Results 1 to 7 of 7
Thread: MK60EC1 long code abs
    Oct 2017
    Canada
    Need help to get a long coding for an abs module on a 2013 jetta 2.0 gas. The instrument cluster was removed to install a starter kill. Don't know why they did that. Thanks in advance.
    Friday,27,October,2017,09:58:49:45632
    VCDS Version: 17.8.0.1  HEX-V2 CB: 0.4401.4
    VIN: 3VW1K7AJ4DM301658   License Plate:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 03 09 15 17 19 25 56
    VIN: 3VW1K7AJ4DM301658   Mileage: 78940km-49051miles
    Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
       Part No SW: 06G 906 055 T    HW: 06G 906 055 B
       Component: 2.0l /85 KW      01 1205
       Revision: T5H06---    Serial number:
       VCID: 3A2DCC402054BDD755E-806E
       Revision: 00H31001
       VCID: 7DA7075C7DFA4AEF30C-8028
                        Reset counter: 161
                        Date: 2017.10.04
                        Time: 00:12:16
                        Count: 20992
                        Count: 195
                        Count: 50432
       Part No SW: 5C0 937 086 E    HW: 5C0 937 086 A
       Component: BCM25 JLB M3  H67 0256
       Revision: B0067001    Serial number: 04351119130239
       Coding: 73994B1808AB0B4000302000240884900042502E60000000300000000000
       VCID: 2E05F010E01C6177F96-807A
       Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 3465
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 3465
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
       Component: J388__TSG_HL  004 3464
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
       Component: J389__TSG_HR  004 3464
       Coding: 800000
    00890 - Switch for Heated Rear Window (E230)
                        Reset counter: 240
                        Mileage: 78007 km
                        Date: 2017.10.12
                        Time: 05:19:16
    00538 - Reference Voltage
                        Fault Status: 00101011
                        Reset counter: 240
       Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
       Component: AirbagVW10G   013 0851
       Serial number: 003LKM04DPF.
       Coding: 00004A33
       Shop #: WSC 00066 000 00186
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 40D9BEA84A08E7071BA-8014
       Serial number: 6940000Y130000TR6T0J
       Coding: 303032
       Serial number: 3572MSME2F35267AZZZ0
       Serial number: 3582MSME0435267AZZZV
       Serial number: 3516KSME6E6D3623ZZZ%
       Serial number: 3526KSME60644423ZZZJ
       Serial number: 3556LSME0D306721ZZZQ
       Serial number: 3566LSME141C6721ZZZT
       Part No SW: 5C6 920 852     HW: 5C6 920 852
       Component: KOMBI         H06 0705
       Coding: 370600
       VCID: 6889460802F8FF47F3A-803C
       Part No SW: 6N0 909 901     HW: 5C0 937 086 A
       Component: GW-K-CAN TP20 H67 0256
       Revision: B0067001
       Coding: 102200
       VCID: 70B92E683AA83787ABA-8024
       Component: IMMO          H06 0705
       VCID: 6A8D3C001CF4CD57E5E-803E
       Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
       Component: LOW NAR       H02 0006
       Revision: -----06S    Serial number: VWZ4Z6N3562487
       Coding: 05000400010006
       VCID: 23131124BBDEDC1F668-8076
    End----(Elapsed Time: 00:51, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Aug 2016
    Switzerland
    VIN 3VW1K7AJ4DM301658
    Jetta AJ PQ25
    LHD
    NAR
    CBP petrol engine
    FWD
    Manual transmission
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 19 bytes of mystery
    B1 4B 20 0C 51 22 08 FB 8D 11 04 E9 8A 21 10 61 A7 10 00 iichel 1st guess
    B14B200C512208FB8D1104E98A211061A71000 try this one
  3. Likes Uwe liked this post
    Oct 2017
    Canada
    Thanks will try as soon as I get the customer back in.
    I believe this would be the factory condition coding for 3VW1K7AJ4DM301658:
    B14B200C492208FB8D1104E992211061211000
  6. Likes iichel, Uwe, Jack@European_Parts liked this post
    Nerd notes for Michel. I have 5-speed manual trans and 6-speed 09G examples from NAR market 2013 Jetta (16) cars with that CBPA engine code. I can't include the VINs but this may help your coding info:
    162 2013 CBPA AT/09G L0L 1K0 907 379 BL @ 0152 B1002000510008008D0004008A001061A71000 B12051088D048A1061A71000 G1A 0N9/0YC 1N1 2UA 1AS 1ZQ/1KD
    162 2013 CBPA MT/5 L0L 1K0 907 379 BL @ 0152 B1002000490008008D00040092001061211000 B12049088D04921061211000 G0C 0N9/0YC 1N1 2UA 1AT 1ZQ/1KD
  8. Likes DrPeter, Uwe, Jack@European_Parts liked this post
  9. #6
    Aug 2016
    Switzerland
    Thanks Dana, I'll add it to my database. I probably took a ROW model, my bad (even though the CBPA engine is unique to the NAR market).
  10. Likes Uwe, Dana, Jack@European_Parts liked this post
  11. #7
    Oct 2017
    Canada
    It's been a while but the customer finally came back in. This is the code that worked.
    Thanks everyone.
  12. Likes Jack@European_Parts liked this post
