Autoscan inside: 2017 e-Golf SEL Premium with digital cluster
leftlanecars
C?ID=63208
Here you go, brand new car, already has faults in the battery! YAY!
Thursday,02,November,2017,15:30:06:32430
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4401.4
VIN: WVWPR7AU4HWxxxxxx   License Plate: MY E-GOLF
Mileage: 325km-201mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 29 2B 39 3C 42 44 4B 51
          52 5F 75 8C A5 BD C0 C5 C6 D6 D7
VIN: WVWPR7AU4HWxxxxxx   Mileage: 325km-201miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAZA)       Labels: None
   Part No SW: 0EA 906 016 F    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 4238
   Revision: WMH24---
   Coding: 000D0016006400003000
   ASAM Dataset: EV_VCU00XXX0110EA906016F 004005
   ROD: EV_VCU00XXX0110EA906016F_004.rod
   VCID: 3228F11D6551CFD64C-8066
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 62057000000242
   Coding: 01FA40A12C25216F857E020981CC2980023484A14081943238915058C2E203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 7CB41F25F795C9A6D6-8028
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0451566071
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3C34DF25B71509A696-8068
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001050500021211102B
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 085C73F5B34D9506C2-805C
          B10CD 00 [008] -  -
                    Fault Frequency: 20
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2017.08.30
                    Time: 08:33:02
                    Dynamic environmental data: 02 86
                    Voltage terminal 30: 13.8 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001722800802
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06407DCDB9598376B0-8052
   Component: WWS    170721  043 0551
   Serial number:         170808043639
   Component: RLHS  047 0105
   Serial number: S9Y17M08D23H13M27S03
   Coding: 00A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617199
   Coding: 2271167811
   ASAM Dataset: EV_EPHVA2CAU3700000 009038
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 52E8919D0591EFD66C-8006
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Component: ACC BOSCH MQB H10 0620
   Coding: 7D0000C159FFC728949C810580401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002005
   ROD: EV_ACCBOSCHVW416.rod
0836 - Databus
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2017.09.21
                    Time: 16:24:16
                    Dynamic environmental data: 02 8D
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 13.4 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
0110 - Transport Mode Active
          U1105 00 [008] - -
                    Reset counter: 40
                    Mileage: 3 km
                    Date: 2017.08.30
                    Time: 08:54:59
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 14.6 V
                    Status_ACC_System: ACC_Init
   Serial number: 003GCR08U3T%
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 47DEB0C9FED35A7E0B-8012
   Occupant Detection:
   Serial number: IBH000000000006SSW5G
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 002 108 17
   Serial number: 357000000001753C962H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 908 17
   Serial number: 358000000008C5C0C62U
   Subsystem 4 - Part No SW: -----------    HW: 480 400 808 17
   Serial number: 3510001BB25EAC162503
   Subsystem 5 - Part No SW: -----------    HW: 480 400 708 17
   Serial number: 3520001B525EAC16D42A
   Subsystem 6 - Part No SW: -----------    HW: 480 401 008 17
   Serial number: 3550001C326C37F5F6DR
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 008 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C926453439691
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 15081708490172
   Coding: 0C10
   VCID: 095A76F1A847EC0EDD-805C
   Part No SW: 5G1 920 895 A    HW: 5G1 920 895 A
   Component: KOMBI         407 3194
   Coding: 0BB4701A6F88CF050288690B5701032080000000
   VCID: 2F2EF8697663E23E23-807A
   Part No SW: 3Q0 907 530 H    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6305
   Serial number: 29071710522498
   Coding: 0201001704F81000FB001212081D00000001070100070000000300000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3424F7059F45C1E65E-8060
   Subsystem 1 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 39170001848430127264
   Coding: 34FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 1096554804
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460010730
   Coding: 06720100321A00010002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861110817102205
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
                    Reset counter: 45
                    Mileage: 14 km
                    Date: 2017.09.25
                    Time: 13:59:51
   Revision: 00000000    Serial number: 17000206365008
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB_004_VW37.rod
Address 39: Right Light (J1023)       Labels: None
                    Reset counter: 46
                    Mileage: 14 km
                    Date: 2017.09.25
                    Time: 13:59:51
Address 3C: Lane Change (J1086)       Labels:* None
   Component: HRE_Master    H12 0080
   Serial number: 0449831845
   Coding: 02011103
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3D32D221AC0F00AEA1-8068
   Lane Change Assistant 2:
   Serial number: 230617EFM3579A
   Coding: 003E13208000040000000000
   VCID: 43C6A4D9CAEB765ED7-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000015835823
   Coding: 111000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: D302
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45C2BAC1C4DF486EF9-8010
   Serial number: 09081710521957
   Coding: 000000050100054A00310F01040000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_VW37.rod
   VCID: 72A8311DA5D18FD68C-8026
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5QE 907 080 H    HW: 5QE 907 080 H
   Component: LE Gen 3.3H12 2044
   Revision: 00H12000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080H 001007
   ROD: EV_DMCM10030115QE907080H.rod
   VCID: 4BD68CF9E2BBBE1E2F-801E
   Serial number: 210717EGL02073
   VCID: 42C8A1DDD5F17F56DC-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000015857261
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0842
   Coding: 02738002FF00000051220001001808009F0505F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3326F4199A4BC6DE47-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT2053141
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Component: OCULowMQBUS   009 0570
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB_VW37.rod
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5GE 915 225 A    HW: 5GE 915 225 A
