ABS Module Coding (MK60EC1 NAR)
Nomad
C?ID=320944
ABS Module Coding Request (MK60EC1 NAR)
First, I'd like to start by saying this is my first post. If I have done something wrong, I apologize and hope someone will point it out so I know for the future.
To make a long story short, I purchased a used 2011 Jetta SEL and a few weeks later, noticed the ABS and BRAKE warning lights flashing. Turns out, someone opened the gauge cluster and covered up the lights. I recently got VCDS and the cable, and have discovered the ABS module on the car is not programmed. The long code is all 0's. I'm really hoping someone can help me out. The ABS module's p/n is 1KO 907 379 BC but I don't know if this is the original module on the car, or if it was replaced and never coded.
The applicable codes from the tag by the spare tire are 1ZP 2UA 7K6 I THINK. I can post any others needed, but there are over 40.
The VIN is 3VWDX7AJ1BM006318
Engine code is CBT automatic transmission code is MAN -Not sure if necessary, just want to be thorough.
I hope someone can help and sorry if I've created this post incorrectly!
Friday,03,November,2017,13:24:19:15250
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4407.4
VIN: 3VWDX7AJ1BM006318   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDX7AJ1BM006318   Mileage: 211010km-131115miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 A    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9214
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 25016 444 13939
   VCID: 2C01FA78BA088E47D72-8078
005784 - Please Check DTC Memory of Steering Wheel Electronics
               P1698 - 000 -  - Intermittent
                    Mileage: 209928 km
                    Date: 2012.03.03
                    Time: 19:37:54
                    RPM: 1286 /min
                    Load: 40.8 %
                    Speed: 11.0 km/h
                    Temperature: 54.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1010.0 mbar
                    Fault Frequency: 85
                    Mileage: 209971 km
                    Date: 2012.03.05
                    Time: 13:36:12
                    RPM: 1356 /min
                    Load: 32.5 %
                    Speed: 13.0 km/h
                    Temperature: 48.0°C
                    Temperature: 31.0°C
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low - Intermittent
                    Mileage: 210631 km
                    Date: 2012.03.23
                    Time: 10:46:33
                    RPM: 683 /min
                    Load: 23.9 %
                    Temperature: 92.0°C
                    Temperature: 30.0°C
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           1741
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 00597EC86600BA275BA-8054
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   VCID: 74B122182EB896874F2-8020
                    Reset counter: 196
                    Date: 2012.03.26
                    Time: 13:22:20
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44032
                    Fault Status: 01100101
                    Reset counter: 196
                    Mileage: 211011 km
                    Date: 2012.03.26
                    Time: 13:21:54
                    Count: 3
                    Count: 12
                    Count: 28672
                    Count: 295
                    Count: 44032
   Part No SW: 5C0 820 047 L    HW: 5C0 820 047 L
   Component: J301  Klimaanlage   0102
   Revision: 2000908S    Serial number: 00000000034037
   VCID: 290F036CB5FA9B6F2C4-807C
03934 - Control Circuit for Seat Heating; Rear
                    Fault Status: 00111011
                    Reset counter: 225
                    Mileage: 210624 km
                    Date: 2012.03.22
                    Time: 21:07:01
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311231100025
   Coding: 73994BBE08A10B0008382000200884C400C2502E60000000300000000000
   Shop #: WSC 25807 444 59326
   VCID: 2D07F77C8D12874FC0C-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3462
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3462
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH000061ZC
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Serial number: 0017246
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3462
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3462
   Coding: 800000
00975 - Heated Rear Window (Z1)
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 196
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   012 0805
   Serial number: 003END07B4B0
   Coding: 00003232
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBB2D74471EB55FB20-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1000000FKL0O
   Coding: 303143
   Serial number: 3572MSME4A713552ZZZU
   Serial number: 3582MSME13486553ZZZT
   Component: S.Sens.Fahr.H  H01 ----
   Serial number: 3516KSME44526208ZZZK
   Component: S.Sens.Beif.H  H01 ----
   Serial number: 3526KSME34606208ZZZJ
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME111A0708ZZZM
   Component: F.Sens.Beif  H01 ----
   Serial number: 3566LSME6D0B0408ZZZ.
   Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
   Component: KOMBI         H07 0406
   Coding: 470001
   Shop #: WSC 00066 123 00148
   VCID: 2B03F964B386897FDE8-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70B92E085AA0AAA7ABA-8024
02078 - Media Player Position 3 (R120)
                    Reset counter: 99
                    Mileage: 180854 km
                    Date: 2011.01.31
                    Time: 00:26:20
   Component: IMMO          H07 0406
   VCID: 6A8D3C607CFC5077E5E-803E
Address 2E: Media Player 3
   Part No SW: 5ND 035 190 A    HW: 5ND 035 190 A
   Component: RCD510USBRVC  001 0003
   Revision: -----001    Serial number: VWZ4Z3M8135616
   Coding: 05000424040006
   Shop #: WSC 00081 790 00128
   VCID: 3A2DCC204C5C20F755E-806E
                    Fault Status: 00101011
                    Reset counter: 220
                    Mileage: 207446 km
                    Date: 2012.01.29
                    Time: 07:00:33
                    Reset counter: 196
                    Mileage: 211011 km
                    Date: 2012.03.26
                    Time: 12:13:08
                    Reset counter: 196
                    Mileage: 211011 km
                    Date: 2012.03.26
                    Time: 12:13:08
00856 - Radio Antenna
                    Reset counter: 196
03272 - Control Module for Audio Interface
                    Reset counter: 99
                    Mileage: 181499 km
                    Date: 2011.02.10
                    Time: 18:23:56
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668295109
   Coding: 0A00000000010100
   Shop #: WSC 01383 790 50316
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 323DE40094ACD8B79DE-8066
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/13.9V)-----------
Revision: 00H30001
Coding: 0000000009220000000E00E590210000000000 LHD stripped VIN
Coding:
OP find scans of the net that have similar attributes and post them here.
Nomad
C?ID=320944
Thanks Jack. Found some donor coding last night from two different VINs that were different by 2 or 3 digits. Donor codes are as follows:
B14B400C492708FB8D1102E7921C1061A70000
B1004400490008008D00220092001061A70000
B14B440C492308FB8D1422EA92191061A70000
How do i find the size of my brakes? I have disc in the front and drums in the back.
Nomad
C?ID=320944
Thanks! I'll give them a try right now and report back. I wish I could wrap my head around how to calculate these codes.
Nomad
C?ID=320944
OHMYGOD! IT WORKED!! The module accepted the first code you suggested! Thank you so much! Is there anything i need to do from here to insure everything functions properly? I know i have to do the steering angle setup now, right?
Nomad
C?ID=320944
Okay so maybe i spoke too soon... The TPMS light keeps coming on and going off, sometimes flashing. The airbag light is also coming on and off, both accompanied by a "ding". Ill post an autoscan.
Nomad
C?ID=320944
Saturday,04,November,2017,11:36:24:15250
VIN: 3VWDX7AJ1BM006318   Mileage: 211040km-131134miles
   Coding: 0000075
               P1698 - 000 -
                    Mileage: 209928 km
                    Date: 2012.03.04
                    Time: 19:37:54
                    RPM: 1286 /min
                    Load: 40.8 %
                    Speed: 11.0 km/h
                    Temperature: 54.0°C
                    Temperature: 42.0°C
                    Fault Frequency: 88
                    Mileage: 209971 km
                    Date: 2012.03.06
                    Time: 13:36:12
                    RPM: 1356 /min
                    Load: 32.5 %
                    Speed: 13.0 km/h
                    Temperature: 48.0°C
                    Temperature: 31.0°C
                    Mileage: 210631 km
                    Date: 2012.03.24
                    Time: 10:46:33
                    RPM: 683 /min
                    Load: 23.9 %
                    Temperature: 92.0°C
                    Temperature: 30.0°C
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B440C492208008D0E22E592211061A70000
   Shop #: WSC 00066 123 12345
6 Faults Found:
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 199
                    Mileage: 211025 km
                    Date: 2012.03.27
                    Time: 08:48:22
                    Count: 3
                    Count: 12
                    Count: 28672
                    Count: 4161
                    Count: 45056
                    Reset counter: 196
                    Date: 2012.03.27
                    Time: 13:22:20
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44032
                    Reset counter: 198
                    Mileage: 211025 km
                    Date: 2012.03.27
                    Time: 07:25:09
                    Count: 3
                    Count: 12
                    Count: 28672
                    Count: 320
                    Count: 45056
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 198
                    Mileage: 211011 km
                    Date: 2012.03.27
                    Time: 14:13:52
                    Count: 16386
                    Count: 4
                    Count: 12800
                    Count: 292
                    Count: 50178
                    Count: 1536
                    Reset counter: 199
                    Mileage: 211040 km
                    Date: 2012.03.27
                    Time: 11:26:10
                    Count: 16391
                    Count: 4
                    Count: 12800
                    Count: 212
                    Count: 48897
                    Count: 254
                    Count: 1023
                    Count: 512
                    Reset counter: 196
                    Mileage: 211040 km
                    Date: 2012.03.27
                    Time: 11:26:10
                    Count: 16391
                    Count: 4
                    Count: 12800
                    Count: 295
                    Count: 48897
                    Count: 254
                    Count: 1023
                    Count: 512
                    Reset counter: 225
                    Mileage: 210624 km
                    Date: 2012.03.23
                    Time: 21:07:01
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 199
   Coding: 00003232
   Coding: 303143
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 199
                    Mileage: 211040 km
                    Date: 2017.11.04
                    Time: 11:27:04
   Coding: 170001
   Coding: 102200
                    Reset counter: 99
                    Mileage: 180854 km
                    Date: 2011.02.01
                    Time: 00:26:20
                    Reset counter: 220
                    Mileage: 207446 km
                    Date: 2012.01.30
                    Time: 07:00:33
                    Reset counter: 196
                    Mileage: 211011 km
                    Date: 2012.03.27
                    Time: 12:13:08
                    Reset counter: 196
                    Mileage: 211011 km
                    Date: 2012.03.27
                    Time: 12:13:08
                    Reset counter: 198
                    Reset counter: 99
                    Mileage: 181499 km
                    Date: 2011.02.11
                    Time: 18:23:56
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 13.7V/13.7V)-----------
iichel
Netherlands, eastern part
C?ID=284912
It would be good to clear all DTCs and make a scan. This way we can see the ones that persist.
