Did my first runs on our 2012 Octavia 2 1.8 FL with HEX-V2(3) and very impressed! My main reason for buying was the newly aquired Octy had Climatronic problems and the dealer wanted to pull the dash apart ($AUS>800) to find it? I had the 80g R134 replaced with 530g and no problem. He asked to put it back on VAS(?) and declared G262 was faulty and showed me it measured 24C at ambient of 10C. (+$AUS60+$AUS136/hr) So, I bought VCDS.
My 1ST RUN; @ 5km; Climatronic on; 90km/hr reached; @22C ambient showed:
The DTC dates were confusing? (Also getting used to formatting, hopefully.) I cleared the DTC generically the next day but the Group 01 was still there;
RUN 2: VEHICLE NOT RUN OVERNIGHT..
I double-clicked and cleared it and it went. Unsure why I had to do this?
Today I did some 100km at random speeds so readiness should be reducing but not yet checked.
I then checked the 'suspect' Climatronic thermistors/sensors:
And cancelled the G262 in a nice way. I still have to check the Climatronic flaps in case these had caused the problem the dealer 'diagnosed' was G262.
One 'ghost-in-the-machine' puzzled me.
The Columbus Infotainment radio messed-up? It wouldn't hold stations and the steering-wheel L/H buttons ceased to function? I rebooted the Columbus and all was well. Unsure if this was coincidental, I never went near that with VCDS.
I am very happy! When my daughter lets me have the Fabia 3 back I'll check it.
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: TMBGK61Z9C2074440 Mileage: 109770km-68207miles
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 3T0 907 115 G HW: 1Z0 907 115 F
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number:
Coding: 0203000C24070160
Shop #: WSC 73430 790 00064
VCID: 35342ED62947C49FB8C-8060
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Mileage: 109003 km
Date: 2012.01.13
Time: 17:22:33
RPM: 2398 /min
Load: 59.6 %
Speed: 90.0 km/h
Temperature: 94.0∞C
Temperature: 18.0∞C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 051 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2710
Revision: 00043014 Serial number: CU501109266904
VCID: 392C22E6055F20FF5C4-806C
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B401C092900FEC80F02E890190081310000
VCID: 7BA0F8EE43E3D2EF0E8-802E
Part No SW: 3T0 907 044 BK HW: 3T0 907 044 BK
Component: Climatronic H18 0506
Revision: 00001007
Coding: 0000000002
VCID: 7CA2FBF2466DD5D7072-8028
Part No SW: 1K0 937 087 Q HW: 1K0 937 087 Q
Component: BCM PQ35 H 110 0651
Revision: 00110 AC
Coding: 48000AB8E00508C04008008011000124417000AE526D89605C8540000040
VCID: 3FD84CFE177B0ECF620-806A
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 14091 26 0601
Coding: 00D7B7
Component: RLS 041011 05 54 0403
Coding: 0730ED
8 Faults Found:
Fault Status: 00101010
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:14
Voltage: 14.25 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:14
Voltage: 14.25 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:14
Voltage: 14.25 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:15
Voltage: 14.20 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:15
Voltage: 14.20 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:16
Voltage: 14.25 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:17
Voltage: 14.30 V
Term 50 Off
Fault Frequency: 9
Reset counter: 123
Mileage: 109413 km
Date: 2012.02.19
Time: 08:09:17
Voltage: 14.30 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 75461127203607
Coding: 10810E
Shop #: WSC 13765 790 00064
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_001.rod
VCID: 333010CE2BB3DAAF968-8066
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q7 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2T8MJ0
Coding: 0020791
VCID: 3D2436F611771CDF70C-8068
Subsystem 1 - Serial number: 6332MSME65742F4DR
Subsystem 2 - Serial number: 6342MSME65120D199
Subsystem 3 - Serial number: 6351HSME29303270-
Subsystem 4 - Serial number: 6361HSME293C104DC
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20111001201586
Coding: 188A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EA6F1FA5071C7C7296-802A
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 843 Q HW: 1Z0 920 843 Q
Component: KOMBI H05 0607
Coding: 110A00
Shop #: WSC 73430 031 00064
VCID: 46D6591A48215F07216-8012
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 270911F1003638
Coding: 352303
VCID: 35342ED62547C49FB8C-8060
Component: IMMO H05 0607
VCID: 6A8ECDAA3CF95B67E5E-803E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 B
Component: RNS-MID H55 3984
Revision: AB001001 Serial number: SKZ6Z7L9230151
Coding: 04000402000100810000
VCID: 2F381CBEC71BFE4FF20-807A
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2120
Coding: 0000758
VCID: 76B6E9DA74C18F87716-8022
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
00914 - Window Regulator Switch; Rear Left; Driver (E53)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 343213D2223DDD978F2-8060
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0000758
VCID: 48CA57224EB54977D3A-801C
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 323E15CAD829D3A79DE-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 333010CE2733DAAF968-8066
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660986920
Coding: 0201000000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2708F49EEF6BA60F3A0-8072
End----------(Elapsed Time: 01:16, VBatt start/end: 12.4V/12.3V)
Readiness: 1110 0101
CHECK CLIMATRONIC TEMPERATURE SENSORS:
Address 08: Auto HVAC (3T0 907 044 BK)
23:00:20
IDE00019 Voltage terminal 30 12.5 V
IDE00973-ENG100004 Outside air temperature-MUX Temperatur 16.5 ∞C
IDE00974-ENG100004 Outside air temperature internally calculated-MUX Temperatur 16.5 ∞C
IDE00976 Left front vent temperature 19.7 ∞C
IDE00977 Right front vent temperature 19.3 ∞C
IDE00979-ENG101755 Left footwell vent temperature-MUX Ausblastemperatur 18.7 ∞C
IDE00980 Right footwell vent temperature 18.0 ∞C
IDE00983 Interior temperature 19.2 ∞C
