Good afternoon
I am changing the electronic unit of this vehicle, but at the moment that I put the coding that it had before it does not recognize it. the code was ..
143B600D492B00FF280C06E692200041B100
coding rejected
error 31 request out of range.
please help...
coding rejected
please help...
Wednesday,01,November,2017,11:39:47:49232
VCDS Version: 17.8.0.1
Dealer/Shop Name: CROSSWAGEN
Workshop Code: 098 13105 001435
VIN: WAUZZZ8P59A073081 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 77
VIN: WAUZZZ8P59A073081 Mileage: 79480km-49386miles
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 E HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH03--- Serial number: AUX7Z0HNFN60DK
Coding: 0103001024070060
Shop #: WSC 06314 000 00000
VCID: 3B7516777AA5F09E9F-806E
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 79486 km
Date: 2017.10.23
Time: 17:58:17
Temperature: 15.0°C
Temperature: 18.0°C
Absolute Pres.: 740.0 mbar
Voltage: 11.684 V
001378 - System Voltage
P0562 - 000 - Too Low - Intermittent
Mileage: 79486 km
Date: 2017.10.23
Time: 19:59:51
Temperature: 27.0°C
Temperature: 22.0°C
Voltage: 9.271 V
Readiness: 0110 0001
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 046 B HW: 0AM 927 769 D
Component: GSG DSG AG7 411 1013
Revision: 41014 Serial number: 00001103096403
Shop #: WSC 04940 001 00001
VCID: 2D51282FB4D16E2E11-8078
006225 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Reset counter: 9
Mileage: 79486 km
Date: 2017.10.23
Time: 18:04:13
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
VCID: 000FA19B93C353468A-8054
8 Faults Found:
Reset counter: 175
Mileage: 79486 km
Date: 2017.10.23
Time: 18:36:53
Count: 16391
Count: 15
Count: 12288
Count: 128
Count: 28672
03306 - Coding Not Valid
Reset counter: 176
Mileage: 79486 km
Date: 2017.10.23
Time: 20:18:43
Count: 3
Count: 14
Count: 12800
Count: 4161
Count: 47872
00003 - Control Module
Fault Status: 01100101
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 143
Count: 30720
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 279
Count: 30720
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 295
Count: 30720
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 270
Count: 30720
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 195
Count: 30720
Reset counter: 175
Mileage: 79486 km
Count: 3
Count: 3
Count: 12288
Count: 212
Count: 30720
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000658 Serial number: 8P0820043BG
VCID: 72EBFB536D6F71D68C-8026
00532 - Supply Voltage B+
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:26:08
Voltage: 7.90 V
01301 - Control Module for Voice Recognition (J507)
Reset counter: 175
Mileage: 79486 km
Date: 2017.10.23
Time: 20:02:28
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009086322
Coding: E18E1F8190141380EF00000A0000000000094E056406040364A000000000
Shop #: WSC 06314 000 08192
VCID: 489F79BB3B73AB0602-801C
Subsystem 1 - Part No: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 06314
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:37:00
Voltage: 8.80 V
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:26:00
Voltage: 7.70 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:27:00
Voltage: 9.60 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 215
Mileage: 79486 km
Voltage: 9.45 V
Reset counter: 176
Mileage: 79486 km
Voltage: 9.40 V
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303031314A55304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 49997CBFE879520E1D-801C
Serial number: 3572DRB4000082D4916T
Serial number: 3582DRB4000082D0A2AW
Serial number: 35128RB40000469B97F-
Serial number: 35228RB4000047200ACB
Serial number: 35547RB4000048D10FCX
Serial number: 35647RB4000048D1213D
13635840 - Supply voltage
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:26:23
13636864 - Control Module for ABS Brakes
U1015 00 [008] - No Communications
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:04:16
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014112
VCID: 4189649F18499A4EC5-8014
Component: E0221 H02 0030
Part No SW: 8P0 920 931 T HW: 8P0 920 931 T
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 224NH006025691
Coding: 0006341
Shop #: WSC 13105 098 01435
VCID: 44876D8B075B8F66EE-8010
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:26:27
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:37:08
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K08A280FBE
Coding: ED817F06100602002102
VCID: 377D0A47468DD4FE7B-8062
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:04:13
Reset counter: 175
Mileage: 79486 km
Date: 2017.10.23
Time: 19:46:24
Revision: D0H18006 Serial number: AUX7Z0HNFN60DK
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000148
VCID: 43856E970255885ED7-8016
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
VCID: 2A5B2333853F7916F4-807E
000 - - - MIL ON
Fault Status: 11100000
Mileage: 79486 km
Date: 2017.10.23
Time: 18:04:12
Battery Volts: 14.0 V
DU
Temperature: 20.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Reset counter: 225
Mileage: 79486 km
Date: 2017.10.23
Time: 18:04:12
Voltage: 14.00 V
DU
Temperature: 20.0°C
RPM: 765 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C8FC677
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674803033278
VCID: 3561004F5C8126EE69-8060
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 18:26:39
Temperature: 19.0°C
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000148
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Fault Frequency: 0
Reset counter: 40
Mileage: 79480 km
Date: 2017.10.23
Time: 18:04:13
Fault Status: 00101101
Fault Frequency: 0
Reset counter: 40
Mileage: 79480 km
Date: 2017.10.23
Time: 18:04:13
Address 56: Radio Labels: None
Part No SW: 8P0 035 195 N HW: 8P0 035 195 N
Component: R Symphony2+ H05 0270
Revision: 00H05000 Serial number: AUZ1Z4H7183857
Coding: 0730212
VCID: 3D71186F64B1FEAEA1-8068
Reset counter: 215
Mileage: 79486 km
Date: 2017.10.23
Time: 19:04:40
Reset counter: 175
Mileage: 79486 km
Date: 2017.10.23
Time: 20:02:34
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
01813 - Supply Voltage for Door Controller; Rear Left (J388)
00098 - Rear Left Central Locking (Safe) Motor (V163)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428B6B931D4F8156DC-8016
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 77: Telephone
End-------------------------(Elapsed Time: 02:20)--------------------------