At first glance, the error in the airbag is not related to the ABS coding.
You'll need to do at least a basic setting of all the sensors (G85, lateral acceleration sender, maybe some more).
The wiki site is a bit messy but I'm sure its readable. http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
Let's try again after basic settings. Does the car have a TPMS reset button somewhere?
Nomad
C?ID=320944
Once my laptop gets its life together I’ll clear the codes and re scan. I have a feeling I caused the airbag code when I was trying to fix the seat heater... woops. Is there a way to clear that or will it go off when I erase the DTCs?
There is a TP reset button in the glovebox. I tried resetting it a couple times but the light wouldn’t go out. The ABS light is on also but it’s been covered up inside the cluster so it’s hard to say for sure what other lights may be on.
iichel
C?ID=284912
Just clear then and see if they return. If you connected all together in the proper way, the airbag light will return.
I'd recommend to go through all the basic settings, then have a look at byte 16 bit 2, byte 17 bit 2 and byte 19 bit 1 and play around a bit to kill the light.
Of course you'll need to reset the TPMS too by driving a bit and 'learn' the system the proper tire circumferences.
Nomad
C?ID=320944
Sounds good. Once my laptop finishes force updating I’ll go mess with it. The bits you’re referring to, do you mean in the airbag module or the abs module?
iichel
C?ID=284912
In the ABS module. The airbag module should be OK after you clear the DTC.
Nomad
C?ID=320944
Firstly, thanks for taking the time to help me out. Okay so here's where I'm at.
I completed all basic settings listed on the Ross-Tech Wiki. The only one I couldn't complete was the basic setting for hydraulic unit disconnecting valves.
The airbag light continues to turn on, no matter how or how many times i reset it. It also comes back on if I run an autoscan. I tried to reset the parameters for the occupancy sensor, but it says error. This issue didn't arise until I put the coding in, it has to be related or the weirdest coincidence ever.
The TPMS light is still on but get this- every time I access the ABS module it turns off. When i exit the module, 'Ding!", it comes back on. I tried driving it around to let it relearn itself, but no luck. I drove about 5 miles.
The ABS light is no longer flashing, but on solid. I think the BRAKE warning light has turned off, but it's hard to tell in the daytime.
Ironically, the car seems to drive much better than before I put the "incorrect" coding into the module. The brakes are more sensitive, the steering seems tighter without a dead spot in the center, and even the engine and transmission seem to be dancing instead of fighting. No more "2nd-gear-feeling" slow starts or annoying downshifting coming out of a tight turn.
I'm not quite sure what to make of my current situation. My car seems to have greatly improved, but my number of warning lights have doubled lol. I played around with the last few bytes on the abs module and was able to get it to accept one change- "ABS monitoring via instrument cluster".
Here is the auto-scan from AFTER all DTCs were cleared.
