Wednesday,25,October,2017,15:26:30:64419
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
VIN: WAUFGAFC7EN123752 License Plate:
Mileage: 92701km-57601mi Repair Order:
Gateway Installation List: 4G0 907 468 AD
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUFGAFC7EN123752 Mileage: 92701km-57601miles
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 J HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07---
Coding: 0A2A0034056601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
ROD: EV_ECM30TFS0214G0907551J.rod
VCID: B02C7379EBD870C6BA-80E4
Readiness: 1110 1101
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
VCID: AD126A0DFCEA1D2E91-80F8
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 44A7970122E5E9805B00
VCID: BB365455329E839E1F-80EE
Part No SW: 4H0 907 064 ER HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0521
Coding: 0DA82046000000000000
VCID: FDB29A4D640A4DAE61-80A8
Serial number: 0214000018594013
Part No SW: 4G0 820 043 AM HW: 4G0 820 043 AM
Component: KLIMA 4 ZONEN H14 0093
Serial number: 12021400040390
Coding: 668120B84D
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: EA98A1110D84CA16B4-80BE
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001520317
Coding: 06002091063C9FE28100088380003908CF9CD208A6090221000008406000
VCID: EFAEB0053E662F3EE3-80BA
Component: WWS57X 140211 H37 0080
Serial number: 140213025108
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22250108
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 30 01 2014 00002222
Component: USHL4.2 H30 0030
Serial number: 0000002274555RA6A803
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: EF68C017000000000001
Revision: 11001001 Serial number: 61031404901910
Coding: A8EB05
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: F1AAB67D205239CEF5-80A4
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E01010202
VCID: A81C9B19D308380662-80FC
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003WGPE
Coding: 303234373131303030324A55304C34473053
VCID: B3267C751ACE4BDEC7-80E6
Serial number: 6940000Y14000125WM0Y
Serial number: 3575HRB40632BDG0B19M
Serial number: 3585HRB40512BDG0DPB5
Serial number: 3515JRB400C50REKDH0B
Serial number: 3525JRB400A50REKK94D
Serial number: 3554VRB401250STQN10X
Serial number: 3564VRB401250STQJ8IC
Revision: -------- Serial number: 90372NBC000GC
Coding: 0004FC
VCID: B83C4B590BA8A886F2-80EC
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 06 07 2013 C0297823
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 984 R HW: 4G8 920 984 R
Component: TBenUsaAcc H58 0621
Revision: 29460235 Serial number: 658150214596001
Coding: 0BC609040F51D705020000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: C5C232AD445AC56E79-8090
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001268798
Coding: 00CD073000
ROD: EV_GatewPkoUDS_001.rod
VCID: F2A8B971255402D60C-80A6
Serial number: 3950702403
Voltage stabilizer:
Part No SW: 4G0 919 158 N HW: 4G0 919 158 N
Component: KLIMA FOND H08 0093
Serial number: 11021400040090
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
VCID: BA3851513DA4BA9604-80EE
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000089137714
VCID: F7BE8865463667FE3B-80A2
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206AR59
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: B620456109BC5EF6E0-80E2
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: B02C737923D870C6BA-80E4
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F14.02.1400H03000AMS14212ÿ
Subsystem 4 - Serial number: S14212ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F17005E00628002000013
VCID: C5C232AD4C5AC56E79-8090
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0026252868
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2287971E5D442D6CC-80E6
Revision: 00002001 Serial number: 0327076428
Coding: 0106023A00FA408580B0080402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000204909
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO27074969
Coding: 101F00
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93170278
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000079819
Coding: 030000
VCID: 9D72BACD844AEDAE01-80C8
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: C6C035A1715CCE7670-8092
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000000961782
ROD: EV_ParkiBrake_AU57.rod
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140215-0002-062
Coding: 1221A6101002A500
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156B00E7967901
Coding: 020007010000000001
VCID: A4048F29A720DC664E-80F0
Part No SW: 4G0 035 746 F HW: 4G0 035 746 E
Component: H-BNT-NA H41 0757
Revision: -------- Serial number: 194B-0E7602258
Coding: 050200000003E9EF7D12CB1E00000003100001000000000000
VCID: AA186111C5040A1674-80FE
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD003WA5Z
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Serial number: 90349NBH000M2
Component: CD-Database 5571
Component: TSG HL H03 0507
VCID: C9DA3E9D6042210E9D-809C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0131307
Coding: 0200000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_005.rod
VCID: AC146709C7F0142686-80F8
Component: TSG HR H03 0507
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: A6009521D91C2E7650-80F2
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010202
U1113 00 [009] - -
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121802147
Coding: 04C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: B12A767DE0D279CEB5-80E4
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:22, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
