Results 1 to 2 of 2
Thread: Missing ASAM data EV_Kombi
    Jul 2014
    Czech Republic
    I found some mssing ASAM data for kombiinstruments...
     Thursday,26,October,2017,15:41:06:35073
    VIN: TMBJM65J9D3xxxxxx   License Plate:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    Address 01: Engine (J623-CBZA)       Labels:. 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 HH    HW: 03F 907 309 AK
       Component: SIMOS10.22AH10 4040
       Revision: --H10---    Serial number:
       Coding: 00110056202400080000
       Shop #: WSC 13765 031 00019
       ASAM Dataset: EV_ECM12TFS02103F906070HH 004006
       ROD: EV_ECM12TFS02103F906070FP.rod
       VCID: 6FBA2260D7159C6FB20-803A
    Readiness: 0110 0101
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AL    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Coding: 410128DB217200BA822A14E784DA00401300
       Shop #: WSC 13765 790 00019
       VCID: 084869FCD27BAB5713A-805C
    00493 - ESP-Sensor Unit (G419)
                        Reset counter: 3
                        Mileage: 64777 km
                        Date: 2055.14.15
                        Time: 18:02:00
                        Hex Value: 0x5440
                        Hex Value: 0x8000
                        Hex Value: 0x3630
                        Hex Value: 0x1A9B
                        Hex Value: 0x2080
                        Hex Value: 0x457B
                        Hex Value: 0x1A5C
                        Reset counter: 235
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:00:53
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x12B1
                        Hex Value: 0x0794
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Reset counter: 19
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:07:10
                        Hex Value: 0x0003
                        Hex Value: 0x0000
                        Hex Value: 0x1211
                        Hex Value: 0x2596
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7FF8
    Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
       Part No SW: 5J0 907 044 C    HW: 5J0 907 044 C
       Component: Climatronic   H09 0103
       Revision: K0000000
       VCID: 2A0CF3742CF7B94725E-807E
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 235
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:04:32
                        Temperature: 16.0C
                        Voltage: 11.50 V
                        Absolute Pres.: 0.0 bar
                        Count: 1879
                        Count: 290
                        Reset counter: 235
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:04:32
       Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
       Component: PQ25 BCM      H28 0555
       Revision: -1------    Serial number: --------------
       Coding: 64980B3808010000003008002C2B08C000C0400F60000000020000000000
       VCID: 4EC49FE470DFB567996-801A
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3211
       Coding: 020000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3211
       Coding: 020000
       Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3211
       Coding: 020000
       Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3211
       Coding: 020000
                        Reset counter: 235
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:04:23
    03591 - Control Circuit for Horn
                        Reset counter: 235
                        Mileage: 64777 km
                        Date: 2056.14.24
                        Time: 00:04:23
       Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
       Component: VW10AirbagT23 H10 0020
       Revision: --------    Serial number: 003GY007KRBW
       Coding: 003233
       ROD: EV_AirbaVW10BPAVW250_VW31.rod
       VCID: 4BC296F0834D804FFE8-801E
       Serial number: 3495RRB400G4UN5GGOR-
       Serial number: 3505RRB40024UN5GH1JR
       Serial number: 3515RRB40064UMPOFA9D
       Serial number: 3525RRB40024UMPORGS4
    Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
       Part No SW: 5J0 920 811 E    HW: 5J0 920 811 E
       Component: KOMBI         H03 0306
       Coding: 110A01
       ASAM Dataset: EV_Kombi_c˙_VDD_RM09 A04113
       ROD: N/A
       VCID: 290E0C782971B25F2C4-807C
    No ASAM data for: "EV_Kombi_c˙_VDD_RM09" (VW36 *)
       Part No SW: 6N0 909 901     HW: 6R7 937 087 M
       Component: GW-K-CAN TP20 H28 0555
       Revision: -1------
       Coding: 232200
       VCID: 70B8211CCAAB8397ABA-8024
       Component: IMMO          H03 0306
       VCID: 6A8C3374ECF77947E5E-803E
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 11240
       Shop #: WSC 13765
       VCID: 3038E11C036BC397EBA-8064
    01288 - Terminal 30; Steering Assist
       Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
       Component: Radio-SWING   004 0003
       Revision: -----07S    Serial number: SKZ4Z2M1359669
       Coding: 050004000006
       VCID: 23121E504BDD680F668-8076
    End----(Elapsed Time: 00:46, VBatt start/end: 11.6V/11.5V. VIgn 11.6V)-----
    MK60EC1 coding solution without online SVM
    No, what you found is an instrument cluster that has been molested, most likely by some "mileage correction" tool.
    "ASAM Dataset: EV_Kombi_c˙_VDD_RM09 A04113"
    This is not a valid ASAM ID.
  3. Likes Eric liked this post
