Audi q5 radio not working
URS4quattro
Suriname
C?ID=248222
Hi i have a audi q5 2.0 liter turbo from a client that has a multi media issue . the mmi display does noet come on and no multimedia functions work. i did a full auto scan and non of the media items can be reached . I also did a optical bus scan and it says everything is ok. Does anyone know whre the amp is located in this car? i sourced the amp on ebay on know what it looks like but don't know where it is located. is seems that the amp does not have an optical bus connection so that explains why i don't get an error for the amp. full auto scan is below:
Thursday,02,November,2017,11:03:32:27662
VCDS Version: 17.8.0.1 (x64)
VIN: WAUZZZ8R6AA100505   License Plate: AUDI Q5
Mileage: 44590km-27706mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 42 46 52 53 55 56 57
          5F 62 6C 6D 72
VIN: WAUZZZ8R6AA100505   Mileage: 44590km-27706miles
0E-Media Player 1 -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 R    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H16 0002
   Revision: E1H16---
   Coding: 0121000C240F0060
   Shop #: WSC 56219 000 1048576
   ASAM Dataset: EV_ECM20TFS0118R0907115R 001002
   ROD: EV_ECM20AVS.rod
   VCID: 4384C822CAF9D65ED7-8016
5390 - Left Engine Mount Solenoid Valve (N144)
          P1573 00 [047] - Open Circuit
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:00:00
                    Coolant temperature: 27 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.237 V
7900 - Right Engine Mount Solenoid Valve (N145)
          P1577 00 [047] - Open Circuit
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:00:00
Readiness: 0010 0001
   Part No SW: 8R0 927 156 AB    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H04 0006
   Revision: --H04---    Serial number: 0000000682
   Coding: 000001
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDL501.rod
   VCID: 7BF470C2F2896E9EDF-802E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 025548
   Shop #: WSC 06335 000 00000
   VCID: 4A9AE506E5D3071614-801E
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0328
   Coding: 051500
   VCID: 04060B3E87771166AE-8050
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 0210000047078016
00192 - Rear Left Door Handle Touch Sensor (G417)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 246
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 15:58:04
   Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D1000000    Serial number: 01070420101463
   Coding: 64156000
   VCID: 77FC6CF2C6A14AFEBB-8022
                    Reset counter: 32
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:05:43
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H29 0380
   Revision: 10029001    Serial number: 00000000510876
   Coding: 260010800030AF010001000300001D0D0F1D470802010141000000
   Shop #: WSC 04902 002 1048576
   VCID: 3C76B3DEBF07A9A696-8068
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 100309  H10 0041
   Serial number: 90243015100304211847
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10843370
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002603100620
Address 0E: Media Player 1
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941009905180
   Coding: 300105
   VCID: 489EDF0EFBDFF50602-801C
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 E    HW: 8R0 959 655 E
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GND0DAV1O
   Coding: 30453331313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4682D136F9CBE376F0-8012
   Serial number: 6334MSME526520362
   Serial number: 6344MSME51610006-
   Serial number: 6352QSME26561B36H
   Serial number: 6362QSME5F561926R
   Serial number: 63732SME635A2C1C7
   Serial number: 63832SME4F5A24120
   Revision: --------    Serial number: 90304JD60006H
   Coding: 000033
   VCID: 3D70BEDAA41DA0AEA1-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 B    HW: 8R0 920 930 B
   Component: KOMBIINSTR.   H11 0255
   Revision: 00300000    Serial number: CJI39X64A
   Coding: 2F0622000200000C010000
   VCID: 336498E2925966DE47-8066
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E1032480AE
   Coding: 00C303
   VCID: 030408228279165E97-8056
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650134495
02076 - Media Player Position 1 (R118)
                    Reset counter: 247
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:50:37
                    Bin. Bits:    11111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10000
01304 - Radio
                    Reset counter: 247
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:50:37
                    Bin. Bits:    11111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10000
00467 - TV Tuner (R78)
                    Reset counter: 247
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:50:37
                    Bin. Bits:    11111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10000
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 247
                    Mileage: 44592 km
                    Date: 2009.06.26
                    Time: 16:50:37
                    Bin. Bits:    11111
                    Voltage: 13.20 V
                    Count: 6
                    Bin. Bits:    10000
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010113004
   Coding: 00781B00000044440000
   VCID: 408EC72ED3EFCD46CA-8014
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010441221
   Coding: 011D12205E01440004
   VCID: 4580D63ACCCDE86EF9-8010
   Revision: 00002001    Serial number: 0128735029
   Coding: 01000E22203934810530053280000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000010448042
   VCID: 4486CB3EC7F7D166EE-8010
   Revision: 00000003    Serial number: 10000000482501
   VCID: 34669BFE975761E65E-8060
   Part No: 8K0 907 357 B
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 34669BFE575761E65E-8060
Address 56: Radio
Address 57: TV Tuner
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000103384913
   Coding: 010C12204001240004
   VCID: 428ACD26DDE3DF56DC-8016
   Part No SW: 8R0 907 441 B    HW: 8R0 907 441 B
   Revision: --H04---    Serial number: 525PA8-J03C007
   Coding: 1022010
   VCID: 3560A6FA5C2D78EE69-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H50 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B74B0C2BA09AE9E9F-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H50 0330
   Serial number: 8R0827852B
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000103384924
End-------------------------(Elapsed Time: 03:23)--------------------------
Control Module Part Number: 8T0 907 468 AD
  Component and/or Version: GW-BEM 4CAN-M H09 0117
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
5F-Information Electr.(High/D3)	OK                  	OK
0E-Media Player 1   	OK                  	OK
56-Radio            	OK                  	OK
57-TV Tuner         	OK                  	OK
URS4quattro
Suriname
C?ID=248222
Is there anyone out there
Seriously? 17 minutes after you post?
Looks to me like everything on the MOST bus is off-line, but that doesn't make much sense since the Optical Bus Diagnosis shows everything OK.
The car does not appear to be configured for a separate amplifier?
URS4quattro
Suriname
C?ID=248222
Thanks for you reply Uwe, :rolleyes: didn't seem like only 17 minutes.
I do believe there is a seperate amp in the car, and hat is what i am trying to find. i have another q5 here on wich i disconnected and close looped the optical bus connectors for the media items on the left side of the trunk and the radio still works so i believe there is a seperate amp. I just can't find it
URS4quattro
Suriname
C?ID=248222
From the link below i found what the amp looks like but can't find its location
https://www.ebay.com/itm/Audi-Ampli...ash=item2eedc6d835:g:SWIAAOSwQgpW~Y6j&vxp=mtr
MuOelCx
