Results 1 to 6 of 6
Thread: 2010 Audi A6 3.2L - can't run any basic settings test, readiness,etc
    Jan 2015
    Hi I am trying to diagnose a P0491 air pump flow code, but can't activate, tried to look at 013 measuring block for injectors, it says Label File: NONE.
    Readiness says no script, etc and it's grayed out
    077 I click ON, and switches to ON but does nothing
    After clearing code I got a new code of p219E - cyl 3 mixture unbalanced
    Please post an Auto-Scan so people can see exactly what this car is made of.
    Jan 2015
    Friday,03,November,2017,14:12:53:46142
    VCDS Version: 17.8.0.1 (x64)
    VIN:   License Plate: A666
    Mileage: 144830km-89993mi   Repair Order:
    Chassis Type: FB-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4C 4F 52 53 55 56
              5F 62 72
    VIN:   Mileage: 144830km-89993miles
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CAL)       Labels: None
       Part No SW: 4F7 910 559     HW: 4F7 907 559
       Component: 3.2l V6 FSI         0040
       Revision: --H06---    Serial number:
       Coding: 0105000A02070120
       Shop #: WSC 49114 000 1048576
       VCID: 6ED84A8279233B3668-803A
    008606 - Fuel/Air Mixture Cylinder 3
                   P219E - 000 - Unbalanced
                        Fault Status: 00010001
                        Reset counter: 40
                        Mileage: 144838 km
                        Date: 2017.11.04
                        Time: 01:49:14
                        RPM: 640 /min
                        Mass Air / Rev.: 114.5 mg/str
                        Temperature: 84.0C
                        Bin. Bits: 00000010
                        Load: 18.4 %
    Readiness: 1110 1101
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F5 910 157 J    HW: 01J 927 156 JG
       Component: V30 01J 3.2l 4V USA 0020
       Revision: --H05---    Serial number: 00000000000569
       Shop #: WSC 02145 785 00200
       VCID: 306494FAA3976DC63A-8064
       Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
       Component: ESP8 front      H03 0060
       Coding: 0020826
       VCID: 6DDA4D8E7425C02E51-8038
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Serial number: 10602601371499
       Coding: 0000003
       VCID: 254A75AEEC55386ED9-8070
       Subsystem 1 - Part No: 4F0 910 132 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AK
       Component: KLIMABETAETIGUNGH30 0080
       Revision: 00000074    Serial number: 00000000652697
       Coding: 0524326
       VCID: 1D3A5D4EC405F0AE81-8048
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H22 0320
       Coding: 0019123
       Shop #: WSC 02335 785 00200
       VCID: 346C98EA578F51E65E-8060
       Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H10 0040
       Coding: 00056595
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
       Component: CDC-MP3-Pana  H49 0050
       Revision: 00000015
       VCID: 214261BE387DD44EA5-8074
    Address 15: Airbags (J234)       Labels:| 4F0-910-655-10.clb
       Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
       Component: Airbag AU1042 H06 0140
       Revision: --------    Serial number: 003FA0010Y6Q
       Coding: 303142373034303030314A55304C34463053
       Shop #: WSC 02323 785 00200
       ROD: EV_Airba10AURB4.rod
       VCID: 3668A2E289F343F660-8062
       Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
       Component: BF-Gewichtss.  H03 0060
       Serial number: 5810000R0000003Z8K
       Serial number: 3574SRB40000915849B7
       Serial number: 3584SRB40000915501AZ
       Serial number: 3516HRB401P9ICPITJBQ
       Serial number: 3526HRB402N9DVI10RE+
       Serial number: 3554NRB40000503786E$
       Serial number: 3564NRB400004EF1B403
    12583424 - Powertrain Databus
                 U0002 00 [008] - No Communications
                        Fault Frequency: 23
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90025091950316
       Coding: 0002041
       VCID: 27567FA696592A7EEB-8072
    Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
       Component: KOMBIINSTR.   H08 0138
       Revision: 00000000    Serial number: BH341CJ79
       Coding: 8BD60A050300CF05020201
       Shop #: WSC 02391 823 56573
       VCID: 316291FE689D64CE35-8064
       Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0031
       Revision: LB000027    Serial number: 2700L09707807A
       Coding: 000303
       VCID: 3972A9DEB0EDAC8E8D-806C
       Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140651083
       Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
       Component: MEM-FS        H08 0062
       Revision: AA000000    Serial number: 00001001330161
       Coding: 00581300004011110000
       Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Revision:             Serial number: 0000101581381
       Coding: 011F07204E40410001
       VCID: 4688D222F113D376F0-8012
       Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Component: Komfortgeraet   H29 0250
       Revision: 02500029    Serial number: 01198421760000
       Coding: 4618269
       VCID: 356AA5EE5CF548EE69-8060
       Part No SW: 4F0 910 274 A    HW: 4F0 907 274
       Component: J793  RKA+      H02 0100
       Revision: 00000506    Serial number: 00005060060895
       Coding: 0000581
       VCID: 22406EB2FD7BCF56BC-8076
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 210
                        Mileage: 144794 km
                        Date: 2017.11.03
                        Time: 20:22:39
                        Hex Value: 0x0001
                        Hex Value: 0x0000
                        Hex Value: 0x0007
                        Voltage: 14.10 V
                        Temperature: 15.0C
                        (no units): 16.0
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H13 0100
       Revision:             Serial number: 00000000437485
       Coding: 0002014
       VCID: 5EB81A428983ABB6D8-800A
       Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Revision:             Serial number: 0000101556956
       VCID: 458AD52ECC15D86EF9-8010
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0005032
       VCID: 214261BEF87DD44EA5-8074
       Part No: 8P0 907 357 H
       Coding: 0000003
       Shop #: WSC 02325 785 00200
       VCID: 3F86C7C66EC982BEB3-806A
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335G-097522369
       Coding: 020000020100000000
       VCID: 1D3A5D4E0405F0AE81-8048
       Part No SW: 4E0 035 664     HW: 4E0 035 664
       Component: H-BN-NA       H41 0042
       Revision: --------    Serial number: 488G/097509530
       Coding: 010200000002E1EC41000304EF6300030000
       VCID: 61C221BE78FD944EE5-8034
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356GN091041408
       Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
       Component: Bedienteil MM  H01 0060
       Serial number: 00000001367310
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
       Revision:             Serial number: 0000101543727
       Coding: 010E07204040220001
       VCID: 438ECB36C221E65ED7-8016
       Revision:             Serial number: 0000101543730
    End-------------------------(Elapsed Time: 03:11)--------------------------
    Readiness setting on that ECU should be possible with Basic Settings group 200. Once Basic Settings are running, press and hold brake, then press and hold accelerator. You should see one of the fields count down. "Tests Remaining" or something like that.
    However, I suspect you're going to have to address whatever is causing that Mixture code for Cylinder 3 first.
    Jan 2015
    Where is the injector balance measuring block?
    I wanted to look at that to make a judgement about the injectors. I suspect this car has a carbon problem in the valves.
    But quite possibly also ports near the cylinder heads may be caked up.
    Is there a way to run the SAI test individually?
    Quote Originally Posted by theBigK View Post
    I'm not convinced it has that. I don't have anything truly specific to this one, but I looked at everything documented about the earlier version of the 3.2 FSI used in the A6 starting in 2005 and don't see any such measuring blocks.
    I'm not sure if these ECMs ever got Selective output tests. Have you tried running the standard Sequential ones?