   Component: K8C           005 0350
   Serial number: 17071707010290
   ASAM Dataset: EV_BECM08820215GE915225A 001003
   ROD: EV_BECM08820215GE915225A.rod
   VCID: 3A38D93DBD21379684-806E
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5GE 915 316 A    HW: 5GE 915 316 A
   Component: A2 HVSMBJBECU  011 0300
   Serial number: 00000019071705010366
   Cell Module Controller 1:
   Subsystem 2 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J991Battmod1  H08 0322
   Serial number: 17620Y18AH0803225243
   Cell Module Controller 2:
   Subsystem 3 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J992Battmod2  H08 0322
   Serial number: 17624Y18AH0803226714
   Cell Module Controller 3:
   Subsystem 4 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J993Battmod3  H08 0322
   Serial number: 17624Y18AH0803226375
   Cell Module Controller 4:
   Subsystem 5 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J994Battmod4  H08 0322
   Serial number: 17622Y18AH0803226624
   Cell Module Controller 5:
   Subsystem 6 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J995Battmod5  H08 0322
   Serial number: 17624Y18AH0803226715
   Cell Module Controller 6:
   Subsystem 7 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J996Battmod6  H08 0322
   Serial number: 17608Y18AH0803228809
   Cell Module Controller 7:
   Subsystem 8 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J997Battmod7  H08 0322
   Serial number: 17723Y18AH0803225242
   Cell Module Controller 8:
   Subsystem 9 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J998Battmod8  H08 0322
   Serial number: 17623Y18AH0803225184
32724 - Unknown Error Code
          P10F7 00 [040] - -
                    Mileage: 95 km
                    Date: 2017.10.29
                    Time: 07:28:24
                    Dynamic environmental data: 20 96
                    Current of H-V / hybrid battery: -509.250 A
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 14081711P23854
   Coding: 000307000000020100221354C150490084000E200120
   ROD: EV_MFKBoschMQBB_VW36.rod
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:* None
   Part No SW: 5QE 915 022 AJ    HW: 12E 915 022 H
   Component: LMSG          H20 1097
   Serial number: 01148072470160
   Coding: 4A4914040400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB_003.rod
Address C0: Act. for Ext. Noise (----)       Labels:* None
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H10 0223
   Serial number: EN172521420000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 5GE 907 458 C    HW: 5GE 907 458
   Component: TME-Min       H06 0203
   Serial number: 0047222
   Coding: 02
   ASAM Dataset: EV_ThermContrVISAU49X 001021
   ROD: EV_ThermContrVISAU49X_VW37.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0009
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR172303003810000048
   Subsystem 3 - Part No SW: 5QE 816 803 A    HW: 5QE 816 803 A
   Component: J842 eKK  H03 0009
   Refrigerant Pressure And Temperature Sender 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0009
   Refrigerant Pressure And Temperature Sender 3:
   Subsystem 5 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G827 pT-Sens3  H11 0009
   Refrigerant Pressure And Temperature Sender 4:
   Subsystem 6 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G828 pT-Sens4  H11 0009
   Refrigerant Pressure And Temperature Sender 5:
   Subsystem 7 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G829 pT-Sens5  H11 0009
   Refrigerant Expansion Valve 1:
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000120202483
   Refrigerant Expansion Valve 2:
   Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000120202489
   Refrigerant Expansion Valve 3:
   Subsystem 10 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000120202495
   Refrigerant Shut Off Valve 1:
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H12 0102
   Serial number: 00000000000140202201
   Refrigerant Shut Off Valve 4:
   Subsystem 12 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000140202213
   Refrigerant Shut Off Valve 5:
   Subsystem 13 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000140209450
37096 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 73 km
                    Date: 2017.10.28
                    Time: 11:07:43
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H52 1560
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
   VCID: 393AC631B8273C8E8D-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:11, VBatt start/end: 13.2V/13.2V)-----------
FWIW: P10F7 is: "Voltage Sense Circuit 8 for HV Battery Pack: Short to Plus".
If it were my car, that one would bother me.
The one in C5: Therm. mgt. not so much because it's flagged "Intermittent - Not Confirmed" and hasn't been reported to the Gateway, which claims: "C5-Therm. mgt. -- Status: OK 0000"
The rest strike me as nothing more than a sloppy Pre-Delivery Inspection; relatively inconsequential, but they should have been cleared before the car was delivered.
DV52
C?ID=194404
^^^Leftlanecars: OOOOOhhh........... nice car!
If you ever get the urge to make adaptation channel maps of any of the modules in your new vehicle (particularly the BCM), I would welcome a copy - please
PS: It's reassuring (not) to know that dealers up there are as slack as those in the Antipodes when it comes to pre-delivery checks - I guess that Golf buyers world-wide just don't pay enough for their new cars to warrant the simple task of hooking-up the ODIS tool to the vehicle before it leaves the dealership!!
leftlanecars
C?ID=63208
Thanks for the code tags. For some reason, the new layout didn't let me do it.
As far as the fault code - yeah, this is my car, and now that I know what it means, I'll clear it, see if it comes back and then hopefully find a dealer that will talk to me about it. I doubt any dealer will do anything till the car's got a fault on the instrument cluster.
leftlanecars
C?ID=63208
I'll try and remember t0 do the map for you on 09!
If it were me, I would not clear it. Right now you've got Freeze Frame Data that show this code having occurred when the car only had 95km on it. If you clear it, you will lose that. Instead, I would look for the Fault Frequency to increase, which is what should happen if the fault is detected again. Alternatively, the code should clear itself after 35 drive cycles (however those are defined in the software in that module).
leftlanecars
C?ID=63208
good idea, I'll leave it alone. car drives fine, no issues, for now.
I'll be sending Ross Tech the adaptation channel maps next week for the undefined modules.
darkchina811
ITALY
C?ID=333184
could I ask you for an admap of module 10? thank you!
darkchina811
ITALY
C?ID=333184
no need for it anymore :P
