Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: A5 Lane Assist (Retrofit Mk.7 Golf)
  1. #31
    Oct 2017
    Northwest UK
    Is it possible to add guided functions onto VCDS? Have the cake and eat it!
  2. #32
    May 2017
    Quote Originally Posted by myounus View Post
    I can't add the A5 camera into the PDC module but I know it's down to it being a 'e' revision. I think it might be possible with flashing the unit with software from say a H or a K version but I'm thinking of retrofitting PLA 3.0 so I might just try that module in in one go 5QA 919 298 C. A bloke on Ali express has it with the extra sensors and ABS sensors for about $250. I think my car already has PLA abs sensors as it has factory fitted ACC.
    It's too close to Christmas to start that project so 1st thing in Jan ��
    I have factory fit A5 Front camera and I don't have anything in PDC module for that. Is it required to be coded there for Blind spot monitoring or what?
  3. #33
    Oct 2017
    Northwest UK
    Well it would seem so as I can't work out what else could be causing the Blindspot to de-activate once the car activates the PDC by putting car into reverse. I've ordered a PLA 3.0 module now so either I'll make a mountain out of a molehill or I might get both working properly!
  4. #34
    May 2017
    Well have you tried disabling this from PDC?
    Try this coding :
    0031051001
    It disables the PDC activation when car rolling back. It enables the PDC normally of course when gear on and moving forward low speed and when putting the car on reverse. See if that fixes the issue.
  5. #35
    Oct 2017
    Northwest UK
    I'll give it a whirl
  6. #36
    May 2017
    And one more thing you could try as well.
    In ABS module, there's possibility to code RCTA = Rear Cross Traffic Alert function when you have BSM modules and PDC.
    So try this as your ABS coding :
    01FA8AA11420096C077F060541C62580512890E06082A4F314 40F078C082
    This enables RCTA in ABS module. Maybe the problem is not in the PDC module but the ABS is not coded correctly?
  7. #37
    Oct 2017
    Northwest UK
    Unfortunately that didn't make a difference and my ABS is coded to exactly that coding string.
    I have a question, what is your ACC coded to?? Mine is 00000300FE0739
  8. #38
    May 2017
    I'll check that when I get home. I have automatic transmission so there's some small differences in coding.
  9. #39
    May 2017
    One question, you have changed your ABS coding at some point? Because latest autoscan you pasted here has this ABS coding :
    01FA8AA11420096C077F060541C62580512890E06082A4F314 40F078C002
    Which is not the same as what I proposed to change it to. The last byte is not the same.
    Can you please do a fresh autoscan and post it here?
  10. #40
    Oct 2017
    Northwest UK
    Your wish is my command: Autoscan below:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F A5
    VIN: WVWZZZAUZFP100853   Mileage: 31843km-19786miles
    Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   X22 7635
       Revision: 84X22---
       Coding: 01110012034505092000
       Shop #: WSC 00028 028 00028
       ASAM Dataset: EV_ECM16TDI01104L906021M 002012
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F6AAE9076139552153-807A
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 60825000001567
       Coding: 01FA8AA11420096C077F060541C62580512890E06082A4F31440F078C082
       Shop #: WSC 12345 123 12345
       VCID: 7EF443D4E1F9ACDACE5-802A
       Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       Shop #: WSC 00028 028 00024
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 3C7089DCB7657ECAA01-8068
       Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
       Component: BCM MQBAB M   H18 0137
       Serial number: 01011507502417
       Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7DF644D8ECFFB7C2D7F-8028
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    150304  042 0551
       Serial number:         150312162128
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S5Y15M03D19H15M47S18
       Coding: 90A8DD
       Serial number: 000000000ZY150481FZR
       Serial number: 00000000000061991997
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391507507581
       Coding: 0071151001
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 3D7684D8AC7F77C297F-8068
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 07031503271652
       Coding: 00000300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001015
       VCID: 387895CC835D52EA449-806C
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    014 0386
       Serial number: 003MLR0D9EUA
       Shop #: WSC 00028 028 00013
       VCID: 7F0ABED0E6F3A5D2C53-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169677B17091450749
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169676B18091450343
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 803 15
       Serial number: 35767000000FE57C8317
       Subsystem 4 - Part No SW: -----------    HW: 480 001 803 15
       Serial number: 3586700000076C54731V
       Subsystem 5 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3516502B119EFD22801D
       Subsystem 6 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3526502C719EFD2472E.
       Subsystem 7 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3556502B519EFD22438R
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 20031504401200
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7BF24AC0F2EBB9F2E9B-802E
       Part No SW: 5G1 920 941     HW: 5G1 920 941
       Component: KOMBI         204 4270
       Coding: 27A51A00678C2F0001887A0B1400000000000000
       VCID: 66C40BB49969141A265-8032
       Revision: --------    Serial number: 18031510800425
       Coding: 030100040F087300FF00025C080F00010001050000000000000000000000
       VCID: 72EC67E4A5A1F8BABAD-8026
       Component: E221__MFL-DC1  H16 0038
       Serial number: 29140002017020084377
       Coding: 2CFFFF
       Serial number: 1306535903
       Serial number: 0400936029
       Coding: 02031203
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0071
       Serial number: 0400325995
       Coding: 020312
    338048 - Databus
                        Reset counter: 76
                        Mileage: 31843 km
                        Date: 2017.12.07
                        Time: 21:07:51
       Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
       Component: TSG FS        009 0015
       Serial number: 0000140168092
       Coding: 00350220D001028000001000
       VCID: 4586EC38C4AF3F02CFF-8010
       Serial number: 00000000000008327686
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 9102
       VCID: 4382F220CA9B0132E1B-8016
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000141936089
       Coding: 00350020DE01028000801000
       VCID: 4480F13CCF95060AD81-8010
       Serial number: 00000000000001049493
       Coding: 050000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
       Component: MU-H-ND-EU    H43 0388
       Serial number: A310G0EB003873
       Coding: 02730001FF00000021111201008800101F010016010001007C
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1A3C6F441D9160FA52D-804E
       Component: ABT_High  H60 0030
       Serial number: VWZ8Z9PS1007K6
       Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Component: Gracenote  --- 1010
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 75
                        Mileage: 31818 km
                        Date: 2017.12.07
                        Time: 11:36:41
                        Voltage terminal 30: 12.1 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0060
       Serial number: 10000102807
       Coding: 0101000001020303000300010100010100
       Shop #: WSC 01725 666 28888
       ROD: EV_MFKBoschAU370.rod
    6422533 - Databus
                        Reset counter: 76
                        Mileage: 31843 km
                        Date: 2017.12.07
                        Time: 21:07:06
                        Control Module temperature: 15 C
                        Outside air temperature: 3.0 C
                        Vehicle speed: 0.00 km/h
                        Voltage terminal 15: 12.0 V
                        Terminal 15 on: 15.4 s