Saturday,04,November,2017,14:24:33:15250
Mileage: 211040km-131134mi   Repair Order:
   Coding: 0000075
                    Mileage: 209928 km
                    Date: 2012.03.04
                    Time: 19:37:54
                    RPM: 1286 /min
                    Load: 40.8 %
                    Speed: 11.0 km/h
                    Temperature: 54.0°C
                    Temperature: 42.0°C
                    Fault Frequency: 89
                    Mileage: 209971 km
                    Date: 2012.03.06
                    Time: 13:36:12
                    RPM: 1356 /min
                    Load: 32.5 %
                    Speed: 13.0 km/h
                    Temperature: 48.0°C
                    Temperature: 31.0°C
                    Mileage: 210631 km
                    Date: 2012.03.24
                    Time: 10:46:33
                    RPM: 683 /min
                    Load: 23.9 %
                    Temperature: 92.0°C
                    Temperature: 30.0°C
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B440C492208008D0E22E592211061A70400
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:48
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 320
                    Count: 45568
                    Count: 65024
00003 - Control Module
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:48
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 143
                    Count: 45568
                    Count: 65024
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:48
                    Count: 2
                    Count: 12
                    Count: 28672
                    Count: 16390
                    Count: 45568
                    Count: 65024
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:51
   Coding: 00003232
   Coding: 303143
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2017.11.04
                    Time: 14:23:46
   Coding: 170001
   Coding: 102200
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:53
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 13:51:47
                    Reset counter: 199
                    Mileage: 211049 km
                    Date: 2012.03.27
                    Time: 14:23:30
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 12.7V/12.7V)-----------
iichel
C?ID=284912
check connectors under the seat, maybe its disconnected.
could also bue due to other modules, i.e. the ABS: http://wiki.ross-tech.com/wiki/index.php/B10B3/037043
it looks like the abs is looking for an external TPMS module J502 but cannot find it (probably because it's not present).
i don't know how to fix it, but maybe nostrajackass or one of the scandinavians do. this is as far as my knowledge goes for MK60EC1
you can make the car a bit happier if you go to the CAN gateway, installation list and deselect 2E since it's not found.
Nomad
C?ID=320944
I checked and rechecked the connections but I haven’t checked passenger side. I’ll go look. I’ll play around with it some tonight and see what I come up with.
I’m hoping they can help! I appreciate you getting me this far though, like I said the car feels a lot better already. Thanks again.
iichel
C?ID=284912
no worries, i'm happy to help but i hope we can fix the last bits too. my guess is, if you manage to fix the abs coding you'll fix the airbag error too.
Nomad
C?ID=320944
We’ll see! I get chronic migraines so I’m bed ridden until my medication kicks in but as soon as I can, I’m going to get back on it. I’m hoping once I complete that self function test I’ll be able to get rid of it.
iichel
C?ID=284912
As far as I'm concerned, there is no need to rush it. Take your time, it's just a car. Your health is more important.
Nomad
C?ID=320944
You're right, health is number 1! Car is number 2 :) Okay so I was able to play around and get the TPMS light to stay off, but I'm pretty sure I just turned off the TPM system, which is fine for now.
The airbag light will not go out, no matter what I try. I think what's standing in my way is the steering angle sensor. It says "defective" and when i try to do the basic settings, the angle is stuck at 68.99 degrees when the wheel is straight. The number wont change at all, I've followed all the directions on the Wiki. Could the steering angle sensor be the problem? I think in order to get the airbag light off, I have to do the system function test for the ABS module, and in order to do that I have to do the basic setting for the steering angle sensor.
Here's a fresh autoscan, after clearing all DTCs. I should say that earlier I had a code for the steering angle sensor but it just said "implausible signal" or similar. After doing the steering angle basic settings is when it changed to "Defective".
Update: I got the airbag light to go off but only by turning it off manually. I don’t think this is a safe or long term solution, but it’ll do for now. Only light left on now is ABS and possibly traction control light.
Saturday,04,November,2017,18:48:39:15250
Scan: 01 02 03 08 09 15 17 19 25 56 77
VIN: 3VWDX7AJ1BM006318   Mileage: 211060km-131146miles
   Coding: 0000075
               P1698 - 000 -
                    Fault Frequency: 13
                    Mileage: 211065 km
                    Date: 2012.03.27
                    Time: 18:23:18
                    Temperature: 93.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 1000.0 mbar
Readiness: 0010 0101
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2012.03.27
                    Time: 18:48:06
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 48384
                    Count: 65280
                    Count: 255
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2012.03.27
                    Time: 18:48:06
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 320
                    Count: 48384
                    Count: 65280
                    Count: 255
            014 - Defective
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2012.03.27
                    Time: 18:48:06
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 292
                    Count: 48384
                    Count: 65280
                    Count: 255
   Coding: 73994BBE08A10B0008382000200A84C400C2502E60000000300000000000
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2012.03.27
                    Time: 18:48:08
   Coding: 00003232
   Coding: 303143
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2017.11.04
                    Time: 18:48:22
   Coding: 170000
   Coding: 102000
                    Reset counter: 200
                    Mileage: 211067 km
                    Date: 2012.03.27
                    Time: 18:48:04
   ROD: UHVNA.rod
End----------(Elapsed Time: 01:18, VBatt start/end: 13.5V/13.6V)-----------
