HEX-V2 on Golf MK7.5 - RLS Activation Coding
unalkarakus
Pirate
Walking the Plank
Turkey
LP/IP
Hello all,
I need to activate Rain Light Sensor on VCDS Menu. But I have problem with BCM Coding. IN 17.8 VCDS when i enter Cent. Elec. -> Long Coding Menu. All codes fill with 0.
In adaptation menu, there is no option for activate rain light sensor. I found something in adaptation, but nothing changed.
How can i activate "light sensor is installed" option?
Thank you so much.
unalkarakus
Pirate
Walking the Plank
Turkey
LP/IP
Hello Uwe,
Here is the result.
Removed.  Data from clone/pirate copies of VCDS is not welcome here.
DV52
C?ID=194404
Hello all,
Thank you so much.
unalkarakus: Merhaba -senin İngilizcen çok iyi
I can't be absolutely certain without seeing an admap for your BCM, but instead of going to the coding screen, look in the adaptation screen for the following channel
REDACTED. Set this to REDACTED -
Eric
HC800000
REDACTED
- set this to REDACTED
Anything he sees/tries to save with his clone will be doubtful at best :popcorn:
DV52
C?ID=194404
^^^^^^^^^ ooops I was too interested in the technical aspects of the problem to notice that this was someone who had participated in IP theft!!:cry:
Back to the naughty corner for me!!
Put on your MAGA hat and go sit with Trumpy Bear! :D
J/K. It's all good. I missed that earlier because someone else beat me to the CODE tags on that post. :eek:
