Results 1 to 7 of 7
Thread: Problem with auto scan
    Jan 2017
    I bought a new cable and i am trying to auto scan. Vcds will not perform an auto scan. If i select my model in the drop down, it will scan but it only finds limited modules. Maybe 4. I have not been able to properly register the dongle and there is an aftermarket radio in the car.
    What model/year car is this? Auto-detect will only work on CAN based vehicles with a CAN gateway. Can you post the scan of the modules you are able to see?
    Jan 2017
    It is a 2005 mk4 jetta. I will post scans this evening when i get home and do it again
    An Mk.4 definitely doesn't support Auto-Detect.
    Jan 2017
    It seemed to not be able to communicate with all the modules. Should i unhook the aftermarket stereo interface. It uses the klines to support accessory power using the key.
    Please post what it does find before you start pulling your hair out.
    On a 2004, an aftermarket radio isn't high on my list of things to worry about because the K-line (single-wire diagnostic bus) didn't go to directly to the radio in that car.
  7. Likes Dana liked this post
    Jan 2017
    Ok. I will post later. Thank you.
