Not sure if this is a bug or car issue?
Seat Ibiza 2008 BWX engine
HEX-NET wont scan Engine ECU
Check engine direct - using 01-engine (No luck)
Check CAN gateway MVB 125 - Engine shows as being online
Tried with the wired HEX-CAN lead and this scan the engine no problem
Anything else you want me to try before the car leaves the workshop???
Thursday,09,November,2017,08:35:48:06091
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4407.4
Dealer/Shop Name: DG Motor Services
VIN: VSSZZZ6JZ9R044368 License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZ9R044368 Mileage: 97700km-60707miles
4B-Multifunc. Module -- Status: Malfunction 0010
Address 01: Engine
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 HW: 6R0 907 379
Component: ABS8.2 front H03 0004
Revision: --------
Coding: 100224DB017100B6082824E880D900000000
Shop #: WSC 04941 000 00000
VCID: FBB6A1ED7EF22B9E5F-80AE
Fault Status: 00101101
Reset counter: 139
Mileage: 97697 km
Date: 2012.03.31
Time: 13:00:35
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3012
Hex Value: 0x138D
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
18265 - Load Signal
P1857 - 008 - Error Message from ECU - Intermittent
Reset counter: 139
Mileage: 97697 km
Date: 2012.03.31
Time: 13:00:35
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x301A
Hex Value: 0x138D
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
Part No SW: 6J0 820 043 HW: 6J0 820 043
Component: Climatronic H07 0203
Revision: S0000000
VCID: E18AF385F85EE14E65-80B4
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Fault Frequency: 11
Reset counter: 139
Mileage: 73169 km
Date: 2010.10.02
Time: 00:02:22
Reset counter: 139
Mileage: 97558 km
Date: 2012.03.29
Time: 07:17:48
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H06 0011
Revision: BF006001 Serial number: 9425A185080124
Coding: 7C8829A88861010000200000660B1CC800C0400F608C00002000
Shop #: WSC 64564 324 38760
VCID: FAB8A4E975C8129644-80AE
Subsystem 1 - Part No SW: 6R0 959 802 A HW: 6R0 959 802 A Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 001 0232
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 C HW: 6R0 959 801 C Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 001 0236
Coding: 020000
Fault Frequency: 15
Mileage: 61585 km
Date: 2009.02.24
Time: 11:52:26
Part No SW: 6R0 959 655 HW: 6R0 959 655
Component: VW10AirbagA0D H07 0013
Revision: -------- Serial number: 003000000000
Coding: 003044
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_VW31.rod
VCID: FF4E55FD66EA37BE73-80AA
Serial number: 3492ERB40335G3476SJ$
Serial number: 3502ERB40315G346VJ2R
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 6J0 920 900 K HW: 6J0 920 900 K
Component: KOMBI 017 0018
Coding: 410A00
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: AF2E45BDF60A073EA3-80FA
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0011
Coding: 422100
VCID: F0AC86C123B458C6FA-80A4
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO 017 0018
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Fault Frequency: 13
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 72945 km
Date: 2016.03.14
Time: 00:00:01
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10121
Shop #: WSC 06402
VCID: ED929FB5A086B52ED1-80B8
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Shop #: WSC 77005 000 00000
VCID: F0AC86C1E3B458C6FA-80A4
00532 - Supply Voltage B+
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H55 0033
Revision: 0H001001 Serial number: SEZ1Z2H5681130
Coding: 0501040002
VCID: A306B98DA2C2B35E37-80F6
End----------(Elapsed Time: 01:12, VBatt start/end: 14.2V/14.3V)-----------
Thursday,09,November,2017,09:43:38:63837
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BK HW: 03C 906 024 BH
Component: MM4HV G 3052
Revision: --H05--- Serial number:
Coding: 0000071
VCID: E8D5FDFBD88A0606A2-5140
17769 - Cylinder 3 Ignition Circuit
P1361 - 000 - Open Circuit - Intermittent
Reset counter: 99
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:04
Bin. Bits: 00000000
Load: 98.9 %
Lambda: 0.0 %
Temperature: 51.0°C
Absolute Pres.: 1005.8 mbar
RPM: 325 /min
17772 - Cylinder 4 Ignition Circuit
P1364 - 000 - Open Circuit - Intermittent
Reset counter: 99
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:04
Bin. Bits: 00000000
Load: 98.9 %
Lambda: 0.0 %
Temperature: 51.0°C
Absolute Pres.: 958.8 mbar
RPM: 340 /min
17766 - Cylinder 2 Ignition Circuit
P1358 - 000 - Open Circuit - Intermittent
Reset counter: 99
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:04
Bin. Bits: 00000000
Load: 90.8 %
Lambda: 0.0 %
Temperature: 51.0°C
Absolute Pres.: 999.6 mbar
RPM: 318 /min
17763 - Cylinder 1 Ignition Circuit
P1355 - 000 - Open Circuit - Intermittent
Reset counter: 99
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:04
Bin. Bits: 00000000
Load: 97.9 %
Lambda: 0.0 %
Temperature: 51.0°C
Absolute Pres.: 1001.9 mbar
RPM: 339 /min
17071 - ECM Power Relay Control Circuit
P0687 - 000 - Short to Plus - Intermittent
Reset counter: 0
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:52
Bin. Bits: 00000000
Lambda: 0.0 %
Temperature: 51.0°C
Absolute Pres.: 1009.8 mbar
Readiness: 0110 0101
Revision: --------
VCID: FBFFB2B77E1CBD9E5F-80AE
Reset counter: 139
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:05
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x3012
Hex Value: 0x1384
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
18265 - Load Signal
Reset counter: 139
Mileage: 97700 km
Date: 2012.04.01
Time: 09:13:05
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x301A
Hex Value: 0x1384
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Revision: S0000000
VCID: E1C3E0DFF8B0774E65-80B4
VCID: FAF1B7B37526849644-80AE
Coding: 030000
Coding: 020000
Coding: 003044
VCID: FF0746A76604A1BE73-80AA
Coding: 410A00
VCID: AF6756E7F6E4913EA3-80FA
Coding: 422100
VCID: F0E5959B235ACEC6FA-80A4
Coding: 10121
Shop #: WSC 06402
VCID: EDDB8CEFA068232ED1-80B8
VCID: F0E5959BE35ACEC6FA-80A4
Coding: 0501040002
VCID: A34FAAD7A22C255E37-80F6
End-------------------------(Elapsed Time: 02:01)--------------------------
