Results 1 to 2 of 2
Thread: Need clarity with wording on on instructions in Adaptation screen
    Jun 2016
    Trying to perform an adaptation for the Charge Pressure Control (Group 11) on my 2013 Golf TDI CJAA.
    The instructions are not clear.
    First line states:
    Prerequisites: Ignition ON/ Engine ON (running)
    Second line is the issue:
    Activate the Basic Setting then firmly press/hold both Brake Pedal and Pedal
    Is the second pedal mentioned the accelerator or clutch pedal? I assume accelerator. If so, I also assume I am to push it to the floor?
    Tried posting screen shots but it would not let me
    2004 Passat TDI 5 speed manual
    2001 AllRoad TDI 6MQ
    2002 Aud A4 Avant
    Do we have a scan of this car somewhere? If not, please post one so we can see exactly what ECU you have.
    Engine Basic Settings are often done with one foot on the brake and the other with the accelerator to the floor. If you've got an appropriate Basic Setting active, this tells the ECU that it's in charge of the RPM and it will then increase the engine speed to whatever it needs to do what that Basic Setting calls for. However, if the engine speed goes to redline, you're doing something wrong, so stop.
    As for posting screen shots, please see: How to Post Pictures.
