B    HW: Hardware No
       Component: R5              G   7828
       Revision: --------    Serial number: VWZ5Z0F4238213
       Coding: 0000003
       VCID: 285F26CC98028B06E2-5124
    Readiness: 0110 1101
       Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
       Component: AQ 250 6F           0759
       Revision: 00H27000    Serial number:
       Coding: 0000008
       VCID: 78FF368C0822DB86B2-5140
       Part No: 1C0 907 379 Q
       Coding: 0019978
       Shop #: WSC 00066 000 00000
       VCID: 387FF68C48A21B8672-5140
       Part No: 6Q0 909 605 AL
       Component: 01 AIRBAG VW71      0811
       Coding: 0012337
       VCID: 01095B685BF89A4E85-5124
       Subsystem 1 - Part No: 1C0 959 339 F
       Component: BF-Gewichtsens. 006 0007
       Part No: 1C0 920 501 T
       Component: KOMBI+WEGFAHRS. M73 V01
       Coding: 11234
       Shop #: WSC 25096
       VCID: 295923C8D308B20EFD-4B00
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V012
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EF0EAC305283C67A-4B00
    Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
       Part No SW: 1C0 920 501 T    HW: 1C0 920 501 T
       Component: IMMO                X007
       Revision: xxxxxxxx    Serial number: VWZ5Z0F4238213
       Shop #: WSC 25096 444 85853
       VCID: 295923C88308B20EFD-5140
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255 C
       Component:  VSG  NBC           3601
       VCID: 408F9E6C10725346CA-5140
       Part No: 1C0 959 799 G
       Component: 6J Komfortgerát HLO 0004
       Coding: 00256
       Shop #: WSC 00066
       VCID: 3B75E9802994309E9F-4B00
       Subsystem 1 - Part No: 1Y1959801C
       Component: 6J Tőrsteuer.FS KLO 0005
       Subsystem 2 - Part No: 1Y1959802D
       Component: 6J Tőrsteuer.BF KLO 0005
       Subsystem 3 - Part No: 1Y0959811
       Component: 6J Tőrsteuer.HL KLO 0005
       Subsystem 4 - Part No: 1Y0959812
       Component: 6J Tőrsteuer.HR KLO 0005
       Part No: 1C0 035 196 BP
       Component:  RADIO DE2         0006
       Coding: 06031
       Shop #: WSC 00066
       VCID: 6ED310D42A66953668-51B6
    End-------------------------(Elapsed Time: 03:59)--------------------------
    Guess re-coding clears faults. Before "coding", checked readiness page; all systems indicated "passed" but P0411 fault in place?????????????????????????
    Thanks for sticking with me.
  2. #12
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuel Pump Relay (J17) faulty
    • Hoses/Pipes to/between Components faulty/clogged
    • Secondary Air Injection Pump (V101) faulty
    • Secondary Air Injection Pump Relay (J299) faulty
    • Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    • Check Fuel Pump Relay (J17)
    • Check Hoses/Pipes to/between Components
      • Check Secondary Air Injection Hoses/Pipes for Carbonization
    • Check Secondary Air Injection Pump (V101)
    • Check Secondary Air Injection Pump Relay (J299)
    • Check Secondary Air Injection Solenoid Valve (N112)
    Please recode with something other than zeros in WSC...............please configure VCDS..........
    Do it here......
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  3. #13
    Nov 2017
    I did read the online manual for "options screen" prior to performing coding the first time warning me not to make changes in the options screen itself. Sorry for the misunderstanding.
    OK will do the following:
    From options screen.
    Shop Name= Ross-Tech LLC.
    WSC= 03743
    VZ/Importer= 444 (for USA)
    Equipment= 00001
    Apply and Save.
    Verify parameters on "option" screen populate same parameters on "coding" screen. With software coding value of 00003, perform "Di it!"
  4. Likes Jack@European_Parts liked this post
  5. #14
  6. #15
    Nov 2017
    I needed that.
    Checked readiness status before coding. All parameters show ready but P0411 fault present.
    Sunday,05,November,2017,13:37:52:61840
                    Address 01: Engine  (07K 906 032 B)
    13:37:38
      0.8 %   Sec. Air Injection System Air Mass
      Test OFF   Result Sec. Air Injection System
    13:41:33
      -100.0 %   Sec. Air Injection System Air Mass
    13:42:49
    Saturday,11,November,2017,11:57:00:61840
    Readiness Status: 0010 0000
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Failed or Incomplete
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Passed
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
    Tuesday,14,November,2017,18:00:54:61840
    Control Module Part Number: 07K 906 032 B    HW: Hardware No
      Component and/or Version: R5              G   7828
               Software Coding: 0000003
                Work Shop Code: WSC 00066 000 00000
                          VCID: 285F26CC98028B06E2-5140
    005170 - Secondary Air Injection Solenoid Valve (N112)
                   P1432 - 004 - Open Circuit
                        Mileage: 137202 km
                        RPM: 937 /min
                        Load: 38.0 %
                        Temperature: 45.0°C
                        Temperature: 29.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 11.049 V
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0030 - 004 - Malfunction / Open Circuit
                        Mileage: 137202 km
                        RPM: 685 /min
                        Load: 26.7 %
                        Temperature: 77.0°C
                        Temperature: 27.0°C
                        Voltage: 13.843 V
    Saturday,18,November,2017,16:49:09:61840
    Readiness Status: 0000 0000
    Oxygen Sensor(s): Passed
    Here is most recent auto scan after coding.
    Saturday,18,November,2017,17:11:21:61840
    Dealer/Shop Name: Ross-Tech LLC.
    Workshop Code: 444 03743 000001
    VIN: 3VWRF31YX6M330145   Mileage: 137470km-85419miles
       Coding: 0000003
       Shop #: WSC 03743 444 00001
       Coding: 0000008
       VCID: 78FF368C0822DB86B2-5124
       Coding: 0019978
       VCID: 387FF68C48A21B8672-5124
       Coding: 0012337
       VCID: 01095B685BF89A4E85-5140
       Coding: 11234
       Shop #: WSC 25096
       Coding: 00006
       Shop #: WSC 00066
       Coding: 00256
       Shop #: WSC 00066
       Coding: 06031
       Shop #: WSC 00066
       VCID: 6ED310D42A66953668-51D4
    End-------------------------(Elapsed Time: 03:58)--------------------------
    Hope this helps you. Does nothing for me.
  7. #16
    O.k........
    Something is FOD here because SAI states passed but the bit shows otherwise.
    Fix DTC's on record for SAI & OXS.....check fuse for heater circuit.
    Please have controller firmware update programming performed at dealer.
